TvonGartzen
- 9
So, es ist vollbracht.
Ich habe jetzt eine Custom Rom geported aus einem CM12.1 CrDroid mt6580 Rom
Bis jetzt funktioniert bis auf Bluetooth alles. Auch die Anmeldung bei Google, Google Play Store usw.
Das wechseln der Internen und externen Speichers ist auch noch nicht möglich, macht aber kein Problem, da man die Apps auf SD Karte verschieben kann.
Link hier:
crDroid Cubot_Note_S.zip
Open gapps Link:
The Open GApps Project
Audio und Bluetooth Fix:
AudioFix.zip
Rom Main features :
CyanogenMod theme manager;
Power menu customizations;
Nav bar tweaks (on/off toggle and custom dimensions);
Left handed navbar option;
Hardware keys disabler;
Hardware keys rebinder from CyanogenMod;
Keys backlight options to HW keys and keyboard;
Linked volume;
Expandable volume panel;
Customizable QS;
Heptic Feedback for tiles;
Battery text mode (from cm);
Battery icon options (from cm);
Media scanner behavior on boot;
HSPA + icons on status bar;
SlimRoms heads up customization;
Traffic metter on status bar;
Omniswitch;
Documents UI;
Gesture lockscreen;
Gesture anywhere (launch apps and activities from custom gestures);
Weather display on expanded status bar;
Hide camera shortcut on lockscreen;
Option to disable brightness slider from expanded status bar;
Wakelock blocker;
XuiMod toast animations;
AOKP custom system animations;
App circle sidebar;
CPU info overlay option in development settings;
[Connect/disconnect notification support;
Long click support on quick settings;
Screen recorder;
Animated rotation tile;
Wake up on plug;
Development shortcut;
Performance settings from CyanogenMod;
Clock and time clickable in expanded status bar;
Notification ticker;
Quick unlock;
PIN keypad shuffler;
Custom lockscreen shortcuts;
Answer calls with hardware home button;
Status bar clock tweaks (right, center or hide clock with many dates formats to show. Custom colors included);
Notifications counter;
Volume keys wake the device;
Ability to hide the alarm clock icon from status bar;
Dialer Lookup;
Profiles form CyanogenMod (new merges and lollipop style);
Protected apps (using trebuchet launcher);
Filter spam notifications;
CyanogenMod SuperUser;
Clear all button in recent panel with custom option (hide, top right or top left);
Disable search bar in recents;
Privacy guard from CyanogenMod with new Superuser access through it!!!;
Ability to hide superuser status bar icon;
Quick settings pull down with one finger (right, left or off);
Smart pull down;
Configurable 0, 90, 180 and 270 degree rotation;
Toggle to not allow quick settings on secure lockscreen;
Brightness control through status bar;
Double tap status bar sleep;
Data activity indicators;
Call blacklist support;
Increasing ring tone;
In call vibrations;
Ambient display (DOZE features);
Advanced reboot menu;
Option to hide adb notification;
Screen shot quick delete with confirmation;
Long press back to kill with configurable timeout;
Volume button custom actions (skip track, wake screen, adjust sound and keyboard cursor control and swap volume buttons);
Less frequent notifications sound;
Advanced keyboard features (auto rotation with timeout, disable full screen, selector notification, show enter key, volume key cursor control);
New Eleven music player and AudioFX from CyanogenMod.
BUGS
-Same as CM12.1
-You tell me
Installation
- Reboot in recovery (TWRP)
- Copy GApps and crDroid zip to your SDCard
- Boot into Recovery
- DO A DATA WIPE / FACTORY RESET
- Flash crDroid zip
- Flash GApps zip
- Reboot
- Enjoy
Link hier:
Open gapps Link:
AudioFix.zip
Rom Main features :
Linked volume;
Customizable QS;
Omniswitch;
Documents UI;
Gesture lockscreen;
Wakelock blocker;
App circle sidebar;
Screen recorder;
Wake up on plug;
Quick unlock;
Dialer Lookup;
Smart pull down;
In call vibrations;
BUGS
-Same as CM12.1
-You tell me
Installation
- Flash crDroid zip
- Flash GApps zip
- Reboot
- Enjoy
