[ROM] Android Revolution HD™ 3.6.1 | High Quality & Performance | OC | faux123 0.1.4
  • 308 Antworten
Sh0X31
Sh0X31
Enthusiast
853
Ich dachte ich stell mein Lieblingsrom vor und hoffe euch gefällt er auch :)
! ! ! NEW ! ! !
Turn your HTC Sensation into HTC Sensation XE - now it's possible by flashing Android Revolution HD !
Proudly presenting you the most popular ROM for HTC Sensation & HTC Sensation 4G...
3uygmp2
Users experience with Android Revolution HD
"My phone is now perfectly smooth, fast, stable. I do not expect much more from my phone!"
DarkAdrien
"This release is amazing! ROM feels super fast! Great job Mike & the team! (...) Never noticed any lag. 1 word: brilliant."
Selec1
"Feels a lot smoother in use - scrolling, swiping between sense screens. Much nicer feel. This is a real good one, Mike. Many thanks :)"
dsm52
>>> Very fast, rock stable, stock look and great support <<<
PLEASE READ THE F.A.Q. DOWN THIS POST !!!
All images in this thread including screenshots, headlines, banners, etc. are copyrighted and you can't use it without permission
» Visit Team Revolution website now! «
» Join me & my Revolution Team on Freenode live chat! «
If you appreciate my work, you can buy me a beer
All my ROMs have great popularity and are a 100% success
About Android Revolution HD
  • Android 2.3.4 (Gingerbread) - latest official HTC RUU 1.45.401.2
  • This is improved version of stock ROM - no visual changes!
  • New kernel: 2.6.35.14 (under-volted & tweaked). Details below:
  • CPU up to 1.56 GHz (1.51 GHz by default - original speed for MSN8660 chipset) - controlled automatically by built it O/C Daemon. How to use O/C Daemon?
  • If you want to control CPU manually, you would need SetCPU from here: SetCPU
  • In SetCPU remember to check "Set on Boot", but using O/C Daemon gives much better performance and battery then SetCPU
  • Many CPU governors (SmartAss, Ondemand, Performance, Conservative, UserSpace)
  • GPU+ patch (Improved 2D & 3D Graphics performance - Thanks to -snq)
  • 3D Engine overclocked from 266.6 MHz to 320 MHz
  • L2 Cache Bandwidth Boost (from max 310MHz to 360MHz)
  • Synchronous L2 Cache
  • V(R) I/O as default scheduler
  • SLQB Memory Management
  • CIFS, TUN & UTF8 support
  • LZMA compression
  • Wi-Fi module improved drivers
  • Code cleaned up with custom voltages, tweaks & many more!
  • You can find custom kernels here
  • ROOT (SU + SuperUser Permissions - Thanks to ChainsDD)
  • Full HTC Sense 3.0 Interface
  • Fully optimized and tweaked
  • Unsecured boot.img
  • Newest BusyBox
  • RAM optimizations
  • Improved Andreno200 configuration for better quality and performance!
  • Speed optimizations
  • Enabled GPU UI rendering
  • SD Card speed tweak
  • Battery auto-calibration
  • Data partition special speed tweak
  • Very fast, clean & stable!
  • Battery auto-calibration script (Thanks to seo)
  • Bloatware applications removed (Amazon MP3, SoundHound trial, etc.)
  • HTC Sensation 4G (US T-Mobile) support like Wi-Fi calling and Visual Voice Mail
  • All system applications updated to latest available
  • Improved camera performance
  • Multilanguage (WWE)
  • Advanced Power Menu and CRT Animation as extra add-ons
  • Arabic and Hebrew languages full support!
  • Zipaligned (Improved RAM management)
  • Zipalign on boot (for user applications on data partition)
  • Fully de-odexed
  • init.d scripts (BusyBox run-parts) support
  • NANO text editor & sysro/sysrw commands support
  • Excellent battery life!
