[KERNEL-JB] Leankernel-Minimalistic Kernel
Gast5050
Gast
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem "Samsung Galaxy Nexus". Wenn ihr nicht sicher seit, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Kernel-Infos:
Leankernel-Minimalistic Kernel für Jelly Bean
Funktionsumfang:
zur Zeit erst mal auf Englisch:
  • Patched to latest in Linux 3.0.x branch: 3.0.36.
  • All unnecessary kernel components removed to make kernel lean and fast!
  • OC to 1.65ghz. Boot speed is maxed at 1.2ghz within kernel (in addition to ramdisk) for stability.
  • User voltage control
  • InteractiveX V2 (screen-off hotplug of cpu1) added. Select it using setcpu if you want to use it.
  • Ramdisk tweaks (sysctl, vm, filesystem speed, etc.)
  • SWAP & zram (next generation compcache) support. Run "zram enable" in terminal.
  • init.d support in ramdisk.
  • lk.conf for basic kernel configuration.
  • HotplugX governor (Hotplug optimized and modified for screen-off suspend).
  • wakelock tweaks for wlan and lte modem
  • lkflash - script to flash latest versions of leanKernel from Terminal (type "su" without quotes, hit enter, then type "lkflash" without quotes and then hit enter)
  • checkv - voltage checking script (for custom undervolting) - detailed at bottom of this post.
  • checkt - script that displays 1) your current temp, 2) # of times you were throttled due to temp "recently", 3) CPU trim type, and 4) CPU silicon type, etc. (sample output)
  • Fast USB charge (by chad0982) and "ffc" toggle script by me. (Open terminal, and type "ffc" without quotes then enter)
  • ColorControl from both CM9 and Ezekeel (compatible with all ROMs). Helpful posts: 1and 2.
  • TempControl - sysfs interface to control the CPU temp threshold. Read these two posts: 1 and 2.
  • Variable GPU OC - sysfs interface to select GPU max speed between 307MHz (stock), 384MHz and 512Mhz. The changes take effect immediately. Check FAQ for more info and how to use it.
  • Custom SR Tuning - override kernel default minimum voltage for SR calibration. More info here and here. V2
  • SoundControl
  • Gamma Control
Flash-Anleitung:
Installation:
1. Neustart ins Recovery
2. Kernel flashen
6. Neustart
Downloads:
Download: JB-Stable
Changlog:
05.07.2012
Erstes Release v. 4.0.0
Support auf Englisch:
Für englischsprachigen Support empfehle ich die Threads bei unseren Kollegen von RootzWiki.
Thread-Changelog:
05.07.2012
- Thread erstellt
Reaktionen: Fabipro, Elting, hotnspicyjohnny und eine weitere Person
In dem Zusammenhang sollte vielleicht noch auf die Bedeutung des Governors unter JB hingewiesen werden.
Zitat imoseyon:
Which governor should I use on JB?
As usual I'd recommend trying all the governors and see which one works best for you. Stock JB, however, is optimized for interactive. The OS will automatically modify various interactive governor parameters on the fly while you're using the phone as part of "project butter". Namely, the following parameters are constantly adjusted by the OS: boostpulse, timer_rate, min_sample_time, hispeed_freq, go_hispeed_load, and above_hispeed_delay.
Für mich ein merkbarer Leistungssprung bei allen Custom Kernels unter JB.
Reaktionen: Fabipro
Iss Super der Kernel, leider geht LKflash und Franco App noch nicht damit
Franco App geht nun seit dem Letztem Update
Das ist auf jeden fall mein lieblingskernel habe schon zu ICS zeiten immer die slim ICS rom drauf gehabt und dort war der lean schon drauf....unter JB läuft der bei mir auch super....nur blöd das die franco app die einstellungen nicht speichert nach einem reboot :cursing:
Bin gerade vom Standard AOKP Kernel auf den Lean 4.3 gewechselt, und es läuft alles extrem flüssig (was davor nicht der Fall war)
Wenn sich der Kernel jetzt noch in der Akkulaufzeit bewährt, bin ich zu 100% zufrieden.
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
Moin, hat jemand den aktuellen 4.3.0 mit 230 auf den Handy oder PC?
Falls ja wäre toll wenn es hochgeladen wird denn bei mir ist die Download Seite schon seit gestern nicht erreichbar..
Ist die smoothness des Kernels eigentlich besser als die vom Franco? Würde zwar gern selbst ausprobieren, geht aber leider nicht, da mein Nexus mit Cm10 nach Installation dieses Kernels leider nicht fertigbootet. Was könnte man dagegen machen?
Nach der Installation eines Kernels eines anderen Kernelentwicklers immer den Dalvik Cache wipen.
Reaktionen: Nexuskiller
Leider krieg ich den Kernel auch nicht zum Laufen.
Hab AOKP und nach dem Flash des Kernels bleibt es beim Bootlogo in der Schleife hängen.
Cache/Dalvic Cache hab ich gewipet.
Edit: Leider bekam ich dann sogar überhaupt keinen Kernel mehr zum Laufen, auch den ursprünglichen nicht. Hing dann alles immer im Bootlogo fest.
Da half nur noch mein Backup einzuspielen.
Der Kernel läuft soweit gut, der Akkuverbrauch wird sich zeigen.
Ich bekomm ihn auch nich zum laufen...
Keine Probleme hier mit 4.3.0exp4 und AOKP JB Build 2...
Geflasht sowohl mit Francos App als auch manuell per TWRP. Alles prima.
Kann mal wer die aktuelle experimental hochladen? Bei mir kommt immer ein Lade Fehler der Seite.
Möge die Macht mit dir sein.
Versendet von meinem SGN
Der Lean gefällt mir sogar noch etwas besser als der Franco, aber da keine Kontrastumstellung unterstützt wird, ist er leider nichts für mich.
Vielleicht in den nächsten Updates.
PS: Gibt es denn eine andere Möglichkeit den Kontrast runterzuregeln ?
So ist das Bild nämlich total überhellt (zuviel Kontrast).
Ich nehme die App Trickster MOD, damit kann man die Gamma und Colour Werte nach eigenem Geschmack einstellen.
Getippt mit nem Galaxy Nexus
Gamma und Color sind nicht Kontrast.
Changelog
Linux updates 3.0.41, 3.0.42, 3.0.43, and 3.0.44. Some omap/android updates including wifi driver. SIO I/O scheduler and Westwood+ TCP congestion algorithm now default. SWAP/zram enabled.
Damit kein Support für Gamma. Trotzdem top.
meLAW
  • meLAW
meLAW
meLAW
firsttyphoon
  • firsttyphoon
4 5 6
qu4nd
qu4nd
Radagast
oif
oif
