1. Nytro, 05.10.2012 #1
    Nytro
    Nytro Threadstarter Fortgeschrittenes Mitglied
    [​IMG]
    [​IMG]
    Welcome to Omegas Thread for Samsung Galaxy Note II N7100
    Omega v29 Kit Kat 4.4.2
    Based on firmware XXUFNE1 Android 4.4.2 (Date: 06/05/2014)
    Screenshots:
    [​IMG] [​IMG] [​IMG]
    Omega v28 Installation:
    Bootloader - Knox:
    Omega does not include bootloader and will not change your knox warranty status.
    Backup:
    Backup your device (nadroid backup, titanium backup, efs backup ... etc), in case you ever need to restore!
    Wipe:
    Full wipe is needed if you are coming from another rom or stock firmware or Omega with another android version
    and format of internal sdcard is needed if you are coming from Android 4.1.2 because updating to Android 4.3 will change the location of your internal sdcard
    Installation Instructions:
    Boot to recovery and flash Omega
    Done, Reboot and enjoy kit kat Omega [​IMG]
    NOTICE: If you are having the old bootloader WiFi will not work, flash this Fix N7100_wifi_fix_for_old_bootloader.tar file with odin. Credits to dr.ketan for the WiFi Fix
    If you are using the new bootloader you do not need to flash this fix, WiFi will work.
    To check your bootloader go to download mode and if you have an entry: KNOX WARRANTY VOID then you are having the new bootloader.
    PLEASE FOLLOW THE EASY INSTALLATION INSTRUCTIONS ELSE YOU WILL HAVE VARIOUS ISSUES!
    csc:
    Multi csc included in Omega
    Remove bloatware:
    You can remove all bloatware during Omegas installation
    Inside Omega v29:
    [FONT=Century Gothic][INDENT][B]Based on firmware XXUFNE1 Android 4.4.2 (Date: 06/05/2014)[/B]
    Kernel Stock
    Modem XXUFND3
    csc multi set to BTU
    Busybox
    [URL="http://forum.xda-developers.com/showthread.php?t=1461712"]Aroma Installer[/URL]
    Installation is [U]fully customizable[/U] by user and there is options to install everything or remove all Bloatware
    aroma installer now has the option to remove more then 800 mb of almost 80 bloatware apps, widgets and services
    Option to full wipe from aroma installer
    Option to Remove all Bloatware from aroma installer
    Option to install or not all Omega addon apps from aroma installer
    Wipe cache partition automatic before roms installation
    Wipe Dalvik Cache automatic during installation
    Wipe preload partition automatic before roms installation
    Wipe System automatic before roms installation
    efs Backup (added the option to create efs backup during installation)
    Omegadroid Walk Bootanimation by Jorq1H and anbech
    Omegas Emblem Shutdown Animation by anbech
    OmegaDroid Kit Kat Wallpapers by our artist [URL="http://forum.xda-developers.com/member.php?u=4834264"]Jorq1H[/URL]
    [B]Applications developed by Omegas Team (bartito & indie):[/B]
    Omega Files by indie
    OmegaDroid - [URL="https://play.google.com/store/apps/details?id=net.indieroms.omegadroid"]The official application of www.omegadroid.co[/URL] by indie
    OmegaDroid Wallpapers application - [URL="http://omega-roms.net/Photos/xda/N9005-442-08.png"]Screenshot[/URL] by indie
    Task manager shortcut app by indie
    Accounts Sync Profiler - [URL="http://forum.xda-developers.com/showthread.php?t=2134387"]xda thread[/URL] for support & suggestions - [URL="https://play.google.com/store/apps/details?id=com.ryosoftware.accountssyncprofiler"]Play Store link[/URL] - by bartito
    Backup manager for apps & data - [URL="http://forum.xda-developers.com/showthread.php?t=2664139"]xda thread[/URL] for support & suggestions - [URL="https://play.google.com/store/apps/details?id=com.ryosoftware.appsbackup"]Play Store link[/URL] - by bartito