  • Improved EXT4 performance by changing mounting method
  • SD card EXT4 partition support
  • ROM is ad-free. It means that you don't need any extra software to get rid of advertisements
  • You can replace HTC boot animation with any custom boot animation.
  • Support almost 24h a day
  • ...and many more!
» Advanced Power Menu, CRT Screen-off Animation & other mods are in the second post!
» You can easily customize my ROM and make it LITE by removing some components with ROM Cleaner by Patrics83
» If you want to flash different custom kernel, you can do it easily using Kernel Update Utility made by jkoljo
3jqlr7e
Code:
Android Revolution HD 3.6.1
--- release date: 27 September 2011 ---
  • New faux123 kernel 0.1.9
  • - Fixed KGSL Ring Buffer Power Management overrides (Qualcomm approved patch my ass)
  • - show-p1984's supposedly working patch == instant reboot on several 3D apps. Fixed 1 thing broke 5 things
  • - Fixed random SPI Operational State Invalid error
  • - Added histogram capability for MSM video
  • - Added lock/unlock for KGSL Early Suspend Drivers
  • - Updated KGSL power level change
  • - Revert Reg Init Patch from earlier (cause of instability)
  • - Optimized memcpy and memmove for string library calls (real working version)
  • - Fixed audio unmapped memory crash
  • - Fixed inaccurate D-Cache size Macro
  • SuperUser updated to latest 4.0 Final version
  • su binary updated to latest 4.0 Final version
  • Daemon Controller updated to latest 2.21 beta 1
  • hosts file updated to latest
  • Thermal configuration file tweaked
  • Zipaligned using new SDK v13
  • Android Market updated to latest 3.1.5
  • Adobe Flash Player updated to latest 10.3.186.7
- You can download custom kernels from here - Remember to remove SetCPU or any other CPU tuner in order to have O/C Daemon working - Read this post to learn about O/C Daemon - No need to use Super Wipe if you have 3.6.x already!
Android Revolution HD 3.6.0
--- release date: 20 September 2011 ---
  • Re-based with new 1.73.401.2 HTC official update
  • New faux123 kernel 0.1.8
  • - Added New Early suspend drivers for 2D and 3D GPU engines (Fixed glitches in Cordy etc.)
  • - Re-Enabled KGSL Ringbuffer Power Management Overrides
  • - Updated to JHash3
  • - Updated Cpufreq to copy policy from siblings
  • - Fixed memory leak in cpufreq stats
  • - Removed CPU from NoHz Idle fair cgroup
  • - Shorten 1080P start up latency
  • - Fixed USB Gadget Serial Crash
  • - Applied more MSM FrameBuffer updates from CAF
  • Now OC Daemon will be automatically disabled if Faux Clock app is installed
  • Daemon Controller updated to latest 2.20 Final version
  • Faster download/upload speeds for Sensation 4G users
  • Fixed build.prop entry - no more Z715e in the description
  • Optimized thermal daemon configuration file
  • setprop ro.HOME_APP_ADJ set to 1 instead of 0
  • Tweaked ondemand governor
  • ES File Explorer updated to latest 1.6.0.6
  • Minor changes and fixes
Android Revolution HD 3.5.2
--- release date: 18 September 2011 ---
  • New kernel 0.1.7 by faux123
  • - Fixed the derp that was 0.1.6
  • - Applied many FrameBuffer patches from CAF yet again
  • Fixed BusyBox
  • Fixed WiFi calling for Sensation 4G users
  • New thermal daemon configuration file
  • Stripped some HTC logging stuff
  • Revised some tweaks
  • Improved execution of init.d scripts
Android Revolution HD 3.5.1
--- release date: 16 September 2011 ---
  • Re-based on 1.72.401.1 WWE official RUU for HTC Sensation XE
  • New faux123 kernel 0.1.6
  • - New CFS patch that will super charge the CFS so it has all the performance characteristics of a BFS yet retained all the CFS compatibility.
