ThiaiZ Gingerbread Clean Rom
Kyomo
Dauergast
182
ThiaiZ schrieb:
Welcome to ThiaiZ O3D V0.2 Clean GB
This ROM is for those who wish all LG bloatware gone.It is my intention to come as close as possible to AOSP keeping 3D fully functional.Many .apks are compiled by me from Android source and on upcoming versions, LG apps will continue to give place for android source compiled ones. Suggestions are always welcome.
Please don't send me PM asking me how to flash the ROM,baseband,kernel or whatever isn't related to development or ideas, I am not gonna answer. Post the questions in the ROM's thread instead.
Here is how it looks:
http://www.youtube.com/watch?v=ergZ-gKUfqI&context=C3e90959ADOEgsToPDskKDbPwpXkKV3Yt9kG14Ivka
Features:V0.2 Clean GB
-Base: V21a official
-Kernel:ThiaiZ Custom Kernel V0.4 1058 OC
-A lot of things from LG are gone. (Some apps and widgets)
-3D converter.
-Deodexed,Zipaligned
-LG Framework and SystemUI are optimized for speed and memory.
-Launcher2,Clock,Android IME,calculator,Google search,analog clock widget, google tips(compiled from android source)
-SSlauncher
-Root browser + FM Radio (Just free apps on my ROM)
-Green Android GB Themed (Bootanimation)
-Original 3D games (Asphalt6) are patched to be installed on SDCARD.
-My Gingerbread theme in it.
-New wallpapers (LG ones are gone).
-Sony Bravia Engine.
-SDcard booster script "Stock 256kb" reads on boot from Init.d (Change the value according to your needs).
-ThiaiZ Smoothness tweak V0.3 (Working together with SS launcher, making it very smooth).
-Increased I/O reading speed with performance pack from O2X.
-LG email + SNS are included back.NEW
-SIP over 3G.NEW
-3D drawer on launcher2.NEW
-MMS.apk( ability to receive larger files ). NEW
-Init.d tweaks (zipalign on boot,RAM management, New SDbooster-1024).NEW
-LG ringtones and message tones are gone. Added a bunch of new ones.NEW
ThiaiZ V0.4 Kernel:
-Init.d scripts reading ability(finally got it to work on GB).
-1008,1058,1088,1108,1188 modules on boot ability.
-Ext 4 ability.
-Unsecure kernel.NEW
-more to come
Known bugs:
-You tell me.
How you Install it:
YOU MUST INSTALL GB BASEBAND BEFORE YOU FLASH THE ROM:
http://forum.xda-developers.com/showthread.php?t=1287236
http://forum.xda-developers.com/showpost.php?p=17177547&postcount=2
Framework + SystemUI and kitchen links:
http://hotfile.com/dl/137249969/642e91a/Framework.zip.html
http://uot.dakra.lt/kitchen/ .Donate to them if you think the kitchen works good.
-Start downloading the original framework + SystemUI, going to uot kitchen and making your own theme if you don't want to use the one on the pictures below.
-Open ThiaiZO3DV0.1GBClean.zip go to system/framework + system/app and replace the frame-res.apk + systemui.apk with the files you got from UOT kitchen.
V0.2 link:
http://hotfile.com/dl/146252942/5b84dfb/ThiaiZO3DV0.2CleanGB.zip.html
-Download and copy the .ZIP file onto your SD or Phone.
-Restart device in CWM (Vol down + 3D + power)
-Backup your old Rom
-Wipe data + cache (All your data will be gone)
-Choose "Install Zip from SD card"
-Browse the .ZIP file and install it.(takes 3 minutes)
-Boot device and ENJOY.
ThiaiZO3D GB Green Theme:
http://hotfile.com/dl/146249754/aa48e34/ThiaiZO3DGBGreenTheme.zip.html
ThiaiZO3D Kernels for GINGER BREAD only:
-V0.4 http://hotfile.com/dl/141095076/01b8611/V0.4.zip.html
-V0.3 http://forum.xda-developers.com/show...1#post21097245
http://hotfile.com/dl/140296857/1bb19b3/V0.3.zip.html
-V0.2 http://hotfile.com/dl/137278560/7eb2...C1100.zip.html
-V0.1 OLDER Kernel package :http://www.multiupload.com/2AJDK75KEL
THANX:
-My mates: Gerrett "Road Runner" and Claudio67 for boot.img compiling.
