[ROM/JB NEU/Diskussion] Blade v4.6 | ~240 MB | 26/01/2012
Q
quercus
Gast
Quelle: XDA
[ROM]Blade
Rom-Info
Ultra Light, Just 283 MB!
EXTREMELY Fast (Confession)
EPIC Battery Life
(Confession), Read this.
Based on Official European base (3.14.401.31) (OrDroidX v12.0.0)​
Android Jelly Bean 4.1.1, Sense 4+​
Deodexed, Recompressed & Zipaligned using SDK r21.0.1.​
Unsecured boot.img.​
SuperSU, Busybox.​
Persistent ADB enabled.​
Init.d scripts support.​
Desensed and Sense Versions​
Sysro/sysrw commands support.​
Memory optimizations.​
Ramdisk tweaks.​
Aluminium Battery Percent Mod​
Rosie with Menu Support​
Advanced Power Menu​
Custom Blade Wallpaper​
Tweaks for amazing performance​
Fast and Stable​
Tons of Bloatware Removed​
Compatible with others JB mods​
I reply to every post on the thread
Changelog & Download
Blade AROMA Package v2.1 - New cool splash image that you saw before you got to this page :) - Added this line - Added Lyapota's EQS and MusicBox from his Mods Pack - Re-Orginized to prevent conflicts between mods - Fixed xLoud not flashing - Added Restore function for HTC's: - - Lockscreens - - Skins - Ringtones - Alarms - Notifications - Added Modded CPU Config by Iba21 - Updated some info - Updated Remove Beats Notification & Powersave mods - Fixed a few mistakes - Added this v2.1 changelog - Added HTCCalendar fix - Added Friend Stream fix v4.6.0 - Lowered size to 239 MB - Removed Lots of Unnecessary Stuff - Fixed Syncing Error (Red Arrows) in Accounts & Sync - Removed NoiseField.apk (Bubbles LWP) - Removed Unnecessary Font Files (gcsh00d-hkscs.ttf, MTLmr3m.ttf, ucsh00d_c.ttf) - Build.prop Mods: - Better and Faster Streaming - Video Acceleration - Better Battery Usage - Removed YouTube and GMaps APKs (Dramatic Size reduction) (Can be downloaded from Play Store)
Video
Blade V2 - HTC One X - JellyBean - De/Sense/d - Extremely Fast - YouTube
Installation
Reaktionen: torxx
Und wie sind die Erfahrungen bisher so? Bin zurzeit noch bei Renovate und eigentlich sehr zufrieden. Hat man hiermit wirklich bessere Akkulaufzeiten, oder ist es nur das was jeder dev sagt? ;)
Dass was jeder Dev sagt ;)
Exakt! :laugh:
UPDATE
Changelog:
v3.0.0
- Rebased on OrDroidX v12.0.0 (3.14.401.31) (thanks Shnizlon!)
- Rebuilt from the ground up
- New icons for Advanced Power Menu. (Cheers @Jotha and Shnizlon)
- Fixed Bookmarks Sync
- Even lighter (282 MB)
- Updated Google Maps
- Cleaned build.prop
- Other minor changes and fixes.
PS - Schlanke Rom mit gefühltem Speed!
Changelog:
v4.1.0
- Rebased on OrDroidX v12.5.0
- OrDroidX Base was built from scratch.
- ROM rebuilt from the ground up
- HTC Mail widget re-added
- Added AOSP Recents App mod by Hassan89 with battery %
- Fixed HTC Media Link HD Connection issues (DLNA)
Other Changelog for 12th Jan:​
- Updated Desensing Script to V4, now removes all Sense widgets (Including Mail Widget)
Update
- Updated some info
v4.6.0
Reaktionen: manne49
Wie sieht's denn mit der Laufzeit aus? Im xda gibts ja schon posts mit Screens von guten Laufzeiten kann das vll jemand bestätigen?
Die Laufzeiten der Roms sind alle gleich - der Faktor wie lange du mit einer Akkuladung auskommst, bist du alleine.
d.h. wenn du viele Anwendungen geöffnet hast, wenn vieles im Hintergrund läuft, wenn du viel telefonierst, zockst, dich im Internet bewegst, alle 2 Minuten deine E-Mails abrufst, deine Displayhelligkeit, Facebook, Google und was weiß ich noch - wird klarerweise dein Akku schneller leer sein.
Unsachgemässes, unsauberes installieren der Rom trägt das selbige dazu bei.
Jetzt zu Fragen, ob die ROM eine bessere Akku-Leistung hat, hat wenig Sinn, da beim Verbrauch des Akkus, jeder seine eigenen Angewohnheiten hat: Telefonieren, Surfen, E-Mails abrufen - macht jeder anders - der eine öfters, der andere eben nicht - daher ist ein Vergleich nicht möglich.
Der einzige Vergleich der Bestand hat - kannst nur du selber sein - indem du versch. Roms flasht und mit deinen Angewohnheiten mit dem Handy umzugehen, vergleichst.
Und dann gibt es noch den Dev-Trick der direkt vom Jahrmarkt kommt, und dort seine Erfolge beim angeheiterten Publikum feiert:
Meine Rom hat bessere Akku-Zeiten!
So, sehen wir uns die Aussage an:
Wenn ich viele Anwendungen - die wenn ich sie am Handy vermutlich nutzen würde - von Haus aus entferne, dann habe ich ein schlankes Rom.
Wenn ich von Haus aus nicht so viele Anwendungen benutzen kann, dann wird auch der Verbrauch des Akkus geringer sein - logisch nicht?
mit anderen Worten:
Viele Anwendungen laufen im Hintergrund mit, obwohl sie nie vom User geöffnet worden sind. Dezimiert man diese Anwendungen indem man sie beim "kochen der ROM" gleich gar nicht am Handy platziert, dann senkt sich auch der Verbrauch.
Nachdem die Handys ohnehin mit Software überladen sind, ist das dezimieren des Software die derzeit vernünftigste Variante zu "SPAREN" was wiederum dieser Rom hier zu Gute kommt - daher der Flashtipp.
Okay aber ich habe festgestellt, dass unabhängig von meiner eigenen Nutzung bei meiner aktuellen Rom mein Handy eigentlich nie im DeepSleep ist und bei App Usage stehen Sense und der Kernel ganz oben, und hatte auf einem Screenshot im xda gesehen dass seine Held awake time sehr niedrig war (bei 20min, meine liegt bei einer Laufzeit von 8h schon bei 5h :o ) deshalb dachte ich wenn diese Zeit wirklich geringer ist bei der Rom kann auch die Akkulaufzeit nochmal erheblich verbessert werden.
mir fehlt im Playstore, das 2 dot Menu um auf meine Apps zuzugreifen - wie bekommt man das?
mfg
chris
qemu.hw.mainkeys auf 1 setzen, dann sollten die 3 Punkte in allen Apps wieder erscheinen, die recent apps Taste kann aber immer noch als Menü-Taste verwendet werden.
Von meinem Nexus 7 für euch!
Schubbie
Q
quercus
Q
debaki
debaki
debaki
