[4.4] KatKiss-KitKat
Belze
Belze
Stammgast
206
[ROM][KK 4.4.4] [ KatKiss-KitKat #030 ] [Stable] [MultiWindow]
attachment.php
KatKiss ROM - Asus TF101 KitKat 4.4.2
attachment.php
Dieser Post wird immer aktuell gehalten. :cool2:
Features of KatKiss_4.4
Rooted
High speed and responsive oriented
High performance and overclockable KatKernel included see dedicated KatKernel thread for more info
Hardware accelerated video & Camera
Full Dock keyboard Support with special keys with additional CTRL + Menu shortcut for recents apps
Global Shortcuts / KeyOverride Macro association (See post #2 for more info)
Battery Level Indicator & Dock Battery support + Mods (icon/Text/%)
HDMI out options: center, crop, scale
CIFS, ext4, NTFS & Exfat support
Native 4.3 FSTRIM + Manual scripts for Database optimization and fstrim (see post #2)
Media Scanner Filters
Advanced per application permission management (AppOps)
Default Android 4.4 Launcher + Trebuchet
Advanced power menu with reboot options.
Expanded Desktop with the option to hide only the NavBar
Choice between PhabletUI with left or middle aligned nav buttons, and multiple NavBar height.
Wifi channels regulatory domains
Integrated cpu & io performance settings panel
Custom Navbars buttons long press actions
Ethernet support with settings panel
Custom Quick Settings tiles
Install Notes
These builds are designed to be installed from your favorite recovery. MAKE SURE TO INSTALL A COMPATIBLE ANDROID 4.2/4.3 RECOVERY!
TWRP >= 2.3.2.3 is recommended, new TWRP available here
Backup everything !
Go to recovery
Make a full wipe / factory reset (you can skip this step if you're already on KatKiss-4.4, if ever you encounter a problem do the full wipe and try again before reporting )
Format /system
Flash the rom
Flash optional kernel
Flash gapps
Wipe cache/dalvik
Reboot
Changelog
06/09/14 - V029 =
- Fix CandyCrush Crashing on start in default Linaro Rom
- Fix PlayStore update image artifacts with optimized libskia
- Trebuchet: update to latest
- Settings: Add Location On/Off Switch in Menu
- Settings: Draw Dock battery graph on Battery stats
- Rom + chromium OpenSSL: Fix multiple vulnerabilities: CVE-2014-3470, CVE-2014-0221, CVE-2014-0224, CVE-2014-0195
- Upgrade libpng from 1.2 to 1.6.10
- Misc libhardware_legacy changes
- Bring back fully optimized libskia (overall smoother)
--> will still make OfficePro suite crash => Those who need it: flash separate Non-Linaro optimized libskia
-- The overall smoothness is better, so if it's only one app that has issues, those who use it will just need to flash the additional libskia
- Make separe Non-Linaro optimized libskia flashable zip
=06/05/14 - V028 =
- Fix OfficePro crashing with default rom
- Fix PlayStore update image artifacts with default rom
- Rom zip:
-- unmount /system first
=06/03/14 - V027 =
beta1:
- Upgrade to Android 4.4.3_r1.1
beta2:
- Fix Bluetooth crashing
beta3:
- Linaro + All Optimizations
final:
- Fix Settings crash in portrait
=06/03/14 - V026=
- OMX: Prevent NVDestroy from crashing - Fix Netflix crash on opening (ESPN and other apps should benefit from that too)
- Rotation Lock: Keep last rotation position when locking
- Floating Windows: Add option to disable/enable AutoSnap
- Global Actions (Available for Long Press & Key Override) :
-- Add Ethernet Toggle Action
-- Add Send KeyCode Action
- Quick Settings: Add Ethernet Toggle Tile
- Settings: Reuse 2 Panes mode
- Fix strict-aliasing in HWComposer
- Fix descriptor leak after accepting connections
- Fix socket descriptor leak from Zygote to child app
- libstagefright: Copy the entire buffer from/to OMX component
- Add mkfs.f2fs
- Optimize:
-- Use -O3 in GLOBAL FLAGS too
-- bionic: target cortex-a9