  • Restored better version of WiFi Calling app for T-Mobile users
  • All my tweaks and scripts from previous base
  • De-odexed
  • Zipaligned
  • Fully optimized
  • Newest SuperUser, BusyBox and all the stuff!
Android Revolution HD 3.5.0
--- release date: 15 September 2011 only on IRC channel ---
  • Re-based on 1.72.401.1 WWE RUU for HTC Sensation XE
  • New faux123 kernel 0.1.5
  • Deadline as default scheduler
  • ES File Explorer updated to latest 1.6.0.5
  • Facebook updated to latest 1.7.1
  • Maxthon updated to latest 2.2.7 customized for AR HD
  • Daemon Controller updated to latest 2.20b5
Android Revolution HD 3.1.1
--- release date: 11 September 2011 ---
  • New kernel by faux123 version 0.1.4
  • - Introducing Global CPU Voltage Table (Under volt capability via sysfs interface)
  • - Re-coded GPU Turbo Boost. Fixed GPU Scaling governor (scaling was disabled)
  • Google Maps updated to latest 5.10.0
  • Improved battery life
  • Fixed Gmail FC
  • Fixed missing Polaris Office
  • Switched to NO OP scheduler
Android Revolution HD 3.1.0
--- release date: 09 September 2011 ---
  • Completely re-based for consistency
  • New kernel 0.1.2 from faux123 Fast NoHz Edition 1.56 GHz Sync L2
  • - Re-Based on HTC MR release! (new baseline)
  • - Introducing Joe's RCU
  • - Re-patched HTC MR release 2.6.35.13 to kernel.org 2.6.35.14
  • - GPU 2D/3D is now same as stock (Due to screen tearing issues experienced by some users)
  • - CAF msm: clock-8x60: Refresh PDM and TSSC halt bits at boot
  • - CAF msm: 8660: Add barriers to SMP boot code
  • - CAF msm: clock-local: Add memory barriers for later move to _relaxed accessors
  • - CAF ARM: SMP: Make resched-ipi-while-offline warning less verbose
  • - CAF msm: clock-8x60: Vote for mmfpb_a_clk at 64MHz
  • - CAF mmc: core: put eMMC in sleep (cmd5) mode before suspend
  • - CAF msm: clock-8x60: Don't disable clocks in reg_init
  • - No more black screens issue
  • Fast and stable edition
  • Theremal senor configuration file tweaked by faux123
  • Amazing HTC Beats modified by Sprintusa
  • Improved carousel spinning
  • Daemon Controller updated to latest 2.13
  • Maxthon updated to latest 2.2.6
  • Other minor changes and fixes
Android Revolution HD 3.0.4
--- release date: 05 September 2011 ---
  • Don't use dual-core script with 3.0.4
  • Included new amazing kernel from faux123 version 0.1.0 (1.56 GHz Sync L2)
  • - L2 Cache Bandwidth Boost (from max 310MHz to 360MHz)
  • - 3D enging libs to fix glitches in games
  • - It's running 1,5 GHz as default because MSN8660 chipset was meant to run 1,5 GHz.
  • - Fixed SD mounting
  • - CAF Patch msm: acpuclock: Subscribe to _FROZEN CPU notifiers
  • - CAF Patch msm: pm-8x60: Remove redundant code for restoring ACPU Clock Rate
  • - CAF Patch msm: acpuclock-8x60: Use hotplug notifications for CPU, L2, BUS, voltage
  • - Added back Scaling_Available_Frequecies sysfs entries to fix empty fields in Daemon Controller
  • - Introducing GPU 2D/3D Overclocking
  • - 3D Engine from 266.6 MHz to 320 MHz (both versions will benefit from this boost)
  • The fastest Android Revolution HD for HTC Sensation ever!
  • Increased performance by more agressive up_threshold
  • This version comes with OC Daemon so remove all your SetCPU, CPU Master etc.
