[Sammy-ROM][ICS] *17.05.12* AndyX ROM v12.1 LP9 - Tweaks
script0r
Δ AndyX ROM™ v3.1 - Android ICS 4.0.3 - Tweaks - Battery % - No TouchWiz - and more Δ
Δ AndyX ROM™ v3.1 - Android ICS 4.0.3 - Tweaks (performance, battery saving, better signal, etc) - % Battery - No TouchWiz Launcher - And much more Δ
Specs
★ Based on Stock Firmware XXLP2 Android 4.0.3 (Ice Cream Sandwich)
★ Rooted with CF-Root
★ Deodexed
★ Zipaligned
★ Busybox
★ Removed Samsung TouchWiz Launcher
★ Ice Cream Sandwich Interface
★ Applications AOSP ICS 4.0 (Music, MMS, Browser, etc)
★ Includes Superuser.apk
★ Includes FM Radio.apk
★ Includes Widget Time and News .apk
★ Includes Camera.apk
★ Includes Flash Player.apk
★ Includes AndyX ROM Gallery .apk
★ Includes FaceUnlock.apk
★ Performance Tweaks:
* Improved speed data connection
* Improved speed internet connection
* Improved stability
* Improving the quality of images. Jpg and videos. Mp4
* etc
★ New icons (FMRadio, Gallery, Music, Phone, SMS, etc ...)
★ And much more ...
Screenshots
How to install Rom
1 - Being Root
2 - Copy from the PC. AndyX_ROM_v3.0_ICS_4.0.3_XXLP2.zip zip on the SD card
3 - Restart the phone in Recovery Mode
4 - Make Wipes:
* Wipe data
* Wipe cache
* Wipe Dalvik cache
* Wipe battery stats
5 - Install zip from sd card
6 - Locate the file and mark AndyX_ROM_v3.0_ICS_4.0.3_XXLP2.zip as i begin to flash the ROM
7 - Reboot system now
8 - Ready, enjoy the Rom!
Information
* As with any Rom ICS may have its faults, I did not give me any so far, no FCs and no rebootS.
* The data I have gone well, but each phone and data company is a different world, so I will comment you.
* Any damage please report it as a comment on this topic to go to all improving Rom.
* Not 100% themed, missing many aesthetic arrangements, which updates it will change.
* DO NOT use a different kernel than the one that brings the Rom or CyanogenMod (CM9), if u change the Siyah not start the phone.
* If you can change the modem, they can start testing the comment you want and which do best in stability data.
* IMPORTANT: rom should let it settle and with 3 cycles of loading greatly improves battery is tested by me and many users.
Update 1 for v5.1
* Fixed sound notifications in Gmail app
* Fixed DSP Manager.apk
* Added Maps.apk (last version)
* Added ICS Clock.apk
* Added Samsung TTS.apk
* Fixed shutdown (shutdown options)
* Added Flash Player.apk (last version)
* New camera app improvements and themed style with ICS
* New script EFSBackup
* Arrangements in the Framework, System.UI and Settings
Changelogs v5.1
★ More FASTER and SMOOTH
★ Kernel CF-Root fixed
★ 15 in Status Bar Toggles (JKay style) with better changes
★ CRT Effect Off
★ All Languages (Multi CSC)
★ Removed Launcher Trebuchet
Download Trebuchet here: http://depositfiles.com/files/8cahg5d6b
★ Removed Launcher Nova
Download Nova here: http://depositfiles.com/files/2e8fpcqx6
NO more crashes or reboots
NO more Fc
★ FM Radio working!
★ Added MMS. Apk AOSP (Messaging) working fine now
★ Internal arrangements in the Framework, System.UI and Settings
★ Data and WiFi fixed (hairline in WiFi off)
★ All apns for data...
★ Google Apps Updated to last version (v11)
★ Removed some unnecessary apps...
★ And much more...
Changelogs v5.0
★ Based on Stock Rom XXLPB
★ Modem: XXLPB
★ CSC: OXALP5
★ CRT Effect Off
★ Added Launcher Trebuchet
★ Added Launcher Nova
NO more Fc
★ FM Radio working!
★ Added Google Messenger.apk
★ Added Samusng service (Account Samsung)
★ Added Google+.apk
★ Data and WiFi signal more better
★ New Bootanimation
★ And much more...
Changelogs v3.1
★ New Modem LP6 (improves stability of the Data)
★ New Kernel LP6
★ CRT Off effect
★ More Tweaks in build.prop
★ Added AOSP Contacts.apk
★ Added AOSP Phone.apk
★ Added AOSP MMS.apk
★ Added AOSP Calendar.apk
★ Added AOSP Calculator.apk
★ More stability
★ Google Apps Updated to v10
★ And other things I'm forgetting now ...
Download Link v3.1
AndyX_Rom_v3.1_ICS_4.0.3_XXLP2.zip
Thanks to:
* Sammobile by Stocks Roms.
* @Chainfire by the Kernel Root.
* @lidroid
* XDA for giving me this opportunity to share this project with everyone.
* ALL XDA users who support me, help improve this ROM and for the good comments.
* All great Devs of this site, every day you learn a lot from them.
