[ROM][XXKI3] GaLaXyZeRoS2 V0.1 26/10/2011 more as smooth and very goood battery!!
Masta_Gee81
Masta_Gee81
Enthusiast
5.396
Quelle :[ROM][XWKL1] GaLaXyZeRoS2 V0.6 02/01/2012 more as smooth and very goood battery!! - xda-developers
[ROM][XWKK5] GaLaXyZeRoS2 V0.4.5 02/12/2011 more as smooth and very goood battery!!
This is my first creation for GS2
GaLaXyZeRoS2 V0.4.5
Features:
- Based XWKK5
- Deodex
- Zipaligned
- Tweak smoothness
- Tweak for battery drain
- Tweak build.prop
- Tweak minfreehandler
- Optimized some apps
- Removed more Samsung apps
- Add Apps
- Rooted
- Kernel SpeedMod K2-18 test2
- Modem KI1
- Theme Jkay v13.2
- Go launcher with Go Locker and more Go apps
- Mix icon from MIUI and ICS
Changelog v0.2:
- Based on XXKI4
- Little change on theme
- Kernel update to SpeedMod K2-16
- FuguTweak
- Tweak kernel, SQL Boost, 3G, ecc
- New camera.apk with hack audio
- Flash player 11.0.1.153
- Updated Gmail, market, GoLauncher
- Delete Cianfire3D
- fix icon h+
- New battery indicator (more visible now)
- Add AOSP Keyboard
- DSPManager
Changelog v0.3:
- Based on XWKJ2
- New siyah kernel 2.1.1
- UV script
- Touchwiz4.5 and TWmanager
- Fix Gapps problem
- Full trasparent statusbar
- Lockscreen AOSP modded
- Add BLN support
Changelog v0.4
- New base XWKK5 android 2.3.6
- Kernel SpeedMod K2-18 Test2
- Updated Superuser e bin
- Maps 6
- Jkay 13.2
- Add ICS
- Add Orologio ICS
- Add Musica ICS
- Little changes on theme and statusbar
- New Font
- Removed launcher Touchwiz
Changelog v0.4.5
- Fix audio bluetooth
- Fix language selection now select automatic
- Little change in theme
- Add rolletube
- Updated titanum backup e goSms
- Add folder Wallpaper in SDcard
Installation:
- Download rom
- Put downloaded zip file on your internal sdcard
- Reboot into recovery
- Select Install zip from sdcard
- Select Browse for zip on sdcard
- Select rom and flash it
- Have fun!!!
ATTENTION!!!
New rom is Full wipe, backup all fine before flash!
Extras:
- Samsung Apps
- Battery
Ginger1
Vertical1
Orizzontal1
Addons
-TouchWiz 4.5
- Restore origianl font
- Camera hack audio
- Androidian statusbar
- Restore original theme
Info
The battery theme and other addons are compatible with all my rom!
Natürlich - Hast du den Release wohl verpasst?:flapper:
Ja das war Ironie falls du es nicht bemerkt hast:D Wenn man sich ein bisschen schlau macht, weis man auch das ICS noch nicht verfügbar ist, es ist überall zu lesen. Man könnte es auch an der Firmwarebezeichnung "I9100XXKI3" erkennen, dass es sich dabei um eine 2.3.5 Firmware handel und nicht um ICS:winki:
Hats schon wer drauf und kann seine Erfahrung zum ROM berichten?
Ich werde wohl noch warten bis die Ki4 oder Kj1 der ROm rauskommt ...
Und warum?
Habs mal installiert, läuft geschmeidig und ist atm recht gut.
Ok ... wenn du es sagst ... kam halt noch nicht dazu ...
Wollte eben warten bis der Entwickler die ROm weiterentwickelt ...
Und da wird dann demnächst eben die Ki4 oder die Kj1 anstehen .
Irgendwelche Bugs etc ???
Bis jetzt keine Bugs entdeckt.
Finde das der Akkuverbrauch recht ordentlich ist, und das will was heißen da ich momentan echt von den 2.3.5 ROMs von Samsung enttäuscht bin. Härte teste für das ROM ist dann eh der morgige Tag :D
Stimmt, KJ2 wäre dann das beste.
Reaktionen: Masta_Gee81
Ja berichte mal ... würde mich mal interessieren ... Danke !
Gut, dann berichte ich morgen Abend mal :D
Es hat noch ein paar Bugs.
Ein h+ Zeichen ist noch nicht im theme, da kommt immer das von Samsung. Ich hatte auch einige Probleme mit der SD Karte, hatte Siyah drauf und sie wurde einfach nicht erkannt...einen Freez und Reboot auch :/
Scheint aber noch ausbaufähig zu sein.
Danke Mad ...
also werde ich doch noch warten ...
greetz M@sta
V2 Online Ki4 ... siehe ersten Post
Greetz M@sta
Changelog v0.3:
- Based on XWKJ2
- UV script
- Fix Gapps problem
- Add BLN support
Changelog v0.4.5
- Add rolletube
Download im ersten Post !!!
Greetz M@sta
pro.aggro
beicuxhaven
beicuxhaven
Masta_Gee81
Masta_Gee81
Masta_Gee81
Masta_Gee81
Masta_Gee81
Masta_Gee81
