[ROM][4.4.2] Resurrection Remix® KitKat [AOKP|CM|PA|Omni|Remix]
Dodge
Dodge
Dauergast
597
Features
Halo
Active Display
Lockscreen Benachrichtigungen
Application Sidebar
Omniswitch
Benachrichtigungseinstellungen
Quick-Settings Kacheln
Pitch Black UI Modus
Kamera mods
Neue Animations
Screen Recorder
Weitere Features
Hardware buttons and navbar options
Status bar traffic monitor
Battery bar options
CRT animations
SB Brightness slider
Expanded desktop
Profiles
Performance controller
Flip tiles
Theme chooser
Keyboard features
Lockscreen see blur and reduce slider
Show Wi-Fi name
Headset action
Low battery warning
Lock clock widget
Privacy guard
Permission management
Power sounds
Share ROM
Battery mods
Changelog
Lockscreen options and targets
Center Clock/No clock/Right Clock
AM/PM,date and colors
Wallpaper App
Nova/Stock launcher
Screenshots
Installationsanleitung
► Philz Touch Recovery flashen
► Wipe data/Factory Reset (Clean to Install a new ROM)
Direkt hier fortfahren wenn Update
► Wipe Cache
► Installiere ROM
► Installiere GApps
► Neustarten
Download
Official Philz Touch Recovery
Goo.im Downloads - n7100
GApps
Dev-Host - The Ultimate Free File Hosting / File Sharing Service
Neueste Version: KitKat v5.0.9 15-04-14
Changelog
https://gist.github.com/westcripp/8874051
XDA-Developers Thread
N7100 [LINARO] Resurrection Remix® 4.4.2 KitKat v5.0.9 [14/04/15] - xda-developers
Resurrection Remix Forum
Resurrection Remix
Google+
https://plus.google.com/u/0/communities/109352646351468373340
Resurrection Remix Team (xda-developers)
westcrip - xda-developers - View Profile: westcrip
xenon92 - xda-developers - View Profile: xenon92
attachment.php
Version Information
Status: Stable
Stable Release Date: 2014-04-15
Credits, Danksagungen und Haftungsausschluss
XDA developers
CM team
Kang (AOKP) team
Omni team
Slim rom
cyberboob [Signaturen, Bilder]
BigDenn [Bootanimationen]
& Allen Spendern und Unterstützern
Wie bei jeder ROM gilt auch hier..
weder ich, die xda-devs, noch das Android-Hilfe-Forum ist für jegliche Schäden haftbar,
flashen und benutzen auf eigene Gefahr!
Reaktionen: R0cc0Naut, tonyMez, Fiedl und eine weitere Person
Sehr gut, nur weiter so! Wenn das so weiter geht, kommt auch in die AOSP-Ecke des Note 2 mal wieder etwas mehr Leben, vielleicht auch in mehrere Threads.
Ich werde den ROM sofort in den INDEX aufnehmen. Wie immer gilt, solltest du in irgendeiner Weise Unterstützung benötigen (z.B. reservierte Posts für Changelogs, etc.), so melde dich bitte einfach bei mir, ich werde alles weitere veranlassen. :thumbsup:
Reaktionen: redbull1, Fiedl, Denowa und eine weitere Person
Gerne! :)
Dieser gefällt mir doch schon etwas mehr als die Sonic.. bis auf die DPI-Einstellung vermisse ich nichts, hab ich aber auch gleich in der Build.Prop geändert :D
Sehr smoothe Animationen und gute rundum performance.. außerdem unterstützt es Viper4Android!
Hi Dodge,hast Recht,die Sonic ist nicht schlecht,aber auch nicht der Brüller.Werd jetzt auch die hier mal probieren. Wie hast Du das mit dpi gemacht,kannste mir das erklären?
Gruß Fiedl
Auch von der Performance finde ich den hier wesentlich angenehmer wie Sonic, außerdem auch mit 0.8%/h im Standby deutlich sparsamer.
DPI ändern geht wie folgt: zuerst installiert man das Xposed Framework, welches dann unter den Einstellungen erscheint. Hier kommt dann das App-Settings Modul ins Spiel, welches die Apps einzeln anpassen lässt (Tablet-Auflösung etc.).
Außerdem dann die allgemeine DPI einstellen:
Die Build.prop unter /system/build.prop mit einem Root-Explorer finden und mit dessen Editor öffnen..
Etwas unten findest du die Zeile:
ro.sf.lcd_density=320
Dieses stellst du auf 240, speicherst ab und startest neu.
Reaktionen: Fiedl
Danke erstmal für Deine schnelle Antwort. Ich muß sagen, die ROM läuft wirklich wesentlich besser. Werd Sie auch erstmal behalten. Kannst Du mir noch sagen wie ich die drei optischen Schalter weg bekomme.
Gruß Fiedl
Von der Navbar ist die Rede, richtig?
