[ROM][G935F][6.0.1][XXU1APF2] *15.06.2016* KING_ROM_S7_EDGE_V8 [OTA][ROM-CONTROL]
SpackEddie
SpackEddie
LATEST FIRMWARE NOBRAND
ANDROID 6.0.1
LATEST SECURITY PATCH
DEODEX
ZIPALIGNED
ROOTED 2.71
BUSYBOX
ADD SUPPORT TO S7 FLAT VARIANTS
DISABLE SIGNATURE CHECK
YOU CAN INSTALL OLD APP OVER NEW
TRAFFIC METER IN STATUS BAR
OPEN ALL TOGGLE ON RIGHT SWIPE IN STATUSBAR
DEFAULT WINDOWS ANIM. x0.5
VIRTUAL LOCK BUTTON SET TO LEFT CORNER STATUSBAR
ENABLE OUTDOORMODE IN SCREEN SETTING
ROUNDED NOTIFICATIONS IN NOTIFICATIONS PANEL
REMOVED GREY BAR WHEN ENERGY SAVING WHAS ACTIVED
REMOVED WARNING SAFE VOLUME
ADD SBROWSER SECRET MODE
FIX PERMISSION FOR EXT SDCARD
SQLite3 OPTIMIZED
RAM OPTIMIZED
ZIPALIGN AT BOOT
KERNEL INSECURE MODE
FULLY SUPPORT FOR INIT.D SCRIPT
3 MINIT BATTERY MOD
POTATO CLOCK
AVANCED REBOOT MENU
DPI SCALING IN SETTING/DISPLAY
TOUCHKEY LIGHT DURATION IN SETTING
SMART MANAGER DUAL LAYER
ADD SAVE/RESTORE SMS IN MESSAGE APP
ADD DATA USAGE IN NOTIFICATION PANEL NEAR AUTO CHECK
GEAR VR FULLY WORK
ADD SAMSUNG MUSIC PLAYER
ADD ULTRA DATA POWER SAVING IN SMART MANAGER
REMOVED EMERGENCY BUTTON IN POWER MENU
MULTIWINDOWS VERTICAL SCROLLABLE
ROUNDED RECENT PANEL VIEW
ADD QUICK LAUNCHER IN RECENT APP
6 TOGGLE IN A ROW
RAM BAR IN RECENT
KNOX REMOVED
MICROSOFT APPS REMOVED
FACEBOOK, INSTAGRAM WHATSAPP REMOVED
GOOGLE MUSIC REMOVED
DUAL SPEAKER V16
ALL APPS MULTIWINDOWS
REMOVED SD NOTIFICATION AT BOOT
FASTER FIX GPS
MULTI FONT
YAHOO PANEL EDGE
MORE SOUND NOTIFICATIONS
DIRECTORY FOR ZIP MOD in /sdcard/KING ROM S7 EDGE
XPOSED READY TO INSTALL (/sdcard/KING ROM S7 EDGE)
DISABLE ANTIMALWARE
ADD 100 CONTACT QUICK CALL
TOGGLE SOUND CAMERA IN CAMERA APP
CAMERA WORK DURING CALL
CAMERA DONT STOP MUSIC
EXIT BUTTON FROM SAMSUNG BROWSER
NATIVE CALL RECORDING
CALL QUALITY IN HD
ADD CALL BUTTON IN CALL LOG
ENABLED VoLTE FOR SPECIFIC CARRIER
MULTIUSER
BEST QUALITY OF STREAMING
KING BOOTANIMATION AT 60 FPS
ENABLED SEARCH DIRECTORY IN ARCHIVE APP
DISABLE CONVERSION SMS TO MMS
ADD MEGA ADSBLOCK
INCREASE BATTERY LIFE
INCREASE PERFORMANCES
ALLOW MOCK LOCATION
ADB FULLY WORKING
OTA UPDATER
KING_ROM_S7_EDGE_V8
RESTORE OLD SETTINGS UI
DANKSAGUNGEN:
@Chainfire - For SuperSU
@SuperR. - For Kitchen
@svadev - For DEODEX tool
@zubi182 - For Dual Speaker mod
@Tkkg1994 - For adb fix, updater-script and efsbackup
@Ticklefish - For Tickle My Android
@raziel23x - For APK Multi-Tool
@metaspook - For Viper4Android
@Modaco - For ota updater
@daxgirl - For Rom control
@Tkkg1994 - for superkernel edge e flat
@jesec - for jesse kernel
@VoLTaqe - for Voltaqe kernel
@Enriquezdelaplaya - For beta test
@proofer - For beta test
INSTALLATION:
1. Download Rom
2. Reboot in Recovery
4. Gehe auf "Advanced Wipe" und wähle "dalvik cache", "cache", "data" and "system" aus und bestätige den Löschvorgang
5. Gehe auf "Install" und wähle den Speicherort aus und starte die Installation der ROM
6. Der erste Boot wird ca. 8 / 15 dauern, also lehne dich zurück und Relax...
Ganz neu:
Ab sofort, alle Mods, Bootload, Modems in der App zur ROM erhältlich.
