root problem
  • 16 Antworten
V
velikib
Halo! Ich hab ein problem mith root auf mein Note. Wen ich wersuche es mith DoomLord. Es meldet mier dieses problem!?
Easy rooting toolkit (v4.0)
created by DooMLoRD
using exploit zergRush (Revolutionary Team)
Credits go to all those involved in making this possible!
[*] This script will:
(1) root ur device using latest zergRush exploit (21 Nov)
(2) install Busybox (1.18.4)
(3) install SU files (binary: 3.0.3 and apk: 3.0.6)
(4) some checks for free space, tmp directory
(will remove Google Maps if required)
[*] Before u begin:
(1) make sure u have installed adb drivers for ur device
(2) enable "USB DEBUGGING"
from (Menu\Settings\Applications\Development)
(3) enable "UNKNOWN SOURCES"
from (Menu\Settings\Applications)
(4) [OPTIONAL] increase screen timeout to 10 minutes
(5) connect USB cable to PHONE and then connect to PC
(6) skip "PC Companion Software" prompt on device
CONFIRM ALL THE ABOVE THEN
Press any key to continue . . .
--- STARTING ----
--- WAITING FOR DEVICE
* daemon not running. starting it now *
* daemon started successfully *
--- creating temporary directory
mkdir failed for tmp, File exists
--- cleaning
--- pushing zergRush
1443 KB/s (23060 bytes in 0.015s)
--- correcting permissions
--- executing zergRush
[**] Zerg rush - Android 2.2/2.3 local root
[**] (C) 2011 Revolutionary. All rights reserved.
[**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
[+] Found a GingerBread ! 0x00000118
[+] Found a Samsung, running Samsung mode
[*] Scooting ...
[*] Sleeping a bit (~40s)...
[*] Waking !
[*] Sending 149 zerglings ...
[*] Waking !
[*] Sending 189 zerglings ...
[-] Hellions with BLUE flames !
--- WAITING FOR DEVICE TO RECONNECT
if it gets stuck over here for a long time then try:
disconnect usb cable and reconnect it
toggle "USB DEBUGGING" (first disable it then enable it)
--- DEVICE FOUND
--- pushing busybox
5177 KB/s (1075144 bytes in 0.202s)
--- remounting /system
mount: permission denied (are you root?)
--- checking free space on /system
0 KB/s (439 bytes in 1.000s)
df: /mnt/.lfs: Function not implemented
df: /mnt/secure/asec: Permission denied
--- Free space on /system : 34456 bytes
--- no cleanup required
--- copying busybox to /system/xbin/
/system/xbin/busybox: cannot open for write: Read-only file system
--- correcting ownership
Unable to chmod /system/xbin/busybox: No such file or directory
--- installing busybox
/system/xbin/busybox: not found
--- pushing SU binary
failed to copy 'files\su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
--- correcting symlinks
rm failed for /system/xbin/su, Read-only file system
link failed Read-only file system
--- pushing Superuser app
failed to copy 'files\Superuser.apk' to '/system/app/./Superuser.apk': Read-only
file system
--- cleaning
--- rebooting
ALL DONE!!!
Anzeige
  • Gerade eben
  • Neu
Hallo velikib,
schau mal hier: root problem. Dort wird jeder fündig!
edit: text removed
Edit:text removed
Was bedeutet das?
Ich hatte bei meinem XCover genau das gleiche Problem.
Lade dir von hier http://downloads.k0k0.de/index.php?dir=MobilePhones/Devices/Samsung/KERUKs/ eine Methode deiner Wahl (ich würde root und busybox nehmen). Entpacke die .7z mit 7Zip und schiebe dann die .zip darin auf die sdcard. Dann bootest du in den recovery mode (entweder Handy ausschalten und VolumeUp und Home drücken und dann Power (also alte drei gleichzeitig) und dan Power loslassen und die anderen beiden gedrückt halten bis du ein Männchen mit ner box in der Hand siehst oder per adb reboot recovery) und dann update from sdcard und die zip auswählen warten und neu starten lassen. Hat bei mir prima funktioniert!
Bejonwe
Gesendet von meinem GT-S5690 mit Tapatalk
Reaktionen: velikib
I dont use google translate. I am sorry for my bad german. I was trying.
Besize my german language I have a problem to root my Note with DooMlord. I have the same problem every time.
Ich danke dier.
Lade dir von hier [/B]?dir=MobilePhones%2FDevices%2FSamsung%2FKERUKs%2F]k0k0's download area (http://downloads.k0k0.de/) eine Methode deiner Wahl (ich würde root und busybox nehmen). Entpacke die .7z mit 7Zip und schiebe dann die .zip darin auf die sdcard. Dann bootest du in den recovery mode (entweder Handy ausschalten und VolumeUp und Home drücken und dann Power (also alte drei gleichzeitig) und dan Power loslassen und die anderen beiden gedrückt halten bis du ein Männchen mit ner box in der Hand siehst oder per adb reboot recovery) und dann update from sdcard und die zip auswählen warten und neu starten lassen. Hat bei mir prima funktioniert!
Bejonwe
The Thank-Button do not bite ;)
Should I try to translate you my text into English?
Bejonwe
I pushed the thank you button. Sorry. :)
You dont need to translate your text. I understand german and have problem only with writing.
Ok, tell us if this method worked. And maybe change the title of the thread to “[Gelöst] Root - zergRush - Hellions with BLUE flames“. Because I searched two days for a solution and so you'll find it faster.
Bejonwe
zergrush is not working any more for recent Samsung firmware. Of course its quite hard, since all Howtos here are in German. Short Summery: You have to downgrade to a Firmwre before KL7 and root with Zergrush. Ortherwise it doesn't work. Please be patient of the ProductCode and IMEI issue, which can occur, if you use a wrong firmware for downgrading. You have to use a firmware applicable for your actual ProductCode.
Maybe you should have a look at xda-developers. Native Language is English over there, which is maybe more comfortable to you.
My solution should works with the newest Version of Android!
Just test it, the script will stop if the device is not supported.
Bejonwe
Hay! Iam tryaing your metod write now. How long does it takes that the process is finished? I downloaded a Keruk root with busybox.
The complete process about 5 minutes. If you need more help: PM me!
bejonwe
It is runnig 15 minutes by now!? Should i interrupt?
What is on the display? PM me or add me at skype, icq or facebook then I can help you faster!
Would be nice o know what happened - did it work?
Hello! I didnt try yet. I had no time. I will do it this weekend and will report everything.