  • Ondemand is default governor and it's the best governor for my device - don't change it
  • Improvements to flashing script
Android Revolution HD 3.0.3
--- release date: 28 August 2011 ---
  • Full ROM this time with separate patch for dual-core support
  • Fixed model ID for HTC Sensation 4G
  • Wi-Fi calling application updated to latest from 1.45 T-Mobile RUU
  • Improvements to dual-core scripts
Previous changelog is here
You need:
How to flash:
Don't use ROM Manager! Flash ROM following the steps below:
  • Download ROM and place it on your SD card
  • Download "Super Wipe" script & place it on your SD card (optionally if coming from earlier version of my ROM, obligatory if coming from stock or other custom ROM)
  • Boot your phone in recovery mode (vol down + power)
  • In main menu, select "install zip from sdcard"
  • Select "choose zip from sdcard" and browse to the location of "Super Wipe" script
  • Once again select "choose zip from sdcard" and browse to the location of Android Revolution ROM
  • After flashing process is complete, reboot the device
*** Please do not post any mirrors. We are currently using fast servers, so there is no need for extra mirrors. Thank you! ***
Remember to check MD5 Checksum before flashing !!!
ROM MD5 Checksum: 29A8C6BA824F0AF974206D369322098D *Android_Revolution_HD-Sensation_3.6.1.zip
--- Direct link to 6 fast server that will randomly use one of our sources ---
--- With thanks to Mavy170, Whiskey103, MarcoHD, Pili21181, Lizard & Denngie ---
>>> Super Wipe <<<
--- This script will erase and format your data, system and cache partition ---
--- Your SD card will remain untouched FAT32 and it's recommended to leave it like that ---
>>> Custom kernels section <<<
--- This will re-direct you to the kernels section, where you can choose the best kernel for you ---
Android Revolution HD 3.6.1 on DropBox
--- Create your own DropBox account, if you see notification about too much traffic ---
Set CPU clock back to 1.2 GHz
--- Flash this, if you don't want your CPU to be overclocked or you had boot-loop or random reboots ---
Radio MD5 Checksum: B804DBC6484915C5A710EB630A353F6F *radio.img
With 3.5.x ROMs I strongly recommend flashing 10.58.9035.00U_10.15.9035.02_2 radio
--- Using a "non matched" radio could have a negative effect on performance, battery life & signal strength ---
--- You don't have to flash RIL files for recommended radio. It's already in the ROM ---
--- You would need S-OFF in order to do it properly ---
Radio_10.58.9035.00U_10.15.9035.02_2
--- Don't flash RADIO from ClockworkMod recovery! Extract downloaded file and read the guide inside! ---
Quelle
Reaktionen: ElDuderinoCoV, Moskauboy, Al_Bundy und eine weitere Person
Die F&Qs
Q 1: After flashing Android Revolution HD my battery drains much faster. What can I do?
A: Please charge your battery to 100%, boot your device in ClockworkMod Recovery and go to Advanced ---> Wipe Battery Stats. Also see Question 7.
Also please read this ---> [GUIDE] Enlarge your battery life : an attempt to fix the battery drain
And this ---> [How to] Brilliant Battery Life 100% working!
For more details about wiping battery stats please read this
Q 2: My Premium Navigation doesn't work correctly. What should I do?
A: Your Premium Navigation may not work correctly for many reasons. Most of them are not ROM related. You can try the following things:
- reinstall your Locations under "Settings" ---> "Locations"
- remove /sdcard/.data/navigator/Data/Temporary from your SD card
- re-download Google Maps from the Android Market
- clear data from Google Maps in system software management
Q 3: When recording HD video, the playback of the clip keeps freezing. How to fix it?
A: This is probably SD card problem. Format your SD card (FAT32 recommended) to gain silky smooth playback.
Q 4: After I reboot my device, mp3 ring-tone is back to default. What should I do?
A: Go to Ringtones > Menu > More Ringtones > Create new ringtone > Select the one you want (Thanks to kill4l)
Q 5: Is there any alternative for SetCPU? I think it slows downy my phone.