-Ricardo Cerqueira - For "boot.img how to" and opening up possibilities to O3D
-Tekahuna - for OC modules http://forum.xda-developers.com/show....php?t=1355474
-ACURA Team for Kernel in old versions.http://www.htcspain.com/roms-384/acu...-2011-a-50087/
-Zeppelinrox for V6 SuperCharger! The ONLY Android MEMORY FIXER! 3G & KAK! http://forum.xda-developers.com/showthread.php?t=991276
-Ipy (Smoothness tweak) I re-made it to our O3D
If you think this ROM is good, buy those people under thanx or myself a beer
I am not responsible for anything this ROM can cause on your device, you shuold know what you are doing
Originalthread: [ROM][25/01/12] ThiaiZO3D V0.1 Clean GB-Non Stock,Stable and fast - xda-developers
Bedenkt bitte, dass diese ROM auf GB21a basiert.
Ergänzung zum beigefügten Smoothness Tweak:
Das Smoothnessscript bewirkt hauptsächlich, dass Apps im Memory (RAM) bleiben. Damit erspart man sich die Wartezeit beim Öffnen dieser, da sie nicht neu geladen werden müssen. Vor allem sinnvoll ist dies bei der Kontaktapp, der Smsapp, dem Kameraprogramm, dem Musikplayer oder jeder anderen App, die ihr oft nutzt.
Eingetragene Apps werden nicht automatisch nach dem Neustart gestartet. Es verhindert nur das Schließen dieser, wenn sie einmal geöffnet waren.
Das Skript ist in dieser Version auf den SSLauncher und Stockapps angepasst.
Um es zu bearbeiten benötigt ihr folgendes:
1. Texteditor, der lesen und schreiben kann (Empfehlung: Jota Text Editor)
2. Einen rootfähigen Explorer (Empfehlung: ES File Explorer (in den Einstellungen auf Root stellen))
Zum Verständnis schreibe ich in dem Beispiel das Script für den Go Launcher EX (Launcher) um.
Schritt 1: Den Namen der App, die ihr permanent im RAM halten wollt, erfahrt ihr in data/data. Der Ordnername entspricht hier dem Prozessnamen. Im Beispiel findet wir den Launcher als "com.gau.go.launcherex".
Schritt 2: Das Script öffnen. Es befindet sich in etc/init.d und heißt "96thiaizsmoothness"
Schritt 3: Ziemlich weit oben findet ihr folgende Zeile: USER_LAUNCHER="hier steht der SS Launcher". Diese Zeile ändert ihr in diesem Beispiel nach: USER_LAUNCHER="com.gau.go.launcherex"
So könnt ihr noch weitere Apps permanent im RAM halten:
Im Script findet ihr 3 verschiedene Bereiche:
# Resident system apps
# Other system apps
# Other apps
In allen Bereichen ist der Code recht gleich und sieht wie folgt aus: if [ $PROCESS_1 -eq "0" ]; then PNAME="blabla"; NICELEVEL=-20; if [ `pidof $PNAME` ]; then renice $NICELEVEL `pidof $PNAME`; PROCESS_1=1; P_CHECK=`expr $P_CHECK + 1`; fi; fi;
Um diesen anzupassen müsst ihr den Prozessnamen eurer App in PNAME="blabla"; eintragen.
Beispiel 1: Go Kontakte EX anstatt stock Kontakte:
Findet die Zeile: if [ $PROCESS_1 -eq "0" ]; then PNAME="com.android.phone"; NICELEVEL=-20; if [ `pidof $PNAME` ]; then renice $NICELEVEL `pidof $PNAME`; PROCESS_1=1; P_CHECK=`expr $P_CHECK + 1`; fi; fi;
in #Resident system Apps.
Ändert PNAME="com.android.phone"; in PNAME="com.jbapps.contactpro";
Beispiel 2: Go SMS Pro als weitere permanent zu behaltende App hinzufügen:
Findet die Zeile: # if [ $PROCESS_1 -eq "0" ]; then PNAME=""; NICELEVEL=-20; if [ `pidof $PNAME` ]; then renice $NICELEVEL `pidof $PNAME`; PROCESS_1=1; P_CHECK=`expr $P_CHECK + 1`; fi; fi;
in #Other Apps.
