  1. quercus, 05.02.2012 #1
    quercus
    quercus Threadstarter Gast
    Quelle: XDA
    {X10}[DEVELOPMENT] -FXP124- CM9.0 - FreeXperia Project
    We suport following accesorries
    LIVEVIEWLiveView | Phone Remote - Sony Smartphones (UK)
    LIVEWATCH http://www.sonyericsson.com/cws/prod...ch?cc=gb&lc=en
    SOURCES
    https://github.com/freexperia
    DONATE
    https://www.paypal.com/cgi-bin/websc...=THUJZQB2U5PNC
    Our team is not responsable of any damage that you or you phone will suffer by using our work
    __________________
    FreeXperia Project
    Latest release FXP111
    CM7.2 RC3
    FXP124
    FXP124_CM7.2_RC3
    mirror
    Files of jerpelea
    CM9.0 RC0
    FXP123
    FXP123_CM9.0_RC0
    mirror
    Files of jerpelea
    cm7.2 GAPPS ADDON - http://cmw.22aaf3.com/gapps/gapps-gb...828-signed.zip
    cm9.0 GAPPS ADDON - http://cmw.22aaf3.com/gapps/gapps-ic...317-signed.zip
    Face Unlock ADDON - http://cmw.22aaf3.com/gapps/gapps-ic...131-signed.zip
    Baseband 64 (recomanded for 2011 devices)
    SEMC BASEBAND 64 - http://ul.to/folder/yrqfhn
    Supported Xperia Devices
    ST Ericsson
    U
    Sola
    MSM8660
    S - nozomi
    MSM8255
    Active - satsuma
    Arc - anzu
    Live - coconut
    Mini - smultron
    Mini Pro - mango
    Neo - hallon
    Neo V - haida
    Play GSM - zeus
    Play CDMA - zeusc
    Pro - iyokan
    Ray - urushi
    QSD8250
    X10 - es209ra
    BUGTRAKER & CHANGELOGS @ freexperia - FreeXperia - Google Project Hosting
    Update auf FXP137 FXP137-cm-9-20120908-UNOFFI…zip (127,18 MB) - uploaded.to
    Update-Ordner aller Geräte FXP137_CM9.1
    Update auf FXP141 FXP141_cm-9-20121006-UNOFFI…zip (127,20 MB) - uploaded.to oder Download file FXP141_cm-9-20121006-UNOFFICIAL-es209ra.zip
    Update-Ordner aller Geräte FXP141_CM9.1 oder Download file FXP141_CM91
    Update auf FXP142 FXP142-cm-9-20121013-UNOFFI…zip (127,21 MB) - uploaded.to oder Download file FXP142-cm-9-20121013-UNOFFICIAL-es209ra.zip
    Update-Ordner aller Geräte FXP142_CM9.1 oder http://rapidgator.net/folder/1161998/FXP142_CM91.html
    http://forum.xda-developers.com/showthread.php?t=1938933 für den Cam-Fix unter CM9
    Danke an das ICH​
    Zuletzt von einem Moderator bearbeitet: 30.10.2012
    lkrys, bluelight21, mieszekatze und 2 andere haben sich bedankt.
  2. SE_X10, 05.02.2012 #2
    SE_X10
    SE_X10 Erfahrener Benutzer
    200
    Erhaltene Danke:
    20
    19.12.2010
    Phone:
    Sony Ericsson Xperia X10
    Wird man dafür einen unlocked bootloader brauchen?
  3. Flo95, 05.02.2012 #3
    Flo95
    Flo95 Ehrenmitglied
    3,740
    Erhaltene Danke:
    787
    29.01.2012
    Phone:
    Samsung Galaxy S7 EDGE
    Tablet:
    Apple iPad Air
    Wahrscheinlich schon, brauchst für CM7 ja auch.
  4. quercus, 05.02.2012 #4
    quercus
    ja ;)
  5. Corefanatiker, 11.02.2012 #5
    Corefanatiker
    Corefanatiker Neuer Benutzer
    14
    Erhaltene Danke:
    11.02.2012
    Error (404) wird angezeigt wenn ich gapps laden will pls reup.
    Dangööö
  6. quercus, 11.02.2012 #6
    quercus
  7. quercus, 22.02.2012 #7
    quercus
    UPDATE 06/03/2012
    { {X10}[DEVELOPMENT] - CM9.0 - FXP109 FreeXperia Project 06/03/2012
    Zuletzt von einem Moderator bearbeitet: 08.03.2012
  8. quercus, 10.03.2012 #8
    quercus
    Update
    {X10}[DEVELOPMENT] - CM9.0 - FXP112 RELEASED FreeXperia Project 19/03/2012
    Zuletzt von einem Moderator bearbeitet: 19.03.2012
  9. Pöschipu, 24.03.2012 #9
    Pöschipu
    Pöschipu Neuer Benutzer
    9
    Erhaltene Danke:
    21.12.2011
    Gibts schon eine Übersicht was mit CM9 FX113 funktioniert?
