StreakDroid 1.9.0 final
UKSheep
UKSheep
Dauergast
569
Wieder mal eine neue Streakdroid Version :D
Download Mirror:
http://www.multiupload.com/TAUYEAQMD2
Quelle: http://forum.xda-developers.com/showthread.php?p=12289176#post12289176
DJ_Steve schrieb:
StreakDroid 1.9.0 ( aka The Final Frontier ) Release Post
Official StreakDroid Website:StreakDroid.comhttp://streakdroid.com
FRING VIDEO CALLING DOES WORK ON THIS VERSION USING THE FRING BETA AVAILABLE FROM FRING (ALSO AVAILABLE ON MODACO)
This Release Version incorporates changes in the INSTALLATION PROCESS, please read the options available to you and the correct method of applying them before proceeding to flash the 1.9 Zip File!
( Disclaimer : As before, this ROM is heavily updated and still being developed at a fairly rapid pace. Bugs are listed below.)
PERFMOD IS NOT enabled by default in this version, had some reports of stabily problems but their is now an installer option to reenable it if you wish, if you choose not to enable the installer will automaticly trasfer your data back to save a reset :)
also lots of other little tweaks been added
1.0 > INSTALLATION CHANGES :
With 1.9, several choices must be made before flashing the Zip file via StreakMod or Clockwork Recovery. These choices are made with very simple edits to a Text file ( explained in section 1.2 below )
Important Options Available ( other options are listed below in Section 1.1 ) -
A.Rebel SIM Compatibility : Users who previously downloaded the NOBB version of the file may now simply select the option by typing it into the text file before flashing the Zip. Please note that Rebel SIM users are still required to manually Fastboot flash the 2.1 8105 Baseband for compatibility.
B.Launcher Option : Users may now select their default Launcher of choice before installation. The options available are LauncherPro, ADW, Stage UI and GingerBread Launcher. GingerBread launcher is installed by default if nothing is chosen.
C.Pixel/LCD Density : Default LCD Density can be set during Installation. Values available for selection are : 120,140,180,200 and 240 DPI.
D.Other Settings : Other settings available include -
•Volume Boost
( flashes the A Modified kernel with louder volume hack ),
•Tabmail
( installs the Galaxy Tab Email Client port beta 2 instead of stock email client ),
•Teetermod
( installs Teetermod edit to get HTC Teeter working, installs the app and a modified build prop with 240dpi lcd density )
•us120/140/180/200/240 -
(installs build.prop with USA related Region Settings and an LCD Density of 120140/180/200/240)
•bios
( installs the Streak BIOS Bootanimation )
•noapps
(this will install an absolute base system with no additional apps installed and the gingerbread launcher as the default launcher)
1.1 > INSTALLATION HOW TO
A. You will need to create a text file on your Streak's MicroSD Card. The file can be created in your Text Editor of choice ( such as Notepad ).
B.This file will be called 'install.txt' - Ensure that this is the exact syntax and that the file is saved with a '.txt' suffix.
C.This file must be saved in the root of the sd card.
E.Inside this text file, you may type each option that you select on a separate line. All the options available to you are listed below. Here is an example :
Code:
adwlauncher
volboost
tabmail
bios
That is it. You can save this text file as install.txt
You will then boot into recovery ( StreakMod or Clockwork ) and begin the Zip file installation process as usual.
