[ROM][JB] [4.2.2] Avatar ROM for LG Optimus G (E975) - Updated [Aug 10, 2013]
toxicOne
toxicOne
Stammgast
120
The Avatar Team is proud to present:
Avatar ROM
CM based ROM for LG Optimus G (E975)
Love the minimal feel of CM? Love the themeing capability of MIUI?
Das Avatar-Team bringt Dir eine kombinierte ROM.
genießt jetz schöne MIUI Designs auf Basis von
Cyanogen
The Avatar team brings you, both combined in one ROM. Now enjoy beautiful MIUI themes on Cyanogen base.
<<Quelle>>
PHP:
Details:
 Android JB - 4.2.2 CM10.1
Code:
Instructions:
If it's the first time flashing avatarrom  or coming from another ROM[INDENT]
[LIST]
[*]Install ClockworkMod Recovery.
[*]Do a NANDroid backup of your current ROM from backup/restore menu.
[*]Wipe Data/Factory Reset & Wipe cache partition
[*]Flash the downloaded .zip file.
[*]Install Gapps package. If you get Google search crash update Google search from play store.
[/LIST]
[/INDENT]
  • The platform for avatarrom as of now is CM10.1. The following components are changed on top CM10.1.
  • Status Bar
    • Fixed memory leaks
  • Theme Chooser
    • Google playstore like theme chooser - head here and download cool MIUI converted themes and CM themes.
  • Bazooka Launcher (market link)
    • Own launcher which is an enhanced version of Trebuchet (you can download this at the end of this post)
    • Enhanced theming by adding dockbar
    • Preview mode to edit workspaces
    • Many new Customization options.
    • Different gestures like swipe-up, swipe-down, double-tap, home-button press are added.
    • Added "edit workspace" option in menu button.
  • Messaging App
    • Changed message thread to make them themeable
    • Themeable Emoticons
  • Boot Animation
    • Themeable boot animation - the only CM ROM to do so.
  • Font Theming
    • Only ROM to support change of font without a reboot.
    • Tons of themes which change font - Eg: Buff, Simpsons, Mi_Xmas, European Gorgeous etc
  • Settings
    • Changed statistics to point to Avatar statistics server
    • OTA updater - you can check for updates to Avatar right from your device
    • Changed to support Avatar ROMs
    • Support for Gapps - download latest Gapps package as an OTA update
  • Framework
    • Integrated with ACRA Error Reporter for system wide crashes
  • Lockscreen
    • Changed to make them themeable
    • Support for complex unlock gestures
  • Weebo
    • A smart tasker kind of app which can help you to automate your device.
    • You can use exisiting rules or create your own customized rules for your needs.
    • More info - Link
  • Layout Theming
    • Themes not only change images, colors but it also can change the size, shape and position of any UI element.
    • More info - Link
  • Theme Editor
    • A tool to insulate you from all the complex operations involved in theming.
    • More info - Link
    • usage - Link
Stable release 3.0 - 07/02/2013
As CM10.1 has hit the general release, Avatar Team is branching with stable and nightly releases.
Stable releases are marked as 3.0. This is the first stable release from Avatar Team. Stable releases will be weekly or bi-weekly and will be tested extensively by our testing team.
Nightly releases will kickstart in a few days. We will merge CM changes every day and it will also contain experiemental features from Avatar.
We highly recommend to wipe cache/data/dalvik before flashing the stable releases.
Changelog:
07/21/2013 - AvatarROM 3.0.1 Nightly release
  • Update to latest cyanogenmod (till July 17) which has
    • Support for exfat, ntfs partitions
    • Some preliminary support for selinux
  • Themechooser is using action bar
  • Launcher
    • Fixed major issues and Critical crashes reported in error reporter have been fixed.
    • Some performance optimizations have been made when scrolling the workspace.
Based on CM10.1.0 (General Release)
2.11b release changelog
05/18/2013 - With more features and fixes Avatar team releasing the latest version 2.11b
  • Merged with CM 10.1 RC2 tag (May 15th, 2013)
  • Added Centre Clock feature - can be enabled/disabled from Settings
  • Made Navigation bar themeable - the resource name is nav_bar_bg
  • Made Statusbar Transparent - Default Status bar is now 25% transparent. Themes which have transparent status bar can make use of this. Seasons is one such theme.