-- bionic: use linaro optimized string handling routines
-- Reswitch to linaro optimize built libkia
-- Misc compile flags
- Rom zip:
-- Force /system format first (prevents rom camera from disappearing with old gapps if not formatting system manually)
-- skip backup tools
- KatKernel 115:
-- Rebuild with Linaro 4.9
-- Update ROW scheduler from codeaurora
-- block: Add support for reinsert a dispatched req
-- block: Add API for urgent request handling
=05/24/14 - V025=
- Build optimize
-- Reactivate global LTO optimization + Fix compile issues
-- Reactivate global strict-aliasing
-- Turn on C++11
- Fix strict-aliasing & C++11 build in following projects:
-- external/stlport bionic external/dnsmasq/ frameworks/av/ frameworks/base external/iputils/
-- framework/native external/powertop external/v8 frameworks/wilhelm packages/apps/Camera2
-- system/core frameworks/ex/ external/chromium-libpac/ external/chromium_org/ external/chromium/ hardware/ril framework/rs
- Set framework/rs version
=XX/05/14 - V024=
- Add floating & resizable windows base code
- Global Actions: Add relaunch TopApp into Floating mode action
- NavBar: Add icon to relaunch TopApp into Floating mode
- Settings: Add Long Press action + Show/Hide for the Relaunch Floating NavBar Button
- Heartbleed openssl fix for platform & chromium webkit
- Trebuchet: update to latest version
- Settings - Storage: Fix Formatting/Erasing SDcard
- Vold misc updates
- LatinIME: Add fallback loader for JNI lib
- Fix reboot on Blank SD card format notification
(+Take to Settings=>Storage to make sure to format the correct device if there are multiple external devices)
- Upgrade libpng
- Add miracast overlay flag
- av: misc changes:
-- ACodec: Add video codec fallback logic
-- stagefright: Smooth Streaming in OMXCodec
-- stagefright: Enable GraphicBuffer usage to decoder before querying formats
-- stagefright: provide a custom key to prefer adaptive playback
- Misc graphic fixes merge
-- Release locked buffer when it fails to acquire graphics buffer
-- Fix for positioning of glyphs within a bitmap
-- Fix graphics corruption caused by HWUI caches
- Rebuild with latest linaro toolchain
=03/20/14 - V023c=
- Include Hebrew, Hungarian + de_ch Keyboard Fix
=03/XX/14 - V023=
- Settings => Accessibility: Fix Autoration locking up
- QuickSettings: Fix Orientation Tile locking up
- QuickSettings: Add Orientation tile, remove battery tile by default
- QuickSettings: Fix Orientation Tile Long Press, open Accessibility
- Turn off Autoration by default
- Hardware Keyboards: Make capslock key behave as shift for all keys including numerics
- Add Global Actions (Available for LongPress + Key Override):
+ Autoration toggle
+ Wifi, Bluetooth, Touchpad toggles
+ Show Power Menu
+ Launch Settings
=02/28/14 - V022=
- Move to GCC target 4.8
- Switch to Linaro-4.8.3 14.01
- Trebuchet: Fix wallpaper not rendering internally when using only 1 desktop
- LockScreen: Display wallpaper when System wallpaper rendering is disabled. (after 1st lock)
- Recents: Increase KillAll button size
- Add libemoji.so
- Fix command line reboot
- Boot tasks parallelizing (should speed up boot by ~30-50% depending on the overclocking and number of packages)
Add multithreading support to Installer/installd
Parallelize package scanning
Parallelize boot dexopt
KatKernel 114:
- Rebuild with Linaro-4.8.3 14.01
- Add isofs + udf modules
=01/26/14 - V019=
- Fix VPN
- Fix ext4 volumes not being mounted when inserted
- Browser: Keep URL bar when using Pie Quick Controls from Labs (Fixes refresh issues with new chromium webview)
- Browser: sync javascript console debug setting with default value (disabled)
- Fix a bootloop problem on xml parsing errors (after improper shutdown ...)
