scimitar
Stamm-User
- 192
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem "Samsung Galaxy Nexus". Wenn ihr nicht sicher seit, was ihr macht, könnt ihr hier gerne Fragen stellen, aber wenn ihr danach immer noch nicht genau wisst, was ihr tut: Lasst es bleiben!
Ersteller und damit alle Credits gehen an codenamedroid
[ROM][06-03-12][AOSP][4.0.3] Codename Android 1.5.0|Fully Open Source+Nightly Builds - xda-developers
Download:
Full ROM 1.5.0: CodenameDroid-(MOD)-1.5.0-GN-GSM.zip
GApps HERE Always use latest GApps
CodeName Android ROM Utility HERE - One stop shop for all ROMs, Kernels, Themes and much more.
Mirror Downlod:
Codename Android: World-of-Nexus
Codename Android is a fully open source rom that focuses on speed, usability, and getting every feature that we can get CRAMMED in there
Our mission is to spread the Open Source Android love to as many people as possible, and get as many people involved as possible. Along with the rom there will be tutorials to get more people involved and learning how to build android step by step. (Will post soon)
Thanks
-CodeNameDroid - New partner in crime
-To those that have donated. THANK YOU! Very much appreciated.
-Google, AOSP, sixstring, arifhn, dvgrhl, boykioy, smorks, nexusphone
EVERYBODY IN THE ANDROID ATMOSPHERE!!!
All other open sourcers that made a contribution to the project:
Specifically: Team Gummy, romanbb (Android Open Kang Project) Birdman (RootzBoat), imoseyon, CM
The whole Android Community.
Sorry if I missed anyone.
Tweaks
-Custom settings package
-Many lockscreen options
--Ability to change from 2 - 8 lock screen shortcuts by increments of two
-Status bar options
--Ability to change battery from stock battery to no battery or battery bar
--Ability to change clock color, position, display AM/PM or remove clock
--Ability to change number of icons displayed on status bar
-Ability to select what you want displayed on screen when docked or plugged into power. Settings -> Display -> Eye Candy ->
-Enhanced power menu+ with fast reboot option
-Status bar widgets with ability to customize status bar widgets - Base CM source
-Enhanced launcher
-Volume keys to control music while screen off. Skip, Previous, Volume up and down.
-Multi language
-t9 Dialer - CM9 Source
-Facebook Contact Sync
-End current app with long press of back key
-Account auto restore fully working
-30 step volume control in media apps
-Smoother scrolling in menus
-So much more
-Root, busybox, zipalign, Bash, init.d scripts, zip align on boot, unsecured Boot.img-ADB enabled, Nano text editor + sysro/sysrw and so many more...
What's Coming
-Ability to turn on/off volume control in Enhanced Power Menu+
-Ability to manipulate amount of icons on status bar
-Ability to manipulate screen rotation timing
-CodeName ROM Utility
CHANGELOG
### 1.5.0
* YOU MUST FLASH GApps since it is no longer included in ROM
* DO NOT USE THEMES OR MODS MADE FOR ANY OTHER VERSION. ONLY USER THEMES OR MODS MADE FOR 1.4.0
*YOU MUST DO A FULL WIPE. Wipe cache & data/factory reset
*Report bugs only after you confirm bug by having nothing else installed besides ROM and GApps. Use the BUG TRACKER.
common: added support for the Galaxy S, Fascinate, Vibrant, Captivate, Incredible, Transformer EEE Pad, Transformer Prime, Xoom Euro and 3G
common: notably, even smoother and faster
Update to Power Menu Options:
Improved torch toggle graphics and strings
Made power off on power menu optional
Add error message to power menu when all power menu options are disabled
Added NavBar Buttons in Power Dialog (Zaphod-Beeblebrox)
Improve navbar on power dialog logic:
Separated hide navbar option from nav buttons
Nav actions on power menu replaces the silent toggle when enabled
Improved nav on power menu graphics
Added recents button to nav actions
Only show nav buttons when the navbar is hidden
Disabled nav buttons when the lock screen is showing
Added reset of hidden nav bar on reset (not reseting causes issues)
Disabled power menu nav buttons the the lock screen is enabled
Added the ability to either place the nav actions on the top or bottom of the power menu
common: Added SMS Split by encoding and counter at end of message with settings (Mike Wielgosz)
common: Added option to display contact pictures in Mms notifications (dragonzkiller)
common: Display contact name if available in delivery report mms notifications (kshlm)
common: updated the phone and contacts with the latest from CM
common: added optional lockscreen before the security lockscreen option (tmoskowite)
common: new advanced testing menu in settings (Development settings, Spare Parts settings, and Testing settings)
common: use the volumer rocker as a cursor while you type (romanbb)
common: added the ability to long hold to uninstall the the launcher (nebkat)
common: Allow unlinking of notification sound and ringtone volume (gsarrica, romanbb) slightly modified layout codenamedroid
common: custom lockscreen wallpapers (romanbb)
common: gave power menu its own category in the interface settings (everything on the power menu is now configurable)
common: the ability to enable rotation on the lockscreen (romanbb)
common: reverted back to previous rotation settings for full 180 degree rotation
common: fixed big brother, little brother menu button issue when all nav buttons are enabled
common: the lockscreen settings menu has been updated and reorganized
common: added the lights level editor to the automatic backlight settings
common: fixed the processor settings crashing with kernels with non-configurable governors
common: reworked lockscreen menu unlock (tpruvot - replaces romans, better logic)
common: removed romanbb's version of volume key wake lock and long press volume and updated with the ones from CM (longpress to change tracks works with volume wake enabled)
common: fix alarm not setting properly with a voice action (romanbb)
common: fix for lockscreen unlocking after dismising an alarm (Danesh)
common: added support for more tag types to the nfc reader (doug yeager)
common: updated the LTE and WiMax toggle
Closed out over 50 issues on the bug tracker
Galaxy Nexus (GSM/CDMA): Codename Android Kernel 1.7.3 - patched to 3.0.23, updated color code, stock volatges by default, and fast charge mod
Exta Tools (Provided by CM):
Bash/
Lsof/
Nano/
OpenVPN/
libncurses/
Busybox/
Rsync/
Superuser app - ChainsDD
SceenShot's:
Credit / Thanks:
1. Make a backup
2. wipe data/factory reset in recovery
3. flash the rom
4. flash the google apps
5. reboot
6. sign in
7. wait for the phone to restore all your apps
8. reboot
Download:
Mirror Downlod:
Thanks
Tweaks
-Status bar options
-Enhanced launcher
-Multi language
-So much more
What's Coming
CHANGELOG
### 1.5.0
Bash/
Lsof/
Nano/
OpenVPN/
libncurses/
Busybox/
Rsync/
SceenShot's:
Credit / Thanks:
- EVERYBODY IN THE ANDROID ATMOSPHERE!!!
- All other open sourcers that made a contribution to the project:
- Specifically: Team Gummy, romanbb (Android Open Kang Project) Birdman (RootzBoat), imoseyon, CM
1. Make a backup
3. flash the rom
5. reboot
6. sign in
8. reboot
