[ROM][6/11]ROM GINGER 2.3.5 ACURATEAM v1
dj_momo
dj_momo
NEW ACURATEAM GINGER 2.3.5 v1 rom
This ROM only works if you already have changed the BASE BAND. If you don't have changed the base band does not work, but you can install to see how it is. Do not break anything.
We are sorry for our English. Expects you to understand
As always, everything that you do install your own risk. We are not responsible for possible problems. Everything is tried and tested to 100%.
]Hey guys, we bring you the first rom with the Acurateam Gingerbread. Remember that all this can be done by the leak that has brought us Scottydoguk fellow with the 3D Indoptimus rom.
Meta-inf Fix is installed the first since the SD and without reboots of any kind, installs reboots and enjoy.
Free standard operator. Although it is necessary as explained above to a new BAND BASE.
As always be very fast and with the Acurateam's tweaks
LG GINGER IMAGES LAUNCHER VERSION
We Upload 3 versions.
LG original Launcher.
Go Launcher
Adw Launcher.
For each person to choose which works best for you. We the moment I'm with the original.
ROM
Kernel Original Lg 2.3.5
Boot Acura2201 v1
ROM ACURATEAM GINGER LINE VERSION v.1
It is as always a VERY FAST and STABLE ROM
THE ROM:
KOREANA D LATEST VERSION (2.3.5)
GAMES CONVERTER WITH A 3D-2D with depth control
PERFECT STABILITY WITHOUT REBOOTS.
IMPROVED THE MENU OF 3D .. More sense of 3D
SEVERAL BUGS repaired
ACURATEAM IMPROVEMENTS.
It has reshaped the initrd.
This is going to like: I added in the initrd a TCP acceleration, you should notice a big improvement in downloads for WIFI and any sign of HSDPA, 3G, GPRS, etc, etc. .. The fellow I say it works very well, which is awesome.
They have added hundreds of TWEKS in the initrd, to improve stability, consumption, etc. ..
BOOT: V1 ACURA2201
** NEW ** New recompilation BOOT
** NEW ** RAMDISK recompilation of the New
** ORIGINAL LG KERNEL 2.3.5 ** Perfect
** NEW ** Tweaks AT commands init.rc
THE ROM
** REMOVED LG UNWANTED PROGRAMS AND UBUDDY
** INCLUDED 3 keywords, LG NORMAL, SWIPE AND ONE ANDROID. SELECT FROM ADJUSTMENTS OR FROM A TEXT BOX.
** DEODEXADA
** MORE RAM ZIPALING
** ADDED THE SPEED Tweaks
** BETTER CONTROL OF APK ..
** CHANGES IN THE BIN
** SET UP THE ACURA MADE FROM GPS HD2
** NO PUBLICITY IN APK
** ADDED MORE TONE IN CALLS, MESSAGES, AND ALERTS
** SUPER USER
** UPDATED BusyBox
** ADDED CONTROL PROGRAM PRO BATTERY
** ADDED MORE NPC SHOULD LEAVE NOW Pepephone CORRECTLY.
** ADDED MORE setings
** ADDED MORE CHANGES IN CONTROL FILES.
** European time / MADRID SERIES.
** ETC, ETC, ETC
NEW GINGER:
** New camera. Bitarte sharper photos of the recording and 12 Mg / s.
** Best audio recording. Improvements implemented data encryption.
** Improved and much video playback. Improved sense of 3D.
** Added Dolby Digital playback with headphones.
** Upload speed HSPDA to 21 Mg / s
** Added a LG Video Editor.
** No FM Radio .. jijijijijij
** Now you can edit, copy and paste text.
** Best Playback and Sound Equalizer.
KNOW BUGS
NO ROOT (AS SOON SOLVE)(USE THE SuperOneClick for ROOT)
INSTALLATION INSTRUCCIONS:
You need to install the O3D baseband for GB before starting!
See:http://forum.xda-developers.com/show....php?t=1331814
You don't need to install the GB baseband again if you already have it installed.
WHETHER YOU COME AND NEW EQUIPMENT, OR OTHER ROM GINGER, YOU HAVE TO DO THIS
COPY THE ROM TO SD.
RECOVERY MODE RESET
DO ALL WIPES.
INSTALLING THE NORMALLY ROM
REBOOT AND ENJOY
**** NO TWO INSTALATION NEEDED, NO NEED TO SET PERMISSIONS .****
REMEMBER NO CHANGE THIS BAND BASE ROM will not work.
ROM ACURATEAM GINGER V1 BASE INDOPTIMUS 3D WITH LG LAUNCHER. LINK
AcuraTeam_GINGER_V1 - Minus.com
Original link http://www.htcspain.com/roms-384/rom...team-v1-51172/
Reaktionen: wattobk
Kann jemand Anleitung auf Deutsch schreiben wie man das Baseband mit Windows 7 64 bit flashen kann?
Und hat jemand das Rom schon getestet?
Hab die room drauf gehabt und wieder gelöscht !
Keine APN !
Keine APN !
was ist daran ein problem? apn kannst du doch eintragen. ich hab diesbezüglich keine probleme. einzig der akku ist mir zu schnell leer.
Hast Recht !
Ich hatte eh einen Fehler gemacht ,da ich die Übersetzung nicht richtig gelesen habe oder konnte :cursing: Mit dem Akkuverbrauch hab bich auch festgestellt !
Warte lieber bis die originale da ist !
dauert ja glücklicher weise nicht mehr all zu lang
joa also ich hatte die auch schon drauf und ich bin mit cm7 so zufrieden das ich auch auf das normale update denk ich mal verzichten kann, diese rom lief bei mir weder flüßig noch schnell ist ein reinfall gewesen zumindestens bei mir^^
I
wholefish
bigdman
itsmemario
I
