[ROM][ICS][IMM76I] CyanogenMod 9 ALPHA (Build 4)
  • 4 Antworten
s54
What's working:
Audio
Receiving and making calls
GPS
Compass
Proximity sensor
Wifi
Bluetooth
USB mass storage
HW accelerated gui
HW accelerated video
Not working:
Camera (not properly)
FM radio
USB tethering
Install
For flashing with Odin:recovery-clockwork-5.5.0.4-ariesve.tar.md5
Arrive Ops:AriesVE.ops
Warning: Only use this recovery to flash CM9. Otherwise, you risk bricking your phone!
Wipe data and cache.
Flash update*.zip.
Flash gapps*.zip. You must flash gapps after every upgrade to CM9 since /system is formatted, wiping your previous add-ons.
Reboot phone.
After you setup your Google account, reinstall the three apps from Market in order to restore most of your apps, call log and SMS history.
Warning: Do not restore backup data of system apps!
If you restore a bad backup with cached settings in telephony.db in data/data/com.*.*.telephony it can break MMS.
It seems that restoring backups can also break Calendar sync.
:confused::confused::confused:
Hä?!
lol
Da es den Thread schon gibt, mache ich hier mal zu.
