[RECOVERY] [Sensation] TeamWin Recovery Project (twrp) v1.0.3 [8/17/2011]
Sh0X31
Sh0X31
Enthusiast
828
Introduction:
TeamWin Recovery Project, or twrp for short, is a custom recovery built with ease of use and customization in mind. We started from the ground up by taking AOSP recovery and loading it with the standard recovery options, then added a lot of our own features that we deemed missing from current recoveries. After weeks of hard work, we are happy to announce the release of twrp.
Key Features:
- Clean, simple, intuitive Menu System
- Ability to save custom recovery settings
º Default partitions to back up
º Default zip folder location
º Default color theme (lots to choose from) (Thanks to ffolkes!)
º Default Time Zone (for more accurate time stamps)
º Zip Verification
- Ability to select which individual partitions to backup, and restore.
- Ability to choose compression or no compression backups.
º Compression takes longer of course, but you save roughly half the space. You choose.
- Ability to auto reboot after successful flashes (for the lazy)
- Battery Level and Timestamp (Better safe than sorry)
Known Issues:
- Battery level does not display correctly yet
- If you see a checkbox in backup or restore below cache and above android_secure, do not check this box
Disclaimer:
As usual, use at your own risk. TeamWin is not responsible for anything bad that may occur from using twrp. We do however take responsibility for the awesomeness that comes with it. Don't be a d3rp and use twrp for bad. With great power, comes great responsibility.
Special Shout Outs:
- TeamWin
º toastcfh - for his under appreciated dedication to the community.
º AssassinsLament, agrabren, Dees_Troy, joeykrim, shift, vividboarder, onicrom, netarchy, kevank, myndwire, bigbiff, dkelle4, shinzul, spiicytuna, eyeballer, OtisFeelgood.
- Amon_RA - for his great Recovery for which we gained a lot of inspiration from.
- Koush - for his dedication to the community and ClockworkMod.
Source Code:
GitHub
Download:
Download link is on our site, click on the link for your device at the top of the page.
MD5 will display with the download link.
(updated download link to include flashable zip - flash using hboot courtesy of xboarder56)
FAQ:
How to install the zip:
1. Download and copy PG58IMG.zip to root of sdcard
2. Rename the zip to exactly PG58IMG.zip using a file explorer like Astro
3. Reboot into BOOTLOADER
4. Let it detect the zip
5. Select Vol UP when it says Do you want to start update?
6. Wait for it to flash
7. Press Power to reboot
8. Let the phone reboot into the regular Android OS
9. Use a file manager like Astro to rename, move, or delete the PG58IMG.zip file so that hboot doesn't try to flash it again
10. Reboot into recovery and enjoy
Error when flashing some zip files:
twrp only supports the latest and greatest edify script for zip flashing. Please bug the zip developer to update the zip script to edify.
Does twrp support off-mode charging?
It is my understanding that off-mode charging does work, but I don't think anyone has tested it on the Sensation yet (it has been tested on the the EVO 3D). If you do fully drain your battery, you will need to let the phone charge for 10 or 20 minutes before you can power it back on though.
Blank checkbox in backup/restore?
If you see a checkbox in backup or restore below cache and above android_secure, do not check this box. This is a bug that will be fixed in the next version.
Which partitions do I need to back up for a proper backup?
Usually you just need boot, data, and system for a normal backup. If you don't know what you are doing, then these are usually the only ones that you need to back up and restore.
Live support:
Click this link or join us in #twrp on Freenode IRC.
Original Post in xda:
The best thing about this recovery are the customizable themes!
I made some previews of each. Enjoy! (sorry about the dimness of Red Rum)
Hab ich schonmal geflasht. Es gab jedoch einen Bug, der das Einspielen von Backups unmöglich machte. Wurde dieser inzwischen behoben? Kann man das Recovery jetzt flashen?
Mfg Marcel
Gesendet von meinem HTC Sensation Z710e mit der Android-Hilfe.de-App
Ich habs drauf, ich hab auch ein backup eingespielt :D. Also ich ahtte keine probleme :)
aber ich finde als die gethemedte versionen nicht :D
Preview zum großen update 2.0.0
YouTube
Ich hab gerade im IRC webchat mit den Jungs aus TeamWin geredet und gute nachtrichten:
[20:05] <@Dees_Troy> most likely, all officially supported devices including the sensation will get it when it's ready
[20:06] <@Dees_Troy> but it still has a long ways to go before it's ready to ship
Ich darf das update für das Sensation testen(v.1.0.3 auf 1.1)
Changelog:
[20:07] <@Dees_Troy> new nandroid code - not really a big deal for Sensation, but good for other devices that have ext3 stock roms and ext4 in CM
[20:07] <@Dees_Troy> files/folders sorted case insensitive
[20:07] <@Dees_Troy> zip queuing
[20:08] <@Dees_Troy> select multiple zips then install them all in the order you chose them
[20:08] <@Dees_Troy> sort zips by date instead of file name
[20:08] <@Dees_Troy> instantly change themes and time zones without rebooting
[20:08] <@Dees_Troy> new way to store settings - future updates won't wipe away your settings
[20:08] <@Dees_Troy> sdcard partitioning
[20:09] <@Dees_Troy> to name a few :)
Es ist ein update da :)
2011-10-05 - v1.1.1
  • fixed fix permissions bug
  • fixed md5 checking for zip install
2011-10-05 - v1.1.0
  • brand new nandroid process with more error checking and supports ext3/ext4 types of devices
  • sdcard partitioning is available for devices with a sdcard (courtesy of koush from CWM source)
  • can choose multiple zips before flashing and they will flash in the order chosen
  • files & folders are sorted case insensitive
  • added option to sort zips by file date instead of file name
  • can apply themes and change time zones without rebooting for instant gratification
  • saved settings will now persist through version changes
  • added myn's warm theme with color codes courtesy of myn
  • added option to wipe system, data, and cache with rm -rf during a nandroid restore to maintain existing file system settings like block size
  • added options for automatic md5 checking of zips
  • twrp spam off by default which makes nandroids up to 10x faster
maaR
  • minecraft2014
Ruftac
  • selinamulle
korrosionsschutzz
