1. Hast Du Lust, bei uns mitzuarbeiten und das AH-Team zu verstärken? Alle Details zu dieser aktuellen Herausforderung findest Du hier.
  1. joker.20, 29.07.2011 #1
    joker.20
    joker.20 Threadstarter Erfahrener Benutzer
    Hier ein neuer custom rom. so langsam gehts los. sehr nice!
    werd ihn natürlich selber flashen und berichten. ob hier das problem auch besteht mit dem mobilfunkdatenverbindung.
    here is the second version of the Italian Rom created
    by me for the optimus 3D.
    The KING_3D_ROM_V1.1
    characteristics:
    version 1.0
    based V10D
    optimized ram
    added root+su
    added busybox
    added animated theme created by me
    removed the original app
    added performance patch
    added gps europe patch created by me
    changed bootanimation
    lg home removed
    added launcher go ex (very fast and powerful)
    added root Explorer 2.16
    the new market optional (open root explorer and go
    to,data/app/nuovomarket.apk and install)
    the keyboard created by me optional (open root explorer and go
    to,data/app/htc_ime by king.apk and install)
    version 1.1
    Fixed bug data network
    Add more APN
    Add anti-ad hosts
    Installation procedure:
    make a backup of applications and data with wipe
    because you will delete 'all the contents of your
    phone
    1) copy the files on the external sd
    2) reboot into recovery (ClockworkMod 4.0.0.9)
    3) make a backup nandroid (useful to restore your
    files and apps)
    4) make the full wipe (Cache, date and Dalvik)
    5) Flash zip from sd card -> select the file
    6) reboot system now
    Optional 7) reboot into recovery and go to backup and
    restore / advanced restore / YOUR BACKUP / Restore
    date (this puts all the files and apps as you had
    before flashing this rom but leaving unchanged the
    current Rom)
    CAUTION DO NOT BELIEVE ME RESPONSIBLE FOR DAMAGE CAUSED TO YOUR ENDING TO THIS ROM
    INSTALLATION REQUIRES A LONG TIME, EVEN 5 MINUTES, AND THE FIRST TO START is very slowly because recreate the cache, do not be alarmed
    1 st version:
    Download KING_3D_ROM_V1.1.zip for free on Filesonic.com
    2 nd version:
    -Equal to the first except that the pixel density has increased, this increasing the screen resolution and the 3D effect in the gallery!
    http://www.filesonic.com/file/1555685051/KING_3D_ROM_V1.1-PIXELDENSITY+.zip
Du betrachtest das Thema "[ROM] king_3d_rom_v1.1 mobile data works too" im Forum "Custom-ROMs für das LG P920 Optimus 3D",