    CPU Adjuster - [URL="http://forum.xda-developers.com/showthread.php?t=2000609"]xda thread[/URL] for support & suggestions - [URL="https://play.google.com/store/apps/details?id=com.ryosoftware.cputweaks"]Play Store link[/URL] - by bartito
    Notification Manager - [URL="http://forum.xda-developers.com/showthread.php?t=2572017"]xda thread[/URL] for support & suggestions - [URL="https://play.google.com/store/apps/details?id=com.ryosoftware.notificationsmanager"]Play Store link[/URL] - by bartito
    Recycle Bin - [URL="http://forum.xda-developers.com/showthread.php?t=2246944"]xda thread[/URL] for support & suggestions - [URL="https://play.google.com/store/apps/details?id=com.ryosoftware.recyclebin"]Play Store link[/URL] - by bartito
    Wireless Scheduler - [URL="http://forum.xda-developers.com/showthread.php?t=2734122"]xda thread[/URL] for support & suggestions - [URL="https://play.google.com/store/apps/details?id=com.ryosoftware.wirelessmanager"]Play Store link[/URL] - by bartito
    more to come ....
    if someone wants to help with our app development, with beta testing, suggestions, translations and be part of our app dev team please sent me a pm.
    [B]Mods:[/B]
    Call Recording
    Phone with no increasing ringtone
    4-way reboot menu
    Omegas OGBatteryMod app with 60 battery mods - credits to [URL="http://forum.xda-developers.com/showthread.php?p=38905053"]OsamaGhareeb[/URL]
    TW Launcher with scrolling wallpaper (can be disabled from Omega Files)
    Hide sms from call logs
    No sms to mms conversion
    Unlimited contacts to sms - mms
    sms/mms Backup - Restore
    Increased sms hour limit to 1000
    Disable scrolling cache
    Email with Exchange Security Disabled
    All supported languages enabled
    All supported languages for Samsung Keyboard enabled
    Exit button to stock browser
    Join more unlimited contacts in the contacts
    Enable sub Symbols on Stock Samsung keyboard
    SamsungSans.apk with a lot of system fonts - by [URL="http://forum.xda-developers.com/showthread.php?t=2734330"]nitol[/URL]
    [B]Addon applications:[/B]
    Xposed Framework Installer by [URL="http://forum.xda-developers.com/member.php?u=4419114"]rovo89[/URL] - read more about Xposed [URL="http://forum.xda-developers.com/showthread.php?t=1574401"]here[/URL]
    Android Camera 4.4.2 with Photoshare
    Android Keyboard 4.4.2 - available at Omega Files
    Flash player Support
    [URL="https://play.google.com/store/apps/details?id=mobi.mgeek.TunnyBrowser"]Dolphin Browser[/URL] with Flashplayer support
    [URL="https://play.google.com/store/apps/details?id=com.dolphin.browser.engine"]Dolphin Browser Jet Pack[/URL]
    [URL="https://play.google.com/store/search?q=Es%20File%20Explorer&c=apps&hl=en"]Es File Explorer[/URL]
    [URL="https://play.google.com/store/apps/details?id=com.smartanuj.hideitpro&hl=en"]Hide It Pro[/URL]
    [URL="https://play.google.com/store/apps/details?id=ru.zdevs.zarchiver"]ZArchiver[/URL]
    [URL="https://play.google.com/store/apps/details?id=yuku.mp3recorder.lite"]Hi-Q MP3 Recorder[/URL]
    [URL="http://forum.xda-developers.com/showthread.php?t=2469767"]Pen Window Manager[/URL]
    [B]Removed:[/B]
    Knox
    [B]Removed (Can be added from Omega Files):[/B]
    Boot sound
    Charger Connection Sound
    [B]Stock Theme Changes:[/B]
    Accuwheather widget transparent by indie
    Omega Theme for aroma installer by our artist [URL="http://forum.xda-developers.com/member.php?u=4699197"]anbech[/URL]
    [B]Bloatware :[/B]
    [B]Rom is Deodexed + Rooted + Zipaligned[/B][/INDENT][/FONT]​
    Omega Files:​
    Omega Files Pro:​
    Omega Graphics:​
    OmegaDroid:​
    Download:
    Twitter:
    Omegas Team:
    Thanks - Credits:
    ::indie's:: Omega Roms Series
    :: User Friendly Developer ::​
    Please use Omegas Threads for Support and Suggestions and don't sent me pm's!
