manne49
Stammgast
- 171
und es hört nicht auf!
Stelle mal kurz ein rom von kmokhtar79 vor,habe es noch nicht geteste,werde ich aber.
General Features
Android M 6.0.1
Based on G935FXXU1APD3 Official Firmware for GALAXY S7 EDGE (SM-G935F)
Added Note 5 features
Rooted with Superuser 2.74 (System Mode)
Optimized, Deodexed, De-Knoxed
Installed Busybox 1.24.2
Init.d Support
Debloated
ROM Control
Sound Control
OTA Update
Supporting all snapdragon variants
Extended Power Menu
Disabled Signature checks
Enabled "Choose app to complete action"
Enabled all apps in Multiwindows
Private mode
Enabled outdoor mode toggle in Settings>Display
Enabled Touch key light duration option in Settings>Display
Added Torchlight
Modded Messaging App
Disabled Volume Warning on Headphon
Added Multiwindows
Added Toolbox supporting up to 12 apps
Added Floating message
Added Omini switch, amazing multitasking app
Added UPSM Manager
Added GalaxyIconThemer
1000 custom fonts
Added FasterGPS for better GPS lock based on region
And maybe more that I cannot remember now...ROM Control
UI Mods
Beat Audio Settings
Viper4Android Settings
Dolby Atmos Settings
Note: Switch off Beats Audio and Dolby Atmos on speakerAroma Setup
Wipe data
Multi CSC 99 choices
Sound mod: Stock/AryaMod Premium Sound Control
CSC Mods
Enable/Disable Sub Symbol on Keyboard
Enable/Disable Exiting Browser Confirmation Pop-up and menu
Enable/Disable Home Button in Browser
Enable/Disable Call Button in Contact List
Enable/Disable Call/Message Block Menu in Settings
Enable/Disable Data Usage View On QuickPanel
Root permission and Custom recovery (PhilZ Touch 6.48.4 or twrp-2.8.7.0) is required for flashing any custom rom so make sure you are done this part.
Make sure your phone is fully charged to 100%.
Now follow as below:
Download the ROM zip and make sure md5sum is matched
Flash odin latest modem and bootloader from here, courtesy @jcadduono
Boot the phone into Recovery Mode
Do a FULL wipe: Dalvik Cache, Cache, Data, System even if coming from a port rom
Flash rom
The first boot may take 15-20 min
Download
https://romhut.com/files/2114
Ein Bericht wie diese Rom läuft reiche ich in kürze nach.
Eine 2te Version!!
[ROM][TW][Aroma][OTA]AryaMod ROM Port S7Edge Port V2 [26 May 2016] - Post #1051
General Features
Android M 6.0.1
Init.d Support
Debloated
ROM Control
Sound Control
OTA Update
Extended Power Menu
Private mode
Added Torchlight
Added Multiwindows
Added UPSM Manager
1000 custom fonts
UI Mods
- Statusbar View
- Battery bar Settings
- Hidden Buttons
- Statusbar Icon Toggles
- Signal Position
- Toggle Multiuser Avatar (SystemUI restart required)
- Custom third button in Notification panel header
- Toggle Single Swipe for Quick Settings Panel from left side
- End Call Delay
- Incoming Auto call recording
- Outgoing Auto call recording
- Advanced Function Menu (hidden settings)
- Power Extended menu (toggle 10 option)
- Customize hard key buttons
Home Button Settings
Toggle Home wake
DoubleTap Assignment
DoubleTap Application
LongPress Assignment (20+ choices)
LongPress Application
Left Capacitive Key
ShortPress Assignment (20+ choices)
Right Capacitive Key
- Toggle Torchlight in lockscreen
- Torchlight timeout
- Volume Key Cursor Control
- USB Plug/Unplug Wake Screen
- Toggle Ambient Display
- Volume Rocker Music Control
- System Sound toggles
- Full battery notification
- Low battery notification
- Toggle Mobile Data popup
- Toolbox Settings
- UPSM Manager
- OmniSwitch
- SuperSu
- OTA Updates
- Faster GPS
- Galaxy Icon Themer
Beat Audio Settings
Wipe data
CSC Mods
Flash rom
Download
Eine 2te Version!!