  • Weebo
    • A 4x3 weebo widget can be added in homescreen. It displays current location and recent actions taken by weebo. This list is updated whenever there is location change or any actions are performed by weebo.
    • Fix for change of location when network is not detected
    • Removed cell-Id display from recent events logs. Remove cell-Id entries from recent events list shown in weebo.
    • Changed location tracking time options from locations page. Put a "recommanded" text for 4 hours option and removed "5 minutes" tracking time.
    • Action notifications are getting cleared now
    • Removed Actions in the notifications s when notification is cleared. When user removes notification the actions shown in notification are cleared.
  • Launcher
    • Feature to lock/unlock homescreen. Once homescreen is locked apps or widgets cannot be moved.
    • Fix a bug related to Gesture detection
  • Theme Chooser
    • Some memory leak fixes
    • Added support to share a fav theme on facebook
    Existing AvatarROM users can update via OTA from setting-> About Phone-> Avatar Updates
    More info about 2.11b release - http://avatarrom.com/update-2-11b-fo...es-draw-along/
05/04/2013 - AvatarROM 2.9b release.
  • CyanogenMod merges till May 2nd 2013.
  • SystemUI fixes during expanded desktop (the background was not covering till the end. Also portrait - landscape transition, the notifications wouldn't expand fully)
  • ThemeChooser : Fixes for text invisible in installed themes tab for dark themes
  • ThemeChooser will not handle market links anymore and Memory leak fix.
  • Old themechooser is removed completely.
  • Launcher : Fix crash without wipe & make dockbar transperant.
  • In OTA updater show that the gapps and rom is installed if they are installed. ( Previously it used to show new or downloaded).
  • Change Cyanogen Mod Updates to Avatar Updates
  • We have a global error reporter collecting the crashes reported by the user using ACRA. Error Reporter link
04/27/2013 - AvatarROM 2.8b Release
  • Merged CM changes till 24th April ( includes Camera driver fixes for lot of devices )
  • Bazooka Launcher
    • Fixed some critical issues reported in previous build.
    • Added Gestures in workspace. A settings page also added to configure gesture actions. Different gestures like swipe-up, swipe-down, double-tap, home-button press are added. Different actions for each of the gesture can be set in preference.
    • Added ""edit workspace"" option in menu button.
    • Removed ""pinch to preview mode"". This option is currently disabled for some issues as we can go to preview mode through many other ways. It will be added later.
    • Many new Customization options."
  • Lockscreen
    • Fixed a bug
  • Fixed Settings crash on Input Method
  • Fixed Version Number problem in Error Reporter
  • Theme Chooser
    • Removed Old theme chooser
    • enabled Total download count of themes
    • Sorting themes based on download count
    • Sorting themes based on date
    • Settings App now launches the new Theme chooser
04/20/2013 - AvatarROM 2.7b Release
  • Merged with CM 10.1 M3 build( 14th April )
  • Changed Error Reporter to send requests to server instead of a google document
  • New Theme Chooser fixes
  • Weebo fixes
  • Support for layout theming
Existing AvatarROM users can update via OTA. Go to Settings-> About Phone-> Avatar updates and hit the refresh button.
Known issues
Update Google search and Google voice from playstore after installing the Gapps.
04/06/2013 - AvatarROM 2.6b Release
  • Full support for OTA
  • Merged with latest CM 10.1 base (Upto Apr 3rd, 2013 - Includes Paranoid style pie control, new Super user app etc)
  • Changes in the framework to redirect trebuchet and android launcher resources from CM themes to Bazooka launcher
  • Fixed launcher menu settings in app space
  • New ThemeChooser - Bug fixes, Performace improvements and new features like download count, caching etc
  • Performance improvements in theming engine
  • Weebo fixes
  • Disabled driving rule in weebo as it was causing lot of confusions
03/31/2013 - AvatarROM 2.5b Release
  • Latest CM 10.1 code merges for 2.5b release(upto Mar 28th 2013)
  • Included new theme chooser based on Aptoide(Alpha release)
  • Lockscreen - Enable/Disable vibration when unlocking from settings -> Lockscreen -> Screen Security -> Vibrate
  • Launcher - Option to edit workspace in menu
  • Weebo - Bug fixes and now you can create your own rules (see - weebo-rules - Avatar)
  • OTA - Full support from client side. Next update will be via OTA.
