Xillius200's,Mikeyman77's,Spikeynick94's DroidEris 2.1r3 ("MTD+2708") (26/11/2010)
MarciWoi
MarciWoi
Dauergast
191
Xillius200's, Mikeyman77's, Spikeynick94's XMN 2.1 DroidEris
ABOUT XMN 2.1 DROIDERIS
I dont know about any of you, but i love sense. however sense has never met my standards in terms of speed, and stability.. well thats what i want to fix. this has been a little project of mine for a few weeks, hope you like and enjoy
as Zach has left I have tried to speak to him doubt he will ever come back so in terms of this day R.I.P ZX but hello XM ^^
Xillius200: Rom developer + Porter
Mikeyman: Rom Developer + Porter
Spikeynick94: Theme creator + apk resizing (hdpi to mdpi etc.)
Steps to a successful install:
0 format sd card and setup the sd card with ext4 of 512mb or above and the swap with 128mb
0.1 go here 2708+ enabled kernel [14MB ram with radio 2.22.27.08/2.22.28.25 & hboot 1.33.0013d] - xda-developers
0.2 follow steps upgrade spl an radio
1. Head over to Firerats MTD page
2. Download FR_Boot_v1.5.6 and FR_Recovery_v1.5.6 to your sd card
3. Create a text file called mtdpartmap.txt with the "mtd 145 2" inside of the txt file without the quotes
4. Download the rom below to sd card
5. enter recovery and wipe cache,data,system
6. Flash FR_Recovery_v1.5.6
7. Wipe cache,data,system
8. reboot but back into recovery
9. Flash Rom
10. Flash FR_BOOT
11. Reboot phone and enjoy ^^
done
BE AWARE ROM IS NOW 2708 ONLY "NO NEED FOR EZTERRY ANYKERNEL" STILL NEEDS MTD BOOT ^^
Zitat:
XMR45: More of a fixed up release
- new widgets
- footprints
- friendstream
- Slight optimization to apps now lol - can be optimized more next build ^^
- wifi fixed
- landscape could be fixed needs checking ^^
- Service seems good lol but was for me anyway so needs testing ^^
- Not the last
- etc.
not working:
- Camera
- Camcorder
- BT
v5 - Speed Boost release - (12/01/2011)
- Alot more speed
- different kernel
- etc.
Download und Installation:
Beste Einstellungen bei SetCPU:
Max.: 614 MHz
Min.: 245 MHz
Threshold: 35
ignore nice load: 1
Ich habe bei dieser Version immer noch den Service-bug, der seit der neuen Base auftritt.
Landscape-mod funktioniert auch nur sehr beschränkt (unbrauchbar^^)
WLAN funktioniert jetzt, bei version 4 hat es Probleme auf dem G1 gegeben.
Infos und Download hier:
http://forum.xda-developers.com/showthread.php?t=807183
ja wollte ich aber mtd funzt net keine ahnung warum dann steht bei mir die fehlermeldung
E:Can´t chown/mod /system/xbin
(no such file or directory)
E:Failure at line 14:
set_perm_recursive 0 2000 0755 06755 System:xbin
kennt jemand das problem? und kann mir helfen?
Hast du vorher auch auf deiner SD/Karte eine Datei erstellt mit dem Namen mtdpartmap.txt und 161 4 reingeschrieben?
hat sich erledigt hab was gefunden nur so zur info
6) Run 'adb shell' in the tools folder of the sdk installation to start interactive mode.
7) Now run these commands:
mount -o rw -t yaffs2 /dev/block/mtdblock3 /system
mkdir -p /system/xbin
touch /system/xbin/removeme
chmod 755 /system/xbin
chmod 664 /system/xbin/removeme
exit
8) Restart phone. Verify that /system/xbin folder is present and contains removeme file
eine frage noch habe ja bereits den ezterry kernel und radio usw. wie mache ich ein system wipe im recovery?
9. Flash Rom
10. Flash FR_BOOT
done
noch ne doofe frage reboot ins recovery mit annehmen-menü-power? und dann home gedrückt halten?
So hab es endlich geschafft.
