  1. MarciWoi, 21.04.2012 #1
    MarciWoi
    MarciWoi Threadstarter Android-Lexikon
    [​IMG]
    Changelog 2.1
    -changed all the lib's system for a better performance
    -changed an huge amount of key libs,etc,and bin files for a better system management
    -revised all the build.prop tweaks for a better launcher management in terms of fps, and better tweaks performance
    -updated a lot of system app to fit the new speed tweaks
    -removed batt% due to request
    -added new better drivers for touch responsive management
    -removed nova launcher
    -added Apex Launcher
    -added Google Reader
    -added aosp Sense 4 clocks widgets for a bit of Sense experience for aosp launcher lovers
    -added @XxXPachaXxX as a new team member for a better team experience LOL
    -updated internal app's
    -more clean up's to the base
    -something I can't remember now
    Changelog:
    RCMixSmartDroid v1.0
    fixed rotation issue in RCMix Tweaks
    fixed build.prop for Sensation, 4g and xe users
    fixed genie.apk lack, now you got it
    updated SU binary
    updated Busybox
    updated bash binary
    updated kernel to 5.4
    fixed sweep to unlock freezes for all users (please report us)
    BassMod v1.6 xLOUD & Beats Audio & Dolby Digital (thx and credits to @bassini)
    added Dolby Mobile app 1.1 with fix ( (thx and credits to @bassini)
    added simtoolkit.apk
    more clean ups i can't remember now
    RCMixSmartDroid v0.1
    Based on 1.53.401.2 CL47230 release-keys (thx baadnewz for the base)
    Sense 4.0
    Android 4.0.3
    Tmous 4g users Support
    rooted
    busybox
    DeOdexed
    4Ext support
    Multilanguages support
    zippaligned for a better ram management
    removed useless stuff
    Beats Audio (with headphones)
    Custom boot animation
    Bravia Engine
    HQ Camera for Sense4 (thx NODO-GT)
    Speed Tweaks
    Tweaked build.prop(memnoc)
    init.d support
    spywarefree(memnoc)
    bloatwarefree(memnoc)
    updated internal apps
    RCMix kernel 5.3 by klquiksall
    RCMix Tweaks (thx j4n87)
    TRUE APM menu(thx j4n87)
    Blocklist/secure sms (thx Capychimp)
    FIXED mms drop signal (thx Capychimp, pm me for usage)
    FIXED search button function
    FIXED Partially Bluetooth ( thx mdeejay for first fix, thx memnoc for second part)
    FIXED most lags in homescreens(memnoc)
    FIXED weak aptic feedback
    FIXED meta-inf+boot.img issues (memnoc)
    Good support
    Bugs:
    Wifi Hotspot
    HDMI Out
    Download:
    http://forum.xda-developers.com/showthread.php?t=1611293
    Grüße Marcel
    PS: Und nicht vergessen Danke zu drücken wenn euch der Rom gefällt :)
    ruhL und xXXSchokiXXx haben sich bedankt.
  2. MarciWoi, 21.04.2012 #2
    MarciWoi
    Werde es jetzt mal drauf hauen und später dann sagen was ich davon halte, aber rein vom lesen hört es sich gut an !
    Grüße Marcel
  3. Zekene, 21.04.2012 #3
    Zekene
    Zekene Android-Ikone
    Bei gb war ich n großer Fan von RCMix. War auch mein lätezter gb Rom :)
    Gesendet von meinem Sensation mit der Android-Hilfe.de App
  4. MarciWoi, 21.04.2012 #4
    MarciWoi
    Sooooo,
    auf den ersten Blick scheint es wirklich sehr schnell zu sein, vom Gefühl her etwas schneller als Ordroid. Was aber auch damit zusammenhängen kann, dass er erst frisch geflasht ist.
    Was mir positiv aufgefallen ist das ich keinen FC mehr beim Setup bekomme :D
    Auch der Kernel scheint flott zu sein, mit Maximal Taktung von 1.7 Ghz.