Ändert PNAME=""; zu PNAME="com.jb.gosms"; und entfernt die # vor dem if am Anfang.
Reaktionen: p920junk
Die Geschwindigkeit ist entsprechend der höheren Taktung noch leicht über der V2.4, ansonsten geht es hier eher um AOSP im Gegensatz zu LG Stock. Echten Performancegewinn bekommt man durch den Wechsel nicht.
Und wie siehts mit akku aus?
das ist doch egal kann mir ja auch auf die 2.4 einen anderen v0.4 Kernel drüberlegen
Ich nutze den Go launcher ex und habe mir Thiaiz script auf go launcher umgeschrieben und es leuft alles butterweich :D
kauf dir einen 3500 er Akku dann hält das Teil auch ganze 3 Tage ohne an die Dose zu müßen (ca 25 euro)
:thumbsup:
Hab ich schon :D hält jetzt schon 12h bei denen es ungefähr 9 h im betrieb war ( bin grad in Paris und mache viele Fotos und Videos und bin viel im internet) und der akku hat noch 30% ist aber der 3500
habe mittleweie halle roms fur 3D probiert das ihr ist eine der beste,
habe mit 1230 mhz und hone probleme usw
gruss
da es meine erste Custom Rom ist kann ich schwer die Vorteile oder Nachteile zu anderen bewerten ich kann nur sagen das ich sehr zufriedend damit bin. Keine Bugs nach paar Tagen intensiver Nutzung. Ah doch eine Kleinigkeit war da , vielleicht ist es auch nur bei mir der Fall , das Anwendugswidget 2x1 zeigt weder die Anzahl der laufenden Apps noch die Verfügbare Ram Kapazität. Das hat mich aber bisher nicht größer gestört gibt ja genug alternative widgets etc.
Das einzige Manko wie ich finde ist die Berechtigung des SS-Launchers der Telefonieren können will. Das ist mir ein Dorn im Auge gewesen und ich habe mich vom SS-Launcher getrennt. Ist das gerechtfertigt weil der Launcher die Telefonate eventuell aufbauen muss wenn die Kontakte auf einem Startscreen liegen. Naja notfalls gibts ja ein Titanium Backup wenn doch nochmal Bedarf danach wäre.
Danke an Thiaiz für die entwicklung und Kyomo für den Support hier.
Danke, dass du sogar an mich denkst ;)
Das Anwendungswidget habe ich gerade mit dem Go Launcher EX getestet, funktioniert. Falls du auch den Go Launcher benutzt kann ich dir vor allem den Go Taskmanager empfehlen. Lässt sich auch in vielen Fällen passend zum Launchertheme themen.
Dass ThiaiZ den SSLauncher favorisiert ist nicht so wichtig, man kann ja einfach wechseln.
Ich schreibe gleich noch in den ersten Beitrag wie man sein (Ipys) Smoothness Script individuell nutzen kann.
Falls die ROM hier jemand benutzt, der nicht selbst bei XDA ist: Update (V0.2) ist verfügbar! Bin gerade am Downloaden. Erster Post editiert.
habe sie vorgestern begonnen zu laden , download brach bei 40% ab , mein Router bringt mich noch in die Klappse. Naja anderes Thema. Wenns klappt werd ich heute Abend noch Flashen und auch einen Test zum V 0.2 machen.
Hast du es schon drauf und kannst schon erste Erfahrungsberichte abgeben ?
Bin schon sehr gespannt. V 0.1 fand ich genial bisher, aber verbessern geht ja bekanntlich immer.
p920junk schrieb:
Habe viele Ghostcalls mit v0,2 ebenfalls laags bei Games und die 3g Verbindung bricht oft ab
Zur Zeit die Beste Rom ist die von Rush (meines erachtens based on Acurateam SAMBA
Ghostcalls hab ich mittlerweile bei V0.1 ebenfalls festgestellt leider. Ich werde die Rom von Rush jetzt auch nochmals ausgiebig testen.
Aber danke für den Tip.
