[ROM][N910F][6.0.1] *30.01.17* Dr.Ketan ROM I MM N5/N7 Port I Theme Store I M12
LocDog
LocDog
Hinweise für User:
Weder Android-Hilfe.de oder ich sind für Schäden an eurem Gerät verantwortlich.
Die Installation der ROM geschieht auf eigene Gefahr.
Haltet euch an die Installationsanleitung!
Dr.Ketan ROM I MM N5/N7 Port I Theme Store by dr.ketan Version M12
XDA Link:
Screenshots
Angewandtes Theme: sd-Black
Features
ROM Features (This is for Lollipop version. For Marshmallow - Read Changelog post of respective version)
Inbuilt features
- N5 ported for Complete theme support
- Edge features (People edge and App edge)
- 300 fonts enabled
- All Language enabled
- Multi DPI. (No S-view support) - Right now not all app moded as well this mod is in beta stage and some glitches expected. Launcher is moded for no DPI and camera not fully.
- Ad Free (dr.Ketan Tweak)
- Auto/Manual Call Recording - dr.Ketan Call record separate app
- Power Menu -5 Way Reboot mod with sound mode
- CSC features - Separate app for CSC features
- All App Multi Window (optional in ROM Control)
- Camera Hack - Use camera with Flash at low battery + Camera shutter sound toggle
- Call/SMS block
- Floating Msg
- Safe media volume warning disabled
- No Increasing ring tone. (Dr.Ketan Tweaks)
- Memory Clean option on expanded notification with switch Also Color can be set.
- Mute/Vibrate/Sound option in power menu.
- NFC hack with screen off (ROM Control)
-.Appoops (permission manager) Settings-LockScreen and security - Application permission
- No call delay mode (preactivated)
- Potato clock mode.
- Sound boost (Dr.Ketan Tweaks)
- Battery Mode. Change battery mode on the fly from 3minit(default)/Stock/No battery (Dr.Ketan Tweak-Battery Mod)
- Advanced Messaging features
    • No SMS to MMS conversion
    • Add recipient upto 200
    • Backup/Restore messages
    • Group and schedule messaging
    • Priority sender
    • Delay sending option
- Auto Start (Disable packages you don't wish to auto start on boot)
- Visibility Toggle for Bluetooth and Toggle statusbar icon
- Status Bar virtual key for Menu and Home (Toggle from Extra settings)
- Infinite scrolling for launcher with Toggle (Extra settings)
- USB Debugging ON by default.
Dr.Ketan Tweaks
This having four parts.
1.Toggles
    • Heads up notification - Enable/Disable Headsup notification.Requires reboot.
    • Fast Chargeing- Toggle fast/Slow charge
    • Auto GPS - Auto On/Off GPS with some pre define app using GPS like map sygic note etc [You require to enable monitor service from accessibility to use this]
    • Auto Wifi - Turns off wifi if remain disconnected > 10min
    • Auto bluetooth - Turns off BT is remains unpaired for > 10min
    • Smart Network - Auto off network after 30 sec of screen off, Auto on after screen on (Only if data connection was on when screen turned off)
    • Media scanner - Enable/Disable media scanner. If you disable, your media library won't update to gallery/music
    • Popup blocker - disable some misc popup like battery full etc
    • Login security - capture screenshot if unauthorized attempt to unlock
    • Ad free - Ad free on/off
    • Auto 2G - After 30 sec of screen off it turns network mode to 2G. It auto connect to 3G/LTE when screen on >10 sec
    • Auto data - Turns off data connection when connect to wifi.
2.Tasks
    • EFS backup Now you can make EFS backup with this option without need of extra tool.
    • SD card Fix
    • Flash recovery
    • Enable 360 rotation.
    • AutoMemory
    • Auto scan - Reverse media scan. It enable media scan when you connect to USB and disable when disconnect.
