DaniYüah
Dauergast
- 416
Tested on G920F | G925F
This porting gives the best performance on the memory and many finishing touches on performance compared to the original rom of galaxy s6 and give new features. So this ROM , contains a portion of the firmware s6 edge + for the Galaxy S6 maintaining customizations.
Galaxy S6 Edge + Port :
ROM Info:
Version Rom: V6.0
Currently Based on G928FXXS2AOK9
Model Number G928F
Kernel: Unikernel v8.002
V6.0 Final Lollipop :
Dedicated for fixes and stabilities of system for the daily usage
Fixed colors bug framework
Fixed calls +48 and other number
Fixed clock fc (issues on java tried with my pc and works perfectly)
Added missing apk of system
Much fastest than v5
Removed lunar chinese calendary
Removed uneless & not working strings
Gear Manager
Google search & voice
S-Healt
Very stable , cool and fresh build for daily usage
V1 Beta :
Debloated removed about 400mb of bloatware
Optimized
De-Knoxed
Smooth Spinner applied on the framework-res
All Edge + system full port base 100% original no mod no tweak
Clean and fast concept for the best usage
All the new features of Edge + like :
OneHand
Touchwiz
SystemUI
Keyboard ....
Stable working fingerprint & camera thanks for the lib + etc + bin file fix @arter97
Applied radio battery drain potential fix thanks to @arter97
Ported Air Message
CSC Features 34kb very slim and much features
Deodex
Meta-Inf thanks to my friend @geiti94
V2 Stable
Galaxy S6 Edge + porting full system OH4
Stagefright pre-fixed by Samsung
Air Message
SideKey Panel
ToolBox
Multi-User
ScreenMirroring working + toggle avaible
Very fast build , optimized
Fixed Camera
Fixed mics camera + 8x zoom video
Fixed Video-Recording all resoluction
Fixed Private Mode [Smali file System_Properties]
Fixed SideSync
Fixed all bugs
Stable build
Fixed Emoticon SMS/MMS
New CSC NobleRom
Light Debloat
New logo in settings added
Meta-Inf new structure build @arter97
Odex build unique fixed all bugs of odex
BusyBox new 3.1.1 custom version + root applied
SmoothSpinner applied on the new framework
V3
Thanks to @JustArchi for the best tool for linux
-Builded with Archi tool, deflated all system.
-Optimized apk
-AOJ1 Firmware updated & ported
-Fixed zoom image camera
-Fixed StageFright in the newest build
-Viper4fx , toolbox , super su , Kernel adiutor added in settings
-New logo + version rom in settings
-Dual Smart manager
-New air message
-New app sms with working blocked message section no fc
-Much fluidity & liquid
-Game Tuner by Samsung implemented
-DHA Tweak + Battery applied for the Edge + base
-Cleaned system with debloat script by me
-Added Google search
-Fixed lag in the lockscreen and multitasking
-Stable Release
-New CSC with new features
-Much battery life
-Removed busybox
-Removed sqlite3
-Added archi init.d
-Applied root with archi tool
-Removed some knox file thanks look in the credits
V5.0 Final Lollipop :
Ported AOK9 base Edge + G928F
Original Style Framework of marshmallow with new bar automatic colored
Original Style of marshmallow Settings
Original Icon of Marshmallow S6
Original Style of marshmallow S6 SystemUI
Ported Gallery 2016 from Note 5 marshmallow build
Ported Calendary from Note 5 marshmallow build
Added Fonts Note 5 marshmallow
Added support in meta-inf unmount and kernel
Fixed Wifi Leak & ported originally wifi files
Returned to stock Smart Manager
Stable build
Removed unnecessary script /reserved/
Removed unnecessary strings /reserved/
Further optimize the S6 slide fluency
Repair improve S6 in question after AOE4 Caton.
Optimized for GPU Mali.
Optimized
De-Knoxed
OneHand
Touchwiz
SystemUI
Keyboard ....
Ported Air Message
Deodex
V2 Stable
Air Message
SideKey Panel
ToolBox
Multi-User
Fixed Camera
Fixed SideSync
Fixed all bugs
Stable build
New CSC NobleRom
Light Debloat
V3
-Optimized apk
-Dual Smart manager
-New air message
-Stable Release
-Much battery life
-Removed busybox
-Removed sqlite3
-Added archi init.d
Stable build
Custom Recovery (Philz oder TWRP) wird vorausgesetzt
1. Install TWRP recovery (recommended)
2. Put ROM on your SD card
3. Enter recovery
4. Take a full data wipe
5. Flash Noble Rom
6. Disable 'Smart Stay' from Settings to gain extra more battery life
7. NOTE: For Deodexed build need 10 / 15 minutes about for firts boot up .
Odexed V6
V1
Noble Edge + Port Deodexed build (Mega Mirror)
Noble Edge + Port Deodexed build (Google Drive)
V2
Noble Edge + Port Odex V2 (Mega Mirror)
Noble Edge + Port Odex V2 (Google Drive)
Noble Edge + Port V2 Deodexed (fixed) (Mega Mirror)
V3
Noble edge + AOJ1 Port 20151021 v3 odexed
Noble edge + AOJ1 Port 20151021 v3 deodexed
Google Drive Mirror
Odexed v3
Deodexed v3
V4
NobleRom v4.0 edge + odexed
NobleRom v4.0 edge + deodexed
V5
NobleRom v5 Edge+ - odexed
NobleRom v5 Edge+ deodex
V2
V3
Google Drive Mirror
Odexed v3
Deodexed v3
V4
V5
@Gabri™
Samsung for the new update
@my collaborator bulldog74ts
Alberto R. my friend tester
@my friend Albe95
MINU THEMER my themer / logo / designer collaborators:http://minuhome.tistory.com @g.lewarne for the kernel
@arter97 big thanks for philz recovery
Powered by SuperSU big thanks for the root
@scrosler for CSC Pack / Debloat list @geiti94 @sardroid for the mirror link
Für Fehler beim Flashen oder ähnlichem übernehme ich keine Haftung.
Alle Angaben OHNE GEWÄHR
