ReWard
[ROM][4.3][-O3][LINARO-4.7] LiquidSmooth v2.37 - 11 November [UNOFFICIAL]
ABOUT US
Deadman96385
Aways
Dhacker29
Jdkoreclipse
Liquid0624
Liquidzgrl
OldDroid
FEATURES
SaberMod Prebuilt 4.74 Toolchain
-O3 Strict-Aliasing & ISO C++11 Mode
ARM Optimized String Handling Routines
Linaro and Code Aurora Optimaztions
Customizable lockscreen buttons/sliders
Chronus clock widget
Customizable hardware and software keys
Transparent navbar and status bar
Customizable navbar ring
Navigation bar widgets
Customizable power menu
Notification power widget
Customizable quicksettings panel
Statusbar mods
Theme engine
Quiet hours
Volume rocker music controls
Full Rotation
Customizable battery and notification light
Frameworks: privacy guard fix UI freeze
Prevent notification acces via HALO on protected lockscreens
HALO: keep apps in recents
HALO: halo can save last position now
HALO: Minimal Style
HALO: Master Switch
HALO: Custom Colors
And way more then this...
SCREENSHOTS
WHAT'S WORKING
Service
Text
Data
Calls
Audio
WiFi
Bluetooth
Google Now
GPS
MMS
VoIP
Qualcomm JB libs & firmware
Video playback
Audio playback
Camera
Camcorder
Tethering ( WIFI & USB )BUGS
3D recording not working
Bluetooth Tether not working
In-call volume sometimes gets reseted to maximum. Temporary fix:ENABLE TOUCH SOUNDS
Hdmi not working
Sending MMS's might not work for everyone, receiving works.
Halo might be buggy...
RECOMANDATIONS
LiquidSmooth Github
Kernel Source
Kernel Toolchain
Device repos
DOWNLOADS & CHANGELOG
OFFICIAL DISCLAIMER
PHP:
#include
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
LiquidSmooth is an aftermarket firmware based on the Android Open Source Project.
Dedicated to providing users with smooth, stable and fast ROMs. A Lightweight modified AOSP base, and then add the features you crave!
While we make every effort to test these builds as much as possible, we are not responsible for anything that may happen to your device.
We ask that you do your part to know your device and know how to recover from problems before you flash!
MEMBERSDedicated to providing users with smooth, stable and fast ROMs. A Lightweight modified AOSP base, and then add the features you crave!
Deadman96385
Aways
Dhacker29
Jdkoreclipse
Liquid0624
Liquidzgrl
OldDroid
Statusbar mods
Theme engine
Quiet hours
Full Rotation
HALO: Minimal Style
HALO: Master Switch
HALO: Custom Colors
SCREENSHOTS
WHAT'S WORKING
Service
Text
Data
Calls
Audio
WiFi
Bluetooth
Google Now
GPS
MMS
VoIP
Video playback
Audio playback
Camera
Camcorder
Hdmi not working
Do not use superwipes
Required HBOOT : 1.49.xxxx
S-OFF
Radio : 11.77.3504.00P_11.25.3504.06_M get it from HERE
4ext recovery
Follow these exact steps to install the ROM :
If coming from an other ROM do this :
1. Wipe data, cache, and system (wipe all partitions except sdcard if on 4ext recovery) if coming from any other ROM
2. Flash ROM
3. Flash GAPPS
4. Reboot
5. ???
6. Profit
If coming from previous build of this ROM :
1. Wipe cache and dalvik-cache
2. Flash ROM
3. Flash GAPPS
4. Reboot
5. ???
6. Profit
To enable Developer Options and Performance go to Settings > About Phone and repeatedly press Build Number.
If you have a problem with ADB, update your android-sdk to latest version.
To enable Advanced reboot menu got Settings > Developer Options > check Advanced reboot
THANKS TOSOURCECODERequired HBOOT : 1.49.xxxx
S-OFF
4ext recovery
2. Flash ROM
3. Flash GAPPS
4. Reboot
5. ???
6. Profit
2. Flash ROM
3. Flash GAPPS
4. Reboot
5. ???
