*[ROM] [4.4.2] Remix Rom
2.9.4 draussen
Ich habe noch die 2.9.2 stable.
Frage: Ist ART schon weit genug ausgereift und implementiert im REMIX ROM, dass es nutzbar ist?
Oder gilt hier:
Einfach ausprobieren, kann nix kaputt gehen?
2.9.5 (Build2) ist draußen
ChangeLog
4th June 2014 (ver 2.9.5 bld2)
fix unknown statusbar and navbar transprancy issue
update halo icon assets
3rd June 2014 (ver 2.9.5)
Kernel: bk14 beta3
1. squashed RAMspeed improvement from MpoKang
- Enable SCU Speculative linefills
- Tuna: set PL310 cache controller prefetch offset to 3
- Enable PL310 double linefill for Tuna board
2. OMAP4 : do not force workarounds for errata fixed in 4460
3. Update to BFQv7R2
4. Governor : Aggressive, Gallimaufry, Pegasusq and Lulzactive
5. IO scheduler : FIFO scheduler (ASKP)
ROM
1. Drop New Theme Engine
this gives nothing but battery eating and instability at this stage.
2. Launcher3
- Add hotword detection
- Gmail className activity update
3. Tiles:
- cleanup WeatherTile and fix NPE
- WeatherTile : show parsed Temp info correctly (depends on LockClock Settings)
- update EqualizerTile
- Pimp up QuickRecord Tile
4. App2SD support (for device with external sdcard)
5. Shake sensitivity adjustment (slim)
6. Fix hiding ADB notification icon (cm)
7. Slim Recents : option to show topmost task
8. Add Volume Control to SlimAction Shortcut
9. Dialer
- Transpatency Glowpad background (slim)
- fix flip action
- Pulse Torch on incoming call(slim)
- Fix reverseLookup (attend: we only accept US number msg)
10. Locscreen Notification : fix expand and clearall button behaviour (vanir)
11. Battery View Fixes (slim)
12. Halo : add boost hints support.
13. OmniSwitch : rework scroller fling
14. Experiment Gps improvement (mwibest)
15. Power Button Fast Torch (Vanir)
nochmal alle ChangeLogs bis zur aktuellen 2.9.7 Build 2
(für alle, die es interessiert)
ChangeLog
19th June 2014 (ver 2.9.7bld2)
Settings : fix derp advanced Menu
update SuperSu to 2.0.0
19th June 2014 (ver 2.9.7)
1. Hover Enhancement (credits Der-Schubi)
- Master Switch enable and hidden option
- option to show up only if statusbar not existing
- QuickSettingTiles
2. Recents Panel rework
- optimize UI execution code (vanir)
- rework switching code base on Vanir's work
- add back HTC View mode
- update dependency logic with panel view option (All Clear Button, Rambar, Slim options...)in Settings menu
3. UserTile code update (CM)
4. Peek : sensor improvement
5. Apollo : external storage readable
6. Add UUID (re-)scan support for vold-mounted volume
7. Settings : remove More Settings Menu, move options inside to Display and Sound settings menu accordingly.
12th June 2014 (ver 2.9.6 bld3)
- update density changer
- add back font size control
- listview animation fix
11th June 2014 (ver 2.9.6)
1. Merged with AOSP source (android_4.4.3_r1.1)
2. PA HOVER
3. PA Peek
- support Peek APK
- rework blacklist interface (based on CRdroid )
4. LockClock : Fix YahooPlaceFinder Api Call
5. OmniSwitch: fix quick switcher derps
6. Lockscreen Notification: invisible clearall button when NonClearable Notification(Mokee)
7. Gesture Lock Security
- remove backgroud and use kitkat color scheme
8. QuickSettings:
- Port CompassTile (CM)
9. Lockscreen
- add unlock icons for Gmail and Snapchat
10. Settings
- Power Button to end call, move to hardwarekey thread
- Fix isPackageInstalled logic. (CM)
- PA PIE : fix dependency
2.9.8!
Reaktionen: mycom
Die letzten ChangeLogs - Aktuell: 3.0.0 :biggrin:
ChangeLog
15th July 2014 (ver 3.0.0 )
1. HEADSUP Notification
- rewrite, merge both CM and Slim's modification, apart from Slim's option,
now we have do not disturb and blacklist support from CM. (Settings option moved to gesture thread)
- add floating Window support as well (credits lion378)
2. Halo and Hover
- code cleanup and possible NPE fix.
