Jetzt kostenlos registrieren: Mitglieder surfen ohne Werbung!
[KERNEL][OC 1.2+/1.4Ghz CPU/GPU][Gingerbread] Titan Kernel v0.1
  • 14 Antworten
  • Neuester Beitrag
Diskutiere [KERNEL][OC 1.2+/1.4Ghz CPU/GPU][Gingerbread] Titan Kernel v0.1 im Custom-ROMs für das LG P920 Optimus 3D im Bereich Root / Hacking / Modding für das LG Optimus 3D.
kampfbestie
XDA-USER samno schrieb:
Hi guys without further ado i present the Titan kernel for Gingerbread Rom's. Its my first kernel so go easy on me, i still dont know that much.This was compile from LG sources with a few mods to get the radio's working. This currently uses a mix of things from many kernels so credit where credits due.
Features: -Overclocked Cpu to 1.2Ghz (From 1.008Ghz) (Credits to bedwa) -Overclocked Gpu to 390Mhz (From 307Mhz) (Credits to bedwa) -Init.d Support (Credits to Thaiz) -Overclock Module Support (Credits to tekhuna) - Carrier IQ disabled (Credits to Accura Team)
To Add: -More Schedulers -More Governors -Under Volting/Over Volting Interface -Tun, Ko & Cifs Into Package. Currently In Zip Not Scripted. -USB OTG -HID Support -More Kernel Twes should be compatible with all GB roms. With the module overclock ive managed to pull 1.4Ghz stable and its lightning quick. Please post your highest frequences and benches with what rom your using too please. This weekend i might add some scripts for different frequinces unless someone could donate some and it would be good if anyone could help me implement my to add list too. Currently using: Thiaiz 2.6
Screenshots Attached Too.
Big shout out back to bedwa too, thanks mate.
Install Through CWM
IMPORTANT! Please tell me what rom youre using if your having problems so I can Test.
http://forum.xda-developers.com/attachment.php?attachmentid=947448&d=1331761839
kampfbestie
Habe meine o3d gerade auf 1.4 ghz getaktet und muss sagen woooow
top leistung 6978 antitutu
I
intik
Hallo, wie installiere ich das? Muss ich bestimmte Firmware drauf haben ?
musso
musso
Hallo jungs, habe den kernel mit cwm installiert... das problem ist das mein wlan danach nicht funktioniert und nur 1,2ghz habe. Habe rushdroid 3.6.3 drauf muss ich voher ein wipe durchführen bzw. setcpu bearbeiten/entfernen oder läuft es rd3.6.3 nicht? Habe diesen fehler schonmal bei einen anderen kernel gehabt...
danke lg musso
I
intik
Und wie hasst du das installiert ? install zip from sdcard ?
musso
musso
Yep abhängig wo du es gespeichert hast must du evtl. bei in internal sdcard schauen ;)
I
intik
Handy Information steht immer noch mein alten kernel.
musso
musso
kann dir nix dazu sagen da ich sofort wieder mein backup gemacht habe weil wlan nicht ging, aber wie gesagt 1.4ghz hatte ich nicht...
@kampfbestie
du hast ja die meisten roms getestet welche würdest du empfehlen?
bin mit rd3.6.3 zufrieden habe den samba-killer kernel drauf...multitasking is nicht so toll.
was nervt ist wenn man ein anderes rom aufspielt muss man immer alles neu einstellen oder gibt es eine möglichkeit es zu überzuspielen ohne die ganzen apps neu zu installieren? titanium backup habe ich schonmal probiert aber nach den backup nur probleme...
kampfbestie
Hallo ja das stimmt mit rush funktioniert zur zeit wlan nicht
ich.nutze zur zeit thiaiz 2.6.1 mit diesem kernel auf 1.4 und es.funktioniert alles
um zu uebertakten I'm market
emulator terminal runterladen dann eingeben
su "enter" dann
echo 1400000000 > /proc/opperator
fertig
leuft schon teilweise über 1.4
Antitutu 6867
kampfbestie
@kampfbestie
Lade dir mybackup root runter mit.dem sichere ich auch.immer meine ganzen apps
stobias
stobias
Stammgast
musso schrieb:
Hallo jungs, habe den kernel mit cwm installiert... das problem ist das mein wlan danach nicht funktioniert.....
Kann ich bestätigen, alter Kernel installiert, wlan geht wieder.
musso
musso
su "enter" dann
fertig
Antitutu 6867
Hallo muss man das ganze beim neustart eigentlich erneut ausführen?
Wie sieht es eigentlich bei games aus... habe mal dead space (EA) und RF2012 getestet ziemlich laggy das ganze... habe dann mal neugestartet prozessor ->1,2ghz ... lg musso
I
intik
Wo kann man sehen ,ob ich kernel richtig installiert habe ? Infomation steht immer noch meine alte kernel.
kampfbestie
hallo also ich habe das script ein mal geändert und bleibt unverändert
mittlerweile habe ich den 1,3 ghz Kernel welchen ich gleich posten werde da der viel weniger energie verbraucht
mfg
