[ROM][25.01.2012] CyanogenMOD 9 ALPHA 1
hmoody
Nexx schrieb:
CyanogenMod 9 Alpha for HTC Desire S
Disclaimer:
Code:
I am not responsible for bricked devices, dead SD cards, thermonuclear
war, or the current economic crisis caused by you following these directions.
YOU are choosing to make these modificiations, and if you point the finger at
me for messing up your device, I will laugh at you.
Notice:
Code:
These are Alpha quality builds and are very much still in development.
Features may not work, or may crash, they may alternate between functioning
and non-functioning between builds. Please look over the lists below before
reporting suspected bugs.
Please do NOT use any other AOSP kernel. Currently only the included kernel
is supported. The Tiamat kernels are not compatible with ICS yet.
Why are we waiting for HTC to release the ICS kernel source code?
Click here to read the full explanation
Working / Bug List:
Please see here
Installation (From any other ROM):
Code:
In recovery:
 - Wipe all (system, data, cache)
 - Flash update-cm-9-XXXXXXXX-SNAPSHOT-saga-signed.zip
   (where X is date of the latest build)
 - (Optional) Flash Google Apps
Installation (Upgrade from previous CM9 builds):
Code:
In recovery:
 - Wipe cache
 - Wipe dalvik-cache
IMPORTANT - Devices unlocked via htcdev.com:
Code:
If you unlocked your phone via htcdev.com, you must flash the included
boot.img after flashing the ROM in recovery:
 - Boot into fastboot, either by:
   - Turning phone on whilse holding VOLUME DOWN, or
   - adb reboot bootloader, or
   - using an option in your recovery (eg. Reboot Bootloader)
 - Connect your phone to your PC and copy the boot.img from the ROM .zip
    to the same place as fastboot.exe and issue the following command:
   - fastboot flash boot boot.img
Failing to follow these instructions on a htcdev.com unlocked device will
cause the ROM to fail to boot.
Downloads:
- CyanogenMod 9 Alpha for HTC Desire S (Updated 14 Apr 2012)
MD5SUM: d2f1280c2f161716fbfd99bc079589ef
- Google Apps for ICS (Updated 17 Mar 2012)
MD5SUM: dc560aa235e8dd8cb00df0cefb5abd38
Changelog:
Code:
14 Apr 2012:
 - Switched to "snapshot" builds (No difference other than name)
 - Integrated fix for ROM flashing issues
 - Integrated fix for security issue regarding USB mass storage mode
 - Latest CM9 code & Gerrit fixes
09 Apr 2012:
 - Touch-screen fixes (Yup, Temple run works now ^u^)
 - Latest camera work from Twisted + more fixes by me
 - Proprietary v8 library integrated
 - Display tweaks for composition (may help occasional corruption)
 - Updated kernel (minor changes)
29 Mar 2012 - Build 2:
 - Dialer fixed (Thanks CM team!)
 - Panorama mode fixed
29 Mar 2012:
 - Updated to Android 4.0.4 (IMM76D)
 - OMX video encoding
   - Camcorder working, front + back
   - Video chat working
 - Panorama picture support
 - Latest camera work from Twisted + fixes by me
 - Torch app added
 - Further encryption work
27 Mar 2012:
 - OMX video decoding work
   - Kernel updated for new OMX code
   - Previously appeared to be working but was decoding in software
17 Mar 2012:
 - FFC work:
   - Face-unlock now works correctly on boot
   - Camera app working correctly on boot with FFC
15 Mar 2012:
 - Updated camera code
 - Fixed camera corruption (hopefully)
 - Added work-around for FFC crashes
 - Fixed OMX decoding (YouTube app / etc)
 - Fixed BootAnimation crash
 - Integrated CM9 BootAnimation
14 Mar 2012:
 - Updated camera code, now maintained by TwistedUmbrella
 - CM9 Volume wake / media skipping re-added
 - Phone profiles support
 - Native audio libraries (mic working in apps without Quattro libs)
 - In-development OMX support (video decoding)
 - Updated Google Apps
 - Latest CM9 code + fixes
 - USB tethering fixes
22 Feb 2012:
 - Fixed camera flash
 - Fixed torch support (Still needs an app, but HW works)
 - Camera updates
 - Initial encryption support (kernel + init, still needs fixes)
11 Feb 2012:
 - Updated adreno (gpu) drivers (again!)
