  1. Seleme190, 31.12.2010 #1
    Seleme190
    Seleme190 Threadstarter Neuer Benutzer
    Ich habe bei meinem Tablet PC ein Problem aber ich weiß nocht was ich tuen soll... Es ist ein mal passiert und imma wieder das selbe Problem. NAchdem ich das Gerät einschalte, es bleibt immer hängen...was soll ich überhaupt machen?
    Sie können das Problem beim video besser beobachten....
    YouTube - SNB17926
    Die Eigenenschaften von diesem Gerät;
    Manufacturer Specifications
    • Primary Function: Android Internet Tablet
    • Screen: 7 Inch Touchscreen LCD
    • Screen Type: Resistive
    • Screen Resolution: 800*480
    • CPU Processor Speed: Samsung S3C6410(ARM11/800MHz)
    • Internal Memory/ROM: 1GB
    • External Memory: Micro SD Card up to 8GB (Not included)
    • USB Flash Drive Support: Yes, up to 16GB
    • Memory/RAM: 256MB DDR
    • Battery Type: Polymer Lithium-ion battery (7.4 V)
    • Battery Capacity: 1800 mAh (5-6 hour of constant use)
    • Speaker: Built-in 2W
    • Earphone Slot: Yes, 3.5mm
    • Mic: Built-in high sensitivity mic
    • Wireless Interface: WiFi 802.11b/g
    • Software
      Operating System:Android 1.6
      Google Marketplace: Yes
      Browser: Google Browser
      Pictures: JPG, BMP, PNG, GIF
      Audio: WWMA, MP3, WAV, AAC
      Video: 3GP, MPEG4, H.263, H.264 (Many more can be supported by third-party software!)
      Support: Office Word, Excel, PPT
      Reader: TXT
      Email: Gmail
      GPS: Google Maps (Internet-based GPS only)
      Languages: English, German, French, Italian, Japanese, Polish, Chinese (Traditional + Simplified), Russian, Korean
    • Dimensions(L*W*D):190mm * 120mm * 10.5mm
    • Manufacturer Ref: AND07TABLET
    Product Notes
    • Download your favorite apps through the Android Marketplace!
    • TV out lets you view the TechPad Android Tablet on your large screen TV
    • Browse the internet for free with WiFi!
    • Why wait for the Samsung Tablet and iPad 7 inch version when you can get the TechPad now, and at an amazing wholesale price!
    • Note: The Android OS version on this device cannot be upgraded or flashed and any attempts to modify the default OS will void the warranty. As a wholesaler, Chinavasion provides no software support, advice, or training regarding the Android operating system and software.
    Package Contents for CVGY-PC07
    • TechPad Android Tablet
    • Earphones
    • Mini USB Cable
    • Micro USB Cable
    • AV Cable
    • User Manual - English
    • Free Travel Adapter (for UK, AU, NA, SA customers)
    Danke im Voraus...
  2. Lion13, 31.12.2010 #2
    Lion13
    Lion13 Ehrenmitglied
    Ins richtige Unterforum verschoben... :)
  3. Seleme190, 01.01.2011 #3
    Seleme190
    Vielen Dank....
    Ich hoffe dass jemand mich auch zur Lösung führen kann....;)
    mfG
  4. Seleme190, 03.01.2011 #4
    Seleme190
    Warum schreibt keine irgendeine Lösung....ich habe im Forum auch durchgesucht aber ich bin nicht auf die richtige Lösung gekommen....ich bitte um die Hilfe von den Experten....
    büdde büdde....
    lg
  1. android tablet technpad problem
  2. android tablet pc 7-inch high resolution hängt sich auf was tuen