6. Profit
LiquidSmooth Github
Kernel Source
Kernel Toolchain
Device repos
11.11.2013
Rom:
- Rom compiled with Linaro toolchain 4.7 - 2013.10
LIQUIDSMOOTH CHANGELOG
Kernel:
- ARM: entry: avoid enabling interrupts in prefetch/data (fixed reboots)
- msm: spm: Allow setting of voltages across cpus
- power: fbearlysuspend: add sleep hack for CRT-off animation
- PM / Sleep: Do not check wakeup too often in try_to_freeze_tasks()
- Patch: Linux Kernel to 3.0.101 (end of life)
- Sweep2wake: Disable some debug messages
- Sweep2Wake: Redefine some functions
- touchscreen: reduce log spam of atmel driver and a small touch up
- touchscreen: atmel: AOSP multitouch fix
- Revert "drivers: net: wireless: bcmdhd: Update to aosp-common-3.0"
- Make tun module built-in
- Patch: Linux Kernel to 3.0.100
- Remove sweep2wake for now (causes BSODs)
- Memory remap by sultanxda, we now have 867 MB of RAM
- msm: smd_pkt: Handle wakelocks appropriately to optimize power usage
- Bcmdhd: Set PM_FAST during screen off
- Patch: Linux Kernel to 3.0.99
Download: HERE MD5: 53c24c3568d1e948676c49c847ffcfca
MIRROR
06.10.2013
Rom:
- Bluetooth: Add trust device feature. (Pradeep Panigrahi)
- Mock SMS (jruesga)
- Added Irda System Service (twendt)
- Allow more hidden apps on devices with lots of RAM (cyanogen)
- Activate PIE on Lockscreen (kufikugel)
- activate PIE on lockscreen apps (kufikugel)
- Fix app widgets not updating for Widgetlocker (teslacoil)
- Re-enable all keyboard features for 3rd party keyboards (kufikugel )
- New profiles icon (gmillz)
- Align the status bar date to the bottom (veeti)
- PrivacyGuard (cyanogen)
- Allow the user to block notifications for foreground services. (dsandler)
- Fix hungarian keyboard layout (bugdani)
- Add support for Samsung extended AGPS (ghepeu)
- HALO batch envelope icon for non-numbered items (drcmda)
- HALO black toasts,italics, blue text (drcmda)
- HALO first start tutorial (drcmda)
- HALO style changes (drcmda)
- TRDS new 4.3 png's (kufikugel)
- SettingsProvider: Add a default for the dialer's autocomplete (rmcc)
- Fix mismerge of implement 1% battery on select devices (dhacker29)
- BroadcastReceiver : Get sender of broadcasts (Fused)
- Quick Settings: Use scaled font size (p4r4n01d)
- Fix: lockscreen bottom trigger on expanded desktop mode (kufikugel)
- Better navbar and navring support for ppl without google now (kufikugel)
- Bring navring/pie/navbar vibrate/sound inline with AOSP (kufikugel)
- Adjust Transition animation scale (TheBr0ken)
Kernel:
- bluetooth: backport from caf-msm-jb_3.2.1
- Enable sync driver
- misc: uidstat: avoid create_stat() race and blockage.
- Patch: Linux kernel to 3.0.98
- drivers: usb: gadget: Backport from caf-jb_mr1_chocolate
- shooteru: Switch to autosmp by mrg666
- add msm_autosmp from MiRaGe mako kernel (replaces mpdecision)
- Patch: Linux Kernel to 3.0.97
- drivers: net: wireless: bcmdhd: Update to aosp-common-3.0
- lowmemorykiller: make default lowmemorykiller debug message useful
- android: lowmemorykiller: add lmk parameters tunning code.
- android/lowmemorykiller: Ignore tasks with freed mm
- android/lowmemorykiller: Wait for memory to be freed
- android/lowmemorykiller: Check all tasks for death pending
- Enable & update ondemand gov (mrg666)
- shooteru: Import sweep2wake
- video: msm: fix video recording crashes disable the debug routine vfe31_do_workqueue which was causing the crash
- shooter(u): Align framebuffers
- msm: Camera: clear control queue
- msm: camera: Remove additional check in msm_queue_drain
- pm8xxx-vibrator: exposed sysfs to modify voltage level
- shooteru: tty: serial: bcm: add lpm support
- netfilter: xt_qtaguid: update to fix network traffic indicators
- shooteru: Enable dynamic buttons brightness
- Rom is now powered by MiRaGe Kernel
Download: HERE MD5: 27620876f2cafce1d1a1c5bfde5d510b
MIRROR
