[ROM][02.06.2012]AOKP Ice Cream Sandwich V6.0
  • 117 Antworten
Udem
Udem
Android Open Kang Project
Features:
  • built from AOSP -- using 4.0.4
  • power menu (source)
  • ICS style toggles
  • superuser and busybox built from source, included
  • deodexed and unsecure boot.img (for adb remount)
  • Facebook contact sync
  • ROM Control application lets you take control of your ROM. Customize it how you want it.
  • Navigation Bar options and layouts (search bar layout, menu visibility options,etc) -- long press search button enabled
  • IME Switcher toggle (show/hide notification when you type)
  • Customize your carrier label
  • Override lockscreen timeout (ie, use Android's timeout when turning the phone off, so it won't lock itself)
  • LED pulse timing options
  • Statusbar toggle options
  • much much more in there
  • 1% battery mod built in (check ROM Control) -- two styles, center and off center
  • Unique Power Saver functionality
  • Turn data off while your screen is off (GSM phones can switch to 2G)
  • manually sync at a time interval for all your accounts (Gmail, etc)
  • Check out all the options in ROM Control
  • Additional Tweaks to be ran at startup!
Downloads:
Neueste Version:
V6.0
Ältere Versionen:
V5.0
V4.0
V3.5
V3.0
Und hier noch die GAPPS mit allen Google Apps.
AOPK Fix (von Nöten)
Mirror 1
Mirror 2
Nach dem installieren der ROM mit installieren.
Probleme:
  • Kamera
  • 3D Panel
[XDA]​
Changelog:
V6.0
Updated Kernel
Fixed USB Mass Storage
Fixed Bluetooth
Fixed Wireless Tethering
Updated to build 37
V5.0
Updated kernel to HTC Ics leak
Music app is built in
Deep Sleep works fine
Updated base to build 35
V4.0
Volume Button gefixt
Wenn man den Hardware Kamera Button drückt, vibriert das Handy
Kamera geht NICHT!
Backlight der Haptischen Tasten bleibt an.
reboot to recovery (from powermenu) reboots phone
reboot to bootloader (from powermenu) reboots phone
"adb reboot recovery" reboots phone
"adb reboot bootloader" reboots phone
V3.5
Brought back the awesome team kang boot anim
Fixed init.d support
Further fixed built-in tweaks and overclock tools
Added some proprietary wallpapers and Nova Launcher
V3
No more based on a CDMA port,built from source,updated on 8/4/12
Fixed Bluetooth
Switched to CyanogenMod 9 kernel(Not tweaked yet due to some problems)
Fixed Signal Meter
Fixed Built-in overclock app
Updated the base to Android 4.0.4
V2
Using new QCOMM libraries for ICS
APNs are choosen automatically now
Meiner Meinung nach die beste ICS Rom im ganzen XDA Bereich. Der Developer arbeitet auch sehr gut daran. :)
Das stimmt! Ich liebe das Vanilla ICS und alles läuft schon sehr smooth aber am besten ist dass man merkt dass sie dran arbeiten :)
Gesendet von meinem 3VO mit LeeDrOiD und der Tapatalk App!
Wie schon gesagt: Ja!
Alleine schon die Issues List bei Ganii ist etwas länger. Ich habe recht guten Kontakt mit helicopter und er arbeitet sehr gut an der ROM.
Reaktionen: Nseries
Ok, hab sie grad geladen und installiert, die Music App gehört inzwischen ja auch zu den Gapps, leider
Habs grad auch mal installiert...WIFI spackt bei mir bei 3.5. Gibt es da eine Lösung? Fullwipe habe ich durchgeführt !
Ja das mit wifi nervt ziemlich, ansonsten ist das echt ne geile ROM, kann nur bestätigen, die beste ICS ROM fürs 3D
Bei mir hat Wifi auch nicht funktioniert, aber es kam auch irgendwie keine Daten Verbindung zustande. Woran kann das liegen? Fullwipe wurde gemacht ;-)
im xda forum hat jmd geschrieben, das mit dem 3.5 update kein wlan mehr geht. ein anderer schrieb er nutzt deshalb das wifi modul aus der 3.0 package.
Der Entwickler arbeitet momentan an dem Fehler.
Flasht das andere Modul dann passt das!
Ist keine Neuerung, ist bei 70% der ICS ROMS. Man braucht bestimmte Hardware revision. Die Front cam funzt auch.
Spacket ... reden wir gerade über Diese ROM oder über alle im Allgemein?
In der ROM wurde jetzt einfach auch die "fast funktionierende" Kamera App hinzugefügt.
Naja, hab die aktuellste version der ROM geflasht, aber das wlan ging nichtmal an, das kann ganiis uralte ics 1.4 noch besser, die funktioniert wenigstens...
Und auf rumflashen iwelcher module habe ich keine lust, wenns mit ganiis rom doch sofort geht... Ist nur als konstruktive kritik gemeint
Funzt die Cam hier?
Gesendet von meinem HTC EVO 3D X515m mit Tapatalk
Nein, funktioniert nicht...
Version 4.0 ist nun draußen. Downloadlink + Changelog auf der ersten Seite.
Funktioniert wlan mit 4.0 ?
Und kann man temple Run spielen, ohne dass die Figur wild rumspringt?
Gesendet von meinem HTC EVO 3D GSM mit der Android-Hilfe.de App