    • Call time reminder* - 1min reminder tone while you are on call
3.ROM
    • Meet here - Location finding utility (like find your car in parking)
    • Battery mode - Select battery type Stock/3minit/None (Default is 3minit)
    • Clock mode - Various option related to clock like Clock style/AM-PM style/Date style and format/Color / Alignment like Lt-Rt-Central
    • [Network type (experimental) - Select 3G only / 4G(LTE) only or Auto (LTE/3G/2G) - New option for 3G only added
    • Quick Panel Toggles - Enable 30 QP toggles and choose number of scrolling toggles
    • Launcher home scroll - Enable/Disable
    • Edge Features - Enable/Disable
    • ROM control - Have many features. Read below for more details.
    • Misc modes and colors - Sorted accirding categories, Read below for details
    • Torch - Long press Vol up while screen off)
4.Help
    • General Info
    • Update/Bloatwares/Fix downloading area : you can find various addon/bug fix and bloatware which removed from ROM here.
ROM Control (Dr.Ketan Tweaks - ROM -ROM Control)
    • .Dr.Ketan App manager added. Here you will see list of all my apps available in ROM. If you are not using any of those apps you can hide (freeze) from here. To hide - long press To unhide - Tap.
      Some application functions doesn't require to monitor and you can hide after using it's functions. for example. If you are using Manual call rcord, you can hide Dr.Ketan call record once you activate it. For auto call record you can't hide. You can Hide DPI changer after applying DPI (Auto reset DPI option won't work). For Extra settings - Only Auto Memory features requires to keep it, for all other features you can hide after setting up. CSC features, Sound mode (available in aroma) you can hide after using required features.Toolbox SideKey requires to keep if you are using 'Shake' feature of it. Virtual key requires to keep if you are using it.
    • Temporary Unroot option added to ROM Control. You can select it to unroot device temporarily and you can use device to perform certain operation which not allowed on rooted device e.g. Encryption/Using some secure apps which not allowed to use on rooted device. To re gain root you simply requires to reboot device.
    • .Key Remap - section added. Which have following three options.
      A.Menu key - You can remap Menu key to Menu/Recent (ROM default is recent)
      B.Double Press Home. It is same as before. You can assign it to camera/Custom app
      C.Long Pressing Home. - You can select any app/shortcut/activity with long pressing home.
      To Use this option you need to select default action as 'LP Home' with long pressing. If you already set other clear it from settings-Applications/Default App then long press home and select LP Home.
    • NFC hack : Nfc with screen off
    • Enable LTE : If your device is 4G and missig lte/4g option in network type, you can use this. This is not a tool to display LTE instead of 4G
    • Enable all app multiwindow.
    • SecretCode Dialer - As it is common issue of broken MMI code. So in case secret code is not working with regular dialer here option added to ROM Control.
      You have to select 'Type code here' this will open popup box and you have to enter code there which you want to dial but without prefix *# OR Suffix #
      For example you want to dial *#06# then you need to simple input 06 same way if you want to dial *#0*# then you need to input 0* only.after than check and apply. Also there is 62 examples available for different codes (Not tested all)
    • Optimization Tweaks
      It's in three categories + Info page for details of tweaks
      1.General -
      1. Boost Device
      2. Device Cleaner
      3. I/O Tweaks
      4. Aggressive Seeder
      5. SQlite optimization
      6. FS Trim
      7. ZipAlign
      8. Play services and other services fix (causing wakelock and battery drain) applied with ROM Control. Fix requires to apply on every boot and while you finishing setup, ROM control should ask for su permission. Also you will see toast message about services fix applied after every boot. In case something went wrong and you can't see this message, you can force fix from ROM control.
      2.RAM Management
      1. Disable Debugging - Disable debugging improve battery life.
      2. RAM Management .A.Balance B.MultiTasking C.Gaming
      3.Build.Prop Tweaks
      1. Battery Improvement
      2. Fast Booting
      3. Better Image quaity
      4. Disable Logcat - To improve performace.
      5. Net Tweaks A/B
      6. Better Scrolling experience
      7. Better Video Streaming experience
      8. Smooth UI - Overall smooth UI
      9. Voice quality - enable Wideband amr support.
    • Sound Mode - This is Sound boost mode and you can boost sound with predefined level (mild/High) OR can use custom level of boosting according requirement.
    • Long Press duration Reset - Select desired value for long press duration. Default is 500ms and you can select it from 100-500ms according your requirement.
