[ROM][5.1.1][AOSP] DarkKat
Sh0X31
Sh0X31
Enthusiast
828
-> original Thread
Entwickler: XXMrHyde (XDA) & XXMrHyde (a-h)
DarkKat ist ein custom Rom, welches auf Android 5.1.1 (LMY47V/AOSP) basiert.
Features:
Zip
  • Use a file based zip
Installation:
  • Fixed long formating time
  • Added more info while flashing
  • Added CM Backup Tool
  • Fixed broken recovery
General:
  • based on Android 5.1 (LMY47I)
  • init.d support
  • Change default sounds:
  • Ringtone: Playa
  • Notification: regulus
  • Alarm: Alarm_Beep_03
  • Added Android 5 bootanimation
  • Boot message dialog: Material (dark) theme
Power menu:
  • Material (dark) theme
Customize entries:
  • Always show the "Power off" button
  • Always hide the "Bugreport" button
  • Reboot: Show/hide, (enabled by default)
  • Airplane mode: Show/hide, (enabled by default)
  • Users: Show/hide, (disabled by default)
  • Settings: Show/hide, (disabled by default)
  • Lockdown: Show/hide, (disabled by default)
  • Silent mode: Show/hide, (enabled by default)
Advanced reboot menu:
  • Reboot
  • Quick reboot
  • Reboot to recovery
  • Reboot to bootloader
  • Volume rocker wake up
  • Wake on charger plug
  • Custom battery saver mode color
Notifications/heads up:
  • Material icons for call/text actions
  • Lock screen:
  • Global lock screen text color
  • Global lock screen icon color
  • Weather panel
Status bar:
  • Double tap to sleep gesture
  • Brightness control
Clock styles:
  • Clock position, (right, centered or hidden)
  • Show a custom date left to the clock:
  • Size option, (small or big)
  • Style, (normal, lowercase or uppercase)
  • Format
  • Clock (& date) color
Battery:
Styles:
  • Icon portrait
  • Icon landscape
  • Circle
  • Text only
  • Hidden
Text appearance:
  • Inside the icon/circle
  • Next to the icon/circle
  • Hidden
Charging animation (icon and circle):
  • Disabled
  • Slow
  • Normal
  • Fast
  • Option to show the circle dotted
  • Circle dot length
  • Circle dot interval
  • Fill color
  • Text color
Mobile and Wifi network icons:
  • Show H+ icon on HSPAP networks
  • Custom mobile and Wifi network icons color,
  • (normal and fully connected)
  • Custom mobile and Wifi network activity icons color,
  • Custom airplane mode icon color
Network speed indicator:
  • Download, upload, both or disabled
  • Option to show/hide the icon
  • Options to show the data summary
  • Show bit or byte values
  • Option to hide the indicator on no traffic
  • Text color
  • Icon color
Custom notification- and system icon colors:
  • Option to colorize notification icons
  • Option to show/hide the ticker
  • Option to show/hide the notification count icon
  • Cutom icon color
  • Custom ticker text color
  • custom notification count icon color
  • custom notification count text color
  • Material icon for missed calls
Status bar expanded:
Header:
  • Custom text color
  • Custom icon color
Weather display:
  • Show/hide weather informations
  • Show/hide weather location
Quick settings:
  • Quick pull down
  • Animated rotation tile
  • Long click support
  • Arrangement:
  • Custom arrangement
  • Add tiles
  • Delete tiles
  • Option for 2 or 3 tiles on first row
  • Added Detail view for location tile, (optional)
  • Option to disable brightness slider
  • Custom background color
  • Custom icon color
  • Custom text color
Display:
  • Configurable 0, 90, 180 and 270 degree rotation
Settings:
  • Launch SuperSU from Settings
  • Launch LockClock preferences from Settings
  • (Category "User interface" -> More)
  • About Phone/Tablet:
  • Added CPU info
  • Added Memory info
  • Added Darkkat version
  • Added Build date
  • Enabled SELinux status
  • Removed System Updates
Apps:
Added:
  • CyanogenMods file manager, (only 5.0.2 version for now)
  • CyanogenMods Eleven and AudioFX
  • Launcher3
  • LockClock:
  • Terminal Emulator (by CyanogenMod), (only 5.0.2 version for now)
Browser:
  • Fixed FC on settings
Contacts:
Dialer
  • Android 5 launcher icons
Mms/sms:
  • Use a card-based UI
InCallUI:
Removed:
  • Music
  • MusicFX
  • VoiceDialer
  • Launcher2
  • Home
  • QuickSearchBox
Kernel:
  • Included kexec, (N4, N5 and N7, (N6 only 5.1 version))
Shamu (Nexus 6):
  • Disabled forced encryption
Changelogs:
General:
  • Updated Android to 5.1.1 (LMY47V)
  • Updated spanish and french translations
  • Custom LCD density
  • Color picker is in full screen now, and much more:
  • Improve color picker, (click for informations)
  • Add tablet layout
Status bar:
  • Clock: fix color in some cases after (re)boot
  • Colorize the vpn icon
  • Color transition animations for the clock and signal cluster icons (mobile and wifi network icons)
  • Add battery color transition animations, part 1, (click for informations)
Settings:
  • Added Build ID to "About phone"
Apps:
  • Removed Launcher3
  • Added DKLauncher
Preferences:
  • Dark Material theme
Homescreen:
  • Show/hide search bar
  • Custom grid with and height
  • Default position
App drawer:
  • Dark background
Dock:
  • App drawer icon color
  • Choose number of icons
  • Added CMFileManager
  • Updated all CM apps, (state from 2015.04.26, 21.00 CET)
Nexus 6:
  • Ambient display: Fix black/dark text for notifications
Some infos about this update:
DKLauncher:
this build replaces Launcher3 with DKLauncher,
if you are using Launcher3, and have a lot of customization,
you should backup and restore Launcher3, (e.g. Titanium Backup)
but I recomment to use DKlauncher instead of Launcher3,
(if you like to benefit from upcomming features),
because I won`t include Launcher3 any more.