- fix notification ticker count issue (credits Vanir)
3. Scroll Animation (Vanir)
- touchslop configuration
4. Quiet Hours
- add back option to diable system sound (camera shutter sound as well)
- Extra Daily Times (Slim)
5. Port AICP weather panel (based off TEAM EOS)
- I have rework the code , incorporate with AOKP panel and fix update view without UI restart (except the option with statusbar icon)
6. Active Notification
- Lockscreen Notifcation : squash update and fix (PA)
- rewrite activation code, use list preference to handle activation of Active Display, Lockscreen Notification and Peek. (only one should be activated)
7. Disable Immersive Message to power menu option
8. NavBar IME cursor : option to use Home/ End action (credits Der Schubi)
9. Attempt to fix LTE toggle in Power Widget
11th July 2014 (ver 2.9.9 bld4 )
- Swiftkey popup issue workaround (credits DirtyUnicorn)
- HeadsUp: Correctly add and remove the window
- fix NPE with missing soundpackage files
10th July 2014 (ver 2.9.9bld3 )
Fix Dalvik merge derp
Fix System UI crash with pattern lock set.
9th July 2014 (ver 2.9.9bld2 )
1. Fix Floating Window Mode.
- Correct wrong behaviour with back button pressed
- Fix possible NPE with press action outside float window.
2. Email
- auto fetch attachment with POP3 account
- fix save attachment to local disk with POP3 account
8th July 2014 (ver 2.9.9 )
1. F2FS &EXT4 all in one support by fallback file system handling (credits Team Motorola Mobility and MWisBest)
- just flash the rom no matter which file system you are using, no need to use base pack replacement anymore.
NOTE : For t0lte user : Only System, Data and Cache partitions support F2FS flags.
2. Volume Wake option fix
3. Swipe to lauch Floating Window with Recents (Stock view) and Notification (PA)
- swipe left/down to lauch Floating mode
- swipe helper
4. Hover performance improvements and updates (PA)
- Respect screen limits
- don't treat outside touch event.
- exclude from insecure lockscreen
- fix custom display timeout not showing
5. Quiet Hours Rewrite (slim)
- New Toggle States.
Toggle is now aware of if quiet hours is truly enabled or not.
Enable "force" mode on click: turns quiet hours on / off
Double-click to return to "timed" mode.
- New Features:
Wifi Connected Requirement
Battery Charging Requirement
Individual day times
- Completely rewrote quiet hours to reduce system calls.
No more calendar objects or checking three preferences
and comparing their values on each quiet hours check.
Reduce that to ONE preference check per preference
6. HEADS UP Notification (Slim)
it is a exposed version feature of AOSP L, simply like PA's Hover and modified by Slim.
- seperate control on Mms, Dialer and Email Client
- replace non-intrusive callcard with Incoming Call in background
- snooze timer support.
7. Settings
- Make settings searchable.
- show devices connect to Wifi hotspot
- Use actual storage type of sdcard/usb
- Show notification on adb over network
- App sidebar : fix icon label
8. OmniSwitch: added flat style
9. Keyguard IO and rotation improvement (vanir)
10. External SD card write permission fix
11. Android Lollipop Fonts
12. Apollo: Display the song duration in the queue and info views
und aktualisiert... Aktuell V3.02 (bld3)
ChangeLogs
11th August 2014 (ver 3.0.2 bl3)
fix webview issue
10th August 2014 (ver 3.0.2 bl2)
- fix compatibility issue with Google Camera.
Previously I am using the Linaro toolchain optimize jpeg library which breaks google camera.
- add back change wallpaper permission with systemui to fix blackscreen issue with google home launcher installed.
- Remove Touch Slop in Scrolling settings which cause hampering
8th August 2014 (ver 3.0.2)
bld1
- fix call delay and fc with sound settings
1. UI rework and organisations
- use actionbar switch for customization options in 2th level.
- move BatterySaver, Quiethours option to first class and add a easy enable switch
- reorganizing menus:
move pie options to navigation, create new divider of notification service.
2. fixes:
- Weather Panel view creation not stick with on/off action
- PA Pie attach code fix, no longer need a systemUI restart to apply changes, and fix possible npe with startup
- Statusbar Carrier Label : make sure settings stick with boots
- Fix SlimPie recent panel bug (CRdroid)
- remove proximity wake option for device not support
- set call in background option to false.
3. Hover
- add touch to hide settings (CRdroid)
4. Recents Panel
- Custom Color background for AOSP stock view
5. SystemUI: Replace CompassTile RotateAnimation with tweening (CM)
6. SystemUI: 4G/LTE icon toggle (base on aokp)
- only show with device support
7. Add information on how to reset swpe to notification (PA)
8. Profile : don't change media volume when music is active (CM)
31st July 2014 (ver 3.0.1 bld1)
fix ListViewAnimation
31st July 2014 (ver 3.0.1)
Kernel :
omap4 nand update (dirtyV)
f2fs update (agni kernel)
add SIOplus scheduler (fancy)
1. art/libcore/dalvik
- A char array copy optimization
2. bionic
- update memmove for 32bits atomic
3. Filter Spam notifications (CM - privacy settings)
note : CM's implementation will override all notifications option (Halo, HeadsUp and Hover)
even you have remove assignment in settings table ,
it still block the notifications unless you turn off & on the notifications option again.
