[ROM-JB] HDREX v3.3 (4.1.2 | JZO54K) l BASE BAMF Paradigm
  • 118 Antworten
  • Neuester Beitrag
Diskutiere [ROM-JB] HDREX v3.3 (4.1.2 | JZO54K) l BASE BAMF Paradigm im Custom-ROMs für Galaxy Nexus im Bereich Root / Hacking / Modding für Galaxy Nexus.
T-REX600
Gast
HDREX v.3.3 (4.1.2 | JZO54K)
| BASE BAMF Paradigm
by
Features:
- Android 4.1.2 JZO54K (Team BAMF Paradigm)
- Trinity Kernel
- BAMF Settings
- Ram Tweaks Optimierung Get more RAM and faster responses by disabling verify-bytecode!
- V6 Supercharger
- Galerie (Android 4.2)
- Photo Sphere camera 360°-Bilder (Android 4.2)
- Tastatur mit integrierter Swype-Funktion (Android 4.2)
- Beats Audio
- AwesomeBEATS
- Themed
- Desing System, Cobalt und BlueElegance1.0
- Brainmaster Tweaks: Build.prop
- mehr Benachrichtigungstöne
- geänderter Lockscreen Style
- Lockscreen Ton geändert
- ES Datei Explorer app
- Apex Launcher app
- Adobe Flashplayer app
- Trickster Mod app
- Busybox app
- TitaniumBackup app
- Sonyericsson Musikplayer
BAMF Settings Features
  • Performance Settings (Based on CyanogenMod CPU Settings)
    • CPU Speeds
    • Governor
    • I/O Scheduler
    • Voltages (where supported)
  • System Settings
    • Ad Blocking
    • Remounting of System Partition
    • Granular Autobrightness adjustment
    • Full management of system apps (disable/enable/uninstall)
  • Visual Settings
    • Lockscreen setup - Back Soon
    • Fully configurable boot animation (enable/disable, enable/disable sound, adjust audio volume)
    • Launcher Tweaks
      • Show or hide the dock divider
      • Show or hide search bar
      • Set number of home screens (3,5, or 7)
    • Status Bar Tweaks
      • Show or Hide Clock
      • Show or Hide Alarm notification
      • Show or Hide Debugging Indicator
      • Battery Skin System (Some sample skins are available in the 2nd post and a tutorial for making your own is available in the "Themes" section) (1.2)
      • Fully customizable battery text including size, color, and visibility (1.2)
      • Normal, Centered, or Hidden Status Bar Clock (1.2)
      • Customizable carrier banner (1.1)
      • Select and arrange Quick Settings (17 currently available)
    • Navbar Tweaks
      • Show or hide the Search soft key
      • Customize long-press functionality of Search Key
      • Soft key reflections on/off (1.1)
      • Set Soft Key color
      • Set Soft Key glow color
Changelog:
Code:
[LEFT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2][B][U]HDREX v.[SIZE=2]3[/SIZE].[SIZE=2]3[/SIZE][/U][/B][/SIZE][/FONT][/SIZE][/FONT][/LEFT]
[FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2]- FIX [SIZE=2]Desings[/SIZE][/SIZE][/FONT][/SIZE][/FONT]
- Desing "[FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2]BlueElegance1[SIZE=2].[/SIZE]0[/SIZE][/FONT][/SIZE][/FONT]"
[LEFT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2][B][U]HDREX v.[SIZE=2]3[/SIZE].[SIZE=2]2[/SIZE][/U][/B][/SIZE][/FONT][/SIZE][/FONT][/LEFT]
[FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2]- update[/SIZE][/FONT][/SIZE][/FONT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2] Camera[/SIZE][/FONT][/SIZE][/FONT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2] ([/SIZE][/FONT][/SIZE][/FONT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2]Photo Sphere camera [/SIZE][/FONT][/SIZE][/FONT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2]360°-Bilder  [/SIZE][/FONT][/SIZE][/FONT]Android 4.2)
- update Galerie (Android 4.2)
[LEFT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2][B][U]HDREX v.[SIZE=2]3[/SIZE].[SIZE=2]1[/SIZE][/U][/B][/SIZE][/FONT][/SIZE][/FONT][/LEFT]
[FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2]- update[/SIZE][/FONT][/SIZE][/FONT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2] Tastatur[/SIZE][/FONT][/SIZE][/FONT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2] (Swype-Funktion integriert  [/SIZE][/FONT][/SIZE][/FONT]Android 4.2)
- update libs
[LEFT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2][B][U]HDREX v.[SIZE=2]3[/SIZE].[SIZE=2]0[/SIZE][/U][/B][/SIZE][/FONT][/SIZE][/FONT][/LEFT]
[FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2]- update Android 4.1.[SIZE=2]2[/SIZE] J[SIZE=2]Z[/SIZE]O54K[/SIZE][/FONT][/SIZE][/FONT]