Einstellungen - Resurrection Tools - Oberfläche - Navbar size & hide: [0dp]
Reaktionen: Fiedl
Geht das telefonieren mit der autofreisprecheinrichtung via Bluetooth jetzt richtig oder kommt es noch zu fc's.
Kann ich leider nicht testen, hab keine FSE im Auto.
Hi,werd`s demnächst mal im Auto testen und dann berichten.
Gruß Fiedl
Der ursprüngliche Beitrag von 10:35 Uhr wurde um 11:55 Uhr ergänzt:
Hi, hab mehrere Nummern im Auto getestet und alles ohne Probleme.
Gruß Fiedl
Mit dem rr oder agni Kernel?
mit rr
Gruß Fiedl
Ah ok, dann liegt es am agni. Wenn ich damit einmal anrufe gehts, beim zweitenmal gibt es einen fc.
Werde ich gleich mal austesten mit dem rr.:thumbup:
Und? schon getestet?
Nein noch nicht. Bin gerade erst von der Arbeit heim gekommen.
So ist drauf. Wo kann man den die Screenshots Funktion im erweiterten Power Menü aktivieren?
So jetzt geht's mal an die freisprechanlage.
So habe mit meiner Ford fs und einer Citroen fs versucht, bei beiden wählt er und direkt nach dem verbinden legt es von selbst auf und verliert dann das Netz.
Schade aber ohne fs ist schlecht für mich.
Das geht unter: Einstellungen - Resurrection Tools - Tasten - Ein/Aus-Taste - Bildschirmfoto [X]
Versteh ich nicht,bei mir gings mit fs einwandfrei. Habe allerdings im Auto meinem Handy einen neuen Namen gegeben. Vielleicht liegts ja daran.
Gruß Fiedl
Nein hab das auch versucht. Auch anderes Modem. Immer das selbe.
Ist natürlich schade.Hat man ja aber schon oft gehört,bei dem einen gehts beim andern nicht.Warum auch immer.
Gruß Fiedl
Update:KitKat v5.0.9 15-04-14
Changelog:
Code:
 Resurrection Remix KitKat 4.4.2 - v5.0.9-20140415 # Basic
- Fix android run time (ART)
- phone-fix flip action call options
- Totally fix for system ui fc
- Add NEW Ringtone C.Y.E-Resurrection - set as default
- Add RR tools Russian translations translated by Aleksashik
- settings: Add blacklist provider permission
- allow Mock SMS
- Separate Change Encryption Password Entry
- Use SSL for submitting stats
- Do not enable Camera widget on non-camera devices
- Update 'Wi-Fi display' string to 'Cast screen'
- SoundSettings: Assigning a null to an unnecessary variable
- update device maintainers nexus 5-nexus 4-i9305-Galaxy Note III hlte
- fix slider torch checkbox
- Settings: Apply Processor settings to all cpus
- New Theme Engine
- Runtime resource overlay, iteration 2
- New command line tool 'idmap'
- Remove T-mobile items not used by new theme engine
- Wallpaper Overscroll and Transparent NavBar
- SysUI: Use LocationController from status bar service for GPSTile.
- Set some GC parameters only for dalvik
- CM11 Themes: Take into account ALL res/xml dirs
- Fix the value type of def_noise_suppression
- SysUI: Don't recreate controllers.
- SlimRecents: user configurable default expanded mode
- Frameworks: SlimRecents pass gesture detector to the cardslistview
- Frameworks: add 1dp more bottom paddingcore: Add support for Luxembourgish
- Frameworks: SlimRecents: Make expanded layout pretty
- Update settings after recreating status bar.
- Suppress String resources build warnings
- Keyguard: Fix problem where PhoneWindowManager waits for keyguard to drawable
- Keyguard: We need to ensure that keyguard is showing as well to set the token
- SlimRecents: Adress the 50ms touch unsresponsive issue
- base: Fix screen on stats after a boot
- Restore pre-KitKat permissions to external sd for all apps
- Don't make isSafeMode a field on the Zygote class.
- [video] : added mime-type for mov files
- Fix LTE tile
- LTE toggle support
- Solve three memory leaks related to PatchCache
- Prevent Lockscreen album art from activating FLAG_KEEP_SCREEN_ON
- Do not show Home behind full screen activity
- core: Add support for Luxembourgish
- hammerhead-hh: Better scaling values
- hammerhead-enable multiuser
- hammerhead-hh: Collapse primary audio outputs
- hammerhead-Make SYSTEM owner of cpu online files
- i9300- Camera2: Don't try to cancel focus messages when preview stops
- i9300- Switch back to the binary camera HAL
- Included lot of sound and media updates
- Included CyanogenMod source updates
Reaktionen: Fiedl, redbull1, tonyMez und eine weitere Person
Dr.No
Astra-Celly
scheues.alien
scheues.alien
Silverblade
Nufan
Nufan