    • NetFlix Fix - To fix rendering netflix videos
    • Full Screen Caller ID Enable/Disable
Misc Modes and colors (Dr.Ketan Tweaks - ROM)
    • SB colors - Internet meter colors + Memory view color
    • StatusBar mods
      1. Lt Virtual menu key
      2. Rt Virtual power key
      3. Rt Network meter
      4. Lt Network meter
      5. Hide blutooth (Once need to toggle bluetooth to take effect)
      6. Hide Alarm (Once need to toggle alarm to take effect)
    • Lockscreen Mods
      1. LockScreen rotation
      2. Pedometer on lockscreen
    • Increasing ring tome Toggle
    • Memory View Toggle (Use RAM display near brightness color)
    • Email Security hack
Auto Starts - Settings - Auto Starts.
You can control which application to not to start automatically with boot. Usually you should disable all App for which you don't require notification OR needed to work in background. For system App just be careful and don't do if you are not sure what exactly it does.
- Virtual key (available separately in aroma)
How to use virtual key :
Open Virtual key - Tap on Right/Left/Center button to enable corresponding virtual keys. (long press to disable)
To assign keys- scroll selected action from tab and tap on selected item to set (message will be displayed on successful assign)
Now long press bottom corner/Center of screen to perform selected (assigned) action. - Here is graphical presentation for location.
Each key have following options to assign
    • None
    • Browser
    • Calendar
    • Contact
    • Home
    • Menu
    • OK Google
    • Power (Long Press power action)
    • Recent
    • Search
    • Sleep (Power button to turn off screen)
    • Screenshot
    • S-Voice
    • Sattelite view
    • Multiwindow
    • Battery
- CSC features(some features not tested) (available separately in aroma)
    • Enable camera during call
    • Enable Popup Notification
    • Shutter sound Menu
    • Enable Sub Menu Symbol KB
    • Raise name lenth limit
    • Max speed dial 100
    • Enable call button
    • Enable export to SD
    • Message
    • Raise recepient limit 999
    • SMS to MMS threshold 999
    • Enable folder view
    • Enable font features
    • Enable schedule msg
    • Disable phone nu formatting
    • Phonebook digit matching
    • Launcher Rotation
    • Web exit option
    • Wifi client 10 for MobAP
    • MultiWindow addOn App
    • Calender export
    • Email White BG
    • Clock enable Auto on off menu
    • Voice call waitingtone 60
    • National Roaming Icon enable
    • Web default desktop site
- DPI Changer. (Separately available in Aroma)
Change DPI on the fly from available range. Read info insede application for info
- Air Command Shortcut - Use AirCommand without S Pen (Smart select still need spen)
- All Rotation (optional in aroma)
- Lock Screen rotation with Toggle
- Email Security hack
- Hide/Show toggle for Statusbar Bluetooth icon. (Extra Settings)
- SideKey - N4 side key panel working (No option to edit)
- Toolbox - S5 Toolbox with ability to edit upto 12 application.
- Init.d Support
There are multiple ways to enable Toolbox and SideKey
1.You can enable 30 toggles which have both toggles
2.There is separate application available 'Toolbox Sidekey' in ROM which have option to enable both application separately as well you can edit Toolbox app.
3.One more facility included in Toolbox Sidekey application is shake to enable/Disable Toolbox/Sidekey/Both
Once you enable this option you can just shake device Lt to Rt while display is ON to toggle Toolbox/SideKey/Both depending on your selection.
Changelog Version M12
- AOD Fix - No intermittent display.
- Screen Mirror Fixed
- Enable VoLTE option available by default in ROM Tool.
- New Ux Touchwiz with all glitches related to TW fixed
- Contact and msg lag happen to some users should get fix
- Overall touch and general performance should be better.
- additional option will be available if you need extra option for smart manager
- ScreenRecord option with shortcut
- ROM tool updated with Gallery fix with two options 1.One time fix 2.Fix on every reboot
- Youtube with HD should prefixed
- Reboot confirmation message removed from powermenu
Standard Installation
1. Vor der Installation TWRP installieren Und einen Full Wipe durchführen + auf der externen SD Karte die Ordner "Android" "Android.Secure" und "Lost.Dir" löschen. PFLICHT!