- update Trinity Kernel TNP1344-384-JB-ALPHA67
- Settings Themed
- neues Desing "[FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2]BlueElegance1[SIZE=2].[/SIZE]0[/SIZE][/FONT][/SIZE][/FONT]"
- neue Bootanimation
- geänderte "power.tuna.so"
[FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2]- geänderter Lockscreen Style[/SIZE][/FONT][/SIZE][/FONT]
[FONT=Impact][SIZE=4][SIZE=3][FONT=Verdana][SIZE=2]- Trickster Mod app
[SIZE=2]- [SIZE=2]B[/SIZE]usybox app[/SIZE]
[SIZE=2]- TitaniumBackup app
[SIZE=2]- [SIZE=2]S[/SIZE]onyericsson[SIZE=2] M[SIZE=2]usikplayer (Standart [SIZE=2]P[/SIZE]lay[SIZE=2]er)[/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/SIZE][/FONT][/SIZE][/SIZE][/FONT]
- Beats Audio Basseinstellungen geändert (mehr Tiefbass)
- EXT4 Partion entfernt
- update Gapps
[LEFT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2][B][U]HDREX v.2.2[/U][/B][/SIZE][/FONT][/SIZE][/FONT][/LEFT]
- update Trinity Kernel TNP1344-384-JB-ALPHA64
- update libs
- Ram Tweaks Optimierung [B]Get more RAM and faster responses by disabling verify-bytecode![/B]
[B]-[/B] V6 Supercharger
- update Apex Launcher
- update Cobalt Theme
[LEFT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2][B][U]HDREX v.2.1[/U][/B][/SIZE][/FONT][/SIZE][/FONT][/LEFT]
[LEFT]- CPU Einstellungen (BAMF Settings) bleiben nach neustart erhalten[/LEFT]
- Videomodus funktioniert
- Volume Track Skip funktioniert
- neues Batterie Icon
- update Gapps "HDREX_gapps_09_26_2012.zip"
[LEFT][FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2][B][U]HDREX v.2[/U][/B][/SIZE][/FONT][/SIZE][/FONT] [/LEFT]
[LEFT]- update Trinity Kernel TNP1344-384-JB-ALPHA63[/LEFT]
- update Bamf settings
- update libs
- update System
- update UI
- Trickster MOD entfernt
- Standart Desing geändert
- Beats Audio Installer app hinzugefügt
- Faster und Smoother
[FONT=Impact][SIZE=4][FONT=Verdana][SIZE=2][B][U]HDREX v.1 Initial Release[/U][/B][/SIZE][/FONT][/SIZE][/FONT]
[LEFT]- Android 4.1.1 JRO03L NEXUS HD[/LEFT]
- Trinity Kernel TNP1344-384-JB-ALPHA62
- BAMF Settings
- [SIZE=4][SIZE=2]Beats Audio[/SIZE][/SIZE]
[SIZE=4][SIZE=2]- Themed [/SIZE][/SIZE]
- Desing System, Paradigm und Cobalt
- AwesomeBEATS
[COLOR=black]- mehr[/COLOR] Benachrichtigungstöne
- Apex Launcher app
- Trickster MOD app
- YouTubeHD + Plugin
[LEFT][B][COLOR=red]Hinweis:[/COLOR][/B] Geht mal bitte nach den ersten Start in die App TRICKSTER MOD /Kernel GENERALS und stellt Min CPU auf 307200 und Max CPU auf 1190400 oder 1036800 mit Apply bestätigen !!![/LEFT]
[LEFT]Danach könnt ihr euch in Ruhe durch BAMF Settings arbeiten.:D:D[/LEFT]
[LEFT][B]Empfehlung[/B][/LEFT]
[LEFT]Governor: Interaktiv
Scheduler: Deadline [/LEFT]
Installation:
- ROM herunterladen und auf interne SD-Karte speichern
- Ins Recovery-Menü booten
- Ein Nandroid-Backup erstellen (empfohlen)
- Full-Wipe durchführen / Factory-Reset / Format System (wenn Ihr von einen anderen Rom kommt) ansonsten Wipe Cache
- ROM installieren (select ZIP from SD)
- Gapps installieren (select ZIP from SD)
- Neu starten
**** Der erste Neustart dauert deutlich länger als normal - geht eine Rauchen oder Kaffee trinken! :D:D:D ****
Download:
Rom:
HDREX_v3.3_Maguro
HDREX v3.1 und v3.2 enfernt wegen BUG in Desings
HDREX_v3.0_Maguro
HDREX_gapps_25102012
Special THANKS to:
TEAM BAMF Rom
morfic Kernel
RockoDev Beats Audio
kriscross
Experte
Hey sehr cool das du diese Rom auch für das GN gemacht hast . Was sie auf dem NS schon genial :)
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
T-REX600
Gast
siehe Startpost !
CMREX v.2 l BASE CM10Nightly l Smooth and Fast
CMREX v.2
- update Android 4.1.1 JRO03L CM10-Nightly Build 15.09.2012 (CM-Team)
- CM Kernel Build 15.09.2012 (CMREX.v2-maguro.zip)
- Trinity Kernel "TNP1344-384-JB-STABLE35" (CMREX.v2-trinity-maguro.zip)
- Hintergrund im Standart JB Design geändert
- update Galaxy Nexus Einstellungen "Bildschirm, Algemein, GPU (nur mit CM Kernel), Wifi"
- Font Installer app entfernt​
AndroidWilly
AndroidWilly
Stammgast
Hey Rex. Schön dich hier auch zu sehen. Nach dem nexus s hab ich mir vor einiger Zeit auch das Galaxy Nexus geholt. ;)
Welchen Kernel kannst du empfehlen der am stromsparensten ist? Das es flott und stabil läuft gehe ich jetzt einfach mal aus.
