[rom] Thiaiz prada 2.6.1
kampfbestie
is a project to mix and port LG Prada 3.0 system to our LG O3D.It is working almost 100% but it is already good for daily use.LG Launcher 2 rolls much smoother than our LGHome one and it is a lot faster than everything I've tried before on O3D. The ROM is mixed with my V2.6 right now, but the idea is to use as much as possible from the other device's framework.
This is how it look:
Features:V2.6.1GBPrada -Base: V21a + V10h Prada official -
Kernel:ThiaiZ Custom Kernel V0.4 NOOC -
All LG apps are stillthere. -
LG Prada 3.0 apks mixed with O3D apks -
LG Prada: Camera,Network monitor, Scene selector, theme selector , IME, etc... etc.... -
LG Prada Widgetsmixed with O3D widgets.NEW -
LG Prada SystemUI and Framework mixed with O3D's.NEW -
3D converter. -
Deodexed,Zipaligned -
LG Framework and SystemUI are optimized for speed and memory. -
Root browser + FM Radio + WIFI Killer(Justfreeappson my ROM) -
Original 3D games (Asphalt6,Golf2,Nova)arepatched to beinstalled on SDCARD. -
LG Prada wallpapers -
LG Prada's: ringtones,notifications tons and alarm. -
Sony Bravia Engine.(WORKING) -
Sony Xloud Engine.(WORKING) -
HTC Beats Engine.(WORKING) -
Google Play.NEW -
SDcard booster script "Stock 128kb" reads on boot from Init.d (Change the valueaccording to yourneeds). -
ThiaiZ Smoothness tweak V0.3 (Working together with LG launcher 2, making it very smooth). -Increased I/O reading speed with performance pack from O2X. -
SIP over 3G. -
Init.d tweaks (zipalign on boot,RAM management, New SDbooster-128). -
LG ringtones and message tones are gone. Added a bunch of new ones.NEW
ThiaiZ V0.4 Kernel: -Init.d scripts reading ability(finally got it to work on). -1008,1058,1088,1108,1188 modules on boot ability. -
Ext 4 ability. -Unsecure kernel. -more to come
Known bugs: -SNS widget will not work.
Download link:
http://api.viglink.com/api/click?fo...ada.zip.html&jsonp=vglnk_jsonp_13319908607824
Verwende das rom mit go launcher ex
thiaiz smoothness tweak einfach auf gewünschten launcher umschreiben und
es funktioniert
mir gefällt gut das black white thena und die neuen widgets
have fun
Hab mir die Version mal drauf gehauen. Läuft unglaublich flüssig. nur ich hab kein Netz mehr Oo. Kann mir jemand helfen? ich blicks leider nicht so ganz woran es lieg!?
lynnie
So wer lesen kann ist klar im vorteil :)
Also Erst 2.6.1 installieren UND UNMITTELBAR DANACH das update drüber installieren. Nun funtioniert alles ;)
lynnie
Update ->>>
This is a project to mix and port LG Prada 3.0 system to our LG O3D.It is working almost 100% but it is already good for daily use.LG Launcher 2 rolls much smoother than our LGHome one and it is a lot faster than everything I've tried before on O3D. The ROM is mixed with my V2.6 right now, but the idea is to use as much as possible from the other device's framework.
http://www.youtube.com/watch?v=ODzXd...KV3Yt9kG14Ivka
Features:V2.6.1 GB Prada
-Kernel:ThiaiZ Custom Kernel V0.4 NOOC
-All LG apps are still there.
-LG Prada 3.0 apks mixed with O3D apks
-LG Prada: Camera,Network monitor, Scene selector, theme selector , IME, etc... etc....
-LG Prada Widgets mixed with O3D widgets.NEW
-LG Prada SystemUI and Framework mixed with O3D's.NEW
-3D converter.
-Deodexed,Zipaligned
-LG Framework and SystemUI are optimized for speed and memory.
-Root browser + FM Radio + WIFI Killer (Just free apps on my ROM)
-Original 3D games (Asphalt6,Golf2,Nova) are patched to be installed on SDCARD.
-LG Prada wallpapers
-LG Prada's: ringtones,notifications tons and alarm.
-Sony Bravia Engine.(WORKING)
-Sony Xloud Engine.(WORKING)
-HTC Beats Engine.(WORKING)
-Google Play.NEW
-SDcard booster script "Stock 128kb" reads on boot from Init.d (Change the value according to your needs).
-ThiaiZ Smoothness tweak V0.3 (Working together with LG launcher 2, making it very smooth).