4. Fix MultiWindow conflicts after floating windows backpress fix.
5. Profiles
- add 4g as connection options for profiles (cm)
- Add Bluetooth A2DP profile trigger
6. Headsup Notification:
Show headsup at the bottom of the screen (slim)
add Slimactions (slim)
7. SlimRecents:
Custom Color Background
8. Settings:
Fix search highlight
9. InCallUI & Dialer:
More locale support to T9 search
Show extra contact details (aokp)
make imcoming call screen style configurable(cm)
make navbar translucent (cm)
avoid layout change on disconnection (cm)
10. Mms:
auto enable data (cm)
mms : mark as unread fix (cm)
storage full npe fix (cm)
aktualisiert: (ver. 3.0.4)
ChangeLog
1st Sep 2014 (ver 3.0.4)
Thanks to the active repsonse from chinese forum user
I believe until I get a phone, this is another stable build to use.
1. Fix UI restart issue of pulling down notification by reverting the contextual statusbar header.
2. HeadsUp notification (blacklist mode, yet DND mode still not working)
3. Mms - slideshow attach npe
4. Add wifi toggle to powermenu
5. Add gesture panel action to slimaction system (port forward from Vanir Rom)
- rework and share the gesture with Gesture Anywhere
6. Fix Active Notification options not sticking.
7. Fix possible SystemUI FC (Omni)
29th August 2014 (ver 3.0.3bld2 fixed)
1. fix Headsup mode not applying with Dialer
29th August 2014 (ver 3.0.3bld2)
1. Revert seperate settings button in notification panel, it mess up the notification header with dpi changes.
assign the settings shortcut to long click action of notification button (we have quick settings edit button )
2. rework headsup incallui funcition in dialer
use listpreference to choss between hover, headsup and headsup with expanded always
27th August 2014 (ver 3.0.3bld1)
1. Fix Density changer derp (white line under action bar)
2. PA Pie cleanup and fixes :
- borrow some code from DU and AICP which fix PIE Stick
- fix swipe action target and notification layout.
3. rearrage notification button order, move clear button to the right side.
25th August 2014 (ver 3.0.3)
This project will be postponed after this build.
I have been working hard and concentrated on polishing some details and bring
in some theming component as an alternative choice for a rom with no new theme engine.
Thx to the beta tester from Chinese forum to help me out with this (final) release.
Add Custom Color support (credits darkKat)
- Slim Recents headers
- Navbar and statusbar background
- Statusbar: system and notification icon
- Notification panel : wifi and carrier label
- Settings menu (root list) : icon and titles
Custom Boot Animation (AOKP and darkKat)
Statusbar
- Taffic Meter style revamps (Omni)
- notfication counts on statusbar
Notification :
- Settings buttons (configurable)
- Tiles edit buttons (shown by default with quicksettings panel)
- consistent animation effect when swiping.
Quicksettings :
- enable equalizer for wifi display
Active Notification :
- fix quiet hours logic (Vanir)
- rework settings menu : Corresponding settings option display according to notification service selected.
Battery :
- Circle Battery : add Dot length, offset and interval settings (darkKat)
Dialer :
- add popup menu with enabler option when selecting headsup notification.
Others
- Increase Cpu Boost time to Scrolling
- Catch possible FC with statusbar recreation
- Soft Reboot mode (CM)
jungs schreibt mal paar Feedbacks zu den updates. bin jetzt auf Nexus 4 umgestiegen und kann die updatens nicht testen. ( Freundin läst galaxy Nexus nicht flashen :D )
Hab nichts weiter dazu geschrieben, da ich hier scheinbar Alleinunterhalter bin:tongue:
Die Rom läuft bei mir sehr smooth und stabil.
Ich hatte nur hin wieder Abstütze der UI bei den Pull down notifications.
Ich hoffe die sind mir dem neuen Update weg.
Mal schauen...
War auch nicht immer. Mir schien es, das es schon mal daran lag, wie schnell ich 'runtergewischt' habe.
Reaktionen: motoroller
Die wahrscheinlich letzten Updates:
Die Final ist erreicht.
Seit der Version 3.0.4 läuft sie bei mir absolut fehler- und abstutzfrei.
Die früheren Abstütze der UI sind Vergangenheit.
Ich kann die Rom nur empfehlen!:thumbup:
ChangeLog
17th Sep 2014 (ver 3.0.4 STABLE Final)
Fix screen turn on dim issue with Stable kernel
Headsup Custom Background
sync slim translation
sync CM aosp patches
Adaptive backlight support (CM)
3rd Sep 2014 (ver 3.0.4 STABLE)
Fix notification keep showing up in several case
Fix Volume Panel overlay time not sticking.
PA PIE :
- add torch, omniswitch, gesture panel button
- not showing search button by default, and option not lights out if google search is not install.
MoRtAl
Pierro
Pierro
Pierro
rl2664