! The full list of Options available are as follows :
Code:
noapps - this will install an absolute base system with no additional apps installed and the gingerbread launcher as the default launcher
adwlauncher - this installs adw launcher and removes the default gingerbread launcher
launcherpro - this installs launcherpro and removes gingerbread launcher
stageui - this installs dells Stage UI and removes the gb launcher
density120 - sets lcd_density to 120 by default
density140 - sets lcd_density to 140 by default
density180 - sets lcd_density to 180 by default
density200 - sets lcd_density to 200 by default
density240 - sets lcd_density to 240 by default
nobaseband - installs the required libs for using a rebelsim
volboost - flashes a new super volume boost kernel - now with per page tables kgsl(3d) tweaks, may break gameloft games)
tabmail - installs the Galaxy Tab Email Client port beta 2 instead of stock email client
teetermod - installs teetermod edit to get htc teeter working, installs the app and a modified build prop with 240dpi lcd density
us120 - installs build.prop with usa related region settings (LCD Density of 120)
us140 - installs build.prop with usa related region settings (LCD Density of 140)
us160 - installs build.prop with usa related region settings (LCD Density of 160)
us180 - installs build.prop with usa related region settings (LCD Density of 180)
us200 - installs build.prop with usa related region settings (LCD Density of 200)
us240 - installs build.prop with usa related region settings (LCD Density of 240)
bios - installs the Streak BIOS Bootanimation thanks to Fone_Fanatic and Frysee
noswype - removes the preinstalled swype install to allow swype beta to work
zeam - installs the zeam launcher, a free open source launcher designed to be small and fast.
gbkb - installs Gingerbread keyboard instead of stock keyboard, this will cause force close in dictionary settings
perfmod - Enables the 1.6.1 Perfmod Option, disabled by default due to possible problems
novolnoppt - flashes a kernel without the new kgsl(3d) per page table support and normal volume levels - fixes some gameloft games
volnoppt - flashes a kernel without the new kgsl(3d) per page table support AND VOLUME BOOST - fixes some gameloft games
tabletphone - installs the modified dellstreak7 dialer, this causes a graphical bug in recent calls list but works fine
161font - restores the fonts from 1.6.1
2.0 > OVERVIEW/SUMMARY OF INSTALLATION PROCESS
1.Download update-1.9.0.zip from the links below
2.Place Zip file into Root of SD Card
3.Make a text file and type in the options you would like to chose as shown above.
4.Save file under SDCard>install.txt
5.Boot into StreakMod or Clockwork Recovery
6.Select Update from Zip File > Select Zip File From SD Card > update-1.8.0.Zip
7.Wait for installation.
8.First Boot may take longer than a normal boot. Things are being installed, stuff is being generated. Patience.
9.Enjoy.
Most Recent Version: v1.9.0
Known Issues:
Accelerometer is dodgy at times but I cant pin down the issue - usually going into Settings > Display and toggling Auto Rotate on and off fixes
Changelogs
UPDATE 22/03/2011
Version 1.9.0 AKA The Final Frontier
rebased off combination of dell 318/319/322/341 and 345 libs and frameworks 2.2.2 dell files
fixed the stock dialer
reverted stagefright libs to fix flash issues
added fards modified Skia and SkiaGL librarys to fix random browser crashes on certain sites
removed transparent install option, will readd for next one depending on demand
added auto zipalign script, FIRST BOOT WILL take some time
fixed an issue with some market apps not appearing
UPDATE 23/02/2011
Version 1.8.1 AKA Bug Extermination Edition
• Reverted Some changes due to stability
• Reverted the 1.5ghz kernel due to issues with wifi.
UPDATE 23/02/2011
Version 1.8.0 AKA Chernobyl Meltdown Edition
• Reverted back to some of the older libs due to the random bugs
• Added honeycomb music player as default
• Tablet Phone App looks much nicer
• Updated honeycomb music
• Added new kernels and install options
• Added adhoc wifi support
• Added slight changes to statusbar
• Reverted to stock phone app due to issues with streak7 one, moved streak7 dialer to installer option instead, this has some graphical bugs but works fine
• Added new kernel with 1.5GHz Overclocking Ability !!!! - this may prove unstable so dont use permanently, 3d may also not work at full clock speed - not certain if it is actually overclocking to that speed either
• Added option to restore the fonts from 161 in installer
• Fixed the huge settings icons
UPDATE 05/02/2011
Version 1.7.0 AKA HD7 Edition
• Replaced some aging libs and frameworks with new ones from dell 322 offical, probably fix some audio issues
• Fixed HDMI output (see note below)
• Added GScript
• Removed Perfmod by default due to some instability discovered
• Added New Keyboard and Langs from official 322 build
• Updated all apps to latest
• Fixed transparent notification bar to new icons etc
• Fixed kang-o-rama live wallpapers
• Updated stageui to version from streak 7 (no huge changes though)
• Slackerradio from streak 7 added
• Removed live wallpapers that are not full screen
• FRING FRONT FACING CAMERA SUPPORT HAS BEEN REMOVED PERMANENTLY, START ARGUING WITH FRINGS DEV IF YOU HAVE A PROBLEM WITH THIS
• Rebuilt theme from scratch, works better now, removed borked batt percentage,
• Changed fonts to much nicer looking one
• Added microbes live wallpaper
• Added fards tweaked libskia libs to fix some websites dying
• Hopefully vplayer is now fixed
• Facebook sync confirmed working
• Tweaked the browser and phone icons to match gb theme :).