  • General bug fixes
03/24/2013 - AvatarROM 2.4b (CM10.1)
  • Latest CM 10.1 code merges for 2.4b release( upto Mar 22nd 2013)
  • Two new themes (MiUi v5 and Pink theme)
  • Weebo and status bar fixes.
  • Weebo adding actions in log.
  • Performance improvements in animations.
03/15/2013 - AvatarROM 2.3b Release
  • Latest CM 10.1 code merges ( upto Mar 13th 2013)
  • Fix Settings -> About phone -> Status crash
  • Usual bug fixes
03/02/2013 - AvatarROM 2.1b Release
  • Latest CM 10.1 code merges (upto Feb 27th 2013)
  • Bug fixes from 2.0b Avatar Release
  • Small tweaks for battery.
Android version 4.2.2 based on CM10.1
Nightly Release 3.x.y - Android version 4.2.2 based on CM10.1
Nightly 3.1 - Aug 10 2013
Stable Release 3.x - Android version 4.2.2 based on CM10.1
Stable 3.0
Beta release - Android version 4.2.2 based on CM10.1
Link (Jun 23,2013)
Gapps (4.2.2)http://goo.im/gapps/gapps-jb-20130301-signed.zip
Sample Video - checkout our MIUI style lockscreens, statusbar, messaging, etc and the smooth transition of themes:
Review by Phone tech kid
All Videos
Ihre Garantie wird bei Nutzung ungültig. ** Ich bin nicht verantwortlich für kaputte Geräte, tote SD-Karten, * thermonuklearen Krieg, oder der gleichen. Bitte * Wenn Sie irgendwelche Bedenken über die Funktionen in dieser ROM haben * Flashen Sie nicht! Sie entscheiden sich selbst, diese Änderungen vorzunehmen, und wenn * Sie mit dem Finger auf uns zeigen für Unordnung auf Ihrem Gerät, sind wir nicht verantwortlich.
Wir werden dich auslachen.
Code:
/* * Your warranty is now void. * * I'm not responsible for bricked devices, dead SD cards, * thermonuclear war, or you getting fired because the alarm app failed. Please * do some research if you have any concerns about features included in this ROM * before flashing it! YOU are choosing to make these modifications, and if * you point the finger at us for messing up your device, we will laugh at you. */
Credits:
  • Cyanogen Team
  • Trebuchet launcher
  • MiUi Theme creators
If there are any errors let us know in the comments or file the bug at team AvatarROM
You can find more information at Home - Avatar
Feature request page - https://avatarrom.uservoice.com/foru...eature-request
Diese Rom lief bei mir im Test auch sehr stabil & ist schwer in Ordnung!.:thumbsup:
Laßt euch von den bunten screens nicht täuschen das sind lediglich Themes die der Rom dev zusätzlich anbietet und das wohl bemerkt im OTA Style also in Echtzeit...:D Ihr könnt natürlich Themen was und wie Ihr wollt!
Viel Spaß damit!
Anregungen & Anmerkungen erwünscht!..:lol:
Beste Grüße
toxicOne
Toll :)
Hatte den launcher mal drauf, is ganz imteressant :)
Falls ich dir bei der gestaltung helfen soll, drück auf edit und kopier den ganzen text in ein windows textdokument und schicks mir :)
Gesendet von meinem LG-E975 mit der Android-Hilfe.de App
Alles klar danke dir buddy.. ;)
Thinkingbridge Stable2 on LG OPTIMUS G via Tapatalk ICS SkyBlue E975
Update auf 10 b.
Thread wird später noch aktualisiert
Beste grüße
füg dann bei denen ROM threads in die ersten zeilen den xda link ein - danke
Ist doch verlinkt Quelle einfach mal auf das Bild klicken!...:thumbup:
auf der ah app gehts schon mal nicht :)
Ja das stimmt tapatalk kapiert einfach immer noch keine image verlinkungen egal!
werde nochmal darunter verlinken!
BIG UPDATE
2.10b release - change log
05/11/2013 - Avatar team is proud to present the 2.10b version based on the latest CM 10.1 RC base (Stable build).
  • Merged with CM 10.1 RC1 tag (May 8th, 2013)
  • Added more space between wifi and signal icons in status bar
  • Added gapps version in Error Reporter
  • Message Bubbles - Reset the bubbles similar to stock version bubble when not themed.