A: You can application called No-frills. Remember to check "Allow on boot" option.
Q 6: After flashing Android Revolution HD my SD card is being mounted as ready only. What should I do?
A: Connect your SD card to your PC and do defragmentation process. If you still have some problems with SD card, please read this.
Mac users can use the repair function of the MacOS disk utility to solve the read only problem (Thanks to Calimero1205).
Q 7: My CPU load is all the time nearly 100% and in most part it's used by system. What is the reason of that high CPU usage and how can I fix it?
A: Delete your htcsense.com account. It takes A LOT of your battery and CPU usage.
Q 8: Do I need to wipe data partition when upgrading from old version of Android Revolution HD?
A: I always recommend wiping data partition but it's absolutely necessary only if I mention that in the changelog. But normally you can live without it.
Wipe data partition if you experience any issues.
Q 9: I have some strange issues with my ROM that nobody reported before. What should I do in first place?
A: In first place you should check, if the MD5 Checksum is correct. Then flash ROM again and see if the issue is gone. A lot of strange issues can be solved this way.
Q 10: I had SetCPU installed on Android Revolution HD, then I flashed new version of AR HD and SetCPU doesn't work any more. How to fix it?
A: Please reinstall SetCPU.
Q 11: I can't send/receive MMS or I can't connect with mobile data connection. How can I fix it?
A: Please check your MMS settings or mobile data connection APN settings.
Q 12: My phone got random freezes or reboots. How can I fix it?
A: Every CPU is different. It seems that your CPU doesn't like OC or UV (undervolt). Set your CPU to default 1GHz.
If it doesn't help, then you need to flash default kernel from the second post.
Q 13: My proximity sensor doesn't seem to work anymore. How can I fix it?
A: Please check this thread for further help.
Q 14: My GPS signal is very weak or GPS is not working at all. How can I fix it?
A: There are some solutions:
1. You can download and install FasterFix to improve your signal strength.
2. You can download and install GPS Status & Toolbox to manage your GPS settings.
3. Turn off "Fast boot" under "Settings" ---> "Power" and reboot your phone.
4. Wipe the EFS data in your device. Read this for further instuctions. This is very effective solution.
5. Read this, this and this
6. [Trick] Speed Up Satelite Fix for GPS on Android
Q 15: My clock/weather widget doesn't show my location. How can I fix it?
A: Please clear data from Google Maps, Clock Widget, Weather, HTC weather sync provider and Weather Provider.
Q 16: My Quadrant score is not as high as on different ROM. What does it mean?
A: It means absolutely nothing. Benchmarks on Android System are more or less lottery and they are not showing the real system performance.
There are many settings that can force Quadrant to show more then 3000 points but it's faked performance, that actually can slow down your phone in some circumstances.
What I always emphasize is a real performance, the one you can feel under your fingers. Remember that I/O has some limit and surpassing it shows just a numbers without true ratio.
Also keep in mind that Quadrant has support for Android Gingerbread only in version 1.1.7 and higher.
Q 17: I have com.htc.bgc process force close few times a day. How can I fix it?
A: It's because you have removed HtcTwitter.apk (HTC Twitter application). Please restore it.
Q 18: My screen-lock sound and keypad sound while dialing numbers is very low. How can I fix it?
A: Download "Quick Settings" application from Android Market and check system volume slider.
Q 19: When I open up the call screen (where I see the recent calls and callers), the calls won't appear in the list. What to do?
A: Probably you are using 3rd party launcher. Remove the dialer shortcut and re-add it.
Q 20: What can I do to prevent few seconds call delay Gingerbread issue?
A: Install "Call Delay Patch" from the Android Market.
Q 21: How can I change VDD level in this ROM?
A: First of all, custom kernel must support possibility to change VDD level dynamically.
Secondly, you would need -vipermod- binary that is already inculded in my ROM if included kernel supports it.
