[5.0] KatKiss-Lollipop
nisi01
[ROM][LP 5.0.0_r6] [ KatKiss - Lollipop #009 ]
attachment.php
KatKiss ROM - Asus TF101
attachment.php
Lollipop 5.0.0_r6​
Please note that this version is made and tested on the TF101 model.
This rom is an aosp based rom with my own additions on top of it.
The main motto of the rom being Kiss. Even though the Meerkat could give you a kiss, it stands for Keeps it Sweet and Simple too
Which means that just like the other K.A.T stuff, the rom's main goal is efficiency, speed/responsiveness,
while not adding bloated features that will slow things down
DOWNLOADS:
ChangeLog: http://public.timduru.org/Android/Ka...ChangeLog.html
Rom Source: https://github.com/timduru (branch katkiss-5.0)
Currently Not Working / Missing:
- Bluetooth
- What is crossed in the Features list
Rom Main Features:
Rooted
Floating & Multiwindow support (see post #3)
High speed and responsive oriented
High performance and overclocked KatKernel included
Built with Linaro GCC 4.8.3, -O3 & High optimization flags, Global LTO, strict-aliasing, c++11...
ART
Dock keyboard Support with full special/function keys support
Global Keyboard Shortcuts / KeyOverride Macro association (See post #2 for more info)
Search key quick launch shortcuts
HDMI Support with center/crop/scale options
Battery Level Indicator & Dock Battery support + Mods (icon/Text/%)
CIFS, ext4, NTFS & Exfat support
Wifi Hotspot
Native Android FSTRIM + Manual scripts for Database optimization and fstrim (see post #2)
Media Scanner Filters
Advanced per application permission management (AppOps)
All Wifi channels support
Integrated cpu & io performance settings panel
Custom Navbars buttons long press actions
Navbar with left or middle aligned buttons, and multiple heights.
Auto immersive mode when docked setting
Advanced power menu with reboot options.
Custom Quick Settings tiles
Misc utils Busybox, rsync...
Installation Notes:
Credits:
Thanks to the original TeamEos, Cyanogenmod & Omni for the work on their roms, BaNks, Guillaume Lesniak, jteagle, MWisBest, D4rKn3sSyS and Yanuar Harry for the original code some of the features are based onto.
Original banner concept by i9apps, Bootanimation by mgeniusm, original drawing by BBF
WebPage
How to report
What to include in the report
Disclaimer: The usual
Use at your own risk, I won't be responsible for any damages caused to your Transformer or to yourself.
In most cases if something breaks, flashing a rom on top should fix it.
XDA:DevDB Information
KatKiss-Lollipop, ROM for the Asus Eee Pad Transformer
Contributors
timduru
ROM OS Version: 5.0.x Lollipop
ROM Kernel: Linux 2.6.x
Based On: AOSP
Version Information
Status: Beta
Created 2014-11-16
Last Updated 2014-11-18
Reaktionen: M. Sobol, Android_Men, Gajus und 2 andere
du hast die Installation Notes vergessen...
How to install:
coming from a different rom :
  • Backup everything !
  • Go to recovery
  • Make a full wipe / factory reset
  • Flash the rom
  • Flash gapps
  • Wipe cache/dalvik
  • Reboot
EDIT: habs grad installiert (naja versucht)... leider hat die Installation abgebrochen und mein TF101 befindet sich seit dem in einem Boot Loop! :huh:
sieht so aus das ganze... (ich nutze TWRP Recovery)
Finding update package
Opening update package
Installing update...
set_metadata_recursive: some changes failed
E: Error in /data/media/0/Download/Android5/KatKiss-5.0_009.zip
(Status 7)
* Verifying Filesystem ...
* Verifying Partitions ...
Error flashing zip '/data/media/0/Download/Android5/KatKiss-5.0_009.zip'
Failed!
Lade dir die Datei aus dem Mirror noch einmal runter inkl. der MD5.
Dann mit Power + VOL down, mit VOL up bestätigen ins Recovery.
Anschl. noch einmal wipen und installieren.
Ich gehe davon aus, dass du das aktuelle TWRP (2.8.1.1) nutzt. Ansonsten dieses zuvor installieren.
Bei mir hat alles beim ersten Versuch geklappt.
Reaktionen: Ronko
Wow! haut mich grad aus den Socken, dass noch 5.0 fürs Transformer Pad rauskommt!
Schnupperte eigentlich nur vorbei weil mein Akku im Dock sich nicht mehr aufläd ( Kabel im Dock lädt das Tab aber auf ).
Aber ich glaub jetzt hab ne Beschäftigung für heute Mittag gefunden ;)
Edit: XDA Link
Hier sieht man welche Features nicht funktionieren, da das Durchstreichen hier nicht klappte.
Edit 2:
@Ronko: mit der CWM Recovery habe ich den gleichen Fehler bekommen! Hab dann auf die aktuelle (?) TWRP 2.8.1.1 geflasht und dann hat es geklappt.