Damit auch wirklich alle Reste der vorherigen Rom weg sind und alles auch ohne Probleme läuft.
2. Datei 01 runter laden, entpacken und mit Odin in AP flashen. (Ist OJ3 Bootloader und Modem in einer Datei.) Danach wenn Handy neu startet direkt ins Recovery rein (TWRP)
3. Datei 02 in TWRP flashen (Rom) danach direkt ohne neustart 03 ( Hvitamin Kernel + Fix).
4. Handy neu starten und einrichten incl Essential Fix (drauf achten der kommt irgendwo zwischen Google Konto einrichtung und Samsung Konto einrichten.)
Bugfix
Hier Updates / Bugfixes die nach dem einrichten gemacht werden sollten (Gallerie und SCloud)
Im Ordner Updates / Bugfixes findet ihr 2 Dateien(APK) Einmal ein Update für die Samsung Cloud damit ihr eure Daten vom Samsung Konto wiederherstellen könnt und auch später Syncen könnt. Und die andere ist ein Update für die Gallerie damit Anzeige fehler verschwinden falls ihr die habt.
Bei der Standard Samsung Tastatur gibt es ein Problem mit dem Wörterbuch
Guckt das ihr bei der Handschrifterkennung auch Deutsch eingestellt habt und nochmal neu runter ladet. Danach funktioniert die Rechtschreib Prüfung auch beim Tippen.
Bei den Themes gibt es das Problem das nach einem Neustart vom Handy das Theme verloren geht bzw Teile davon. Und ihr das Theme wieder manuell amwenden müsst. (unter verwendung des xceed kernels)
1. Wählt das Standard Theme und Entfernt im Theme Store alle Themes icons und Hintergrund Bilder.
2. Entfernt mit einem Root Browser alle "Themes" Ordner in /Data/App/
3. Entfernt den "Overlays" Ordner in /Data/
4. Erstellt einen neuen "Overlays" Ordner an gleicher Stelle und gebt ihm alle Berechtigungen (777)
5. Geht auf Einstellungen und Anwendungen und Alle Apps. Dort sucht ihr den Theme Store und löscht bei diesem den Cache und alle Daten.
6. Handy neu starten.
7. Nach installation neuer Themes werdet ihr diese nun nach einem neustart auch beibehalten.
Wichtig: Diese lösung erst Anwendem nachdem ihr mal ein oder 2 Themes installiert hattet und angewendet habt und neu gestartet habt. Da es vorkommen kann das ansonsten der Theme Store seinen dienst verweigert mit ständigem "FC"
Downloads:
Hier findet ihr alle Dateien.
Diesen Link nicht in anderen Foren Posten, sondern bitte den ganzen Post von mir verlinken.
Bekannte Bugs:
- AOD
- Finger Abdruck Sensor (Alternative Play Store App verwenden)
Telegram Gruppe für die Schnelle Hilfe:
Join group chat on Telegram
Reaktionen: TeeKayDodo, manne49, Mystic und eine weitere Person
Hallo
Ich hab mir bei xda diese Rom gezogen die ja eigentlich für das 910G ist, aber es wird super erklärt wie es auf unseren 910F funktioniert. Es läuft super und der Akku ist auch sparsam, ich komm über den ganzen Tag.
Ich kann euch das nur Empfehlen:thumbsup::thumbsup::thumbsup: aber......
Hier noch der link zum download N910G
Ihr müsst diese version N910G pb6 MM Dr.Ketan ROM M6 XDA ziehen.
Ja diese 910G Version ist für unser 910F Version.
Ihr müsst COJ3 mit TWRP installieren
dann H-Vitamin Kernel und den M6 fix für Note 4neu installieren
Danach ca. 20min warten und schon könnt ihr glücklich sein.
Reaktionen: Traubie
Du kannst gerne einen ROM Thread draus machen, dann schieb ich Dich sehr gerne zurück :)
Ok ich werd nochmal lesen. Sorry
Beschreibe am besten die ROM mit ein paar Worten, stelle Features, einen Changelog und v. a. eine Installationsanleitung und einen Downloadlink bereit.