 - USB tethering fixed
 - Camera support added to ROM
   - Front cam functional
   - Rear cam functional
 - Updated Google Apps, includes latest updates and face unlock
 - Battery icon configuration added
 - Volume wake / track skip temporarily removed
30 Jan 2012:
 - Bluetooth headset fixed
 - CPU settings now restore on boot
 - Other minor tweaks
27 Jan 2012:
 - Enabled HSDPA icon
 - Renamed "USB Storage" > "SD Card"
 - Fixed LCD back-light flicker when dimmed
 - Increased virtual-key vibration
 - Temporarily worked around mic issues (Uses Quattro RC3 libraries)
 - Volume Wake + Track Changing from nk111
 - ADB runs as root now
 - Hardware support updates
 - Fixed CM CPU settings
24 Jan 2012:
 - Camera preview fix from nk111
 - Integrated CM settings patches
18 Jan 2012:
 - Key layout fixes from nk111 (Accidentally left out of 17 Jan build)
17 Jan 2012:
 - WiFi tethering fixed
 - Menu key unlock disabled
 - Kernel updates
 - Newer EGL drivers
 - Highly experimental camera support (Please reflash ROM to remove)
12 Jan 2012:
 - Updated kernel (USB tweaks)
 - New composition mode (MDP instead of C2D)
 - Misc fixes/tweaks for hardware
11 Jan 2012:
 - Updated kernel (su kernel oops fix)
10 Jan 2012:
 - Updated kernel (random restart fixes)
07 Jan 2012:
 - Home touch-button fixed
 - Webcore crashes / issues fixed (Browser / etc)
 - su fixed
05 Jan 2012:
 - Initial Release
Credits & Thanks:
KanocX for the very generous hosting of these ROMs.
Also, a big thank you to everyone who has donated and supported my work!
Zitat aus [ROM][14 APR 12] CyanogenMod 9 Alpha Builds [4.0.4][CM 2.6.35.14-ICS] - xda-developers
Hmmm...
Semi-Functional:
  • Headset / Headphones (Working, no icon being displayed)
Non-Functional:
  • Camera (Front & Rear)
  • Market purchasing
  • USB tethering
Confirmed Bugs:
  • Home touch-button not working correctly
  • GMail rendering issues
  • su causes kernel panic and reboot
Unconfirmed Bugs:
  • None yet.
bin mal gespannt wie schnell die entwicklung voran geht!
Alpha 2 für heute nachmittag/abend angekündigt
Nexx on xda schrieb:
I'm planning to release a new build later today. It should solve the random reboots and will have the latest CM9 code too.
Ich habe die Alpha 1 getestet und hatte keine reboots oder sowas festgestellt, einziger FC war einmalig bei Google Maps. Leider lief WhatsApp nicht richtig. Akkulaufzeit war top :) Hat sie sonst schon jemand getestet?
Ich werde mir die Alpha 2 flashen.
Bis sie mit allen Funktionen läuft wird es noch etwas dauern, aber heute scheint ein kleiner Durchbruch geschafft worden zu sein ;)
Heißt wir können hoffen hehe ;D
Hi zusammen,
@ fetz: Nexx war es nicht der die Kamera zum laufen gebracht hat. Es war zbwu86 aus dem XDA Desire HD Forum. Alle anderen basieren auf dieser Entwicklung...
