[Rom]LG Optimus 2X - DjangoManouche 1.0 - ROM AGAINST GLOBAL CRISIS - V20q
burningfight
Gast
DJANGO MANOUCHE 1.0 [25.02.2012]
with Anti - crisis - Kernel - versions
5 versions:
1 - Spica RC12-R OC
2 - Spica RC12-R NO-OC
3 - Gueste Kernel 1.1 EXT3
4 - Gueste Kernel 1.1 EXT4
5 - Fajarep SiKancil 0.2 EXT3
6 - Stock with 20q kernel - EXT3
Die 1.0 ist keine Beta mehr.Also los gehts ;)
Changelog 1.0:
- ALL NO WIPE (so remember to convert to ext3 to install ext3 versions)
- 20q base
- New sqlite lib 3.7 with full support to WAL mode (thanks Spica!)
- No Ota update in settings (+20 Mb ram)
- No OSP in settings and fully removed
- Transparent curtain and circular battery
- ICS animation
- CM APN
- Bravia Engine Mod
- Build.prop tweaked for market compatibility
- 20q ril (suggested baseband: 20q)
- 3 new profiles for memory management in 90carbutweak script
- Enabled ADB
- Optimized host to remove spam and ads
- Stock camera from 20q
- Removed 2x reboot
- Removed Battery Calibration
- Removed LG UI 2 Weather, many animated wallpapers and other LG apps
- Added DSP Manger (Thanks Spica)
- Added Android weather (light and simple )
- Back to Adobe flash 10.3 (IMHO best performance)
- Removed LGStartupWizard
- Gmaps up to date
- ES file explorer Up to date
- Su binary up to date
- Facebook up to date
- Google Music Up to date
- Voice Search Up to date
- Titanium Backup Up to date
- Updated Supercharger script in /systems/xbin folder
- Deactivated scrolling cache
- Twitter Up to date
- 2 launchers: TW launcher and QQLauncher IMPORTANT: I added at last minute QQ launcher but I suggest to avoid using it because after reboot I never have Pin unlock phone... Use TW (that is faster too)
Hier könnt ihr die Rom fürs Optimus Speed P990 Downloaden.
DjangoManouche 1.0 - Spica RC12-R OC :
Ist gleich Verfügbar!​
DjangoManouche 1.0 - Spica RC12-R NO-OC:
Noch nicht Verfügbar!​
DjangoManouche 1.0 - Gueste Kernel 1.1 EXT3:
Download​
DjangoManouche 1.0 - Gueste Kernel 1.1 EXT4:
Download​
DjangoManouche 1.0 - Fajarep SiKancil 0.2 EXT3:
DjangoManouche 1.0 - Stock with 20q kernel - EXT3:
Download​
Ich empfehle die
DjangoManouche 1.0 - Gueste Kernel 1.1 EXT4 und das Baseband V20q
(im Anhang zu finden/RIL V20q in der ROM enthalten)
da diese sehr flüssig läuft.​
DJANGO MANOUCHE 1.0 Transformation Packs
Also Thanks to:
Topogigi
Gueste
Hell97
Spica1234
Dr4go
Flix132
Gabriesu
Mjuksel
Vadonka
jaspi72
Owain
whole XDA community
Italian forum for support (HDBlog, Androidiani, IpMart, Facebook group "LGDual"
Screenshots:​
Würde mich über ein Dankeschön Sehr Freuen! ;)
Reaktionen: subdie, Tozupi, defy-ist-meins und 3 andere
Registrieren, nur damit man etwas von handy-faq posten kann? Ich weiss ja nicht...
Reaktionen: Stoan
Ich empfehle die ROM gerne weiter. :)
Mittlerweile ist ja schon 1.3 im Kommen. Batterielaufzeit ist super, und alles läuft flüssig und wie es soll.
Bin von CM9 gekommen ;)
Bin mit der 1.2 auch so zufrieden wie noch nie! Die ROM läuft einfach super!!! Kann sie auch nur jedem weiterempfehlen!
Welchen Kernel habt ihr drauf und wie ist die AKkulaufzeit?
Hallo, wo bekomme ich denn die 1.2 und welchen Kernel hast du genommen???
Gesendet von meinem LG-P990 mit Tapatalk
Benutze die Rom mit Gueste Kernel 1.1 EXT4. Akkulaufzeit ist super wie gesagt. Kann dir aber leider keine genauen Angaben dazu machen :( Aber ich kann dir auf jeden Fall sagen das ich bessere Laufzeiten habe als unter CM7 :)
Von dem Kernel ist auch schon die 1.5 draussen. Werde denke ich Gueste 1.5 OC with LiteBattery Driver - Overclock mal probieren.
Hab auch den 1.5 gemeint sorry :) aber ich hatte viele Probleme mit der OC-Version des Kernels :( Daher auf EXT4 Gueste 1.5 NoOC gewechselt.
Hab auch Gueste 1.5 @1100mHz :)
Mit der Django Rom? Wie lange hält da bei Dir der Akku, bei welcher Nutzung? Performance alles ohne Probleme?
Ja. Kann ich nicht so genau sagen, habs erst seit vorgestern drauf.
Ich denk, so um die 11 Stunden bei häufiger Nutzung. :)
Performance ist super ;)
Also mein Akku hält bei normaler Nutzung 2 Tage. Selbst wenn ich nachts 3G+Wlan anlasse verliere ich nur 3%. Bei CM7 waren es immer so um die 10%.
So sieht es bei der Gueste ROM + 1.5er Kernel im Moment auch aus. Testet hier jemand bereits die neue Beta 2 der 1.3?
Ich warte auf ein stable Release. Habe keine Lust andauernd neu aufzusetzen und einzurichten.
Ich. Läuft klaglos, vollkommen bugfrei, Aroma ist super und allein die Idee einer "Antifa-ROM"! :thumbsup::biggrin:
Reaktionen: pukidukie
Klingt gut :thumbsup:
Welchen Kernel nutzt du bei welcher Taktung? Wie sieht die Akkulaufzeit aus?
Gueste 1.6.2 @1100mHz
Akku, wie immer bei mir... 7-12 Stunden, je nach Nutzung.
Gibt bald eine 1.3 stable. Ich würd warten, wenn du Django flashen möchtest, sonst musst du dann nochmal wipen :)
habe irgendwie das problem, dass wenn ich die rom mit cwm 5.0.2.0 flashen will immer folgende meldung kommt: " THIS IS NOT A ROM"
habs nun schon zwei mal diese datei geladen
DjangoManouche1.2.1WipeEXT4Gueste1.5NoOC.zip
und immer das selbe ergebnis.
weiß jemand rat?
Das ist gewollt :) Warte einfach ein bisschen, die Rom wird dann gerade installiert.
Dann kommen noch so 2 Sprüche, this is Not a fascist Rom oder so. Das ist einfach der normale Text im cwm während des installierens, kam bei mir auch.
Gesendet von meinem LG-P990 mit der Android-Hilfe.de App
Reaktionen: el-lutschi
sgspluss
djtw09
djtw09
mischka
mischka
mischka
R4G3
Donauschwabe
Donauschwabe
