Klarooo
Ehrenmitglied
- 22.918
Das Ziel der PureNexus ROM ist es, Stabilität und Features auf unsere Geräte zu bringen. Dabei soll Google 'Vision' nicht weit verlassen werden. Ihr seid auf der Suche nach einer stabilen ROM mit wirklich getesteten Features, dann probiert mal PureNexus!
-General
*Based on AOSP Android 6.0_r26
*Pre-rooted with SuperSU 2.52
*SELinux Enforcing
*Busybox
*Init.d support
*Addon.d support
*T-Mobile US WiFi Calling + Project Fi Support
*Fully Working VoLTE
*Native Sprint PRL/Profile update
*Full Layers 4.0 support
*Google sounds from factory image not the horrible AOSP ones
*Googles marshmallow wallpapers added to wallpaper picker
*Advanced Reboot menu enabled by default
*Advanced rotation settings
*Enabled Developer settings by default
*Enabled SystemUI tuner by default
*Enabled option to use multi-window mode
*Enabled click/longclick on notification panel header items
*Disabled forced encryption
*Disabled Device modification warning
*Disabled Tethering checks
*Disabled Full screen keyboard in landscape
*Show apps being optimized during initial boot
*Bug fix's and stability improvements
*UI Improvements (fixed a bunch google forgot to materialize)
*Download Speed in download notifications
*Scrolling cache improvements
*Seek-bar animation speed and font size control
*Hostname customization
*Added Native Google Double tap to wake option
*Added Standalone documents ui file manager
*Added Special keys to all keyboard keys
*Added more smileys to the aosp keyboard
*Removed googles bug report option
*Removed googles SystemUpdate option
*Removed googles legal information
-PureNexus Settings
Lock Screen
*Option to customize lockscreen shortcuts
*double tap anywhere to sleep
*Option to disable lockscreen media art
*Scramble pin layout
*Quick unlock
*Lockscreeen Wallpaper (add/crop/delete)
Notification Drawer
*Weather
*Force Expanded Notifications
*quick settings pulldown (left,right)
*brightness slider on/off toggle
Recent Apps
*Clear all recents toggle
*Clear all recents location option
*Clear all recents but last app toggle
*Recent searchbar on/off toggle
Statusbar
*Battery customization (stock, landscape, circle, dotted circle, text, none)
*Battery percent options (hidden, inside the icon, next to the icon)
*Carrier Text customization (text placement, custom text)
*Clock customization (position, am/pm, date, date style, date format)
*Network traffic meter options (disabled/incoming/outgoing/both, units displayed, update interval, autohide, autohidethreshold)
*Status-bar options (double-tap to sleep, statusbar brightness control)
Navigation Bar
*Enable/disable
*IME toggle
*Option for arrow cursor keys
*Option for double tap navbar to sleep
*Long-press back to kill toggle
*Long-press recents for last app toggle
*Navigation bar size customization (width, height, length)
*Navigation bar customization (placement, buttons)
PowerMenu
*Option to disable on secure lock
*Add/remove (reboot, screenshot, screen-record, airplane mode, user switcher,settings shortcut, search, voice search, lock now, sound panel)
Volume Rocker
*Volume key wake
*Volume key music control
*Volume key keyboard cursor control
*Volume button swap toggle
*Control media volume anytime toggle
Display
*LCD density control
*Expanded desktop options
*option to enable/disable wake on plug
*LED controls
Notifications
*option to disable low battery notification
*Option to disable battery saver notification
cLock Settings
*Customize the cLock widget
Tools and info
*device info
*battery history
*usage statistics
*wifi info
*build.prop editor
*fi switch tools (if project fi sim is installed)
*SELinux Enforcing
*Busybox
*Init.d support
*Addon.d support
-PureNexus Settings
Lock Screen
*Quick unlock
Notification Drawer
*Weather
Recent Apps
Statusbar
Navigation Bar
*Enable/disable
*IME toggle
PowerMenu
Volume Rocker
*Volume key wake
Display
*LED controls
Notifications
cLock Settings
Tools and info
*device info
*battery history
*usage statistics
*wifi info
*build.prop editor
Klick mich
ROM: Download
GApps: Download
Vendor: Download
SuperSU: Download
Möglichst die oben verlinkten GApps nutzen.
Anleitung:
1. CustomRecovery installieren (TWRP wird empfohlen)
2. Data, system, cache, dalvik cache in TWRP wipen
3. ROM flashen
4. GApps flashen
5. Solltet ihr eine Meldung sehen, dass eure Vendor 'veraltet' ist, noch die oben verlinkte Vendor.zip hinterher flashen
6. SuperSU flashen (Bitte hier kurz einlesen)
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine Garantie auf Erfolg, oder die Haftung für jegliche Beschädigungen an eurem Gerät!
