Radagast
Ehrenmitglied
- 23.366
Ich wiederhole mich ... Neue Version da
# Purity # 08/10
http://htcfanboys.com/download/rawdealer/?action=list&folder=5672
Bionic:
- Redo clang patch in a way that doesn't break gcc 4.8
- Fix mismatch between declaration and forward declaration
- Declare __page_shift and __page_size with C linkage
Build:
- little changes
Busybox:
- bunzip2: fix off-by-one check
- [x86] Changes and Additions to fix broken x86 build
Calculator:
- Animate the theme change smoothly
- Calculator: no back icon in action bar
Dalvik:
- Dalvik: Better compatibility with different compilers
Device_samsung_tuna:
- tuna: add support for battery LED charging
Dsp_manager:
- Add xhdpi launcher icon, cleanup others a bit.
External_bluetooth_bluedroid:
- Fix uipc.c to never pass -1 to FD_ISSET.
- Bluetooth losing HF connection to car-kit after 5 seconds
- a2dp: Set the default A2DP bitrate to high quality
External_libpng:
- Memory leak in png_read_destroy function.
Frameworks_base:
- Revert "Add support for MNC=00"
- Make EntropyMixer mix in output of Hardware RNG into Linux RNG.
- Reduce EntropyMixer seed size from 4096 to 512 bytes.
- Fix a copy/paste typo in ViewPropertyAnimator
- Check if intent can be resolved before starts
- Make ActivityManagerService.systemReady thread safe
- Don't ANR when no windows are touchable.
- Avoid IndexOutOfBounds Exception in ActivityManagerService
- Scroll: modified velocitytracker
- SystemUI: Ignore lint check ProtectedPermissions
- SystemUI: Remove obsolete layout params (fix lint warning)
- KeyguardViewMediator: Play lock screen sound sooner
Frameworks_native:
- Reset the FrameNumber for dropped frame in async mode
- Check fence is not NULL before dereferencing it
- Surface: Initialize variable and add a defensive check.
Vendor:
- Update apns.conf
# Purity # 08/10
Bionic:
Build:
- little changes
Busybox:
Calculator:
Dalvik:
Dsp_manager:
External_libpng:
Frameworks_base:
Frameworks_native:
Vendor:
- Update apns.conf
