[ROM] VillainRom AOSP R2 - mit Advanced Power Menü
boshot
boshot
Enthusiast
1.070
This is a ROM compiled directly from the Android source code repo (branch = android-4.0.1_r1.2 (ITL41F), with Google apps/permissions, etc added. It is of course not odexed, so first boot will take a while. Subsequent reboots will be much faster. Here are a few screenshots, as I know how many of you guys won't download a ROM unless there are screenshots in the OP :
R2 Changelog:
Rebased to aosp 4.0.3 IML74K
Phone and Messaging shortcuts on lockscreen (thanks to Xoomdev)
FB sync (Thanks to Romanbb)
Added Screenshot to powermenu (thanks to CM)
Fixed Calendar Sync
Added custom kernel:
tuned governors (ondermand and interactive)
OC to 1.35Ghz
UV interface (use setcpu)
Github kernel source (GPL):
https://github.com/richardtrip/android-omap-tuna
R1.1 Changelog:
- Fixed Root Issue (mini root fix or full ROM available)
R1 Changelog:
- Slightly modified AOSP based on android-4.0.1_r1.2 ITL41F (compiled from source, not based on stock ROM)
- Includes STOCK ITL41F kernel and NO recovery image (keeps CWM in tact)
- Added Google apps & permissions
- Full adb root, and su & busybox binaries + latest Superuser.apk
- Added REBOOT option to power menu (see above screenshots)
- Added RECOVERY (reboot) option to power menu (see above screenshots)
- Enabled 'Dreams' - Android screensavers, accessible via Settings>Display
- Increased minimum dalvik heap start size to 16mb for performance testing
- Defaults to live wallpaper
- Faster than stock.
- Build defaults to English - Great Britain (sorry ;))
- png optimized and zip-aligned all APKs
- Included working LED Flashlight application
- New VillainROM bootanimation
Installationsanleitung:
- Rom auf die SD kopieren
- in die CWM booten
- Full wipe (data/cache/dalvik)
- Install zip from..
- reboot (kann etwas länger dauern)
Beim ersten Boot, gibts ein Auswahlmenü:
1. com.android.provision.Default.Activity
2. Setup Wizard
Bei 1. wird der Google Setup Wizard übersprungen und das System bootet ganz normal
Bei 2. kommt (logischerweise) der Google Setup Wizard
Das ist vom Rom Ersteller so gewollt >
This is not a bug, it's a feature!
Download Villain Rom R2:
http://xda.richardtrip.org/samsung/galaxy_nexus/Villain_Maguro_R2.zip
Mods:
overclocked GPU Kernel:
http://xda.richardtrip.org/samsung/galaxy_nexus/kernels/Villain_Maguro_Kernel_GPUOC.zip
orginal R2 Kernel: (wenn man sich den GPU OC geflasht hat und wieder zurück will)
http://xda.richardtrip.org/samsung/galaxy_nexus/kernels/Villain_Maguro_Kernel_GPUNOOC.zip
Pläne für die Zukunft:
- Add VillainROM OTA update notification system
- REMOVE Google OTA system
- Landscape launcher additional functionality
- % Battery mod (100 images)
- Brightness mod (need to investigate)
credits@xda
Link:
[ROM] VillainROM AOSP R1.1 (ITL41F) GSM ONLY - Featuring Advanced Power Menu Options! - xda-developers
Reaktionen: Alex.Sikes
Installation hat einwandfrei funktioniert. Info: Ich habe noch zusätzlich einen wipe battery stats durchgeführt.
Läuft sehr flüssig und stabil. Ist zur Zeit noch sehr nah am Stock-ROM. Die Zukunft wird mehr bringen.
Alex.S
Werds mir am Wochenende auch mal drauf tun.. VillainRoms waren bisher immer sehr gut.
(hoffe Battery percentage usw kommt bald)
Oder gehn evtl. he_stheone seine mods?
Ich würde da keine fremden Mods einspielen. Das könnte bei späteren Updates zu Problemen führen.
Der Grund für meine Annahme: Der Entwickler vom VillainROM will ja noch ein OTA-Update für sein ROM einbauen und das Original Google OTA deaktivieren.
Für solche Mods ist das ROM von Drew Garen eher geeignet. Das werde ich übrigens auch noch Testen. Sieht von den Specs sehr vielversprechend aus.
Alex.S
Was bringt es ein pures Android mit einem Rom zu flashen ? Also beim S2 wollte ich es möglichst "nackt" und schneller als direkt von Google geht es kaum oder ? Beim S2 ok, aber wo ist jetzt noch der Vorteil? Danke für Infos
von meinem Galaxy NEXUS
Es gibt halt immer noch zusätzlich interessante Features, wie z.B. das advanced Power Menü, oder der 1%Battery Mod. Interessant sind auch UV/OC Features in Custom Kernels, etc...
