[rom] king_3d_rom_v2.2
boostermbkking
13th version of the KING_3D_ROM by KING3Developers.
  • Based on v10k
  • Busybox + Root
  • Updated Superuser
  • Updated bin/su
  • Full deodex apps & Framework
  • Original Kernel
  • New King ICS framework
  • Optimized ram
  • Increased speed of microSD
  • Performance patch
  • Increased speed of system
  • Added ringtones ICS
  • Added bootanimation ICS
  • Added music ICS
  • Added Roboto ICS font
  • Added live wallaper
  • Added 2D-3D Converter
  • Added KING-manager
  • Removed LG Apps
  • Fixed bug of GoSmsPro
  • Android Market 3.1.5
  • GoLauncher 2.61
  • KING-manager 1.0
KING_3D_ROM v2.2
KING_3D_ROM v2.2 BETA (more performance but more battery drain)
To install: Put the patch that you want in your SD, and flash it.
Original apps patch
3D games in internal SD
3D games in external SD
KING ICS framework
Frame KING (the old grafics)
Original LG framework
NOTE! You should make a nandroid backup, if something goes wrong, or if you want to restore configuration and apps.
Installation procedure - Quick guide:
1) Copy the KING_3D_ROM in your SD.
2) Reboot in to recovery (ClockworkMod)
4) Do the 3 wipe (data/factory reset, cache partition, and in advanced, dalvik cache.
5) Go to Flash zip from sdcard -> Choose zip from sd card and select the KING_3D_ROM and confirm.
6) When the installation is completed, reboot your system.
Installation procedure - Detailed guide for newbies (ENG\ITA):
- Nandroid buckup
- Install the ROM
Note! Please not restore the data from recovery mode, it may cause reboots. Restore your apps with programs as MyBackup PRO.
Preview of new King ICS Framework
For good effect, you shoud install the GoLauncherEx Ice Cream Sandwitch theme (and apply it in the theme section of GoLauncherEx)
GoLauncherEx Ice Cream Sandwitch theme - Download
hatte eine frage bei mir lauft alles super ,nur habe das problem das bei Gallery
alles zu klein ist weis jemand warum ?
Ich hatte das selbe Problem als ich Chainfire 3d verwendet habe und da was umgestellt hatte.
MfG
Habe einfach Quickpic fur die foto genommen und habe keine problem mehr und lauft beim foto Gallery schneller das ganze
Kann bitte jemand der des Rom hat mir nen Link schicken.
Hab gehört es gibt von dem Rom schon ne neuere Version :smile: also wenn des einer hat dann könnt ihr mir auch davon nen link schicken, ok :winki:
Immer der scheis mit den links down und jetzt kommt dann bald noch des neue Gesetz dinsdabumz (ACTA) :angry:. Naja is ja nicht gerade illegal was wir hier tun. :flapper:
Also bitte :rolleyes2: UPLOADEN und mir nen LINK geben
Danke
MFG Dani4385
KING_3D_ROM_V2.3.zip
Selbst mit Googletranslate komme ich nicht dahinter, wie man da was runterlädt...
Aber Mipony weiß es und lädt es gerade runter, der Jdownloader müsste das wohl auch können :D
Allerdings ist der Speed unter aller Sau, wenn es fertig ist mach ich einen Mirror.
Erstmal Danke für den Link :)
Leider dauert der download wirklich ewig, da steht bei mir dran dases noch einen tag dauert und der läd mit maximal 4 kb/s.
Freue mich dass sich jemand überhaupt die mühe für sowas macht.
MFG Dani4385
bei mir funzt eigentlich alles super, aber mein p920 stürzt andauernd ab.. keine ahnung wieso, ich kann nur den pin eingeben, bisschen im menü rumgucken und dann bootet er von neu. :/ ideen?
1. Warum nutzt du so eine alte Androidversion und so eine alte ROM?
2. Dein Handy verträgt die hohe Taktung dieser ROM nicht. Zu Zeiten dieser ROM war alles über 1150MHz nur für einen Teil der Geräte stabil möglich. Das hat sich inzwischen übrigens geändert.
Reaktionen: s0aPii
hm.. und was nun ?:blink:
Danke für die Hilfe :) , aber habs mit Glück geschafft, in SetCPU zu gelangen und dort den Takt niedriger zu stellen. Hab jetzt wieder die normale stock-rom raufgezogen.
I
wholefish
itsmemario
I
  • Baltasar2k4
palma
palma