    datt-bo bedankt sich.
  2. Robby57, 05.10.2012 #2
    Robby57
    Robby57 Android-Guru
    Tastatur muss ich mal sehen könnte sie vieleicht aus der Stockrom rausziehen wenn es mir die Zeit erlaubt.
  3. indie, 05.10.2012 #3
    indie
    indie Fortgeschrittenes Mitglied
    New version Omega v2.0 Jelly Bean:
    Based on firmware XXALIE Android 4.1.1 (Date: 21/09/2012)
    Added:
    Es File Explorer (with great Root Explorer)
    Hide It Pro
    OmegaDroid wallpaper
    Omegas JB Bootanimation by anbech
    xperia keyboard
    Mods:
    TouchWiz with wallpaper scrolling
    Disable Scrolling Cache
    Battery % mod
    Updated:
    Flipboard
    ChatOn
    YouTube
    hosts
    Removed:
    Samsung keyboard (due to not working)
    Removed Bloatware:
    Learning hub
    Reading hub
    All mods and updates from previous Omega JB versions added
    Rom in no Full Wipe
    Please read the following before flashing v2.0:
    1. Make sure to make and keep in a safe place an efs backup - a nadroid backup + titanium backup, in case you need to restore.
    2. After installation Device reboots automatically to Android.
    Donation:
    If you like Omega v2.0 please consider a donation to help me continue this project.
    [​IMG]
    Enjoy the new Note II Omega [​IMG]
    Edit:
    Please fix the first posts to be the same with xda - thank you!
    Aponatur bedankt sich.
  4. indie, 06.10.2012 #4
    indie
    New version Omega v3.0:
    Based on firmware XXALJ1 Android 4.1.1 (Date: 02/10/2012)
    New:
    Kernel Stock XXALJ1
    Modem XXALIH
    CSC: XXALJ1 set to EUR
    Updated:
    YouTube
    Mods:
    Contacts with Greek index
    Shutter Sound menu Enabled to stock camera
    Moved to Bloatware:
    Chrome
    VideoHub
    Rom is no Full Wipe
    Please read the following before flashing v3.0:
    Donation:
    If you like Omega v3.0 please consider a donation to help me continue this project.
    Enjoy the new updated Omega [​IMG]
    [​IMG]
  5. Robby57, 06.10.2012 #5
    Robby57
    Zwei Fragen
    Ist der Mehrfenstermodus jetzt dabei kann oben nichts darüber finden
    und hat jemand ein alternatieven download denn 134 kb pro Sekunde dauert Stunden
    um die V3 runterzuladen.
  6. Money, 06.10.2012 #6
    Money
    Money Android-Hilfe.de Mitglied
    Weiß jemand ob die Samsung Tastatur geht und die Synchronisation mit Kies.
    Danke für die Info
  7. Robby57, 06.10.2012 #7
    Robby57
    Ich weis garnix solange die V3 nicht downloadet. Steht immernoch auf 39 Minuten.
  8. Aponatur, 06.10.2012 #8
    Aponatur
    Aponatur Erfahrener Benutzer
    Nimm den Torrent, der läuft mit ~ 1mbit/s (ich seede mit unter).
    Samsung Tastatur läuft 1A und auch der Multiwindow läuft.