Viele Grüße
Handymeister
Ok Danke und was kann man mit einem extended Power Menü machen ? Ist das Villain Rom ein Rom welches sich empfehlen lässt?
Zum Beispiel direkt ins CWM booten ohne die entsprechende Tastenkombination drücken zu müssen.
Ist halt sehr komfortabel und wenn man sich einmal daran gewöhnt hat möchte man diese Annehmlichkeit nicht mehr missen. ;)
Edit: Guck dir mal die entsprechenden Screenshots aus dem XDA Thread zu dem Rom an: KLICK
Die verdeutlichen das am Besten.
Ok Danke ich werde es mir mal anschauen, war gerade froh, dass ich auf Standard bin und den Bootloader gelocked habe ;) hatte ein MM Gerät. Irgendwie reizt es mich aber. Ich habe nur immer Angst, dass es dann plötzlich eingestellt wird vom Dev. Beim S2 hatte ich öfter mal das Problem ;)
Für Interessierte: Ich habe mal einen Benchmark, CF-Bench Pro; laufen lassen. Hier die Ergebnisse:
| ROM: Villain R1.1 | CPU: 1200MHz | Governour: Interactive |
Native MIPS: 1200
Java MIPS: 242
Native MSFLOPS: 585
Java MSFLOPS: 291
Native MDFLOPS: 360
Java MDFLOPS: 222
Native MALLOCS: 23792
Native Memory Read: 3228
Java Memory Read: 546
Native Memory Write: 1274
Java Memory Write: 1033
Native Disk Read: 630
Native Disk Write: 9
Native Score: 11228
Java Score: 3533
Overall Score: 6611
Anmerkung: GPU Werte sind in dem Test nicht mit eingeflossen, da der Benchmark beim Testen nicht auf die GPU zugreift.
Alex.S
In absehbarer Zeit sollte es was neues zu dem Rom geben..
Nathan bei xda:
Its taking a little longer than expected due to new small issues cropping up, but when I get all these issues ironed out, we should have a very nice AOSP rom here.
For the guys saying this is not AOSP due to the camera working, I assure you, it is.
I have now added a few additional features and have just set a build going. Once its done and I have finished my actual work for the day, I will look at the smaller issues such as calendar sync.
Bear with me for now guys; I'll definitely be keeping this ROM updated as I am running it on my main daily phone. I don't want a buggy daily driver
@Alex
Nix gegen dich, aber Bennchmarkwerte gehn mir sowas von am Allerwertesten vorbei, das glaubst gar net :)
Wenn das Rom sauber, flüssig und mit gutem Akkuverbrauch läuft, könnte da von mir aus ne 0 rauskommen.
Aber trotzdem schön das du sowas postest, manche nehmen das ja als Entscheidungshilfe, welches Rom sie nehmen sollen.
Ahhhh soll ich es flashen oder nicht :D
Wie sieht es aus boshot, hast Du es am laufen ? Läuft es flüssiger als Stock ?
Ach ja..Benchmarkwerte sagen nichts und sind mir auch egal ;)
Hats kurz drauf, sicherlich nicht schlecht..aber hat noch paar kleinere Bugs..z.B Kalendersync.
Wenn die überarbeitete Version kommt werd ichs sicher nochmal testen, aber so den Mehrwert hat ich jetz auch nicht bemerkt..
Bin wieder zurück auf deodexed stock mit stock-mod kernel.
Bin damit absolut zufrieden.
Aktuell spiel ich bischen mit Set CPU an meiner max. Frequenz (schwank zwischen 700 &. 920mhz) und den Spannungen aller Frequenzen (UV).
Danke für die Infos, aber UV ist nichts für mich, es ruckelt ja jetzt schon mit Stock manchmal.
Ich bin ja mal gespannt, werde das hier und CM9 dann im Auge behalten. Weust Du zufällig was bzgl. SGN und CM9 ?
Die teilweisen Ruckeler liegen wahrscheinlich am govenor..probier mal ondemand.
Zwecks CM9:
Codeworkx hat schon die neuste Version davon auf seim Gnex laufen..*leicht neidisch bin*
(mal meine Kontakte spielen lassen ;))
Top Danke für die Info ! Leider bin ich noch so hin und her gerissen ob sich die ganze Arbeit lohnt mit dem rooten usw. denn purer als Google geht ja kaum ;)
aber OK ich will ja jetzt nicht zu OT werden, aber vielleicht kannst Du ja so einen CM9 Info Thread aufmachen?! Wäre super !
Neue Version: VillainROM AOSP R2
Download-Mirror: World-Of-Nexus
Alex.S
Reaktionen: boshot
schnueppi
schnueppi
schnueppi
MoRtAl
Pierro
Pierro
Pierro
