Misty-Rom
  • 111 Antworten
udo7777
udo7777
Stamm-User
372
Moin Mädels :D
Neues Futter für Euer Handy :thumbsup:
Port von Micromax A110
Misty-Rom (Relaese)
FEATURES OF MISTY - ROM
-Amazing User Interface
-Super Smooth and Fluid
-Wolf Scripts
-Xthemes Engine
-Best Boot Animation Ever
-Xposed Framework
-Viper Audio Engine (Latest)
-In-Built Ad Blocker
(Latest Version of Mother of all Ad Blocking)
-Full GPU & CPU Utilization
-Smooth & Improved Touch
-Special Optimization For Gamers
-Pre-Rooted
-Improved Touch Quality
-Latest & Inverted Play Store
-All Dark Themed Google Apps
-Amazing Battery Backup
-Cool Ringones, Notifications
-Nova Launcher as default Launcher
-Improved GPS Lock Speed
-Wi-Fi Improved
-Super Fast Internet Speed
-Removed Black Screen After Call Ending
-Proximity Sensing Improved
-Removed Bloatware
-Removed Useless Ringtones
-Quick Boot Option
-Super Smooth Performance
-Adrenaline Boost
-Adrenaline TaskManager
-Sqlite Optimizing/Vacuum
-Increase touch Sensitivity
-Zipalign on every reboot
-Battery Saving Tweaks
-Lazerdroid
-MUCH better Ram usage
-Cache Cleared at every boot
-SD speed tweak
-Logger removed
-Better browser performance
-Sysctl tweaks
-Better battery life
-Faster GUI
-Xbin Tweaks
-Loopy smoothness tweak
-CPU GPU rendering
-Faster Networking
-Smoother LWP animation
Installation
Wipe all Data - Cache
Format System etc.
Install Rom from SD-Card
Reboot
Complete the Setup Wizard
Open 'Xposed Installer' from App Drawer
Select 'Install/Update' and close the App
Open 'Viper4AudioFX' from App Drawer
Download Terminal Emulator from Play Store
How to use Wolf Scripts:
How to Use It Adrenaline Boost Script?
1) Open terminal emulator
2) Type Code:
su
boost
How to Use It Adrenaline Task Manager?
2) Type Code:
su
tm
How to Use Seeder?
2) Type Code:
su
seeder
How to go to wolfscript menu?
2) Type Code:
su
wolf
For a Fast and Smooth UI
In Settings>Developer Options>Set Both Animation Scales to Zero
and from Nova Settings>Look and Feel>Set Animation Speed and App Animation to Fast or Very Fast.
Go to Recovery Again
Fix Permissions and Wipe Dalvik Cache
Reboot the Phone
Enjoy the Rom
Update 12 Juli 2013
Microfon
SD-Karte
Downloadlink: Updated Version
Was nicht funktioniert:
GPS
Viel Spaß :thumbsup:
Credit to Akshitbanta - XDA Developer
Screenshots:
Gruß Udo7777
Reaktionen: Hummel95, FailFire, raucherbein und 3 andere
Anzeige
  • Gerade eben
  • Neu
Hallo udo7777,
schau mal hier: Misty-Rom. Dort wird jeder fündig!
Hört sich gut an :thumbup:
Ja klingt verdammt gut. Werds dann gleich mal testen wenns oben ist :thumbup:
Iss ja mal Hammer, freue mich schon sie testen zu dürfen:thumbup:
Wird die Rom nächste Woche kommen?:)
Wann ist die oben? :)
Gesendet von meinem ALCATEL ONE TOUCH 997D mit der Android-Hilfe.de App
Moin :D
Habt mal noch ein kleinwenig geduld.
Es werden noch diverse Test gemacht. Kamera macht noch etwas zicken. Will ich aber noch beheben!
Sie wird aber bis Dienstag Abend hier zum Download bereit stehn. Versprochen :winki:
Hier schon mal ein paar Screenshots :thumbup:
Gruß Udo7777
Na sieht ja mal für´s erste echt Klasse aus:biggrin:
Freu ma schon riesig druff :thumbsup:
Wird die Rom auch die Dual-SIM Funktion vom 997d unterstützen oder ist die nur fürs Lutea3?
Im ersten Screenshot ist der Punkt SIM Verwaltung zu sehen, also dürfte Dual SIM dabei sein :)
Sobald die oben ist, werde ich mal die SystemUI aus der Lewa porten, wenn das ok ist? :)
Ist die Performance wirklich so gut? Wäre echt gut, da die Performance auf der Lewa ROM echt manchmal hinterherhinkt. :)
Juhuu, ich freue mich schon! :) kann man einfach die Data Partition backuppen und wieder zurückspielen?
Freu mich drauf die auf mein Handy zu packen,
schaut ja schon mal seeehhhrrr vielversprechend aus!
Abend ist zwar schon vorüber, aber egal, hoffe dass es noch heut kommt ~
Moin :biggrin:
Ich weiß noch nicht ob ich es heute Abend noch schaffe die Rom frei zu geben.
Benötige erst das OK von oben :winki:
Ich lasse meine Roms erst schecken wegen Urheberrechtsverletzung vorzubeugen :thumbup:
Gruß Udo7777
Der ursprüngliche Beitrag von 22:23 Uhr wurde um 22:57 Uhr ergänzt:
Rom ist oben :cool2:
Viel Spaß damit!
Gruß Udo7777
Reaktionen: TIMMI93, raucherbein und Julix3
So Rom ist installiert und nun gehts auf zum Alltagstest :D
Werde mich dann in paar Tagen nochmal melden.
I tested the rom ,it's great and fast but there is a problem:rolleyes2:.Sdcard(ext) is now sdcard2(mnt/sdcard2 folder only)and problem is with games data,I cant start games when data is on larger sdext card(now sdcard2),games start only If data is on internal small sdcard 1gb(now called sdcard).Same is for titanium backup.
I've tried various combinations in sdcard and storage settings but without success.:sad:
Thanks for great work.
Leider spreche ich kein Deutsch.
Ich habe das ROM getestet, es ist schnell und schön.
Aber ich habe ein Problem mit den SD-Karten. Die interne SD-Karte (1GB) ist jetzt die externe SD-Karte. Die eigentliche externe Karte wird als intern ausgewiesen.
Spiele können nur von der vermeintlichen externen SD-Karte mit 1 GB gestartet werden.
Ebenso verweist Titanium Backup auf die falsche SD-Karte.
Ich habe verschiedene Varianten ausprobiert leider ohne Erfolg.
Danke für die großartige Arbeit.
[translated by RATTAR, Moderator]
I think you can change this in storage settings...
Die ROM ist doch Stock-based oder?
Hi!
Die Rom gefällt mir sehr gut, läuft alles super und so,
nur leider habe ich Probleme mit meiner SIM ins Internet zu kommen s:
Ist dieses Problem bekannt oder liegt es doch an mir?
MfG
Um ins Mobilnetz zu kommen musst du die APN Einstellungen für deinen Provider manuell eintragen. (Einstellungen->Mehr...->Mobile Netzwerke->Zugangspunkte) Die sind nach der installation der Rom leer :thumbup:
Ich hab aber noch ein ganz anderes Problem. Beim Telefonieren verstehe ich meinen Gesprächspartner super nur er kann mich garnicht hören. Wär schön wenn das noch jemand testen könnte.