Regards
ADESIRELLO
__________________
Mi Custom ROM for Samsung Galaxy SII - Android ICS 4.0.3
>>> ROM UPDATE!!!! <<<
Changelogs v5.2
★ Fixed problem to install apps from the Market (sd)
★ Kernel LP6 (improved tactile response failures and lets you install apps on the sd)
**READ** By putting in the v5.2 kernel LP6, the radio stops working, but do this, after having installed the ROM, install all apps that want to market and then flashed by Recovery and without wipes LPB to the kernel will run the radio.
Link to download the Kernel LPB (only those who want them to work the Radio)
http://depositfiles.com/files/zbgf03s2y
★ Fixed dark buttons (for TheAyden)
★ Fixed effect on signal icons
★ Added Polaris original Office
★ Fixed and added Flash Player
★ Arrangements aesthetic in Framework, Settings and System.UI
★ New Icons in Status Bar (Bluethoot, USB, Music, Emails, etc) (blue ICS)
★ Added Widget News and Time (Transparent widget)
★ Added Samsung AccuWeather Widget
★ As with v5.1, Nova and Trbuchet Launcher removed, install them by Recovery.
Trebuchet Launcher Deposit Files
Nova Launcher Deposit Files
★ And other things but I do not remember ...
PLEASE, READ: ROM v5.1 IS NO-WIPE, only wipe Dalvik Cache. If something is wrong you must make 4 wipes! I personally I recommend the 4 wipes, but you may choose to not do so
DOWNLOADLINK v4:
DOWNLOAD
DOWNLOADLINK v4.1:
DOWNLOAD
UPDATE 1 Verfügbar!!
>>>> Download Hier <<<<
DOWNLOAD 5.1
<< HERE >>
(FAST MIRROR)
DOWNLOAD 5.1 Update!!!
<< HERE >>
(FAST MIRROR)
Download 5.2
AndyX_Rom_v5.2_ICS_4.0.3_XXLPB.zip
Download 7.1
AndyX_Rom_v7.1_ICS_4.0.3_XXLPQ.zip
Download 7.2
AndyX_Rom_v7.2_ICS_4.0.3_XXLPQ.zip
oder
Und hier noch Kernel fix, und Modem fix, fall irgendetwas davon nicht funktionieren sollte:
Modem Fix: ModemKG5.zip
Kernel Fix: kernel_cm_9_SGS2_01112012.zip
Reaktionen: enami, m4dd0gg, Roobox und 13 andere
sieht nicht schlecht aus, liest sich gut... schon einer getestet?
ja... also vom Ergebniss bin ich sehr zu frieden,... leider noch nicht ganz so perfekt wie der Onecosmic fürs SGS GT9000....
Aber meineserachtens nach der beste ICS Rom für SGS 2 GT9100
Warum wohl fürs GT9000 vorher ein ICS Rom heraussen is, verstehe ich bis heute noch nicht, aber egal :)
Reaktionen: dolox
Hat zufällig jemand einen alternativen Download Link? Der Speed vom Link ist extrem lahm... ^^
Ich lade mit 7,5 MByte/s ... und keine probleme
lohnt ein umstieg von miui?
Reaktionen: Blackout4
Besser als CM9? Gleich mal Laden :tongue:
Bei mir läd er mit 50KB/s....
Ich habe eine 6000 Leitung und diese wird auch voll ausgelastet 720 KB/s
Screenshots new AOSP Apps in v3.1
Phone.apk (dial)
Contacts
Status Bar (15 Toggles)
MMS
Calendar
script0r schrieb:
würd ich schon sagen,.. mach hald mal ein backup und teste mal :)
ai :D hab die möglichkeit vom backup ganz verbaselt xD wenn ich mich nicht irre sollte ich aber vorher wieder ne 3teilige offirom flashen und dann dannach die hier oder?
backup wird schonmal gestartet :p
also bei mir hats mit
Backup / Clear Dalvik/Cache/Data&Factory reset/Battery reset / install zip
gleich auf anhieb funktioniert. letzter CWM wäre vielleicht empfehlenswert.
hab direkt über Lightning Rom drübergeflashed.. keine probs.
gibts keine probleme wenn man von einer aosp(miui) auf eine officialbased flasht? ich mein sowas mal gelesen zu haben
sagen wir so,.... in der regel dürften keine probleme auftreten,... sollten sie aber,.. dann ist es empfehlenswert, da handy zu resetten,.. also internal sd format, etc... original flashen, cwm kernel drüber, und dann die neue fw....
hab bis dato glaub ich alle roms auf meinem SGS und SGS II probiert,.. und es sind nur beim SGS-Onecosmic leichte probleme aufgetreten... ansonsten immer wieder drüber,.. bis der perfekte rom drauf ist,.. dann alles mal resetten (damit handy clean ist) und sauber installieren :D
Reaktionen: zoomann und Blackout4
gut dann mach ich mich gleich mal ran an den speck ;) erst titanium backups machen dann nandroid und drauf mit der rom :D
funktioniert das titanium bei dir?? also hab eigentlich nur erfahrungen gemacht, dass trotzdem alles weg is XD
verlass mich aufs CWM/Backup-Restore.. dass hat mich bis jetzt noch nicht im stich gelassen :)
ich mache zur vorsicht immer beides ;) titanium soll mir einfach nur sicherungskopien von ausgewählten apps machen
debaki
debaki
debaki
FotoMichi
debaki
debaki
debaki
debaki
debaki