Leider hab ich auch mit der alten version vom Rom Manager keine Möglichkeit den Recovery Mode zu installieren. habe v4.4.4.7 installiert mit der die recovery mode installation problemlos funzt doch jetzt ist da leider nichts mehr zu holen. es erscheint jedes mal die meldung fehler beim doenload vom server , kennt da jemand eine lösung. ich suche jtzt mal selbst nahc einer funktionierenden version/variante weiter aber vll kann mir ja jemand einen tipp geben .
MFG
Werde wohl passen, denn ich habe mich in das Real3D ICS Theme verliebt und das will bei ThiaiZ einfach nicht funktionieren. Bin derzeit auf WaterBear3D V4 unterwegs und bleibe dort bis das Theme gepatcht ist.
Wäre ja toll, wenn Acuras Experimente tatsächlich das Ghost Call Problem gelöst haben, aber ich habe da noch meine Zweifel. Mal abwarten, bisher leide ich eh nicht unter dem Problem, vermutlich, weil ich derzeit so gut wie nie mit 3G unterwegs bin.
Zu deinem Problem: https://www.android-hilfe.de/showthread.php?t=201313
Ich glaube das hilft dir weiter.
Sent by my LG Optimus 3D using Tapatalk
MFG
So mein Rom Manager Problem ist gelöst. Etwas peinlich aber ich hab unter Droidwall den Internetzugang noch nicht freigegeben für den RomManager wodurch der natürlich keine Chance hatte das Recovery menü zu installieren. aber gegen 1 Uhr kam mir dann der gedanke noch gestern abend.
Ich habe dann Thiaiz Clean V0.2 mal angetestet nachdem ich bei der Rom von Rush 2 mal nicht fertig flashen konnte. Der vorgang unterbrach an 2 verschiedenen Stellen also muss ich mal auf fehlersuche gehen.
V0.2 ist optisch identisch abgesehen von der optik im Menü. Mit dem ICS Theme kann ich bestätigen , das hat bei V0.1 nicht gefunzt und wird hier vermutlich auch nichts aber ich evrsuchs mal.
im Thread zu Rush`s Rom gabs ja auch eine Problembeschreibung wegen nicht funktionierender Installation da werd ich mal ein wenig ausschau halten und nochmal alle lösungsansätze probieren.
mal schauen iob ich dann mal eine konstellation finde die mir gefällt.
Das ICS 3D Theme is extrem gelungen. wenige änderungen würde ich noch gerne durchführen , dazu muss aber mal ein langer freier sonntag her.
Also ThiaiZ V0.2 läuft mit dem ICS Theme V1.1 nun wunderbar. Ist schnell, gefällt mir gut, V0.1 und WaterBear3D waren aber auch gut. Da ich nach subjektivem Eindruck und nicht nach Benchmarkpunkten bewerte fällt mir keine Leistungssteigerung auf. Ist aber auch egal, denn ich bin generell sehr zufrieden mit den ROMs.
Benchmarks sagen zwar nette vergleichbare daten aber bei mehreren messungen gibts da ja auch unterschiede der persönliche bedienkomfort muss stimmen.
Momentan bin ich mit Thiaiz 2.4 und dem ICS Style gut bedient was ram und leistung angeht. Soweit passt alles , das problem ist nur das ich feststellen musste das ich beim versuch jemanden anzurufen nach dem ersten klingeln nicht mehr im telefonmodus bin. Bisher hatte ich das Problem noch nicht , ist heute zum ersten mal aufgetreten. Mein Baseband ist original ich habe damals den LG Updater genutzt danach Thiaiz Clean V0.1 zufrieden geutzt , danach jetzt 2.4 mit dem ICS Look. Bei 2 telefonnummern (beide Festnetz) trat das Problem auf. Ich werde es mal weiter beobachten wie es voran geht. Über Ghostcalls bekam ich noch keine Meldung bisher. ich werde aber mal ein paar tage lang mich selbst mehrfach anrufen und da auch mal schauen ob ich probleme feststelle.
Ich würde gerne noch eine Rom von Rush testen bevor ich dann meinen dauerhaften Zustand whle bis das Samsung Galaxy S3 erscheint. Ich hoffe auf April . Ein solch teures Gerät wenn ich esneu hole würde ich aber nicht modifizieren erstmal weswegen das P920 dann vermutlich trotzdem in meinem Besitz bleibt.
  • kampfbestie
Kyomo
I
wholefish
  • Kyomo
9 10 11
palma
palma