• Finally managed to fix the phone app in lcd densitys other than 160 - thanks to the dell streak 7 dump for this :)
• Added an auto transfer feature to move from 1.6.1 with perfmod to stock 170 without
• Reverted Some 3D Tweaks made in 1.6.x causing Gameloft games to fail
UPDATE 22/1/2011
Version 1.6.1 AKA ITS OVER 3 THOUSAND
• Updated libs to fix oovoo
• Updated volboost kernel to new version
• Fixed some installer issues
• Added gopus battery icon, modified colors
• Made settings > about > System Update work for updating streakdroid roms (yes you can check for updates direct from your streak :)
• Added a Noswype installer option to remove the preinstalled swype
• Added zeam launcher
• Fixed fc's in settings
• Added HEAVILY Tweaked Performance Mod data2ext Tweak, using just the streaks internal sd card now no need for changing things on external sd
• Added an option to install gingerbread keyboard instead of stock keyboard - dictionary settings force closes with gingerbread keyboard installed
• Added Live Wallpaper From Nexus S
UPDATE 10/1/2011
Version 1.6.0 AKA Install-o-Rama
• Added heavily modified advanced installer thanks to kang-o-rama mod for nexus one.
• Changed theme to add black statusbar due to transparancy issues
• Fring support available through installer
• Transparancy available through installer
• Changing lcd density available via installer
• Baseband/nobaseband via installer
• Re-enable old louder volume kernel
• Teetermod via installer
• Enable galaxy tab email client via installer
• USA region settings in build prop via installer
• New kernel with some perf changes, cfq reenabled
• Bios animation bootscreen chooseable via installer
NOTE: for HDMI to work you must run gscript and load the 2 files from your memory card (the rom will of created a gscript folder containingthem) then run the hdmi output on script before trying video, once you are done either reboot or run the hdmi off script
this is due to one of the performance tweaks interfering with hdmi
Code:
#include <std_disclaimer.h>
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
also please feel free to donate to my work if you find it useful :D - any amount is appreciated
GBP Donate | USD Donate
Rom Download Links:
Primary Download Site: http://mirror2.streakdroid.com/update-1.9.0.zip
Mirror 1: http://downloads.streakdroid.com/djsteve/update-1.9.0.zip
IT IS HIGHLY RECOMMENDED TO UPDATE TO THE BELOW BASEBAND FOR 1.5.1+
Baseband File Download:
Primary Download Site: http://downloads.streakdroid.com/djsteve/amss.mbn
Mirror 1: http://mirror2.streakdroid.com/amss.mbn
VPN USERS: TUN.KO IS INCLUDED IN THE ROM ALREADY - LOOK IN /SYSTEM/LIB/MODULES.
if you have NOT already flashed the dell 2.2 pkg or my 720p fix you need this to fix 720p video - otherwise ignore
http://downloads.streakdroid.com/testing/dsp1.mbn
flash this using the fastboot command fastboot -i 0x413c flash dsp1 dsp1.mbn
Thanks to:
Everyone for suggesting things they want adding
Kang-O-Rama Rom Maker for nexus one for allowing me to use his advanced installer
omca & xplanet hosting for providing additional mirrors
ALL the BETA testers who put up with multiple screwed up builds and multiple dell logo freezes to get this working, couldn of done it without you all
android-roms for the mirror
Vinokirk for helping diagnose and sort out 2.1 baseband ril support and gps
Andycap & fards for providing modified Gps.conf
homeiss forthe excellent upgrade/downgrade guide
everyone else for just jumping in and helping each other, thats the true community sprit that makes me do this sort of dev for android and not some other mobile os.
everyone else who helped/is helping
ALL THE TESTERS DESERVE HUGE THANKS FOR THEIR HELP EVERYONE !!