+ schöne optik
+ htc sense
+ geschwindigkeit
+ keine fc´s
- 67 mb intern
- kein Bluetooth
- kein froyo
- kein multilanguage aber more loacale2 aus dem market macht so gut wie alles auf deutsch
- akku
mfg Marcel
aber nach meiner meinung der beste hero sense ui rom :)
mfg marcel
:)ja find ich auch ist hammer. kann man net mit normalen roms vergleichen
neue version :
ROM DOWNLOAD: xm3_5_signed.zip
Best Settings:
Animations: OFF
Setcpu: 576mhz and interactive I think is good lol ^^ but up to you lol - the ones on by default I find good
XMR3.5
Fix to widget problems in framework - hopefully xD
ALOT More speed lol
A few other things modded for better stability ^^
faster keyboard - If keyboard don't work adb push replacement lol
renice tweaks
etc.
LÄUFT NOCH BESSER :OO
ja läuft wirklich besser akku laufzeit heute 55% verbrauch bei gleicher nutzung vorher ende des tages nur 15 %
mfg Marcel
Kleine INFO :
4.0 wird im dezember erscheinen :)
9. Flash Rom
10. Flash FR_BOOT
done
einmal "mtd 145 2" einmal "161 4" ...
und da heist es, man kann nicht lesen. Also was jetzt ?
EDIT:
Hat sich erledigt ! mtd 145 2 ist richtig.
Andere Frage:
Kann es sein dass bei diesen ROM der Internetzugriff für Apps gesperrt ist ?
Go Chat! ect. funktionieren nicht !
Ansonst super Sense-ROM !
ich weiß nicht genau , aber solche probleme hatte ich nicht :o
Go!Chat, imo-App funktionieren nicht .. dass sind beide Chat-Apps für verschiedene Netzwerke.
=> "Trillian" funktioniert , hab gerade getestet.
Weis jemand wie man beim SMS schreiben diesen automatischen Vorschlag-modus (T9 oder sowas kA) deaktivieren kann ?
Wenn ich unter Language & Keyboard => Device keyboard => "Auto-replace" deaktiviere, dann ändert dass irgendwie nichts.
mfg
Findeste doch sowieso gleich allein raus.....Alleinunterhalter ;)
mhh bei mir gehts einwandfrei unter Einstellungen=>Sprache und Tastatur=>Tastatur des Gerätes und alles deaktiviert, im vormenü hab ich auch Touch input deaktiviert.
mfg Marcel
Find ich nicht xD
Hab im xda-Forum nachgefragt ... und zufälligerweise bekam ich dort schneller eine Antwort.
Natürlich Poste ich dann auch hier die Antwort, falls wer die selbe Frage hat. Das ist doch der Sinn vom Forum ;)
Das ROM läuft super, am anfang halt..
Nach dem ich 1-2 Apps installiert hab, sagt er "Out of Space"
Hier das logcat beim installieren:
VIEW dat=file:///sdcard/Android.111410/Angry%20Birds%20v1.4.2%20Ad-Free.apk typ=
application/vnd.android.package-archive cmp=com.android.packageinstaller/.Packag
eInstallerActivity }
I/ActivityManager( 3097): Start proc com.android.packageinstaller for activity c
om.android.packageinstaller/.PackageInstallerActivity: pid=4297 uid=10018 gids={
I/installd( 3075): free_cache(59532180) avail 59101184
W/PackageManager( 3097): Couldn't clear application caches
I/ActivityManager( 3097): Displayed activity com.android.packageinstaller/.Packa
geInstallerActivity: 6126 ms (total 6126 ms)
D/dalvikvm( 4175): GC freed 7701 objects / 404416 bytes in 146ms
"Couldn't clear application caches" kommt mir verdächtig vor ^^
Zu meinem G1:
Radio: 2.22.27.08
HBoot: 1.33.0013d
Kernel2.6.34.7-cm6-biffmod ezterry@zack #7
mtd 145 2
Partitionen sind auch in ordnung:
Number Start End Size Type File system Flags
1 32.3kB 6901MB 6901MB primary fat32 lba
2 6901MB 7692MB 791MB primary ext4
3 7692MB 7948MB 256MB primary linux-swap(v1)
Weis wer was da falsch ist ? hab es schon öfters installiert... immer das selbe.
mfg
artMkiss
artMkiss
artMkiss
winne
Technoolli
Rushness
