AndroPlusKernel
hier der originalthread von androplus
[KERNEL][D6503] AndroPlusKernel v15 | Sony Xperia Z2 | XDA Forums
Features
neu in v16
-O3 + A15 + Graphite Optimizations - v16
Added some patches for network and memory management - v16
Added power key emulator - faster than "input keyevent 26" - v16
Code:
#For screen off
echo 10 > /sys/kernel/ponkey/ponkey_emu
#For power menu
echo 600 > /sys/kernel/ponkey/ponkey_emu
Added VR, ZEN, SIO-Plus iosched - v16
Added frandom module - v16
Deleted USB keyboard/mouse function - v16
Disabled MSM-Sleeper - v16
Deleted non-working voltage for CPU OC - v16
Fixed SmartassH3 (thanks sh4d1t0) - v15a
Enabled MSM-Sleeper - v15
Changed TWRP to [NUT]'s one - v15
Added "Convert device into USB keyboard/mouse" function (thanks pelya) - v15
You can control your PC with Xperia (download and install USB-Keyboard.apk from here)
Fixed Smartass v2 - v14
Added CPU govonors smartassH3, adaptive, intellidemand 5.0 - v14
Updated TWRP to 2.8.3.0 - v13
Updated intelli_plug to v3.9 - v13
Added fast_hotplug by pec0ra - v13
Support loading recovery from FOTA kernel by pressing power button - v12
Deleted fast charge for faster charging - v12
Disabled zzmove - v12
Added CPU governor zzmove - v11 I'll revert in v12
Fixed Sound Control, now it's working! - v11
Added glocklee's "A sexy kernel patch for notification light" - v10a
Disabled sony_ric completely in kernel - v10a
Build for D6503 23.0.1.A.3.12 - v10
Updated to 23.0.1.A.5.77 source - v10
Enabled TCP cong algorithms BIC, Westwood+, H-TCP, Vegas, Veno, YeAH TCP - v9
Enabled advanced congestion-avoidance algorithms - v9
Fixed simple_ondemand GPU governor crashing - v9
Changed GPU OC to 657MHz, Idle on 27MHz, added back stock freq and add 100MHz Step - v8
Added Simple GPU Algorithm - v7
Added GPU OC to 644 MHz and idle on 120MHz - v7
Added CPU overclocking 3.2 GHz - not working, need someone who can break limit! - v7
Added "intelliminmax cpu governor" -v6
Fixed OC - v5
Added back 2.457GHz -v5
Updated TWRP to 2.8.1.0 -v4
CPU OverClock upto 2.89GHz -v3
Intelli-Plug driver v3.8 -v2
Intelli-thermal v2 -v2
Intelli-KSM -v2
Sound Control driver v3.6 -v2 [Not working]
PowerSuspend drivers -v2
Force FastCharge -v2
kernel level Color Control -v2
kernel mode NEON -v2
msm_cpufreq_limiter "Snake Charmer" -v2
per-core overall stats -v2
NTFS R/W support -v2
I/O schedulers -v2
BFQ
FIOPS
CPU governor (Some are not tested) -v2
Intelli-active
LionHeart
SmartAssV2
LagFree
Wheatley
Disabled ric -v1
CWM (Volume Up) -v1
TWRP Recovery (Volume Down) -v1
PhilZ touch recovery (Camera Key) -v1
CPU OverClock upto 2.8 GHz -v1
GPU OverClock -v1
CPU Undervolting -v1
SIO I/O scheduler -v1
Requirements
Xperia Z2 [D6503]
stock 4.4.4
23.0.1.A.3.12 - v10 ~
23.0.1.A.0.167
Download
v16 - Z2 D6503 23.0.1.A.3.12
Direkt Download
How to flash
1. Reboote ins Recovery oder den Bootloader
2. Flash kernel mit dem Recovery oder fastboot
Recovery - Install zip
fastboot - Extrahiere die boot.img aus der zip und start cmd mit diesem befehl
Code:
fastboot flash boot boot.img
3. Rebooten
4. Fertig!
Reaktionen: bandit_crc
Link zum download geht bei mir nicht
Gerade mal eben die Links probiert und funktionieren beide Problemlos!
Gruß,
snoopy-1
hab mal nen 2ten downloadlink eingefügt
Ja geht, und Läuft erste sahne
Was heist erste Sahne der Download oder der Kernel?
Falls du den Kernel meinst wäre mal interessant zu wissen was daran besser
ist.
LG Robby
Meine den Kernel, ich hatte bei Lagfree starke Hänger, Ruckelte recht stark. Jetzt ist davon nichtmehr zu sehen.
Bilde mir sogar ein der Akku Verbrauch wäre geringer geworden
Reaktionen: Robby57
Update
Reaktionen: Robby57
Die Meinung kann ich leider nicht teilen zumindest nicht bei der v15, denn der Kernel hat mir über Nacht den Akku bis auf 1% weggesaugt und das Z2 war heute früh aus.
LG Robby
Hast du denn Kernel mal neu aufgespielt?
Ich habe zuerst den originalen und dann die v15 aufgespielt.
Und ja dieses Problem nicht bestätigen.
Nein nur über die 12 er geflasht. Aber vielleicht reicht ja auch schon ein vipe denn das hatte ich bei der V12 gemacht.
LG Robby
Update
Update v16
Code:
#For screen off
#For power menu
Welche Einstellung habt ihr bei diesem Kernel?
[KERNEL][D6503] AndroPlusKernel v17c | Sony Xperia Z2 | XDA Forums
Update
v17c
  • Added working kexec hardboot, just wait for MultiROM! - v17c
  • Reverted some optimizations for sched and writeback - v17c
  • Added back USB keyboard/mouse function with ON/OFF - v17c
To enable, run these commands on device:
Code:
su
echo "0" > /sys/devices/virtual/android_usb/android0/enable;
echo "1" > /sys/module/g_android/parameters/usb_keyboard;
echo "mtp,adb,hid" > /sys/devices/virtual/android_usb/android0/functions;
echo "1" > /sys/devices/virtual/android_usb/android0/enable;
To disable:
Code:
su
echo "0" > /sys/module/g_android/parameters/usb_keyboard;
echo "mtp,adb" > /sys/devices/virtual/android_usb/android0/functions;
Download
v17c - Z2 D6503 23.0.1.A.3.12
Direkt Download
update
Ist die Version 19a die letzte Version des Androplus Kernels?Oder wurde die jetzt ersetzt?Wäre sehr nett wenn ihr mir einer helfen könnte
19c war die letzte version mit multirom support.
dort wurden sämtliche optimierungen entfernt,
philz touch recovery &
cwm recovery wurden entfernt.
wer kein multirom support brauch und
sonst keine probleme hat,
kann ruhig bei v18 bleiben.
hier geht's zur v19c
*edit*
ich hab v19 beabsichtigt weggelassen