Am besten an ein paar anderen Threads dort orientieren ;)
Tut mir leid, für sowas bin ich zu dumm. Lösche es einfach raus.
Ich wollte nur anderen mitteilen das es eine wunderschöne Rom gibt.
Trotzdem danke.
Was ist das denn für eine Antwort??? Dann bittet man jemanden das ROM Thread zu führen. Nicht erst groß auftrumpfen und dann zurück ziehen. Aber nun, jedem das seine.
Mich würde allerdings die hoch gepriesene Rom interessieren, aus zeitlichen Gründen ist es mir allerdings nicht Möglich den Thread zu führen, muss auch sagen, dass mangelnde Englisch Kenntnisse den Rest dabei tun.
Bitte versteh mich, auch mein Englisch ist besch... und kann doch nicht einfach von einem in ein anderes board kopieren. Mir fehlt da kompl. die Kompetenz dazu.
ich spiele auch mit dem Gedanken mir eine Custom Rom auf mein Note 4 (910fF)zu spielen,
Wie sieht es denn mir der Funktionalität des S-Pen aus? Ist sie uneingeschränkt unterstützt? Ich benutze ihm nämlich sehr oft und gerne.
Vielen Dank
Stephan
[Hallo
also ich bin sehr zufrieden und auch der S-Pen funktioniert super, ich schreib gerade damit. Ich hab noch ein ein Update dazu gemacht, das gibt's bei Dr. Ketan auf der Seite. Auch sonst funktioniert alles einwandfrei z.b. die die S7 funktionen.
Ich hab bis jetzt keine fehler festgestellt. Es läuft und läuft, ich hoffe das ich vielleicht noch dazu komme die Bilder hochzuladen.
Hey, sieht cool aus, aber warum steht denn als Modellnummer 935F?
Hast du auch ein Bild vom S-Pen Menü?
Das sieht genau so aus wie beim Note 4 Original. Die Modellnummer ist das S7 edge
Ok, das sind ja eh eine menge threads die man das lahm muss!
Kannst du mir detailliert sagen welchem Dateien du geladen hast? Ich bin jetzt etwas durcheinander, weil ich immer mit 910g lese. Ich habe aber dafür 910g, wie du. Ich habe schon einige Handys geflash uns kenne mich etwas aus aber mir der richtigen Auswahl der Dateien tue ich mich Hefe schwer, weil mein englisch auch nicht wirklich gut ist.
Danke schon mal
[doublepost=1466009928,1466009530][/doublepost]Ich habe bis jetzt folgendes gezogen
BL_N910FXXU1COJ3.tar
CP_N910FXXU1COJ3.tar
M5 Fix für Note 4
H-Vitamine Kernel
vorher muss ich aber noch eine recovery flashen,.oder? Welche Verion hast du benutzt?
Was hast du jetzt? Ein 910G oder 910F?
[doublepost=1466010194,1466009971][/doublepost]Du musst noch hier Laden N910G nimm die MM version
Ich hab eine 910F ohne Branding
Hallo
Bin mir nicht sicher ob ich es richtig verstanden habe,bei dr ketan rom 910G runterladen und flashen und dann gleich M5 Fix hinterher oder? hab auch Probleme mit englisch.
dumbo1 schrieb:
Jetzt noch einmal, bin wohl jetzt völlig durch den Wind! :)
- Erst eine Recovery installieren (welche Version)
- dann die MM Version des 910G
- dann die beiden COJ3 Dateien
- H-Vitamin Kernel
- M5 Fix für Note 4
Ist das jetzt die richtige Reihenfolge oder habe ich etwas vergessen oder durcheinander bekommen? ,
Als erstes über Odin den bootloader und modem installieren dann die rom und die fix und den Kernel. Das hab ich im twrp nacheinander ausgewählt und dann booten. Dauert ca 15min.
Ja okay und welche Version von twrp hast Du genommen? Hast du evtl auch einen link?
Die Reihenfolge in odin mit twrp , bootloader und Modem ist eigentlich egal oder?
Ich hab twrp 3.0.2.0 drauf die bekommst du ja hier board
Reaktionen: Traubie
LocDog
handynutzer2016
LocDog
Nufan
Nufan
Lexuzz
manne49
manne49