If it does, you would only need terminal app (I use Android Terminal Emulator) and type:
su
vipermod
Be careful with setting to low or to high VDD. In case of bootloop flash VDD reseting tool.
Q 22: My Wi-Fi doesn't reconnect automatically after boot. How to fix it?
A: Disable fastboot in settings or check this solution.
Q 23: When I listen to music from HTC stock player it accidentally pauses for short time and then keep playing.
A: Turn OFF fastboot in settings.
Q 24: Why my "4G" icon is gone from the status bar?
A: My ROMs are based on WWE HTC ROMs. It means that there is no "4G" icon but you have HSPA+ connection with "H" icon anyway.
Q 25: How can I enable built it screen-shot feature on Sense 3.0 < based ROMs?.
A: Edit your build.prop file in /sytem and change:
ro.htc.framework.screencapture = false
to
ro.htc.framework.screencapture = true and clear dalvik-cache or install ShootMe from the Android Market.
Credits and thanks goes to:
---- Android Revolution Team: ----
- Bumble-Bee aka Apache14 (Kernels developers & Linux expert)
- Dude360 (Mods developer)
- Euphorie (Site support)
- HyperCriSiS (Beta-tester & Homepage administrator)
- jkoljo (Beta-tester & unlocking Android devices expert)
- Lizard (ROMs hosting)
- lukogriffioen (Beta-tester)
- madmaxx82 (Recovery developer)
- Mavy170 (ROMs hosting)
- Patrics83 (Beta-tester)
- seandk (Beta-tester)
- Whiskey103 (Beta-tester & ROMs hosting)
I also thank to seandk, TWioE, Moe|Joe, jonata, kill4l & MultiCulti for being in the team in the past.
Thanks goes also to themes developers - he_stheone64, Vistagamer, liamstears and kalagas.
---- Others: ----
- klquicksall for compiling kernels for Android Revolution HD
- Krzysiec for amazing logo graphic projects
- adsamcik, erikstar & KID_1194 for graphic support
- dsixda for his Android Kitchen
- Everyone who made a donation
Und die "No-Sense" Version
Removed:
  • Rosie launcher
  • HTC Themes
  • HTC Widgets
  • HTC Lock-Screen (WARRNING - while incoming call you would have to unlock screen first to pick up the call. I'm working on the fix - DON'T REPORT IT AS ISSUE IN THE THREAD)
  • Most of the HTC Sense UI components like Stock, HTC Likes etc.
Kept:
  • HTC Dialer - still better then Android stock one
  • HTC Contacts
  • HTC Live Wallpapers
  • Facebook for HTC Sense
  • HTC Navigation
  • Genie Widget
  • + Go Launcher EX
How to install:
  1. Download Android Revolution HD ROM from the first post
  2. Download Android Revolution HD no-sense script
  3. Place both files on your SD Card
  4. Flash ROM and don't reboot, stay in the recovery!
  5. Flash Android Revolution HD no-sense script
  6. Reboot
  7. Additionally you can download no-Sense wallpaper from here
Changelog:
no-Sense 0.16
- Switched to GO Launcher EX 2.3.8
W A R N I N G ! ! !
If you want to use any theme with no-Sense ROM, then:
1. Flash ROM, boot and reboot
2. Flash Theme, boot and reboot
3. Flash no-Sense script​
--- All extras listed here with meta-inf folder inside the .zip archive needs to be installed via ClockworkMod recovery!
--- After every ROM update please check first, if the theme or mod you used to flash is still compatible with current ROM version ---
Boot Animations:
Download bootanimation.zip and place it on \data\local on your device.
Custom modifications:
For all ROMs
For 3.0.x ROMs
For 2.1.x ROMs
For 1.1.x ROMs
Content for UOT kitchen:
Others:
Wo finde ich den Link zum Advanced Powermenu für 3.0.x ROMs?? Ich hab jetzt schon den Originalpost bei den xda devs durchgearbeitet, aber konnte dort leider auch nichts finden (vll. hatte ich ja auch einfach nur Tomaten auf den Augen). Ich nehme an, dass ich das Advanced Powermenu von den 2.1.0er ROMs nicht verwenden darf/kann/soll.