Gesendet von meinem Galaxy Nexus mit der Android-Hilfe.de App
T-REX600
Gast
Na schön:thumbsup:, wennigstens ein alter bekannter hier. Dachte schon das Rom will keiner probieren. Mit 15 Downloads (stand gestern) lohnt sich die Arbeit fast nicht.:D:D
Ich empfehle Trinity, läuft Smooth selbst mit 1036 MHz Taktung und Akkusparend !
Gib mal bescheid wie dir der Hintergrund gefällt (in Einstellungen usw.) !! Sonst änder ich ihn wieder !
Rallyharry
Rallyharry
Lexikon
Guten Abend,
Wollte es auch gerne mal testen da ich grundsätzlich von cm10 schon sehr begeistert bin. Leider funktioniert der Download nicht.
Evtl kann das bitte mal jemand checken
Danke
T-REX600
Gast
Rallyharry schrieb:
Guten Abend,
Danke
Geht bei mir !!!!!
AndroidWilly
AndroidWilly
Stammgast
Download funktioniert bei mir auch!
Gesendet von meinem GT-N8010 mit der Android-Hilfe.de App
AndroidWilly
AndroidWilly
Stammgast
(OT): kommt das nur mir so vor oder ist die Szene vom galaxy nexus langweiliger als beim nexus s?
@Rex bin gerade bei Ca 50% beim Download werde berichten wie es läuft/aussieht/gefällt :)
T-REX600
Gast
Moin moin,
das kommt dir nicht nur so vor, das ist auch so !!!!:D:D:D
AndroidWilly
AndroidWilly
Stammgast
Guten morgen. Die erste Nacht hat die Rom überstanden , welch ein wunder^^ naja war auch nicht anders zu erwarten :) Läuft JB typisch gut und stabil. Zu den Hintergründen in den Einstellungen. Wenn es gefällt OK ich persönlich mag es nicht so "Nexusierisch" hätte da etwas dezenteres lieber.(anderes theme installiert und gut ist^^) Aber ansonsten top wie gewohnt die Rom.
HB76
HB76
T-REX600 schrieb:
Moin moin,
is das ein müdes forum hier! :) bin grad am testen von deinem rom, :thumbsup:
T-REX600
Gast
Viel Spaß !!!:D:D
Der ursprüngliche Beitrag von 18:29 Uhr wurde um 18:31 Uhr ergänzt:
@AndroidWilly: Danke für deine Meinung, ändere es wieder beim nächsten update :thumbup:!!
T-REX600
Gast
Will hier jemand mal eine HDREX testen Base ist NexusHD4.4 ROM !
Finde ist eine schöne Rom mit viel Einstellmöglichkeiten :D:D:D
Lade sie mal morgen hoch !!!
AndroidWilly
AndroidWilly
Stammgast
Immer her damit :) kommt mir so vor als würdest du die Roms nur für mich machen...
WARUM IST HIER SO WENIG LOS ? ? ?
T-REX600
Gast
So hier mal eine andere REX ROM !! :D:D
HDREX v.1 l BASE NEXUS HD 4.4
Features:
- BAMF Settings
- Beats Audio
- Themed
- AwesomeBEATS
- Apex Launcher app
- Trickster MOD app
- YouTubeHD + Plugin​
Hinweis: Geht mal bitte nach den ersten Start in die App TRICKSTER MOD /Kernel GENERALS und stellt Min CPU auf 307200 und Max CPU auf 1190400 oder 1036800 mit Apply bestätigen !!!​
Installation:
- Recovery: Full Wipe Data und System
- Recovery: ROM.zip flashen
- Recovery: Gapps flashen (immer)
- neustart​
Download:
nekyl
Hat jmd. HDRex schon mal getestet? Es sieht jedenfalls gut aus!
AndroidWilly
AndroidWilly
Stammgast
Ich hab sie seit gestern drauf...
Bin total begeistert die ganzen Einstellungsmöglichkeiten sind der Hammer. Ansonsten läuft die Rom wie gewohnt 1A.
Guapo
HDRex sieht ja recht ansprechend aus :thumbup:. Werde es auch mal testen
Cumberland20
So, ich habe gerade das HD Rom geladen und der erste Eindruck ist positiv. Genaueraus kann ich natürlich erst morgen sagen...Ich bin gespannt.
Der ursprüngliche Beitrag von 09:38 Uhr wurde um 09:42 Uhr ergänzt:
Was mir allerdings bis jetzt aufgefallen ist, dass Benachrichtigungslicht funktioniert nicht. Bug? Oder bin ich zu blöd?
Der ursprüngliche Beitrag von 09:42 Uhr wurde um 11:00 Uhr ergänzt:
Ok, Benachrichtungslicht funktioniert wieder :)