    Gesendet von meinem X10i mit der Android-Hilfe.de App
  10. quercus, 24.03.2012 #10
    quercus
    {X10}[DEVELOPMENT] - CM9.0 - FXP113 RELEASED FreeXperia Project 24/03/2012
    Mein Freund, steht alles auf der ersten Seite - anklicken (changelog) und du weißt es. ;)
    Zuletzt von einem Moderator bearbeitet: 24.03.2012
  11. quercus, 31.03.2012 #11
    quercus
    UPDATE
    {X10}[DEVELOPMENT] - CM9.0 - FXP114 RELEASED FreeXperia Project 31/03/2012
    [​IMG]
  12. Kitzi, 03.04.2012 #12
    Kitzi
    Kitzi Android-Hilfe.de Mitglied
    120
    Erhaltene Danke:
    12
    25.11.2011
    Ahh ich bekomme es nicht insterliert :(
    Bei meine Galaxy geht es so einfach. Aber hier sagt er mir immer in Recovery geht net.
    Das X10 ist aber das es209ra oder? :> ich weiß nicht was ich machen soll *g*
  13. quercus, 03.04.2012 #13
    quercus
    Das was jeder halbwegs vernünftige User machen soll:
    Genau schreiben wie er was gemacht hat - dann erst kann man auch helfen. ;)
    PS: Welche Vorstellungen hast eigentlich von der halbfertigen ROM?
  14. Kitzi, 03.04.2012 #14
    Kitzi
    120
    Erhaltene Danke:
    12
    25.11.2011
    Habe das Handy heute geschenkt bekommen *g* habe ja mein Galaxy wollte nur mal gucken wie CM9 oder auch 7.2 auf dem Xperia läuft, bin mit ICS auf dem Galaxy mehr als zufrieden ;)
    also ich habe nun CM7.2 zum laufen bekommen. Bei CM9 Hängt er beim dem Free Xperia Logo. Aber ich habe in der Update Zip auch kein Kernle gefunden den ich vorab über Flashtools insterlieren soll vielleicht liegt es daran??
    edit.
    Ich habe jetzt die Costum ftf in der EXP113 gefunden :) nun läuft zwar cm9 aber es ist alles orange??
  15. me_droid, 05.04.2012 #15
    me_droid
    me_droid Neuer Benutzer
    16
    Erhaltene Danke:
    13.01.2012
    ich hab über SEUS mein x10 auf stock 2.3.3 geflasht, über das flashtool gerootet, bootloader entsperrt, xrecovery draufgemacht und über dieses cm7.2 geflasht aber beim reboot bleibt es beim se schriftzug hängen.
    woran liegt das?
  16. quercus, 21.04.2012 #16
    quercus
    UPDATE Seite 1 ;)
    {X10}[DEVELOPMENT] - CM9.0 - FXP117 RELEASED FreeXperia Project 21/04/2012
  17. Das-Ich, 20.05.2012 #17
    Das-Ich
    Das-Ich Android-Lexikon
    1,471
    Erhaltene Danke:
    375
    23.06.2011
    Hi
    Update auf FXP121 Download FXP121 update RC0 es209ra UNOFFICIAL signed zip
    Update-Ordner aller Geräte Files of jerpelea: FXP121_CM9.0_RC0 folder
    Im xda-Thread wird allerdings von Problemen mit dem Kernel gesprochen, laut FreeXperia soll man nicht vergessen den Kernel zu flashen, nur gibt es kein eigenes Kernel-Paket wie bei der FXP119. Einige reden davon den Kernel aus der .zip zu nehmen, alias kernel.sin, und daraus eine .ftf mit dem ftf-Creator zu erstellen, oder eine bundle. Siehe ab hier http://forum.xda-developers.com/showthread.php?p=26330593#post26330593
    MfG
  18. Das-Ich, 20.05.2012 #18
    Das-Ich
    1,471
    Erhaltene Danke:
    375
    23.06.2011
    Hi
    habe mit dem Flashtool eine Custom-Kernel.ftf erstellt, mit diesem fährt das Handy hoch hat aber einen extremen Gelbstich. Daraufhin den Kernel von der FXP119.7z Datei und danach nochmal FXP121.zip drüberinstalliert und der Gelbstich ist weg.
    Der Kernel ist nun auch online http://uploaded.to/file/9jgnnzgk/from/ccquyj.
    Wenn es damit auch das Problem mit den Farben gibt, soll man laut xda-Form, die Datei /system/lib/hw/copybit.qsd8k.so und mit der von der FXP113 ersetzen. Einfach mit Root-Rechten das ganze erledigen.
    MfG
  19. Das-Ich, 22.05.2012 #19
    Das-Ich
    1,471
    Erhaltene Danke:
    375
    23.06.2011
  20. Das-Ich, 28.05.2012 #20
    Das-Ich
    1,471
    Erhaltene Danke:
    375
    23.06.2011
Diese Seite empfehlen