    Robby57 bedankt sich.
  9. hasbai, 06.10.2012 #9
    hasbai
    hasbai Fortgeschrittenes Mitglied
    wie schalte ich das multiwindow ein bitte?
  10. Aponatur, 06.10.2012 #10
    Aponatur
    Lange die zurück Taste drücken
    Gesendet von meinem GT-N7100 mit Tapatalk 2
  11. FuzzyHead, 06.10.2012 #11
    FuzzyHead
    FuzzyHead Android-Hilfe.de Mitglied
    Mal ne kurze Frage? Im Aroma wird mir gleich zu Anfang angezeigt:
    Für wen zählt das denn jetzt :). Nicht das ich mir heut noch das Teil zerschiess ^^.
    Danke!
  12. hasbai, 06.10.2012 #12
    hasbai
    Europa würde ich sagen
    aroma wird gezeigt und sogar führt sogar die installation aus
    Ich habe es drauf und läuft super
    Der ursprüngliche Beitrag von 20:16 Uhr wurde um 21:48 Uhr ergänzt:
    Kann bitte jemand den wallpaper von 3.0 hochladen?
    finde es meine irgendwie nicht mehr
  13. jannnn, 06.10.2012 #13
    jannnn
    jannnn Fortgeschrittenes Mitglied
    Wird bei der Installation irgendwas gewiped? Oder kann ich die rom ohne probleme drüber bügeln?
    Wie sieht es mit dem counter aus?
  14. xmrr3dx, 06.10.2012 #14
    xmrr3dx
    xmrr3dx Moderator Team-Mitglied
    Es wird nichts gewiped. Einfach drüber. Der Counter bleibt auch bei der 1 falls Du gerottet hast.
  15. jannnn, 07.10.2012 #15
    jannnn
    Nee habe ich noch nicht. Muss ich wohl erst machen oder?
  16. xmrr3dx, 07.10.2012 #16
    xmrr3dx
    Ja ohne Root keine Coustom ROM wie OMEGA
  17. Partystoned, 07.10.2012 #17
    Partystoned
    Partystoned Erfahrener Benutzer
    Hallo Leute,
    Das Omega Rom läuft absolut ohne Probleme ;)....
    Die Multi Fenster Ansicht hat echt was gutes ;)... Muss man sich zwar etwas dran gewöhnen aber kann man gebrauchen ...
    Gruß Partystoned
  18. Brunnebutzer69, 07.10.2012 #18
    Brunnebutzer69
    Brunnebutzer69 Erfahrener Benutzer
    Hallo, Ihr Flasher,
    Wo gabs denn nochmal eine schrittweise Anleitung für Omega und von wo habt ihr die Version 3 downgeloaded?
    Danke Euch
  19. xmrr3dx, 07.10.2012 #19
    xmrr3dx
    Brunnebutzer69 bedankt sich.
  20. Aponatur, 07.10.2012 #20
    Aponatur
    Im ersten Post findest du auch den Link zum Download-Center (riesengroß :laugh:)
    Ich empfehle jedoch die Torrent Variante (nicht Deposit-File), da sie deutlich schneller geht!
    Genau die Anleitung gepostet von xmrr3dx folgen. Dann hast du das CWM und dann über das CWM die heruntergeladen Omega.zip flashen und schon hast du das ROM am laufen.
  1. omega rom note 2
  2. omega rom note
  3. omega note 2
  4. rom omega cho note 2,
  5. download manager version 4.1.1 n7100 xxalie,
  6. omega room note2,
  7. n7100 modem xxufne1,
  8. omega.rom for note 2,
  9. themes for note 2 kitkat,
  10. rom omega note 2,
  11. samsung gt-n7100 themes download,
  12. rom stock 4.1.2 cho note 2 n7100,
  13. N7100 xxAlie download,
  14. omega rom,
  15. rom omega cho note2