Viel Spaß damit ;)
MfG
UKSheep
Reaktionen: VtecMac, payce, makkabe und 2 andere
Dankeschön! Wie hast denn das wieder aufgestöbert? Egal, jetzt hab ich was zum Spielen :thumbsup:.
Habe mal "einfach so" bei google nach "Dell Streak" "Multi Recovery Flasher" gesucht. ;)
Man muss ja mal schauen wo so etwas noch auftaucht. :D
Dabei bin ich durch Zufall, (im gleichen Türkischen Forum) auf den Beta Thread gestoßen und dachte mir nach deinem Post hier, das es dich interessieren könnte. :D
Na dann erstmal viel Spaß beim "testen" und bitte Berichten wie es läuft, bzw. was "besser" läuft. :)
MfG
UKSheep
ich gehe davon aus, dass Du zu gegebener Zeit einen gesonderten 1.9.0-Thread aufmachst (Du hast es ja aufgestöbert). Diesen Beitrag könnte man dann verschieben.
Vorwort: Während des Bootvorganges kommt der Hinweis, dass es wohl die letzte 2.2 (Froyo) Version sein wird. Schließlich arbeitet Steven an 2.3 (Gingerbread): Bild siehe unten; bei Twitter gefunden. Schaut bitte die Taskbar an! CyanogenMod?
Vorgeschmack auf die 1.9:
+läuft seidenweich, bei mir Null Ruckler; Update von 1.8.0 kommend ohne Probleme;
+alle Apps und Daten sind geblieben;
+Sound ging sofort nach dem Flashen ohne Kunstgriff;
+Browser schmiert bei Wikipedia nicht mehr ab;
-fring spielt (wenn man es aufruft) mit FCs verrückt;
-GPS fällt immer wieder auf 4 -1 Satelliten zurück (war früher nicht)
Ich hatte vergessen, meine Install.txt zu löschen, so habe ich wieder density180, bios, stockphone.
Quadrant 2 Minuten nach dem Flash: 1462; nach "Kill all Apps": 1565.
Soweit sogut. (Hoffentlich sieht es Steven nicht). Release kann aber nicht mehr lange dauern.
Grüße
Reaktionen: UKSheep und tb999
ich nehme an, das das flashen immer noch gleich abläuft, mit install.txt etc.?
ich glaube ich werde mal eine noapps - installation versuchen, um zu sehen ob meine ständigen freezes damit verschwinden...
Ich kann es dir zwar nicht zu 100% sagen, aber ich bin mir sehr sicher, dass die Installation wie seit 1.6 mit der install.txt gemacht wird.
Viel Spaß beim testen ;)
Ich denke ich warte auf Gingerbread, :D oder teste ich doch die 1.9.0, wenn sie keine Beta mehr ist? Na mal abwarten was ihr so erzählt :D
Danke erstmal @Timo für den "ersten" Bericht. Hört sich ja erstmal ganz gut an.
MfG
UKSheep
Ja, Flash wie gehabt. Ich würde aber noch kurz warten, denn Fring treibt einen beim Löschen durch gefühlte 500 FCs auf die Palme.
Der Upload der 1.9.0 final läuft...(Twitter 12 Uhr)
#streakdroid 1.9.0 final uploading as i type
edit: Download geht, aber sehr langsam. Es saugen einfach zu viele nach 5 Wochen Abstinenz...
Reaktionen: UKSheep
Passe Post 1 an sobald er auf Modaco oder XDA verfügbar ist.
MfG
UKSheep
oha.. man könnte ja meinen wer das immer als erstes herausfindet ist der Master..;)
ps. skype app ist nicht mehr im market zufinden.. bei euch genauso?
:blink:
Nö, skype wird nach 3 Sekunden Suche im Market angezeigt.