Aber jetzt in den ersten paar Minuten läuft erstmal alles ;)
Reaktionen: Ronko
ok danke, probier ich demnächst nochmal :)
Macht es Sinn das unser TF101 überhaupt noch 5.0.0 bekommen soll ?
Ich finde das 4.4.4 schon zu viel für das ASUS TF101 ist.
Wenn alles mal gestartet ist, geht es ja, aber gerade der Browser egal ob Chrome oder Dolphin kommen sehr schnell an die Leistungsgrenze von dem Gerät.
Ich weis, das es undankbar ist, besonders weil manche Geräte nicht mal über 4.0.0 hinaus kommen, geschweige über 4.2.2.
Kann auch sein, das 5.0.0 weniger Performance braucht, weil es Flacher ist, aber ich glaube das hat es beim 4.4.4 auch schon geheißen.
Wie ist die Performance für alte Geräte wie dem TF101 nun ?
Schlechter oder besser als 4.4.4 ?
Die performance ist ähnlich der 4.4.4. Mach doch ein Back-up (ohnehin Pflicht) und probier 5.0. Wenn du nicht zufrieden bist, kannst du immer noch zurück. Aber ich denke timduru holt bei den nächsten Versionen noch etwas mehr performance raus.
Hat jemand schon die Dock-Batterie auslesen können? Ich habe bisher noch keine Möglichkeit gefunden, den Ladezustand auszulesen?
Also die Dock Batterie ist bei mir hinüber... die lädt gar nicht mehr, daher kann ich da keine Aussage treffen. EDIT: Auf der XDA Seite ist dieses Feature durchgestrichen. Kommt also irgendwann später.
Aber ich muss sagen dass die Leistung mit der Version 011 deutlich gestiegen ist! Bin recht zufrieden mit dem aktuellen Stand. Nutze das Tab aber nur auf der Uni als PDF Editor (Tastatur funktioniert 100%) und als Suchmachine. Chrome läuft definitiv besser mit der 011, davor wurden Eingaben spät erkannt und das Scrollen war alles andere als smooth. Jetzt läufts besser, aber doch nicht so geschmeidig wie auf meinem S5. Aber wie gesagt, für mein Einsatzgebiet reicht es vollkommen aus.
Seit heute ist Version 12 verfügbar. Sie basiert auf Android 5.0.1.
Einige neue Funktionen sind dazu gekommen und die performance hat deutlich zugenommen.
Reaktionen: Gajus und M. Sobol
Kann mir jemand helfen oder hat evtl das selbe Problem? Ich kann nach dem aufspielen von Lollipop weder über den PlayStore (unbekannter Fehler 972) noch über apk direkt Apps installieren... gibt ja eigentlich nicht viel falsch zu machen. Katkiss 4.4.4 lief problemlos
Hast du fullwipe (Data) + factoryreset gemacht. Am besten noch einmal durchführen.
Müsste eigentlich danach laufen.
Reaktionen: Gajus
Wie bekomme ich den die neueste TWRP Version?
Also ich hab das Problem, dass ich wenn ich die GApps geflasht hab, das Tab nicht bootet. Jemand ne Idee?
Da wirst du noch mal wipen und neu Flashen müssen.
Danke, habe die 5.0.1 installiert - mit der hat es funktioniert :)
=12/16/14 - V014 =
- Remove SuperSU (=> install with the official zip)
- Allow user to force immersive mode (Settings => User interface)
- Add AutoImmersive mode on docked (Settings => User interface)
- Global Action: Add Immersive mode (available for long press/Keyboard override)
- RightClick: allow to change behavior in settings (normal or send BACK) (Settings => Dock)
- Add Thai font
- Add tip in power menu to reboot to recovery
- Allow to disable sound played when adjusting volumes (Settings => Sound & Notification => Other sounds)
- Disable adjust volume sound by default
- MainBatteryIcon: show as charging when dock is charging it and not only when plugged
- Fix LongPress to UnPin app
- Rebuild with more optimized flags
- Fix kat script permissions
TF101:
- increase EGL cache
- add Framebuffer native window
Version 14 ist draußen! Wahnsinn wie schnell es immer noch voran geht. Werde Morgen oder Übermorgen diese Version mal aufspielen und berichten. Aber ich glaub es besteht kein Zeitdruck... ist ziemlich ruhig hier geworden ;)
Ich habe die V14b ausprobiert. Die lief nicht wirklich toll. Browserabstürze usw.
Bin erst mal wieder auf die V12 zurück. Die läuft bisher am besten.
Update:
Ich habe gerade bei XDA gelesen, dass es am der fehlenden SuperUser Installation liegen könnte.
Die SU-Zip muss also gleich nach flashen der Rom und Gaps mit TWRP geflasht werden.
Werde ich Abend gleich ausprobieren.
Update: Lag am super-user. Also unbedingt vorher die su-zip runterladen und nach Rom und gaps flashen.
Das heisst nach dem flashen vom Super User wieder alles geschmeidig?
Belze
  • Belze
Crazy_Malamute
Crazy_Malamute
Belze
  • Belze
regn
Crazy_Malamute
  • Crazy_Malamute
Crazy_Malamute
Crazy_Malamute