  • Theme Chooser - Themes now display the size of the apk.
  • Theme Chooser - Fixed memory leaks
  • Theme Chooser - Fixed download problems with some themes - cobalt blue, cobalt inferno etc
  • Bazooka --> Fixed Widget scolling issue when Widgets are placed on Home screen.
  • Bazooka --> Fixed the dockbar pages issue. You can select number of pages in Settings screen of Bazooka launcher.
  • Bazooka --> Other minor bug fixes.
  • Weebo --> Fixing the issue where files cannot be read from /mnt/sdcard/weebo folder.
  • Weebo --> Contact picker to make it simpler to select the contacts you want to call/send message to.
  • Weebo --> New categories in "All rules" callled Enabled and Disabled. This shows currently enabled/disabled rules.
  • Weebo --> Location exit condition bug fixed. You can now trigger actions when you leave a particular location.
Existing Avatar ROM Users - Hit the refresh button from "settings -> About Phone -> Avatar ROM Updates" for download via OTA
AvatarROM is now available for download via ROM Toolbox lite and pro versions. Thanks jrummy.
Checkout the below video, it gives glimpse of Avatar ROM
Beste Grüße
toxicOne
Jemand Erfahrung mit dieser Rom in sachen Performance usw.?
Hallo! Ich bin Sam und neu hier^^
Natürlich komme ich mit einem Problem hier her. Ich habe mein LG Optimus G gerooted und unlocked. Danach habe ich mit CWM Installiert und die Avatar ROM gleich danach. Alles lief toll bis jetzt. Nachdem alles installiert war, war die Boot Animation zu sehen. Doch sie hört nicht auf. :ohmy:
Kann mir bitte jemand helfen?
Hi Sam,
Willkommen hier im Forum :)
hast du bevor du die zip installiert hast auch wipe data und wipe cache in cwm gemacht?
bei meiner ersten rom hatte ich auch 3 anläufe gebraucht, bis sie bootet :D
Kleiner Hinweis am Rande:
Man sollte, besonders, wenn man von Stock kommt, immer auch das System formatieren, bevor man eine andere ROM flasht. Die Option gibt es im aktuellen CWM unter "Mounts and Storage" und dann auf "format /system"! :)
Mit den entsprechenden Wipes (/data & /cache) sollte es nun aber auch funktionieren! :)
LG,
Afro
Vielen Dank, hat funktioniert *.*
Aber ein Problem habe ich noch.. Der Playstore ist weg, wie komme ich jtzt an Apps :'D
Du mußt noch die Gapps installieren.
Steht im angepinnten Guide wo man die bekommt ;)
Der ursprüngliche Beitrag von 13:02 Uhr wurde um 13:26 Uhr ergänzt:
Mir ist aufgefallen das im Guide nichts über die Gapps steht oder ich bin blind :)
Von hier kannst Du die passenden laden:
Goo.im Downloads - Browsing gapps
Rom lief ganz gut!
War leider nicht so mein ding und 2.seite der statusleiste ging übers icon nicht, nur über den slider, ganz unten die leiste, wo man die statusleiste wieder zu macht ;)
Reaktionen: psycho-sonic
Ich hätte noch ne Frage Leute, wie bekomme ich die ROM wieder von meinem Handy C:
Danke nochmal an alle die mir geholfen haben.
Entweder stellst Du ein Backup wieder her (falls Du eines gemacht hast) oder Du flasht via KDZ Tool wieder ein Stock Rom (wie das geht steht im Root Thread, der oben angepinnt ist).
Viele Grüße
Lars
Backup hab ich keines :o
Ich habe aber das Problem das der KDZ File dings mein Handy nicht erkennt. Hab es schon mit 2 verschiedenen versucht. Was soll ich jetzt tun?
Bist Du Punkt für Punkt den Anweisungen zum Flashen einer Firmware aus dem Root Thread gefolgt?
Hast Du die Treiber für Dein Optimus G installiert?
Viele Grüße
Lars
Anstatt jetzt die ROM zu löschen will ich lieber 2 Bugs weg bekommen. Wenn ich in den Play Store gehe oder versuch *** zu öffnen, schließen sie sofort.
toxicOne
toxicOne
toxicOne
magic16
magic16
bublegum007
bublegum007
