Wegelagerer
Ja, battery drain ist hier ebenfalls echt heftig: heute morgen um 7 mit 100% angefangen, 4 Stunden später (etwas Websurfen, Twitter und Facebook) exakt 50%
Anmerkung: Diese Funktion erfordert derzeit den Zugriff auf die Seite über den integrierten Safari-Browser.
Hey MIUIers,
We’ve made many fixes and optimizations in Phone, Camera, Music, File Explorer and Alarm Clock this week, for example,
[Music]
Optimization - Absorption efficacy while sliding the song list (06-18)
[File Explorer]
New - Remote management supports Big5 encoding (06-18)
As we only worked 2 days because of dragon boat festival in China last week, the changelog of this week will be a bit shorter than usual. Sorry about this. Hope you understand. Thank you!
The full changelog will be posted on Friday as usual.
[Phone]
Fix - Large square contact photo distortion in incoming call interface
[Themes]
Fix - In some cases, downloaded themes disappear or cannot be used
Fix - Downloading a large amount of themes from the web causes Themes app to FC
[Camera]
Optimisation - When clicking to focus or clicking the menu, QR code button will be hidden
Fix - After scanning QR code, press MI key can still take pictures
Fix - In the photo preview, press the menu button and then quickly slide right to enter camera preview page, white menu will appear at the bottom
Fix - While recording in simple mode, colour effects can still be selected
Fix - Thumbnails not displayed issue
[Music]
Optimisation - Improve efficiency while sliding the song list
Optimisation - While setting ringtone, if not supported format, pop up will display
Fix - For songs which do not support editing ID3, you can manually enter ID3 editing interface
[Browser]
New - Added function for smart loading of pictures
New - When opening browser, prompt whether to open the url from clipboard will pop up with prompt
Optimisation - Improved bookmark history interface
Optimisation - After app installation package download is complete, prompt whether to install or upgrade will pop up.
Fix - While opening browser through third-party apps, multi-window management mode of the browser cannot exit
[File Explorer]
New - Remote management support for Big5 encoding
Fix - Multiple selection editing mode cannot exit after switching directory
Fix - Location error of current directory
[Alarm Clock]
Fix - Alarm and music playback simultaneously
Fix - In some cases, creating a new alarm will cause FC errors
[Transfer]
Optimisation - Error descriptions
Fix - Notifications in the status bar cannot be cancelled
Kannst du das mal näher erläutern. Mein Nexus z.b hatte kein Simlock, da kein Prepaid Handy.Einzigst, dass man den Sim Lock deaktivieren muss, ist ein Kritik Punkt von meiner Seite.
by Ducati1987 / Miuiandroid.comHello, after installed the rom I'm still trying to put my pin code in order to unlock the phone but something is going wrong. Every pin code is incorrect and I can't continue. Is my bad? Thanks for your support.
[Phone]
Optimization - Attribution database update
[Messaging]
Fix - In some cases "pre-written" messages can not be displayed
Fix - When adding dialog box of private contacts, the Back key does not disappear after being pressed
Fix - Adding image with high aspect ratio as an attachment might cause Messaging app FC
Fix - Switching Xiaomi account results in MMS synchronization failure
Fix - Reboot might cause "Show previews" feature to be enabled again after being disabled
Fix - MMS thumbnails occupy too much memory and cause the program to run slowly or crash
[Music]
New - In Filter Files, "recording" and "ringtone " folders will be filtered by default
New - Songs in Music can be pushed to Xiaomi MiBox
[Desktop]
New - Added desktop batch sorting mode (In edit mode, you can click the icons for multiple choice)
[Themes]
New - Clicking on the recommended theme image can go to related web page
Fix - Prompt error for authorization obtaining failure
[Camera]
New - Added time watermark (MI2)
[Transfer]
Optimization - Improved application stability
[Browser]
Fix - In some cases , watching videos might cause FC error
Fix - In some cases, using Flash plug-in might cause FC error
[Others]
Fix - Accessibility relevancy errors
Note key fixes: Galaxy Nexus
- in car bluetooth fixed - inconsistant
- boot animation fixed
- miui launcher, animation transitions fixed e.g. cascading
We are working hard with xiaomi miui dev team to get core issues fixed.