KING ROM S7 EDGE – Android-Apps auf Google Play
Reaktionen: numenic74, shamanous, Con_Air und 2 andere
Changelog der aktuellen ROM:
V8 - 15/06/2016
BASED ON NEW APF2 FIRMWARE
ALL MOD FROM PREVIOUS VERSION
UPDATE SAMSUNG MUSIC
UPDATE TELEGRAM
UPDATE AROMA INSTALLER TO V3.00
UPDATE 3MINIT BATTERY TO 3.1
UPDATE KING MOD
ADD BATTERY BAR IN KING MOD
ADD SYSTEMLESS OR SYSTEM SuperSU INSTALL
ADD ANDROID N SOUNDS
ADD BUILD.PROP PERSONALIZATION IN AROMA
ADD GPS.CONF SPECIFIC FOR COUNTRY
ADD BUILD.PROP FOR G930F VARIANT
ADD LATEST KERNEL CHOOSE IN AROMA
ADD SOME CSC
ADD NEXT ALARM IN LOCK SCREEN
NEW LAYOUT IN SETTINGS
REMOVED QUICK APP IN RECENTS
AND MUCH MORE
[doublepost=1466966461,1466966225][/doublepost]Wenn Sie mit der Arbeit des Entwicklers zufrieden sind, unterstützen Sie ihn bitte......Danke
Reaktionen: numenic74, shamanous und JasonMason
hallo,
hab die Rom drauf, läuft auch ganz gut bis jetzt, meine frage ist, mir ist aufgefallen das es sobald am Stromkabel hängt, die rote led im Intervall blinkt und nicht durchgehend
kann man das irgentwo einstellen ?
mfg
Da habe ich bis jetzt nichts gefunden dazu. Ich schaue später mal nach.
Ich nutze die Rom aktuell mit dem AEL Kernel 4.3
Meinst das liegt am Kernel?
Liegt an Kernel, hab mal den AEL Kernel genommen und da ist es nicht so
Okay, danke für die Info.
Hallo hat schon einer den Super Kernel von. 1.4 ausprobiert und wenn ja läuft er gut ...???
Habe bis jetzt nur Jesse Kernel probiert. Aber der AEL Kernel ist mein Hauptfavorit.
So habe den Super Kernel von. 1.4 drauf Rom läuft super .
Darf ich mal fragen warum der AEL Kernel dein Favorit ist und läuft das Rom gut damit ...???
AEL Kernel nutze ich schon lange, ich kann mit Synapse vieles einstellen. Beim Super Kernel bekomme ich bei Synapse UCI nicht unterstützt und kann nichts einstellen.
Mit was stellst du den Super Kernel ein? Synapse geht bei mir nicht.....
Gar nicht bin neu
Probiere vieles Grade aus. Was kann man so einstellen mit Synapse UCI
Ich meinte mit Synapse kann ich beim Super Kernel nichts einstellen. Fehler No UCI Support
Mit dem AEL geht es mit der App Synapse. Da kannst du die CPU in Sachen Taktfrequenz einstellen, einen Governor etc.
Ael kernel drauf Synapse INSTALLIERT Werde ich mal an die Einstellungen machen
Kann mir jemand sagen wie ich die Uhr neben dem eigentlichen Akku Symbol in der Statusleiste wieder dahin bekomme? Habe die rom mit der vollen Modded UI installiert. Da gab es ja auch die normale UI. Falls das nicht klappen sollte ohne erneutes Flashen und nachhaltigem auswählen der normalen UI muss ich dann trotzdem einen Factory Reset machen?
Gehe in die App Potato Clock, dort unter Alignment kannst du auswählen wo die Uhr sein soll.
In der App kannst du auch noch mehr einstellen was Uhr und Datumsanzeige betrifft.
Weis einer wann eine neue Version rauskommt:confused2::confused2:
Neue V9 ist soweit fertig, aktualisiere wenn ich heute Mittag kann.
Ist aktuell über die King App verfügbar.
Im Moment ist der Download auch nur über die App freigegeben, auf Wunsch des Erstellers.......
Bearbeitet von: bandit1976 - Grund: Direktzitat entfernt.
Über welche app ???
King Rom ...... Gibt es im Play Store
Cloud
Cloud
Cloud
petlura
petlura
petlura
submain
Cajul