-SIP over 3G.
-Init.d tweaks (zipalign on boot,RAM management, New SDbooster-128).
-LG ringtones and message tones are gone. Added a bunch of new ones.NEW
ThiaiZ V0.4 Kernel:
-Init.d scripts reading ability(finally got it to work on GB).
-Ext 4 ability.
-Unsecure kernel.
-more to come
Known bugs:
Download link:
http://hotfile.com/dl/149144239/70d7...Prada.zip.html
How to install it:
-Backup your old ROM just in case.
-Full wipe.
-Flash the ROM in CWM.
-Flash update right after the ROM.
Update link:http://hotfile.com/dl/149260046/3bb1...cript.zip.html
-Reboot and enjoy.
Servus,
Also irgendwie gehn eure links zum Downloaden net "no Found"
Habt ihr nen aktuellen link zu hand ?^^
mfg
Vielen Dank^^
mal schauen wie sie leuft ;)
jetzt mo dumm gefragt!
wenn ich
gegen die neue Baseband V21D ersetzen will, gibts da nen trick ohne mir jetzt den kopf zu zerbrechen?^^
Will mei Handy net noch mo einschicken, deswegen frag ich jetzt mo vorher lieber nach
mfg
wenn ich
mfg
irgendwie versteh ich dein Problem nicht ^^ steht doch alles drin was benötigt wird :)
Na passt schon hab mich nur selbst verwirrt! ^^
trotzdem Dangö^^
hallo, guten tag.
habe mir ebenfalls die version daruf gemacht und es läuft echt perfekt. Auch google apps funktionieren alle und netz habe ich auch. Bis jetzt stört mich blos, dass die nachrichten die ich bekomme (sms) so schwarz hinterlegt sind, dass ich den text nicht lesen kann. Gibt es dazu eine lösung ?
Ich meine dass die "sprechblase" von den eingehenden nachrichten komplett schwarz ausgefüllt ist, sodass man den text nicht lesen kann.
MfG Gotti600
Gotti600 schrieb:
hallo, guten tag.
MfG Gotti600
Ja in dem Thread von Thiai
Ist ein Link für eine update.zip.
Einfach downloaden und dann in den CWM und "install zip from sd card" und die update file installieren. Schon sollte alles normal sein.
Wenns immer noch auftritt,
Factory Reset & Rom neu flashen.
Gesendet von meinem LG-P920 mit Tapatalk
Könntest du mir den link zu der zip datei schicken ?!
wäre echt nett.
Gotti
Perfekt! Merci Vielmals :)
weis jemand was es mit dem "Deko-Modus" auf sich hat un dem Homescreen button? beide funktionieren nicht :)
Hey darf ich nochmal um eure/deine Hilfe bitten ?!
habe da das nächste problem an der rom entdeckt ;-) und zwar kann ich zwar videos ganz normal aufnehmen, diese aber dann nicht abspielen weil sie 0,00Bytes groß sind, dass heißt er tut irgendwie nur so als würde er aufnehmen und erstellt dann bloß eine dateiverknüpfung in der Galerie.
gibt es dazu auch schon ein fix ?
mfg Gotti
Schau mal ob du verschiedene Kamera apps hast die Graue hatt bei mir Funktioniert da gingen dann auch die Videos
eine Frage von einem absoluten Custom-Rom-n00b:
Ich habe ein LG O3D P920 und das habe ich vor ein paar Wochen mit CWM auf Cyanogen fürs O3D von hier geflasht: LG Optimus 3D P920 - CyanogenMod CM7 [Rom]
Grundsätzlich läuft es gut und flüssig, nur die 3D-Kamera und -Video tun nicht mehr so ganz wie sie sollen. Außerdem ist der Akku-Verbraucht auch nicht mehr so toll.
Habe ich einen Vorteil, wenn ich auf Thiaiz flashen würde? Also laufen die 3D-Sachen da besser und wie siehts mit dem Akku-Verbrauch im Vergleich zum Cyanogen aus?
Btw: Ich habe das Baseband LGP920AT-00-V21a-EUR-XXX-NOV-15-2011+0 , kann ich Thiaiz damit problemlos installeren? Also einfach das Thiaiz....zip und das Update auf die SD-Karte schieben und mit CWM flaschen?
Danke vielmals für Eure Unterstützung! Vieles kann man sich sicher selbst irgendwo anlesen, aber ich bin da noch recht unsicher und habe Schiss vor einem "Brick"...
Gruß,
Stefan
I
wholefish
  • Kyomo
p920junk
  • Da_Domi
henfri
