Status des Themas:
Es sind keine weiteren Antworten möglich.
  1. STaaFF7o, 22.04.2012 #1
    STaaFF7o
    STaaFF7o Threadstarter Fortgeschrittenes Mitglied
    [​IMG] Epsilon Project - GB - V4 + UpdateMe (20/04/2012) [CUSTOMIZE TO YOUR LIKING]
    [​IMG]
    Epsilon Project now enters the world of Samsung S2 Galaxy, having gone through Motorola Atrix, from the beginning being GingerMod and then moving to the new Epsilon was looking to give as always the best for each development. I hope this rom will enjoy it and together we can continue to get always the best for our teams.
    I decided to do basing on Ginger as ICS for the moment has a high battery consumption and low flow. There is nothing to envy of ICS ...
    [​IMG]
    Changelog v1:
    Base LA4 GB 2.3.6
    Modem LPS
    Kernel Stock LA4 CF
    Rooted
    Busybox
    Deodexed
    PNG Optimized
    Auto Zipaligned (system and data apps) (Thks Darky)
    Hosts Adblocking
    Proximity sensor hack
    GPU hack
    WiFi battery saving hack
    Saves power when phone is sleep
    Allows the phone to sleep better
    Helps Scrolling Responsiveness
    Increase overall touch responsiveness
    Increases quality of photo and videos
    Change the Dalvik VM heap size 128Mb
    Disable usb debugging popup
    Render UI with GPU
    Optimized internet connection
    Less delay in calls
    Best download market
    Best ram memory management
    Enhanced Screen Sensor Delay off
    Removed the delay in calls
    Improved memory management
    Best video streaming
    Added Reboot Power Panel
    MicroSD Card Speed 1024KB/s
    Perfect Mod mount options
    Market Connection Speed Fix
    Original Visual GB
    Added JKay Deluxe v13.6.4 (15 toogles, lockscreens, power extended, etc) (Thks Jkay)
    Fast Power
    Switch-off the camera when the battery charge 0%
    Video/audio profiles 24-20Mbps/192Kbps_44100Hz
    Disabling increasing the volume level for incoming calls
    Removal of noise reduction options
    Removing the delay after talk end
    Disabling autoconversion SMS to MMS
    Disabling control the number of contacts for the simultaneous sending
    Increase the maximum size of send messages with 300 KB to 1 MB
    Increasing the speed of response Automatic Brightness Control (ABC)
    Increased speed and smoothness of transitions brightness in ABC
    Bravia Engine Mod (Thks ykk_five)
    SuperCharger Mod (Thks Pikachu01's)
    AFTR enabled
    Sched_mc disabled
    Logger disabled
    Custom Brightness
    Static Bus Frequencies
    Custom Deepsleep Levels
    GPS Tweaks (Thks Crypted's)
    Dynamic hotplug
    Logging disabled
    WIFI/3G/4G Tweaks
    Hot Plug Thresholds
    Sampling Interval & Frequency
    Battery 1%
    Gtalk 1.3 Mod (VideoChat and more)
    Google Play 3.5.16 Mod (Unlimited access to apps in Google Play Store, Removed countries restriction in Google Play Store, Fixed the issue which your device is not compatible with this item in Google Play Store) (Thks Deeco7)
    CallRec Mod
    Phone Mod
    Added CPU Spy
    Added Screen Filter
    Added FasterFix
    Added ScreenMod (Thks wql)
    Added Screen Filter
    Added Voodoo Screen
    Update Google Apps
    AutoBackup EFS Folder
    Theme ICS Mod Optional (Thks Vertemus)
    And More...
    Changelog v2:
    ICS Animations Stock Theme
    Google Play 3.5.16 MOD (Unlimited access to apps in Google Play Store, Removed countries restriction in Google Play Store, and more)
    Youtube Mod (Wifi and 3G HD)
    Beats Audio + XLoud Mod
    Some details of the visual system and the modified
    Changelog v3:
    Update FasterFix
    SD Card Speed 2048 kb/s
    Added System Apps Removed in FTP Folder
    Camera Volume Up Mod (volume up button for shutter)
    Disable SuperCharger Tweaks
    Remove Disable Logger
    Kernel SpeedMod K2-21 (Optional Phenomenals Kernels UV) (Thks Hardcore)
    Fix Bugs
    Changelog v4:
    Built again from the beginning to solve all the bugs
    Fix Bug Sounds
    Kernel CF-Root XWLA4
    Disable Logger
    Google Play Store v3.5.16 MOD Fix
    YouTube APK with 720p HD playback (WiFi) Fix (Thks theos0o)
    GPS Optimize
    Updated hosts Ad-Blocking
    Bravia Engine
    Remove Fasterix
    FuguTweaks ICS in GB (Thks nikademus)
    Browser with user agent & bounce effect
    ICS Transitions Fix
    Old version of Gtalk with video and voice
    Google Services Optimize
    New Wallpapers
    Added UpdateMe (Thks acquariusoft) (Now you can update the rom and install all add-ons/modems/kernels/theme/apps downloaded from the same Epsilon Project)
    [​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG]
    [​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG]
    Download - http://gingermod.grupoandroid.com/SG...ject-GB-V4.zip
    It is advisable to be on base before installing GB Epsilon Project. The best way is to do a clean install from the stock rom with Pit XWLA4
    Link Rom - Link CF-Kernel.