PS: ist kein Kunststück, erster zu sein - Dank des Streak und der Twitter-App. Wenn DJ Steve laut gibt, piepst es bei meinem Streak :winki:
:blink:
Ich nutze Skype nicht... Kann so gut wie jeden "umsonst" anrufen. Nutzen würde ich es höchstens wegen der Videotelefonie, aber Skype bietet diese ja in ihrer Beta noch nicht an.
ooVoo kann ich da nur Empfehlen :) und ist seit der 2.2.2/345 mit im Rom. Leider startet die aktuelle Version nach jedem Boot mit... und man muss sie von Hand ausschalten.
Muss dir da recht geben ;) Aber der Link zu der Beta war schon "glück" obwohl man eig. nur im IRC nach der Beta fragen muss... :)
Würde man es extreme "verfolgen" hätten wir schon die Beta 1 posten können ;D Frage ist... ob das gewollt ist.
MfG
UKSheep
für irgendwas muss ja twitter gut sein... ich nutze das nicht.. mit skype schau ich nachher nochmal...
trotzem DANKE Timo & UKSheep
Ich nutze Twitter eig. nur zum "folgen" zB DJ_Steve wegen der "neuen" Info´s.
Aber jetzt habe ich selber follower :D wegen dem "MultiRecoveryFlasher" :D Also poste ich da ab jetzt auch "neue" bzw. "testversionen" oder Anfragen nach hilfe für Probleme die das Tool betrifft :)
MfG
UKSheep
Edit:
Post 1. aktualisiert !!!
hi,
doofe frage, kann ich die rom direkt über die 345er drüber bügeln?
und noch was, bei dem ADWLauncher, handelt es sich da um die standard Version oder um den ADW EX?
Danke und Gruß,
Mac
Logo. Anderes recovery (für. zip) brauchst halt.
ADW: Standard; ex kostet.
Reaktionen: VtecMac
sollte funktionieren :)
Zu adw, es handelt sich wohl um die "normale" Version, da adwEX "kostenpflichtig" ist und somit nicht in CustomRoms integriert werden darf.
MfG
UKSheep
Reaktionen: VtecMac
Danke euch beiden.
hatte nur iwas von nem anderen Baseband gelesn und da mein englisch nur für das nötigste langt war ich mir net so sicher.
noch ne frage an Timo.
du hast die 1.9.0 ja schon drauf, hast du den Perfmod auch drauf?
irgendwelche probs damit?
Danke und Gruß,
Mac
Nee, Baseband ist nur nötig, wenn man noch unterhalb von 1.5.1 rumhängt, bzw unterhalb des Stock 318.
1.9.0 läuft bei mir so gut, dass ich wohl bis Gingerbread nichts mehr ändern werde. Steven arbeitet ja auch schon daran. Während des Flash kommt eh ein Hinweis, dass diese 1.9.0 das letzte Froyo sein wird/könnte.
Auf Perfmod habe ich von jeher verzichtet. Ist einfach nicht stabil genug (für meine Bedürfnisse). Das 1.9.0 brachte unmittelbar nach dem Flash 1562 Punkte im Quadrant. Da stellt sich für mich die Frage nach Tuning nicht mehr.
Ich habe diesmal noapp geflasht. Ist offenbar nicht die schlechteste Wahl, wenn man sowieso viele Kaufapps hat. Und es sind kaum Apps vorinstalliert, die man später entfernen müsste.
install.txt: bios, noapps, density180, 161font. Mehr nicht
Die läuft so geschmeidig. Auch meine ADW-ex Übergangseffekte beim Sliden. mmmmmhhh. Wenn ich nicht so faul wäre, müsste ich darüber eigentlich ein Video drehen :laugh:
Grüße
Reaktionen: VtecMac
Ein paar Fragen zur 1.9.0, Timo:
- Gehen die drei LEDs wieder nach ein paar Sekunden aus oder bleiben die an, solange der Bildschirm läuft?
- Auf was kann man den overclocken?
- Irgendwelche sonstigen, anzumerkende Bugs?
Dankö! :)
Agent_Payne
  • Agent_Payne
tobben
b-rabbit1984
blau
