[KERNEL-ICS] [GPL] 4.0.4 FuguMod Kernel (open, stable and secure)
  • 14 Antworten
  • Neuester Beitrag
Diskutiere [KERNEL-ICS] [GPL] 4.0.4 FuguMod Kernel (open, stable and secure) im Custom-Kernel für Galaxy Nexus im Bereich Root / Hacking / Modding für Galaxy Nexus.
joker.20
joker.20
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem "Samsung Galaxy Nexus". Wenn ihr nicht sicher seit, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Ersteller und damit alle Credits gehen an nikademus .
http://forum.xda-developers.com/showthread.php?t=1438417&highlight=fugu
[KERNEL][GPL] FuguMod kernel (linux 3.0.22, stable and secure)
FuguMod kernel is now available for the Galaxy Nexus.
You can download them at:
https://faramir.eriador.org/r/galaxy_nexus/
Source and changelog can be found here:
https://github.com/renaudallard/gnexus_kernel
IRC channel:
irc.freenode.net #fugumod
To install, just download the appropriate version for your ROM (4.0.x) and flash it with fastboot (RAW version: fastboot flash boot kernel-$VERSION.img) or flash it with CWM (CWM/zip version).
Please note that not all versions exist in CWM format.
4.0.2 version is based on official google initramfs + init.d support (is now in deprecated state, no future updates will be brought)
4.0.3 version is based on the initramfs of AOSP + init.d support
Features:
- stackprotector
- various security enhancements
- congestion managed by VENO algorithm
- RCU boost
- Automatic process grouping
- TUN (compiled in kernel)
- CIFS (compiled in kernel)
- linux kernel 3.0.22
- newer wifi driver
- color hack if using CM9 based ROM
Versioning:
New kernels will be based on the below versionning
kernel_FuguMod_20120111_r20-4.0.3.img
20120111 is the date it has been packaged
r20 is the release number
4.0.3 is the ROM it is compatible with
ROM
Here is a ROM I built:
It's an AOSP/master release:
https://faramir.eriador.org/r/maguro...ro-ota-eng.zip
- it requires gapps to be flashed
- it does not come with FuguMod kernel by default
- it has no su
- it doesn't have cwm
- you may need to wipe
Security
was not vulnerable to CVE-2012-0056
scimitar
Stammgast
--GNex--
Gast
Ich kann den r143 Test-Kernel mit CM9 empfehlen, läuft sehr gut.
Taptalked by GNex running CyanogenMod 9
MacPontios
MacPontios
du meinst doch die 134 Version, oder?
Nuel
Nuel
Er meint bestimmt die 143. Die 134 ist die Stableversion und die 143 eine Testversion
MacPontios
MacPontios
Mist habe falsche Kernel aufgespielt die 134 für CM9
:sneaky:
--GNex--
Gast
Der Kernel ist nicht speziell für CM9, der Kernel läuft auch auf AOKP. Wie beschrieben ist der r143 der TEST-Kernel, der jedoch läuft sehr stabil und die meisten Tester sind damit äusserst zufrieden.
skdubg
Gast
bin aktuell auch auf dem FuguMod.
der läuft sehr rund, heute nacht wird die r143 zur stable, laut dem Entwickler.
bisher keine schwierigkeiten, der Akku verbrauch ist ähnlich gut wie beim Franco
Z
zurchpet
R144 basierend auf kernel 3.0.23-rc1 im testing branch von FuguMod verfügbar.
Beinhaltet einen ARM code fix und sehr viele networking code fixes.
Läuft bei mir prima :)
Gesendet von meinem Galaxy Nexus mit Tapatalk
Lokisto
Lokisto
Kann irgendwie nicht verstehen, warum hier so wenig los ist. Der Kernel läuft super flüssig, das Gerät wird kaum warm bei normaler Benutzung und die akkulaufzeit ist ähnlich wie bei dem lean kernel.
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
Z
zurchpet
Vielleicht eben genau darum :)
Renaud macht solide Arbeit ohne den Kernel sinnlos mit Features voll zu stopfen die kaum jemand braucht und den Kernel instabiler machen.
Lokisto
Lokisto
Möchte mal eben erwähnen, dass es jetzt eine Jelly Bean Testversion gibt. In gewohnter Qualität ;)