Es gibt seit gestern auch eine neue Version von der ICS CM ROM, bzw. seit dem letzten Update hier gibt es einige Neuerungen. Im aktuellen Build ist die Hauptkamera mit sofortigem Preview vorhanden (man muss nicht erst einmal den Auslöser der Kamera drücken...).
24 Jan 2012:
18 Jan 2012:
17 Jan 2012:
- Kernel updates
- Newer EGL drivers
Mehr Info´s wie immer bei den XDA´s
Meine Erfahrung:
Ich habe mir die ROM gestern installiert. Erster Eindruck ist bisher gut.
- Der Trebuchet Launcher läuft relativ flüssig, ab und zu gibt es noch einen kleinen hänger (Abhilfe: Nova Launcher).
- Die Hauptkamera funktioniert, allerdings habe ich einen ziemlichen Rot-Stich in den Bildern. Frontkamera wie auch die Videorecorder oder Panorama Funktion funktionieren noch nicht.
- Wechsel zwischen Wlan und mobiler Daten geht ohne Probleme. Hatte bei der Virtuous ROM ab und zu Probleme damit.
- FC´s hatte ich noch keine...
@ Moderator oder hmoody: Bitte passt doch den Titel von diesem Thread an damit dieser ROM auch noch ein bisschen aufmerksamkeit geschenkt wird...
Wie soll ich anpassen bzw. welcher neue Name? :)
Eben, gibt keine neue Release Nummer oder?
Sonst vielleicht aktuelles Datum....
Gut. Datum ist eingefügt. Aber mehr kann man da ja jetzt auch nicht machen..
@ Znarf2369: So wie du das gemacht hast passt das doch ;) Titel aktuallisiert und das Changelog in den ersten Post gepackt. Danke.
@ Mod´s: Bitte ersten Thread aktualisieren. Die neue Version ist seit 11.02. verfügbar und hat einige verbesserte Features. Interessiert vielleicht den ein oder anderen nicht XDA follower ;)
11 Feb 2012:
30 Jan 2012:
[ROM][11 FEB 12] CyanogenMod 9 Alpha Builds [4.0.3][CM 2.6.35.14-ICS] - xda-developers
Reaktionen: Jubatus
Ich hab mir den rom gerade installiert und gestartet, ist es normal, dass das erste mal starten so lange dauert?ich meine diese bunte geflacker oder wie auch immer man das nennen soll....
Ja, das ist beim ersten Starten normal.
habt ihr auch das problem, dass facebook sich nicht mit den kontakten synct? hatte cm9 drauf, fand es auch mega geil, nur dass facebook nicht in den sync einstellungen zu bringen war und ich keine bilder mehr in den kontakten sehen konnte etc. hat mich ziemlich genervt ...
Hi wie bekomme ich die Google search bar weg? Normal ja unter einstellungen. Aber nichts gefunden
habe es selber rausgefunden :)
habe das ROM jetzt mal ein bisschen ausprobiert und ich muss sagen,
dass das die beste ROM unter "Android 4.0" ist.
sie läuft flüssig und alles was man benötigt ist vorhanden.
Die Kamera und Screenshots funktionieren einwandfrei. Auch die Front Kamera funktion ist gegeben ;) leider kann man keine Videos drehen und Panorama funktioniert auch nicht.
Um Screenshorts zu machen müsst ihr den Ausschalter gedrückt halten und dann öffnet sich ein Fenster, wo ihr das Handy ausschalten und neustarten
könnt. Dort ist der Menu punkt Screenshort :)
Das Kernel ist vom Akku her top. Bisher mein bestes ergebnis.
Nach 8 Std habe ich noch 77% Akku :thumbsup:
weiter schwächen habe ich bis jetzt nicht gefunden werden aber ansonsten nachgereicht :)
Hoffe ich konnte ein kleinen eindruck verschaffen.
LG
Flo:laugh:
Erledigt...bin am Einrichten :p
Janity
Janity
  • LilaLauneBaeaer
LilaLauneBaeaer
  • Heck
Heck
