[ROM][ICS]nuhetri-reloaded[First 4.0.4 ROM]
T-REX600
Gast
[ROM][ICS][4.0.4](02/26/2012) nuhetri-reloadedv3.0.1 [QuadLock & Ext Power Menu]
Nuhetri hat es geschafft, in das ICS 4.0.4-reloaded Rom weitere Features einzubauen. Seht selbst und lasst euch überraschen.
ICS 4.0.4 Fastest ICS ROM to date, the proof is in this thread
Features:
-StatusBar Widgets
-Extended Power Menu
-Quad Lockscreen
-nuhetri-settings
-battery mod
-rooted
-busybox
-deodexed
-gapps included.
Install instructions
-Reboot to recovery
-Flash
-Wipe Dalvik and Cache
- DO NOT WIPE DATA there is a bug and wont boot if u do. working to fix it.
-v3.0.1 changelog
-fixed cmstats bug
-v3.0.0 changelog
-StatusBar Widgets
-nuhetri-settings in Settings
-performance settings in Settings
-Matr1x Kernel baked in
-long-press to kill app
-volume rocker wake
-facebook sync
-new battery icon
-more optimizing
-brainmaster tweaks
-v2.3.0 changelog
-Optimized some framework files.
-Bluetooth deep_idle fix.
-v2.2.0 changelog
-added T9 Dialer
-added Apex Launcher
-added nuhetri boot animation
-more optimizations
-v2.1.0 changelog
-fixed MMS (thanks Evil)
-added quad lockscreen
-optimized a bunch of stuff.
-v2.0.0 changelog
-rebased on 4.0.4 leaked build
-new battery mod
Whats to come:
What doesn't work:
Download Here: -v2.3.0
-ROM
Download Here: -v3.0.1
-Experimental ROM
Link:
http://forum.xda-developers.com/showthread.php?t=1416451
EXTRAS:
[MOD] Reloaded ICS | für nuhetri-reloaded 3.0.1
Download:
update-reloaded-1.4-cm9-031112.zip
[MOD] CM9-NIGHTLY MOD 2
für nuhetri-reloaded 2.3.0/3.0.0/3.0.1
-Status bar toggles
-neue toggle Batt Anzeige
-Statusleisten Anzeige Signalstärke in dBm oder Balken
-Leistungs Einstellungen (Prozessor, Speicherverwaltung usw.)
-Helligkeitsregler durch Wischen in der Statusleiste
-Profile (Default, Home, Night, Silent)
-Framework CM9 Nightly 21.03.2012
-Entwickleroptionen/Root Access
-Trebuchet Launcher
-in CM9 Optik
Credits:
A BIG thanks to CyanogenMod
Download: http://www.file-upload.net/download-4209313/Nuhetri2.3.0_TOGGLE_CM9NI.zip.html
[MOD] für nuhetri-reloaded 2.3.0
-Status bar toggles
-Processor Einstellungen
-in Kang Optik
Download: http://www.fileuploadx.de/689347
[MOD]nuhetri-reloaded Bootanimation zum flashen
Download:
nuhetri_Bootani.zip
[MOD] softkey mod. flashable
Download:
Softkey Mod
Credits:
-Google for 4.0.4
-CM for some stuff
-Brainmaster for his tweaks
Es läuft,:D werde heute noch Screenshot´s hochladen !!!
Screenshots aktualisiert !!:D
In den Benchmarks von bedalus hat die ROM ja viel +.. Kommt das von der neuen Android Version? 4.0.4??
Ich nehme es mal an, weil sie noch ziemlich Stock nah ist!
Okay ;) Naja cool das es sowas gibt. Ich bleibe erstmal noch auf 4.0.3 bis 4.0.5 rauskommt :)
Lange ist es ja nicht mehr!
Mit Brainmaster`s 3D-Patch läuft die schön smooth:biggrin:
Habe sie auch nur zum Testen drauf! Ansonsten siehe Sign
Version 2.2.0 kommt bald raus!
Was euch erwartet:
changelog is
-added apex launcher
-T9 Dialer added
-nuhetri boot animation by rascarlo
-more optimizations
PS: Vergisst nicht im Verzeichnis "/system/lib/egl/" die Datei "libGLES_android.so" zu löschen und danach ein Reeboot! (Die rom ist dann noch viel smoother):scared:
update!! :scared:
[ROM][ICS][4.0.4](02/12/2012) nuhetri-reloadedv2.2.0 [First 4.0.4 ROM with quad lock]
-v2.2.0 changelog
-added T9 Dialer
-more optimizations
Und? Wie siehts mit dem Akku aus?
Ist da spürbare Verbesserung?
Gute Frage :D ! Und muß dazu sagen "nicht schlecht" aber schau selbst.
Nuhetri 2.2.0 mit ICUP Speedy 7
Einstellungen Speedy7
Aktiver Scheuduler: deadline
Governor: ondemandx
Mini CPU: 200 MHz
Max CPU: 1100 MHz
ARM Spannung: 200 MHz - 1100MHz um -25mV undervolted
Reaktionen: druzil
update!! :scared:
[ROM][ICS][4.0.4](02/13/2012) nuhetri-reloadedv2.3.0 [QuadLock & Ext Power Menu]
-v2.3.0 changelog
-offset battery mod
-softkey mod. flashable
Reaktionen: Nexus S
läuft. thx
Governor: ondemandx
Mini CPU: 200 MHz
Max CPU: 1100 MHz
naja aussage eigentlich gleich null, du nutzt das teil ja fast nicht.
Wie man es sieht, versuche es mal mit 4.0.3. Da sieht die Kurve anders aus. Glaube es mir .:D
PS:
- Phone war dauernt im 3g Netzt wenn kein W-Lan.
- hatte viel Netzsuche da ich an dem Tag 300 Km unterwegs war.
****Nur zur Info!****
@T-Rex: Ich werde mal einen Versuch wagen.
Muss ich GAPPS mitflashen? Falls Ja, weißt Du welche?
nööööööööööö, alles mit dabei!:scared:
Danke,
und wie sieht das nun aus? Darf man immer noch keinen Fullwipe machen?
Denke ich teste erstmal einen Fullwipe
forb'S
forb'S
forb'S
Adinoid
  • Adinoid
4 5 6
Adinoid
Adinoid
forb'S
forb'S
forb'S