    Zum Akkuverbrauch kann ich jetzt noch nichts sagen, aber man wird sehen!
    Probiert ihn mal selbst aus, läuft echt wie geschmiert :D !
    Grüße Marcel
    EDIT:
    memnoc hat gerade noch Bescheid gegeben das er heute Nacht noch ein Update rausbringt, wo er Bash reinbringt, Beats Audio und Dolby Mobile Mod hinzufügt und weitere kleine Sense 4 Fixes reinpackt :)
    Werde Morgen dann den Thread dementsprechend erneuern!
  5. Zekene, 21.04.2012 #5
    Zekene
    Kommt gleich auch mal drauf :)
  6. MarciWoi, 21.04.2012 #6
    MarciWoi
    Du wirst begeistert sein ! :)
  7. Zekene, 21.04.2012 #7
    Zekene
    Muss nacher neu laden. Bei 96% beendet xD
  8. MarciWoi, 21.04.2012 #8
    MarciWoi
    :D und hast du es drauf? :)
  9. Zekene, 21.04.2012 #9
    Zekene
    Wie gesagt muss nacher noch mal laden :D gehe aber eh jetz gleich an den lappy ;)
    Gesendet von meinem Sensation mit Tapatalk 2
  10. MarciWoi, 21.04.2012 #10
    MarciWoi
    Ok berichte dann :)
  11. Zekene, 21.04.2012 #11
    Zekene
    Sehr gut!! Erste blick ist wirklich gut! sehr flüssig! sehr schick finde ich die downgreadanimation ^^ gehe aber erstmal wieder zurück zu OrDroid. Denke aber das ich früher oder später wieder RCMix nutzen werde :)
  12. MarciWoi, 21.04.2012 #12
    MarciWoi
    Mal sehen wie er sich weiterentwickelt ist ja erst 0.1 ;)
  13. Zekene, 21.04.2012 #13
    Zekene
    Genau! Das wird noch was ganz großes hier glaube ich !
  14. MarciWoi, 21.04.2012 #14
    MarciWoi
    Das glaube ich auch! Zwei sehr gute Entwickler sitzen dahinter, das kann nur gut werden ! :)
    Grüße Marcel
    Und wer es noch nicht getestet hat einfach mal ausprobieren ! Man bereut es auf keinen Fall :)
  15. larsm., 21.04.2012 #15
    larsm.
    larsm. Erfahrener Benutzer
    Ich flash es grad, komm vom Elegancia, leider hat RCMIX noch keine eigenen Tewaks, Mods oder Themen, aber so wie ich sie aus dem Incredible S Forum kenn, kommt das bald. Damals waren das die besten Tweaks von RCMIx.
  16. MarciWoi, 21.04.2012 #16
    MarciWoi
    Schreib dein Feedback dann bitte hier rein :)
    Grüße Marcel
  17. larsm., 21.04.2012 #17
    larsm.
    Läuft flüssig, hab viel Ram frei, hab aber noch nicht gespielt oder sonst was, richte es grad wieder ein. Mal schauen was der Akku so übernacht macht.
    Der W-Lan/GSM empfang ist viel viel besser, wahrscheinlich durch den RCMIx Kernel. :smile:
  18. MarciWoi, 22.04.2012 #18
    MarciWoi
    So,
    v1 ist raus hier ist der Changelog + Download:
    Changelog:
    updated SU binary
    updated Busybox
    updated bash binary
    Download
  19. Zekene, 22.04.2012 #19
    Zekene
    Ich teste heute vllt. Die neue Version
  20. MarciWoi, 22.04.2012 #20
    MarciWoi
    Ich lade gerade runter, Feedback wie immer später :)
    Grüße Marcel
    EDIT:
    Hatte gestern wieder OrDroid drauf und es wahr viel langsamer als RcMixSmartDroid. Ich glaube ich habe meinen neuen Rom gefunden :D
