[Theme/Diskussion] SenseCream V4.0 BLUE für alle 4.0.4 Sense Roms - 15/08/12
  • 5 Antworten
Q
quercus
Gast
Quelle: XDA
[THEME] SenseCream Blue v4.0 - *ALL* OneX Sense4 ROMs (ICS4.0.4) [updated 13th Aug]
Download auf XDA
WHAT DO YOU GET
v4.0
  • Rebased on 2.15.x / 2.17.x base
  • changed common app background from black to endursa's fixed holo background
  • Few other minor cosmetic issues
Code:
v3.1
  • Fully themed Dialer/Phone.apk (including lockscreen answer button thanks to geenyous!)
  • Changed HTC green system text to blue (thanks to lex_is300 and jerrytan93)
  • Themed Play Store to match system appearance
  • Fixed notification pulldown - now supports transparency/custom backgrounds
  • changed common app background from dotted grey to black
v3.0
  • Rebased on latest HTC ROM base (2.05.401.2)
  • Dialer elements changed from green to blue (more dialer themeing to come!)
  • Few more graphical glitches addressed
v2.5
  • Themed HTC IME.apk
v2.4
  • Converted to the VillainTheme system, to provide compatibility with all Sense 4.0 ROMs
  • Made my own wifi icon, will try and post some screenshots tomorrow - let me know what you think
v2.3
  • Updated to be compatible with LeeDroid v6.x
  • Skin rebased on HTC Matte skin
  • Fixed wifi icon alignment
v2.2
  • Updated to be compatible with LeeDroid v5.1 and j4n87's Extended Quick Settings mod
  • Included Lee's fix for the notification pulldown glitch, and endursa's fixed holo background
v2.1
  • Themed framework-res/SystemUI/com.htc.resources - *blue/black theme throughout
  • Battery icons/charging icons
  • Other system icons*
  • Shutdown menu etc
  • Signal strength indicators
  • ICS styling for non-ICS apps (see Titanium Backup screenshot)
  • Blue progress bars (see Titanium screenshot and volume slider)
  • Blue overscroll / press highlights etc
  • Pop-up menu boxes / dialog boxes
  • Notification shade looks more ICS-style - you WILL lose the transparent notification shade mod
  • All stock HTC apps now have an ICS feel to them (calendar / HTC Music / Mail etc)
  • More things I forgot - seek and you shall find!
funzt einwandfrei .... klasse theme
update v 3.0
UPDATE
Version 3.1 - for ROMs built on the 2.05.x Base
ViperX v1.x - tested myself
InsertCoin v7.x - thanks to meleelord and robertus23
maXimus v2.x - thanks to jejehtc
ARHD v7.x - thanks to SweDunda and thom109 (though others have had issues, so proceed with care..and a nandroid backup!)
hallo
habe arhd 7.x..
theme instlliert, scheint auch soweit zu funktionieren, nur das mein sense ui sich beendet...kann man da was machen?
gruss
andy
