1. joker.20, 11.09.2011 #1
    joker.20
    joker.20 Threadstarter Erfahrener Benutzer
    hier ein update.
    8° version of the Italian Rom created by me for the optimus 3D.
    The KING_3D_ROM_V1.6
    characteristics:
    v1.6:
    resolved bug of market 3.1.3
    update facebook to 1.7
    add call record, traduttore e my track
    new kernel ( not oc) from htcspain
    augmenting velocity of system
    minor bug fix
    v1.5:
    based V10E
    modified framework with new animations and icons
    optimized ram
    increased the speed of the external sd
    added performance patch
    added gps europe patch created by me
    added root + su
    added busybox
    adding keyboard created by me (go to install it on / app /HTC_IME_by_KING.apk and install)
    added animated theme created by me
    LiveWallpaper added created by me
    removed many of the original app useless or too power-consuming
    changed bootanimation
    lg home removed
    added launcher go ex (+ very fast and powerful)
    the new market option (go to install it on / app / nuovomarket.apk and install)
    added google + black edition
    added twitter Black Edition
    optimus 3D notifications added
    new framework (grazie a samno)
    new tweaks to aumenting velocity
    full deodex (grazie a fab985)
    new market 3.1.3
    new icone animated
    new font: ubuntu
    add widget dialer (per avere il tastierino numerico come widget
    add msn
    add driver for chainfire 3d
    enhanced framework
    Sony added fonts
    changed boot animation
    added a lot of ringtones and notification sounds (about 200)
    added transparent facebook
    XDA added transparently
    added google + transparent 1.0.6 in Italian
    added fasterfix
    Black added gmail
    increased battery life
    greatly increased the fluidity of the scrolling menu
    more tweaks and minor bug fixes
    go to the updated launcher version 2.55 final
    maps updated to version 5.9
    Installation procedure:
    make a backup of applications and data with wipe because you will delete 'all the contents of your phone
    1) copy the files on the external sd
    2) reboot into recovery (ClockworkMod 4.0.0.9)
    3) make a backup nandroid (useful to restore your files and apps)
    4) make the wipe 3 (Cache, date and Dalvik)
    5) Flash zip from sd card -> select the file
    6) reboot system now
    7 optional) reboot into recovery and go to backup and restore / advanced restore / YOUR BACKUP /
    Restore date (this puts all the files and apps as you had before flashing this rom but leaving unchanged the current Rom)
    CAUTION DO NOT BELIEVE ME RESPONSIBLE FOR DAMAGE CAUSED TO YOUR ENDING TO THIS ROM
    PREVIEW:
    Download:
    KING_3D_ROM_V1.6
    [​IMG]
    Zuletzt von einem Moderator bearbeitet: 19.06.2015
  2. Ryou-sama, 11.09.2011 #2
    Ryou-sama
    Ryou-sama Fortgeschrittenes Mitglied
    Wow, das läuft richtig schnell und smooth.
  3. ela8000, 14.09.2011 #3
    ela8000
    ela8000 Android-Hilfe.de Mitglied
Du betrachtest das Thema "[rom] king_3d_rom_v1.6 immer up-to-date" im Forum "Custom-ROMs für das LG P920 Optimus 3D",
  1. Android-Hilfe.de verwendet Cookies um Inhalte zu personalisieren und dir den bestmöglichen Service zu gewährleisten. Wenn du auf der Seite weitersurfst stimmst du der Cookie-Nutzung zu.  Ich stimme zu.