- Fix reference leak in ActivityManager
- Keyguard: fix statusbar lags when default widget shown
- Make ImageView drawable update more efficient if same size
- Fix tablet battery icon alignment
- bcmdhd: add missing interface command fini
- KatKernel 113b: add missing Netfilter/IP options
=01/15/14 - V018=
- Fix NTFS & exFAT volumes not being automounted
- Revert use /dev/input for audio jack detection
- chromium webkit: restrict use of absolute href only if link on image
- chromium webkit: misc updates
- Browser: Add History back
- Browser: Add Debug back
- Add Thai Font
- Add libnetcmdiface
- KatKernel 112: add ip6table filter mangle raw + usbaudio
=01/11/14 - V017=
- Fix GPS/Location Quick Settings Tile
- Fix error when opening linked image in new tab if the link is already an absolute url
- Disable audio level warning
- Disable Dream by default
- Remove old android launcher
- Misc perf tweaks
- Use /dev/input for microphone/headset jack detection (Those who had external microphone detection issue, test and report if that helps or not)
- QuickSettings: Add Immersive Mode Tile
- QuickSettings: Add Location + Immersive Mode Tiles by default
- Add Czech qwerty keyboard layout
- Add new wallpaper mode settings (Settings => Display)
** Normal(regular android mode)
** Disable System Wallpaper rendering (set as default)
** Disable Wallpaper service
2nd setting will prevent the wallpaper being rendered by system and also freeing resources
That's the recommended setting you want to use if you are using a launcher that has internal wallpaper rendering
If you see a black wallpaper that means that your launcher was using system rendering which is not good on our tf101
3rd setting disables wallpaper completely, depending on your launcher it might be better
- New gapps package 20140110
Remove Google Home Launcher from package
- Add separate zip for Google Home Launcher
=01/06/14 - V016=
- Fix HDMIOut options not being applied
- Fix Date not showing in Notifications
- Fix /storage/sdcard0 showing up as empty
- Fix Dock Battery still showing up when booting undocked
- Fix SDCard not being remounted after forced eject or dock sleep
- Browser: Fix img src being used instead of href when long pushing on a linked img and clicking open
- Browser: remove incognito entries (not implemented in kitkat chromium yet)
- Browser: remove debug mode from labs (not implemented in kitkat chromium yet)
- Reactivate rotation by default
- Deactivate MultiWindow icons until fixed
- Report battery charging correctly
- Misc conf change
- Switch Window Animation Scale to on by default
- Migrate Expanded Desktop to Immersive Mode
(Window Animation Scale must not be 0 for swipe down to work)
=01/03/14 - V015=
- Upgrade to Android 4.4.2
- Fix Dock Battery
- Fix reboot to recovery feature
- Fix Bluetooth
- Allow to clear foreground services notifications
- Update busybox
- Settings: Fix missing UI & dock icons
- Default to PhabletUI NavBarLeft + SlimNavBar
- Unify battery text & dock icon colors with kitkat grey
=01/01/14 - V014=
Initial KitKat public release
Download
DEV-Rom
KatKiss-4.4.2_030
Stable-Rom
KatKiss-4.4.2_028
Gapps
Gapps KatKiss 4.4.3 (Stand_05.06.14)
KAT-Toolbox - App
KAT_V1.5 (4.4 kompatibel)
Recovery
aktuellste TWRP 2.7.0.3 zip for TF101
SL101 AddOn Compatibility Pack
TF101G AddOn Kernel
KatKiss-4.4_AddOn_TF101G_Kernel
Tips & Tricks
Autorotation
- Autorotation works, but when changing its on/off state it will sometime freeze for about 1 minute and restart.
(works fine after the restart until you change it again)
Autorotation is on by default for the moment.
Note that autorotation when on will eat a few percent of cpu, so if you don't need it you are better to turn it off.