Vielen Dank für den Finder/poster!
Die für version 2.1.X funktioniert auch bei 3.0.4 habs gerade getestet. Jetzt versuch ich ma die Quick Settings!
PS: QuickSettings funktioniert auch... :)
Reaktionen: chief_l
Danke fürs "Vorkosten"! Hab die beiden zips auch noch schnell geflasht und es funktioniert alles (obwohl es schon ziemlich lang in der bootanimation gehangen hat)...:unsure:
Ja seit dem dauert iwie das laden länger -.-
Hier dazu ein Aussage kräftiger Benchmark mit CF-Bench und Quadrant Standard. Es wird der Kernel ohne Hochtakten in diesen Rom verwendet.
Ich bin mit den Rom zufrieden, wobei ich auf CM7 und MIUI warte, das sind meine Top Favoriten für die Zukunft.
Das du nur das Rom installiert? Und was ist "Full Dual-Core forcing script 0.7"?
Ein Script, dass dafür sorgt, dass die prozessoren nicht mehr unterschiedlich takten sondern immer gleich. Soll angeblich die Leistung steigern.
mfg Marcel
ehm hab ich was nicht mitbekommmen?
es steht doch drin "Full Dual-Core forcing script 0.7
--- Don't use it with Android Revolution HD 3.0.4 and above ---"
also heißt das doch das es nicht mit der 3.1 läuft
Bin heute vom Virtuous Rom auf dieses hier umgestiegen weil bei Virtuous sich im Moment nicht wirklich was tut in Sachen mal neue Kernel oder andere Verbesserungen.
Ich muss sagen ich bin im Moment total begeistert. Läuft alles mega rund, mit Sicherheit auch Aufgrund des Sensationellen faux Kernels.
Werde erstmal bei diesem Rom hier bleiben. :thumbup:
Man soll das "Full Dual-Core forcing script 0.7" nicht ausführen da es seit 3.04 schon mit Eingebaut ist und zwar die Verbesserte Version davon.
Wer RHD schon langer mit macht, wird die Unterschiede kennen und in der jetzigen Version 3.1 läuft alles wirklich sehr gut...wobei für meinen Geschmack noch zu viel Sense mit drin ist obwohl ich das Script für das Löschen des HTC Launcher immer durchführe.... Es geht halt nix über ein reines Android von CM oder aber meinen Favoriten MIUI.
Die Android BIOS boot animation ist jawohl endgeil, kann ich die auch bei einem anderen Rom flashen (Virtuous Sensation)?
ja. Kannst du machen. Mußt in /Data/Local verschieben.
Mike hat ein kleines update released
Code:
[CENTER]New kernel by faux123 version 0.1.4
 - Introducing Global CPU Voltage Table (Under volt capability via sysfs interface, inspired by snq adapted for Snapdragon Dual-Core by me  )
 - Joe's RCU option is deprecated (based on download stats)
Fixed Gmail FC
Switched to NO OP scheduler[/CENTER]
Android Revolution HD™ 3.1.1
Ich bin bis jetzt auch sehr zufrieden, vorallem in Verbindung mit dem Faux Kernel.
Ich habe gleich mal bisschen undervoltet, mal sehen ob es auf Dauer stabil läuft und vorallem erhoffe ich mir ein paar Stunden mehr Akkulaufzeit :thumbup:
Edit:
So habe diesen CF Benchmark auch mal laufen lassen:
HAst du nur das Rom geflasht und diese Werte bekommen?
Edit:
Das Script für das Undervolting habe ich auch schon gesehen, aber wie binde ich es ein ?
Wäre nett wenn du mir weiterhelfen könntest..