    And then proceed with installation method is traditional to travez of CMW. Previously always take the Wipes Data / Cache / Dalvik Cache, Format System / Data / Cache and then proceed with the installation.
    In case you want to have a visual style to leave them as optional ICS installer by CWM. The credits are for Vertemus, I just edited and corrected some bugs of the same to operate properly in all EpsilonProject.
    To have a lower battery consumption is advisable to follow these steps:
    According to several people testing kernels that consume less battery in GB are the Phenomenal in versions 2.2 and 4.0. We recommend using the Extreme, in case your computer crashes be changing this medium or normal.
    Settings> Display> Brightness: put it to a minimum
    Settings> Display> Lighting duration: "1.5s"
    Settings> Display> Display Power Auto adjust: off
    Settings> Applications> Samsung Apps> "OFF"
    Settings> Location & security> Ustilizar networks: off
    Telephone keypad> * # 9900 #> "Disable fast dormancy"> exit (this comes to swallow a 20% battery usage)
    If you have multiple email accounts, disable auto-sync and manually click Refresh on:
    Settings> Accounts and synchronization> Auto-sync: off
    If you want to continue with the automatic brightness another way to lower consumption is from the application of JKay change the values ​​in the brightness profiles.
    Another way is to also play with the different types of modems available and find the best we go according to our area. Remember that to be possible to use 2G connections have a lower consumption than autimaticas. If you need more speed to sail can move to 3G or Automatic again.
    It is important to always install after the end of the Rom google open the play and update the UpdateMe because I I will be updated as we get better application and if they do not always updated will not see the improvements that arise and you will see only Rom and Setting
    List Update Me
    This ROM includes a new application that keeps you informed of updates, and also allows you to get off with just a click all the kernels, modems, issues that need.
    Update I called and now includes this:
    ROM
    This section tells you if you have the latest version and apart from donations (deserved)
    KERNELS
    All Epsilon Projet compatible kernels
    Cleaning Kernel Script
    XWLA4 CF-Root
    Siyah v2.6.14
    K2-21 SpeedMod
    N.E.A.K 1.4.2x
    2.2 Phenomenal Black Normal
    2.2 Phenomenal Black Medium
    2.2 Phenomenal Black Extreme
    4.0 Phenomenal Black Normal
    4.0 Phenomenal Black Medium
    4.0 Phenomenal Black Extreme
    MODEMS
    Modems most used and recommended by the forum
    Modem-KG4
    Modem-KI1
    Modem-KI4
    Modem-KL1
    Modem-LP3
    Modem-LP7
    Modem-LPQ
    Modem-LPR
    Modem-LPS
    Modem-LP6
    APPLICATION REMOVED
    Applications that have been removed to let more light rom. (install themselves alone)
    BuddiesNow
    ChocoEUkor
    Days
    dlna
    email
    EmailWidget
    GameHub
    GenieWidget
    HelvNeueLT
    Kies
    KiesAir
    KiesWifi
    Kobo
    LiveWalpapers
    LiveWalpapersPicker
    memo
    Microbesgl
    MiniDiary
    MusicHub_10
    PhotoRetouching
    PolarisOffice
    Sticky
    PressReader
    Protips
    ReadersHub
    SamsungApps
    SamsungAppsUNA3
    SamsungIM
    SecretWallpaper1
    SecretWallpaper2
    SevenEngine
    Signin
    SnsAccountFb
    SnsAccountLi
    SnsAccountMs
    SnsAccountTw
    SocialHub
    Swype
    Syncmldm
    Syncmlds
    Tasks
    TrimApp
    VideoEditor
    VoiceToGo
    Wssyncmlnps
    Zinio
    EXTRAS
    AOSP-ICS-Email
    Stock-Email
    Clear-Email
    BeatsAudio-Mod
    Browser-Mod
    Stock-Browser
    VolumePlus
    Mod CallRec
    Call Mod Stock
    Bounce Overscroll
    Overscroll Stock
    Youtube HD Mod 3G
    Youtube HD Mod 3G and Wifi
    Youtube Stock
    Camera Mod
    Camera Stock
    Fix FlashPlayer
    TW Mod 4x5x5
    TW Mod 5x5x5
    TW Stock
    THEMES
    Topics to change the look completely out of the rom
    ICS-EpsilonProjet-GB-v4
    Theme Stock
    SETTINGS
    Various configuration options
    Nightchiller, FotoMichi, vbauer86 und eine weitere Person haben sich bedankt.
Status des Themas:
  1. what is CHOCOeukor for spy