(Settings => Accessibility => Auto rotate screen)
Global Key Override/Shorcut Mecanism
Available in Settings => Language & Input => Add Key Override Actions
or in Dock Settings
This will allow you not only to redefine function keys assignment, and other special keys actions,
but you'll also be able to assign global macro actions / app launch to any key + Meta key combination (shift Left or Right , ctrl..)
You can also add multiple actions to one key combination, simply click again on the "+" button for the same key combination.
It might not make much sense for the moment, but once I'll add more actions it could be practical.
For example if you want to assign to one key combination a list of action to run before going to bed for example, like: turn wifi off, bluetooth off, mute sound, and turn screen off. You'll be able to do that in the future
Note that starting multiple applications with one key is kinda a miss and hit for the moment due to some mecanism in android that seems to prevent applications to start too close to each others.
Wifi channels:
Choose which channels are available based on your country in Settings => Wifi => Advanced => Change wifi regulatory domain
Google search:
If the version you're using is crashing when you open Google Now,
go to Settings => Language & Input => Voice Search
then uncheck Hotword Detection.
CIFS & 3rd party Mount Apps:
The Rom/Kernel have native support for them as long as you mount it outside or /storage/ and /mnt/shell/emulated/
GPS:
if it is taking a long time to get a lock or no lock, follow this:
Hardware keyboard layouts
More languages have been added in the default asusec keyboard
Set the keyboard layout through Settings => Language & Input => asusec => setup keyboard layouts
These also allow live switching without reboot with ctrl + space
Storage (fstrim) and Database optimization:
Fstrim is native in 4.3 and will happen in the background if your tablet is idle / sleeping and that your battery is > 70%
There is also a script to run it manually in the rom: /etc/kat/optimizestorage
To optimize the Database: /etc/kat/optimizedb
To run both, open a terminal and run:
su
/etc/kat/optimize
Be warned that the optimize storage can take from a few minutes to hours.
But the speed / lag will be greatly improved afterward
Slow downs & Battery drain after a full wipe ? :
Things to keep in mind after flashing with a full wipe:
- Media scanner will need to scan everything again, it can take from a few minutes to hours or days if you have a lot of medias or medias that it doesn't like.
During that process it'll use a lot of cpu and disk, and so can make things lag a bit and drain the battery until it's done.
You can use the Media Scanner filters to speed things up and make it scan only parts that are really containing your medias
- After a wipe, it wipes your battery stats, if you don't flash while you are with a 100% full battery, the battery stats will be inaccurate for a while until it learns again your battery capacity.
The battery can appear to drain faster because it doesn't know where your 100% is.
(see here for tips on how to speed up the learning process)
- Check that you don't have a rogue process eating cpu in the background. (run the top command)
- Check that you don't have a process keeping your tablet awake
MultiWindow
NavBar:
- To switch between full screen and split View you can use the NavBar Button
(It will lay apps alternatively in one SplitView spot then the other.)
- To change focus simply Tap on the app or use the NavBar Button
Recents:
- Clicking on the app Thumbnail works as before and displays the app fullscreen
- Clicking on the app icon or the icon will switch the app to splitview and lay it in "automode"
(If you use automode when an application was set in a SplitView slot it'll be recalled to that previous spot.)
- Clicking on the other icons will force the app to the 1st or 2nd SplitView slot.
Actions
Actions to switch the app between fullscreen / splitview, switch between the 2 most recent apps and to force the splitview slot have been added
so you can bind them to a key / key combination with the Global KeyOverride or long press action too.
Note: Most apps works ok in splitview mode, but some of them might not refresh correctly sometime.
Same when rotating the screen while in splitview mode.
To force a refresh simply tap the app or if you have 2 apps in split, just click twice on the switch to last app button:
__________________________________________________
Thanks to Timduru for KatKiss-KitKat
attachment.php
:scared: ein Danke ist immer gern gesehen :scared:
Reaktionen: Durden, TrapperTheOne, Freitagvormittag und 9 andere
Hat jemand schon Erfahrung mit dem TF101G und dieser ROM? Es gibt ja anscheinend keinen extra Kernel mehr für das Tf101G wie bei 4.3.
