  1. dragonflyser, 09.06.2012 #1
    dragonflyser
    dragonflyser Threadstarter Neuer Benutzer
    Erhaltene Danke:
    20.05.2012
    english speaker.
    x3 (u8510), originally from lidl,
    I updated the stock rom to 2.3.5 and then to 2.3.6
    now the wifi works for a minute and then disconnects. it then reconnects automatically. problem is really annoying.
    i have factory reset, reflashed rom, and other things, but without success.
    please help.
    thank you, c
    Der ursprüngliche Beitrag von 14:27 Uhr wurde um 14:58 Uhr ergänzt:
    have timed it and the wifi cuts out after 90 seconds (3 minutes). every 90 seconds. wtf?
  2. Major_Tom, 09.06.2012 #2
    Major_Tom
    Major_Tom Fortgeschrittenes Mitglied
    335
    Erhaltene Danke:
    80
    11.09.2011
    Hello dragonflyser,
    I vaguely remember this problem is related to a DHCP lease-time set to "infinity" in some wifi-routers.
    Try setting the lease-time of DHCP to one day or one week in your router´s DHCP-configuration, that should solve your problem.
    Major Tom
    dragonflyser bedankt sich.
  3. dragonflyser, 09.06.2012 #3
    dragonflyser
    Erhaltene Danke:
    20.05.2012
    Tom, you rock!
    problem solution: dsl router Vodafone Easybox 802. goto 192.168.2.1 -login username: root pw: 123456
    change dhcp lease to 1 week.
    save settings.
    smile a bunch, because your X3 connects to the internet and now stays connected.
    :thumbsup::thumbsup::thumbsup:
Diese Seite empfehlen