If you are using an alternative launcher,
you will be fine, too.
LCD density:
Changing the density will force an UI restart,
(you`ll see the bootanimation for some seconds,
this is expected, and not a bug, FC, ...)
I have no Idea if it comes to data loss if you have unsaved documents,
and the UI restarts, so use this feature with care!
[/LIST]
-> Download
Installation:
- Downloadet das Rom,die GApps (PA) und SuperSU
- Kopiert die 3 .zips auf euer Nexus 6
- Geht nun ins Recovery und flasht die Rom, Gapps und SuperSU.
- Startet in das Recovery und flasht
Meine Erfahrung mit DarkKat:
Da vielleicht einige DK nicht kennen, wollte kurz meine Lieblingsfeatures vorstellen.
Mein lieblingsfeatures sind, dass man die Farben anpassen kann (Uhr, Symbole wie WLAN, Benachritigungen, ect) und das alles "Dark Material" ist.
Das Rom läuft sehr gut und der Akkuverbrauch ist auch ganz in Ordnung. Solltest es mal mit MulitRom testen.
Reaktionen: XXMrHyde und Elting
Blöde Frage: basiert die nun auf dem factory Image 47v oder auf 47i
Weil im Spoiler 47i steht
Die Rom basiert auf AOSP LMY47V
Reaktionen: vergilbt
Cool, Mr. Hyde... Hatte damals schon deine ROM auf dem one S drauf... Und auch später immer wieder bei den Nexen...
Ja, kann mich erinnern.
Hallo. Bin auf der suche nach einem Rom das in den einstellungsmenüs keine weisse Hintergründe hat. Dieses wäre ja eines. Wie läuft dieses Rom? Hat es viel mehr funktionen zum einstellen? Auf der ersten seite ist zwar geschrieben, hab aber paar sachen nicht so verstanden.
Ja, Einstellungen sind "Dark", (eher nicht schwarz, außer die Einstellungen für den Erweiterten Desktop). Was hast Du nicht verstanden?
Einfach CM Design nutzen. Gibt da jede Menge Dark Themes, unabhängig der Custom Rom.
siehe einfach mein aktuelles Profil unter:
https://www.android-hilfe.de/forum/...-fragen-keine-diskussionen.647890-page-2.html
Hab nicht genau verstanden was für einstellungen man in der statuszeile und battery icons usw ändern kann. Farbe und uhr das kenn ich noch vom samsung
Themes/Designs sind immer mehr oder weniger romabhängig,
für CM-Designs muß CM`s Theme-Engine eingebaut sein,
für Layer/RRO muß die "Unterstützung" eingebaut sein
und "richtige" Themes, (bei denen apks ausgetauscht werden),
müssen speziell für Rom und Rom-Version erstellt werden.
Die Statusleisten Einstellungen im Einzelnen:
Helligkeitskontrolle ein/ausschalten,
(wischen über die Stausleiste ändert die Bildschirmhelligkeit,
Automatische Helligkeit muß deaktiviert sein)
Standby durch doppeltes tippen ein/ausschalten
(Uhr kennst Du ja)
Akku Symbol:
  • "Standard" Balken (Hoch oder Querformat)
  • Kreis
  • Text
  • Verbergen
  • Text kann jeweils ein/ausgeblendet werden,
    und im oder neben dem Symbol angezeigt werden
  • Ladeanimation, (nicht für Text):
    • Deaktiviert
    • Langsam
    • Normal
    • Schnell
  • Kreis:
    • Kann gepunktet angezeigt werden
      (Punktlänge und -abstand sind einstellbar)
Netzwerkaktivität kann angezeigt werden,
(die alten Symbole in/neben den Netzwerk Symbolen,
wurden ab Kitkat entfernt)
Netzwerk Geschwindigkeits Anzeige:
  • Download,
  • Upload,
  • Beides,
  • Deaktiviert
  • Symbol ein/ausblenenden
  • Letzte verbrauchte Datenmenge kann im Leerlauf
    angezeigt werden
  • Anzeige in Bit oder Byte
  • Anzeige kann im Leerlauf verborgen werden
Nachrichten Ticker anzeigen/verbergen
Benachrichtigungs Zähler anzeigen/verbergen
Farben kennst Du ja, sollte aber (hoffentlich) selbsterklärend sein.
Reaktionen: thomas.b
Dankeschön
Bitte, sollte noch etwas unklar sein, auch in anderen Einstellungsbereichen, frage einfach nach.
Reaktionen: Sh0X31
Sunny
Sunny
Sunny
SaschaKH
Netbook
Netbook
bearclaw
abramotte
abramotte