Der aktuellste Kernel von Timduru war auch bei der 4.3 schon intergriert. Ist bloß extra nochmal angeboten worden. Den Kernel findest Du in der Rom zip.
Hi, ich meine aber den TF101G AddOn Kernel, der speziell wegen den auftretenden Reboots bei 4.3 und dem Tf101G angeboten wurde.
Achso, ja sowas gibts noch nicht. Das Addon wurde aber ja auch erst später veröffentlicht nachdem die Probleme bekannt waren. Mal schauen wie sich es entwickelt.
Reaktionen: Scott1904
Ja, Kann ja sein, dass es das Problem gar nicht gibt. will aber erstmal nicht flashen. Bin gespannt auf User Feedback. LG
Bei mir crashed immer die Katkiss Toolbox.
Ich bin von KatKiss mit Android 4.3 auf KatKiss #015 gewechselt weil ich eh ein Factory Reset machen musste (Youtube hat sich in der neusten Version immer beendet).
Habe es bisher nicht bereut :biggrin:.
- Denn Freeze mit Auto-Rotation habe ich schon gehabt
- Google Launcher verzerrt irgendwie die Wigets und Icons doch etwas groß, bin wieder bei Tretbuchet
- seit #16 -> #17 Lockscreen ohne Wallpaper?
- Stock Browser, Video schwarzes Bild aber Ton läuft? Bei Fullscreen, Firefox,Chrome und altem ROM #226 keine Probleme
Flashplayer nicht installiert, ich hoffe der wird endlich begraben.
Habe alles aktuell drauf und ein TF101g. Ich habe auch mit 4.4.2. ständige Reboots. Ansonsten läuft es noch schneller, nur die ständigen Starts nerven sehr. Einen separaten Kernel fürs g habe ich noch nirgends gefunden.
die Reboots kommen nur, wenn das Tablet vom strom ab ist., mit Ladekabel bootet es nicht immer wieder neu
Das weiß ich, macht es aber leider nicht besser.
Stimmt,aber ich kann damit leben...
Das freut mich ;-) Ich brauche das Teil mehr um unabhängig zu arbeiten, was so dann nicht wirklich gegeben ist. Aber sicherlich kommt auch der Kernel für TF101g bald, dann ist alles wieder prima.
Wer hat sein TF101 übertaktet? Wieviel und bringt es überhaupt etwas?
@grimes, läuft dann alles ein Tick flüssiger! Noch dazu läuft die 4.4 ausgesprochen flüssig!
Kann man nicht das 3g Modul komplett abschalten? Mir gehen die RRs aufn Sack und die letzte 4.3 von Shevt mit 3g Unterstützung schafft es genauso wenig, hab auch RRs und eben sogar ein SOD -.-!
018 eingefügt
Changelog Update
Google Home Launcher eingefügt
gibt wohl schon ne 019...
=01/26/14 - V019=
- Fix VPN
Add-On fürs Tf101G & SL101
[ROM][KK 4.4.2] [ KatKiss-KitKat #019 ] [Stable] - Page 102 - xda-developers
Bis jetzt keinen Reboot! Muss sagen für mich genauso wie es sein muss, kein Grund mehr das TF zu verkaufen! Für mich ein guter Sprung von Katkiss 4.3 TF101G von Shevt zu Katkiss 4.4! Mein Vertrag ist mittlerweile auch durch und daher interessiert mich das G jetzt nicht mehr sonderlich!
ist eingefügt
Habe jetzt auch mal geflasht,keine reboots,dafür geht bei meinem apex launcher das hintergrundbild nicht mehr...
Belze
  • Belze
regn
Crazy_Malamute
  • Crazy_Malamute
Crazy_Malamute
Crazy_Malamute
Belze
  • Belze
Crazy_Malamute
Crazy_Malamute
