MDXDave
Ehrenmitglied
- 1.391
Code:
#include
* Unlocked Phone @ HTCDEV or S-OFF
* Custom Recovery
* Common Sense, Brains and logic
By downloading and flashing InsertCoin Custom ROM for HTC 10 you agree to the following:
- Your warranty is now void.
- We are NOT responsible for bricked devices, dead SD cards, thermonuclear war, or you getting fired because the alarm app failed. Please do some research if you have any concerns about features included in this ROM before flashing it! YOU are choosing to make these modifications, and if you point the finger at us for messing up your device, we will laugh at you.
- Support is limited. We do this as a hobby in our free time. We'll do our best to help you if you state your problem in clear English, with as much information as you can (what mods you selected, have you wiped, when exactly does the error occur, what type of phone you have (ul, l , ws etc.), what carrier, logcat and so on. The more information you offer, easier for us to help you. If you do not ask for support in clear English and with no information what-so-ever we will ignore your issue!
- Leave the self entitled customer attitude at the door. We are under NO obligation what-so-ever to do anything for you. If we do it is because we like helping people. Using custom work published on XDA is not a right, it is a privilege. If you think otherwise please read here. Or watch this video.
- NO Requests! When we work on InsertCoin we have in mind that we have to satisfy all users to a decent level. What works for us might not work for you and vice versa . We are not your personal ROM developers and it is not our job nor our intention to make everybody happy.
- Do not come here asking "Hey mate, X rom has that awesome feature and if you don't implement it in your rom, I'll <insert whatever here>!" You flashed this ROM because you liked it at some point, if that change please stop using it.
- Suggestions for improvements are always welcomed. As long as they are well documented and as long as you understand that NOT everything is possible.
- NO ETAs! While we do our best to constantly work on the ROM to improve, *fix and add new features, again this is a hobby! There are periods when due real-life issues we can't spend too much time for InsertCoin! If this becomes an obligation passion fades and we might stop cooking the ROM
ROM Base features:
- HTC Latest European Base: 1.80.401.1
- Android 6.0.1
- HTC Sense 8
- All languages enabled (FULL WWE)
- All HTC 10 Carrier Variants Supported
- Rooted with the latest SuperSU 2.74 thanks to [MENTION=631273]Chainfire[/MENTION]
- ForceEncrypt enabled
- De-odexed
- BusyBox, SQlite3, Bash & Nano shell
- init.d & su.d support
- sysro / sysrw binaries
- Persistent ADB enabled
- Ramdisk improvements
- Battery life, performance and memory improvements
- Disabled logging & removed bloatware
- Stripped debugging info for improved performance
- Optimized with latest SDK for improved performance
- Trimmed partitions for improved performance
- Zipaligned apps for improved performance
- Advanced Power Menu - Reboot, Recovery, Bootloader & Safe Mode
- Ambient display / Doze Support
- Improved battery statistics > settings power
- SystemUI Tuner - long press settings icon in pull down to enable
- Fast fixes / updates
- ICE Configurator
Options are subject to change between app versions and ROM versions
UI Tweaks
UI Tweaks
- Sense Launcher Landscape Support
- Infinite Apps in Folders
- Allow All Rotations
- Enable APM (Advanced Power Menu)
- China Sense Recent App Style (has RAM usage monitor and kill-all button
- China Sense Launcher (Alternative Launcher without app-drawer)
- Right Cornet for quick QS pull down
- Traffic Indicator
- Traffic Indicator Color
- MIUI Battery MOD
- Disable NFC Notification
- Disable USB Debugging Notification
- Disable Power Saving Notification
- Disable Android Sync Notification
- Disable MTP Notification
- Disable Heads Up Notification
- Blink LED on notification while charging
- AM/PM Clock styles
- Navigation Bar Size
- Enable Navigation Bar
- Long press back button to kill foreground app
- Dynamic Navigation Bar Color
- Double Tap Status Bar to put the device into sleep
- Control keyboard cursor with volume keys
- Enable flashlight on long press power button
- NFC Modes
- HTC Power Manager
- Haptic feedback duration
- Ambient Display Settings
- Increase Caller Contact Picture
- Hide Photo Mask for low-res pictures
- 4G / LTE Notification Switch
- Auto Record Incoming Calls
- Disable SMS to MMS Converstion
- Toggle Fast Dormancy
- MM Game
- Toggle Boot Audio
- Default USB Mode
- Enhanced MM Permissions
- Default app install location
- Install as system app
- Fix Permissions
- ZipAlign apks
- Mount System RW / RO
- Trim Partitions
- Wipe Dalvik
- Wipe Cache
ICE v2.0.6 - 4. Juli 2016
- updated CleanSlate Kernel v1.2.1 (backlight dimmer)
- added Settings - Security - Auto-Start Manager
- Sense Home Update v8.14.772696
- option for long press volume down for flashlight when screen is off
- added AppCircle Side Bar thanks CM original code, @LeeDroid porting
- added Telstra AU carrier support patch thanks @jbm76 & @purple patch
- ICE Configurator option in Buttons : long press volume down for flashlight
- option to use AOSP Lockscreen instead of HTC Lockscreen (double press power button lunches Camera)
- fixed Screen Record service
- updated play store apps
mikrosmile, V6-Maniac, flar2, LeeDroid, lyapota, j to the 4n, Turge, show-p1984 , ivicask, omniw0lf, snq-, deagleone, shnizlon, topjohnwu, jcase, Captain_Throwback
Thema bei XDA
Contributors
baadnewz, mikrosmile
ROM OS Version: 6.0.x Marshmallow
ROM Kernel: Linux 3.10.x
ROM Firmware Required: 1.80.401.1
Based On: Stock HTC Base
Version Information
Status: Stable
Current Stable Version: 2.0.6
Stable Release Date: 2016-07-04
Created 2016-05-12
Last Updated 2016-07-10
Bearbeitet von:
rolkeg
- Grund: Threat Titel aktuallisiert, von rolkeg
